Regarding JESD2014 Error in ZCU102_ADRV9009 Petalinux Image
Greetings !
I have built a BOOT.BIN, by the combination of the following
1. HDF file generation using the script  from master branch of  https://github.com/analogdevicesinc/hdl
2. Vivado 2019.1
3. Petalinux 2019.1
4 Meta-ADI layers from Master branch of https://github.com/analogdevicesinc/meta-adi
The image was built successful & able to boot. But when I give the command "iio_info"  in the serial monitor of PICOCOM, I shall end up with JESD204 error.
Request to go through the following log and provide me the solution for this
root@zcu102_9009_tmplt191:~# iio_info
Library version: 0.21 (git tag: v0.21)
Compiled with backends: local xml ip usb
IIO context created with local backend.
Backend version: 0.21 (git tag: v0.21)
Backend description string: Linux zcu102_9009_tmplt191 4.19.0-xilinx-v2019.1 #1 SMP Mon Nov 9 18:11:38 UTC 2020 aarch64
IIO context has 2 attributes:
local,kernel: 4.19.0-xilinx-v2019.1
uri: local:
IIO context has 8 devices:
iio:device0: ams
30 channels found:
voltage6: vccpsintfpddr (input)
2 channel-specific attributes found:
attr 0: raw value: 18507
attr 1: scale value: 0.045776367
voltage14: vccpsio2 (input)
attr 0: raw value: 19478
attr 1: scale value: 0.091552734
voltage16: psmgtravtt (input)
attr 0: raw value: 39522
voltage23: vccplintlp (input)
attr 0: raw value: 18549
voltage0: vcc_pspll0 (input)
attr 0: raw value: 26251
voltage22: vccbram (input)
attr 0: raw value: 18505
voltage26: vccams (input)
attr 0: raw value: 39150
attr 1: scale value: 0.015258789
voltage8: vccpsintfp (input)
attr 0: raw value: 18557
temp1: remote_temp (input)
3 channel-specific attributes found:
attr 0: offset value: -36058
attr 1: raw value: 40792
attr 2: scale value: 7.771514892
voltage9: vccpsaux (input)
attr 0: raw value: 39689
voltage25: vccplaux (input)
attr 0: raw value: 39732
voltage18: vccint (input)
attr 0: raw value: 18528
voltage15: psmgtravcc (input)
attr 0: raw value: 18558
temp0: ps_temp (input)
attr 1: raw value: 40690
voltage2: vccint (input)
attr 0: raw value: 18522
voltage5: vcc_psddrpll (input)
attr 0: raw value: 39727
voltage21: vccvrefn (input)
attr 0: raw value: 0
voltage7: vccpsintlp (input)
voltage11: vccpsio3 (input)
attr 0: raw value: 19691
temp2: pl_temp (input)
attr 1: raw value: 40626
voltage13: vccpsio1 (input)
attr 0: raw value: 19458
voltage3: vccbram (input)
attr 0: raw value: 18482
voltage4: vccaux (input)
attr 0: raw value: 39199
voltage12: vccpsio0 (input)
voltage10: vccpsddr (input)
attr 0: raw value: 26013
voltage24: vccplintfp (input)
attr 0: raw value: 18607
voltage1: vcc_psbatt (input)
attr 0: raw value: 30685
voltage19: vccaux (input)
attr 0: raw value: 39263
voltage17: vccams (input)
attr 0: raw value: 39592
voltage20: vccvrefp (input)
attr 0: raw value: 27309
1 device-specific attributes found:
attr 0: sampling_frequency ERROR: Invalid argument (-22)
No trigger on this device
iio:device1: ad9528-1
4 channels found:
altvoltage3: FMC_SYSREF (output)
attr 0: frequency value: 120000
attr 1: phase value: 0.000000
attr 2: raw value: 1
altvoltage1: FMC_CLK (output)
attr 0: frequency value: 245760000
altvoltage12: DEV_SYSREF (output)
altvoltage13: DEV_CLK (output)
9 device-specific attributes found:
attr 0: pll1_feedback_clk_present value: 1
attr 1: pll1_locked value: 0
attr 2: pll1_reference_clk_a_present value: 0
attr 3: pll1_reference_clk_ab_missing value: 1
attr 4: pll1_reference_clk_b_present value: 0
attr 5: pll2_feedback_clk_present value: 1
attr 6: pll2_locked value: 1
attr 7: sync_dividers ERROR: Permission denied (-13)
attr 8: vcxo_clk_present value: 1
1 debug attributes found:
debug attr 0: direct_reg_access value: 0x18
iio:device2: ad7291
9 channels found:
temp0: (input)
attr 0: mean_raw value: 151
attr 1: raw value: 151
attr 2: scale value: 250
voltage1: (input)
attr 0: raw value: 2102
attr 1: scale value: 0.610351562
voltage5: (input)
attr 0: raw value: 2909
voltage2: (input)
attr 0: raw value: 1475
voltage6: (input)
attr 0: raw value: 1239
voltage3: (input)
attr 0: raw value: 2729
voltage7: (input)
attr 0: raw value: 2143
voltage0: (input)
attr 0: raw value: 2771
voltage4: (input)
attr 0: raw value: 2957
iio:device3: adrv9009-phy
25 channels found:
altvoltage1: (output)
1 channel-specific attributes found:
attr 0: AUX_OBS_RX_LO_frequency value: 2430000000
voltage9: (output)
4 channel-specific attributes found:
attr 0: offset value: 2726
attr 1: raw value: 0
attr 2: sampling_frequency value: 245760000
attr 3: scale value: 0.782954
voltage8: (output)
voltage3: (input)
7 channel-specific attributes found:
attr 0: hardwaregain ERROR: Protocol error (-71)
attr 1: powerdown value: 1
attr 2: quadrature_tracking_en value: 0
attr 3: rf_bandwidth value: 200000000
attr 4: rf_port_select value: OBS_TX_LO
attr 5: rf_port_select_available value: OBS_TX_LO OBS_AUX_LO
attr 6: sampling_frequency value: 245760000
voltage2: (output)
voltage1: (output)
8 channel-specific attributes found:
attr 0: atten_control_pin_mode_en value: 0
attr 1: hardwaregain value: -10.000000 dB
attr 2: lo_leakage_tracking_en value: 0
attr 3: pa_protection_en value: 0
attr 4: powerdown value: 0
attr 5: quadrature_tracking_en value: 0
attr 6: rf_bandwidth value: 225000000
attr 7: sampling_frequency value: 245760000
voltage0: (output)
altvoltage0: TRX_LO (output)
attr 0: frequency value: 2400000000
attr 1: frequency_hopping_mode value: 2400000000
attr 2: frequency_hopping_mode_enable value: 0
voltage2: (input)
voltage5: (input)
attr 0: offset value: 45
attr 1: raw value: 1539
attr 2: scale value: 0.775194
voltage6: (input)
attr 1: raw value: 1732
voltage12: (output)
attr 1: sampling_frequency value: 245760000
attr 2: scale value: 0.805861
voltage6: (output)
voltage13: (output)
voltage4: (input)
voltage5: (output)
voltage1: (input)
10 channel-specific attributes found:
attr 0: gain_control_mode value: manual
attr 1: gain_control_mode_available value: manual slow_attack
attr 2: gain_control_pin_mode_en value: 0
attr 3: hardwaregain value: 30.000000 dB
attr 4: hd2_tracking_en value: 0
attr 5: powerdown value: 0
attr 6: quadrature_tracking_en value: 0
attr 7: rf_bandwidth value: 200000000
attr 8: rssi value: 44.250 dB
attr 9: sampling_frequency value: 245760000
voltage3: (output)
voltage10: (output)
voltage7: (input)
attr 1: raw value: 1611
voltage0: (input)
voltage4: (output)
voltage11: (output)
voltage7: (output)
temp0: (input)
attr 0: input value: 66000
17 device-specific attributes found:
attr 0: calibrate ERROR: Input/output error (-5)
attr 1: calibrate_frm_en value: 0
attr 2: calibrate_rx_phase_correction_en value: 0
attr 3: calibrate_rx_qec_en value: 0
attr 4: calibrate_tx_lol_en value: 0
attr 5: calibrate_tx_lol_ext_en value: 0
attr 6: calibrate_tx_qec_en value: 0
attr 7: ensm_mode value: radio_on
attr 8: ensm_mode_available value: radio_on radio_off
attr 9: gain_table_config ERROR: Permission denied (-13)
attr 10: jesd204_fsm_ctrl value: 1
attr 11: jesd204_fsm_error ERROR: Invalid argument (-22)
attr 8: ensm_mode_available value: radio_on radio_off attr 9: gain_table_config ERROR: Permission denied (-13) attr 10: jesd204_fsm_ctrl value: 1 attr 11: jesd204_fsm_error ERROR: Invalid argument (-22)
[edited by: Prasanna Kumar K at 11:50 AM (GMT -5) on 11 Nov 2020]
