I'm getting the following error when programming EVAL-TPG-ZYNQ3 with the requested profile.
2020-11-13 11:55:54,099 FATAL AdiCmdServerClient.Logging - ERROR during programming of ARM binary: ERROR: 97, LoadHex() line checksum is invalid 2020-11-13 11:55:54,099 FATAL AdiCmdServerClient.Logging - AdiCmdServerClient.InvalidRespException: ERROR during programming of ARM binary: ERROR: 97, LoadHex() line checksum is invalid at AdiCmdServerClient.Talise.LoadArm(String fileName) at TaliseApiCommands.Api.API_LoadARM(String fileName) 2020-11-13 11:55:54,100 FATAL AdiCmdServerClient.Logging - AdiCmdServerClient.InvalidRespException: ERROR during programming of ARM binary: ERROR: 97, LoadHex() line checksum is invalid at AdiCmdServerClient.Talise.LoadArm(String fileName) at TaliseApiCommands.Api.API_LoadARM(String fileName) at TaliseApiCommands.Api.API_ProgramTalise(String fileName, String streamFile) 2020-11-13 11:56:01,309 FATAL AdiCmdServerClient.Logging - AdiCmdServerClient.InvalidRespException: ERROR during programming of ARM binary: ERROR: 97, LoadHex() line checksum is invalid at AdiCmdServerClient.Talise.LoadArm(String fileName) at TaliseApiCommands.Api.API_LoadARM(String fileName) at TaliseApiCommands.Api.API_ProgramTalise(String fileName, String streamFile) at Analog.Views.ConfigPages.InitTalise() at Analog.Views.ConfigPages.bgw_DoWork(Object sender, DoWorkEventArgs e) 2020-11-13 11:57:27,319 FATAL AdiCmdServerClient.Logging - ERROR during programming of ARM binary: ERROR: 97, LoadHex() line checksum is invalid 2020-11-13 11:57:27,320 FATAL AdiCmdServerClient.Logging - AdiCmdServerClient.InvalidRespException: ERROR during programming of ARM binary: ERROR: 97, LoadHex() line checksum is invalid at AdiCmdServerClient.Talise.LoadArm(String fileName) at TaliseApiCommands.Api.API_LoadARM(String fileName) 2020-11-13 11:57:27,321 FATAL AdiCmdServerClient.Logging - AdiCmdServerClient.InvalidRespException: ERROR during programming of ARM binary: ERROR: 97, LoadHex() line checksum is invalid at AdiCmdServerClient.Talise.LoadArm(String fileName) at TaliseApiCommands.Api.API_LoadARM(String fileName) at TaliseApiCommands.Api.API_ProgramTalise(String fileName, String streamFile) 2020-11-13 11:57:36,580 FATAL AdiCmdServerClient.Logging - AdiCmdServerClient.InvalidRespException: ERROR during programming of ARM binary: ERROR: 97, LoadHex() line checksum is invalid at AdiCmdServerClient.Talise.LoadArm(String fileName) at TaliseApiCommands.Api.API_LoadARM(String fileName) at TaliseApiCommands.Api.API_ProgramTalise(String fileName, String streamFile) at Analog.Views.ConfigPages.InitTalise() at Analog.Views.ConfigPages.bgw_DoWork(Object sender, DoWorkEventArgs e) 2020-11-13 11:59:11,089 FATAL AdiCmdServerClient.Logging - System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseUInt32(String value, NumberStyles options, NumberFormatInfo numfmt) at AdiCmdServerClient.AdiCommandServerClient.FpgaRead(UInt32 addr) at TaliseApiCommands.Api.API_FpgaRead(UInt16 addrToRead) 2020-11-13 11:59:11,091 FATAL AdiCmdServerClient.Logging - System.Net.Sockets.SocketException (0x80004005): Une connexion �tablie a �t� abandonn�e par un logiciel de votre ordinateur h�te at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at AdiCmdServerClient.Zc706TcpipClient.Query(String writeString) at AdiCmdServerClient.Talise.GetRadioState(UInt32& radioStatus) at TaliseApiCommands.Api.API_GetRadioState()
How can this issue be solved please
