JESD204B TX-Link status is always in "CGS" and SYNC is always in "assertion"
Hello, everyone!
I am working with zc102 and ADRV9009 evaluation boards.
I have encountered this problem:
    Using the TES to create the init .c files and the talise_config.c in project. Compile and run,the tx JESD204B status is "CGS", not "DATA".
I am stuck for long times about this problem, could you help me resolve this problem.
Please see my configuration:
AD9009:
JESD204B:
All works OK!
Then i use "TOOLS->create init.c files" to create the init files. The result is:
- the tx JESD204B status is "CGS", not "DATA"
the rx and orx JESD204B status is "DATA"
Please see the code.
headless.c:
 * \file headless.c
 * \brief Contains example code for user integration with their application
 * Copyright 2015-2017 Analog Devices Inc.
 * Released under the AD9378-AD9379 API license, for more information see the "LICENSE.txt" file in this zip file.
 * All data structures required for operation have been initialized with values
 * which reflect these settings:
 * Device Clock = 245.76 Mhz
 * Rx1 and Rx2 are enabled
 * Tx1 and Tx2 are enabled
 * Talise Framer:
 * Lane Rate = 9830.4 Mbs
 * L = 2
 * K = 32
 * M = 4
 * F = 4
 * Talise Deframer:
 * L = 4
 * K = 32
 * M = 4
 * F = 2
 * Talise Observation framer:
 * L = 2
 * K = 32
 * M = 2
 * F = 2
 * Using these profiles:
 * Rx 200Mhz, IQrate 245.76Mhz, Dec5
 * Tx 200/450Mhz, IQrate 491.52Mhz, Dec5
 * ORX 450Mhz, IQrate 491.52Mhz, Dec5
#include "headless.h"
#include "talise.h"
#include "talise_jesd204.h"
#include "talise_arm.h"
#include "talise_radioctrl.h"
#include "talise_cals.h"
#include "talise_config.h"
#include "talise_error.h"
/****< Insert User Includes Here >***/
/********** Talise Data Structure Initializations ********/
int main()
    /*< binary[114688]> contains ARM binary file as array - set by user > */
    uint8_t mcsStatus = 0;
    uint8_t pllLockStatus = 0;
    uint8_t armBinary[114688] = {0};
    uint32_t count = sizeof(armBinary);
    uint8_t streamBinary[4096] = {0};
    uint32_t initCalMask = TAL_TX_BB_FILTER | TAL_ADC_TUNER | TAL_TIA_3DB_CORNER | TAL_DC_OFFSET | TAL_RX_GAIN_DELAY | TAL_FLASH_CAL | TAL_PATH_DELAY | TAL_TX_LO_LEAKAGE_INTERNAL | TAL_TX_QEC_INIT | TAL_LOOPBACK_RX_LO_DELAY | TAL_LOOPBACK_RX_RX_QEC_INIT | TAL_RX_QEC_INIT | TAL_ORX_QEC_INIT | TAL_TX_DAC | TAL_ADC_STITCHING;
    uint32_t trackingCalMask = TAL_TRACK_NONE;
    uint8_t errorFlag = 0;
    uint16_t deframerStatus = 0;
    uint8_t framerStatus = 0;
    uint32_t talAction = TALACT_NO_ACTION;
    /************ Talise Initialization Sequence *************/
    /** < Insert User System Clock(s) Initialization Code Here >
     * System Clock should provide a device clock and SYSREF signal
     * to the Talise device.
    /*** < Insert User BBIC JESD204B Initialization Code Here > ***/
    /**** Talise Initialization ***/
    /*Open Talise Hw Device*/
    talAction = TALISE_openHw(&talDevice);
    if(talAction != TALACT_NO_ACTION)
        /*** < User: decide what to do based on Talise recovery action returned > ***/
    /* Toggle RESETB pin on Talise device */
    talAction = TALISE_resetDevice(&talDevice);
    if (talAction != TALACT_NO_ACTION)
    /* TALISE_initialize() loads the Talise device data structure
     * settings for the Rx/Tx/ORx profiles, FIR filters, digital
     * filter enables, calibrates the CLKPLL, loads the user provided Rx
     * gain tables, and configures the JESD204b serializers/framers/deserializers
     * and deframers.
    talAction = TALISE_initialize(&talDevice, &talInit);
    /***** CLKPLL Status Check *****/
	talAction = TALISE_getPllsLockStatus(&talDevice, &pllLockStatus);
    /* Assert that Talise CLKPLL is locked */
    if ((pllLockStatus & 0x01) == 0)
        /* <user code - CLKPLL not locked - ensure lock before proceeding */
    /**** Perform MultiChip Sync (MCS) on Talise Device ***/
    talAction = TALISE_enableMultichipSync(&talDevice, 1, &mcsStatus);
    /*< user code - Request minimum 3 SYSREF pulses from Clock Device - > */
    /**** Verify MCS ***/
    talAction = TALISE_enableMultichipSync(&talDevice, 0, &mcsStatus);
    if ((mcsStatus & 0x0A) != 0x0A)
        /*< user code - MCS failed - ensure MCS before proceeding*/
    /**** Prepare Talise Arm binary and Load Arm and    ****/
	/**** Stream processor Binaryes 					****/
    if (pllLockStatus & 0x01)
        talAction = TALISE_initArm(&talDevice, &talInit);
        /*< user code- load Talise stream binary into streamBinary[4096] >*/
        /*< user code- load ARM binary byte array into armBinary[114688] >*/
        talAction = TALISE_loadStreamFromBinary(&talDevice, &streamBinary[0]);
        talAction = TALISE_loadArmFromBinary(&talDevice, &armBinary[0], count);
        /* TALISE_verifyArmChecksum() will timeout after 200ms
         * if ARM checksum is not computed
        talAction = TALISE_verifyArmChecksum(&talDevice);
        if (talAction != TAL_ERR_OK)
            /*< user code- ARM did not load properly - check armBinary & clock/profile settings >*/
    else
        /*< user code- check settings for proper CLKPLL lock  > ***/
    /**Set RF PLL LO Frequencies ***/
	TALISE_setRfPllLoopFilter(&talDevice, 50, 3);
    talAction = TALISE_setRfPllFrequency(&talDevice, TAL_RF_PLL, 1800000000);
    /*** < wait 200ms for PLLs to lock - user code here > ***/
    if ((pllLockStatus & 0x07) != 0x07)
        /*< user code - ensure lock of all PLLs before proceeding>*/
    /**** Run Talise ARM Initialization Calibrations ***/
	/*** < User: Turn ON the PA (if any), and open any switches on ORx input used to isolate it for calibrations > ***/
	/*** < User: Open any switches on the Rx input (if used) to isolate Rx input and provide required VSWR at input > ***/
    talAction = TALISE_runInitCals(&talDevice, initCalMask & ~TAL_TX_LO_LEAKAGE_EXTERNAL);
    talAction = TALISE_waitInitCals(&talDevice, 20000, &errorFlag);
    if (errorFlag)
        /*< user code - Check error flag to determine ARM  error> */
    else
        /*< user code - Calibrations completed successfully > */
	/*****  TALISE ARM Initialization External LOL Calibrations with PA  *****/
	/*** < Action: Please ensure PA is enabled operational at this time > ***/
	if (initCalMask & TAL_TX_LO_LEAKAGE_EXTERNAL)
		talAction = TALISE_runInitCals(&talDevice, TAL_TX_LO_LEAKAGE_EXTERNAL);
		if (errorFlag)
		else
	/**** Enable Talise JESD204B Framer ***/
	talAction = TALISE_enableFramerLink(&talDevice, TAL_FRAMER_A, 0);
	talAction |= TALISE_enableFramerLink(&talDevice, TAL_FRAMER_A, 1);
	/**** Enable SYSREF to Talise JESD204B Framer ***/
	/*** < User: Make sure SYSREF is stopped/disabled > ***/
	talAction = TALISE_enableSysrefToFramer(&talDevice, TAL_FRAMER_A, 1);
	talAction = TALISE_enableFramerLink(&talDevice, TAL_FRAMER_B, 0);
	talAction |= TALISE_enableFramerLink(&talDevice, TAL_FRAMER_B, 1);
	talAction = TALISE_enableSysrefToFramer(&talDevice, TAL_FRAMER_B, 1);
	/**** Enable  Talise JESD204B Deframer ***/
	talAction = TALISE_enableDeframerLink(&talDevice, TAL_DEFRAMER_A, 0);
	talAction |= TALISE_enableDeframerLink(&talDevice, TAL_DEFRAMER_A, 1);
	/**** Enable SYSREF to Talise JESD204B Deframer ***/
	talAction = TALISE_enableSysrefToDeframer(&talDevice, TAL_DEFRAMER_A, 1);
    /*** < User Sends SYSREF Here > ***/
    /*** < Insert User JESD204B Sync Verification Code Here > ***/
	/**** Check Talise Deframer Status ***/
	talAction = TALISE_readDeframerStatus(&talDevice, TAL_DEFRAMER_A, &deframerStatus);
	/**** Check Talise Framer Status ***/
	talAction = TALISE_readFramerStatus(&talDevice, TAL_FRAMER_A, &framerStatus);
	talAction = TALISE_readFramerStatus(&talDevice, TAL_FRAMER_B, &framerStatus);
    /*** < User: When links have been verified, proceed > ***/
    * Allow Rx1/2 QEC tracking and Tx1/2 QEC       *
    * tracking to run when in the radioOn state    *
    * Tx calibrations will only run if radioOn and *
    * the obsRx path is set to OBS_INTERNAL_CALS   *
    talAction = TALISE_enableTrackingCals(&talDevice, trackingCalMask);
    /* Function to turn radio on, Enables transmitters and receivers */
    /* that were setup during TALISE_initialize() */
    talAction = TALISE_radioOn(&talDevice);
    * Shutdown Procedure *
    /* Function to turn radio on, Disables transmitters and receivers */
    talAction = TALISE_radioOff(&talDevice);
    /* Put Talise in safe state for power down */
    talAction = TALISE_shutdown(&talDevice);
    /*Close Talise Hw Device*/
    talAction = TALISE_closeHw(&talDevice);
    return 0;
the orignal talise_config.c:
 * \file talise_config.c
 * \brief Contains Talise configuration settings for the Talise API
 * The top level structure taliseDevice_t talDevice uses keyword
 * extern to allow the application layer main() to have visibility
 * to these settings.
 * This file may not be fully complete for the end user application and
 * may need to updated for AGC, GPIO, and DAC full scale settings.
 * To create a full initialisation routine, the user should also refer to the
 * Iron Python initialisation routine generated by the GUI, and also the Talise User Guide.
#include "talise_types.h"
#include "talise_agc.h"
#ifdef ADI_ZYNQ_PLATFORM
#include "zynq_platform.h"
#endif
int16_t txFirCoefs[20] = {-39, 24, -62, 112, -175, 298, -574, 1284, -2814, 20281, -2814, 1284, -574, 298, -175, 112, -62, 24, -39, 0};
int16_t rxFirCoefs[72] = {0, 0, 2, 0, -7, -1, 15, 4, -31, -10, 57, 23, -99, -47, 161, 86, -247, -146, 372, 238, -542, -381, 762, 583, -1064, -883, 1470, 1331, -2057, -2059, 2975, 3403, -4748, -6898, 9698, 30806, 30806, 9698, -6898, -4748, 3403, 2975, -2059, -2057, 1331, 1470, -883, -1064, 583, 762, -381, -542, 238, 372, -146, -247, 86, 161, -47, -99, 23, 57, -10, -31, 4, 15, -1, -7, 0, 2, 0, 0};
int16_t obsrxFirCoefs[24] = {-15, 9, -13, 19, -28, 38, -73, 110, -195, 409, -1006, 17711, -1006, 409, -195, 110, -73, 38, -28, 19, -13, 9, -15, 0};
#ifdef ADI_ZYNQ_PLATFORM /** < Insert Customer Platform HAL State Container here>*/
 * Platform Layer SPI settings - this structure is specific to ADI's platform layer code.
 * User should replace with their own structure or settings for their hardware
zynqSpiSettings_t spiDev1 =
	.chipSelectIndex = 1,
	.writeBitPolarity = 0,
	.longInstructionWord = 1,
	.CPHA = 0,
	.CPOL = 0,
	.mode = 0,
	.spiClkFreq_Hz = 25000000
 * Platform Layer settings - this structure is specific to ADI's platform layer code.
 * The structure is held in taliseDevice_t below as a void pointer, allowing
 * the customer to pass any information for their specific hardware down to the
 * hardware layer code.
zynqAdiDev_t talDevHalInfo =
	.devIndex = 1,
	.spiSettings = &spiDev1,
	.spiErrCode = 0,
	.timerErrCode = 0,
	.gpioErrCode = 0,
	.logLevel = ADIHAL_LOG_ALL
#endif
 *  TalDevice a structure used by the Talise API to hold the platform hardware
 *  structure information, as well as an internal Talise API state container
 *  (devStateInfo) of runtime information used by the API.
taliseDevice_t talDevice =
    /* Void pointer of users platform HAL settings to pass to HAL layer calls
     * Talise API does not use the devHalInfo member */
	.devHalInfo = &talDevHalInfo,
#else
	.devHalInfo = NULL,     /*/** < Insert Customer Platform HAL State Container here>*/
#endif
	/* devStateInfo is maintained internal to the Talise API, just create the memory */
	.devStateInfo = {0}
taliseInit_t talInit =
	/* SPI settings */
    .spiSettings =
		.MSBFirst            = 1,  /* 1 = MSBFirst, 0 = LSBFirst */
		.enSpiStreaming      = 0,  /* Not implemented in ADIs platform layer. SW feature to improve SPI throughput */
		.autoIncAddrUp       = 1,  /* Not implemented in ADIs platform layer. For SPI Streaming, set address increment direction. 1= next addr = addr+1, 0:addr=addr-1 */
		.fourWireMode        = 1,  /* 1: Use 4-wire SPI, 0: 3-wire SPI (SDIO pin is bidirectional). NOTE: ADI's FPGA platform always uses 4-wire mode */
		.cmosPadDrvStrength  = TAL_CMOSPAD_DRV_2X /* Drive strength of CMOS pads when used as outputs (SDIO, SDO, GP_INTERRUPT, GPIO 1, GPIO 0) */
    /* Rx settings */
    .rx =
        .rxProfile =
            .rxFir =
                .gain_dB = -6,                /* filter gain */
                .numFirCoefs = 72,            /* number of coefficients in the FIR filter */
                .coefs = &rxFirCoefs[0]
            .rxFirDecimation = 2,            /* Rx FIR decimation (1,2,4) */
            .rxDec5Decimation = 4,            /* Decimation of Dec5 or Dec4 filter (5,4) */
            .rhb1Decimation = 2,            /* RX Half band 1 decimation (1 or 2) */
            .rxOutputRate_kHz = 122880,            /* Rx IQ data rate in kHz */
            .rfBandwidth_Hz = 100000000,    /* The Rx RF passband bandwidth for the profile */
            .rxBbf3dBCorner_kHz = 100000,    /* Rx BBF 3dB corner in kHz */
            .rxAdcProfile = {265, 146, 181, 90, 1280, 366, 1257, 27, 1258, 17, 718, 39, 48, 46, 27, 161, 0, 0, 0, 0, 40, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},            /* pointer to custom ADC profile */
            .rxDdcMode = TAL_RXDDC_BYPASS,   /* Rx DDC mode */
            .rxNcoShifterCfg =
                .bandAInputBandWidth_kHz = 0,
                .bandAInputCenterFreq_kHz = 0,
                .bandANco1Freq_kHz = 0,
                .bandANco2Freq_kHz = 0,
                .bandBInputBandWidth_kHz = 0,
                .bandBInputCenterFreq_kHz = 0,
                .bandBNco1Freq_kHz = 0,
                .bandBNco2Freq_kHz = 0
        .framerSel = TAL_FRAMER_A,            /* Rx JESD204b framer configuration */
        .rxGainCtrl =
            .gainMode = TAL_MGC,            /* taliserxGainMode_t gainMode */
            .rx1GainIndex = 255,            /* uint8_t rx1GainIndex */
            .rx2GainIndex = 255,            /* uint8_t rx2GainIndex */
            .rx1MaxGainIndex = 255,            /* uint8_t rx1MaxGainIndex */
            .rx1MinGainIndex = 195,            /* uint8_t rx1MinGainIndex */
            .rx2MaxGainIndex = 255,            /* uint8_t rx2MaxGainIndex */
            .rx2MinGainIndex = 195            /* uint8_t rx2MinGainIndex */
        .rxChannels = TAL_RX1RX2,                /* The desired Rx Channels to enable during initialization */
    /* Tx settings */
    .tx =
        .txProfile =
            .dacDiv = 1,                        /* The divider used to generate the DAC clock */
            .txFir =
                .gain_dB = 6,                        /* filter gain */
                .numFirCoefs = 20,                    /* number of coefficients in the FIR filter */
                .coefs = &txFirCoefs[0]
            .txFirInterpolation = 1,                    /* The Tx digital FIR filter interpolation (1,2,4) */
            .thb1Interpolation = 2,                    /* Tx Halfband1 filter interpolation (1,2) */
            .thb2Interpolation = 2,                    /* Tx Halfband2 filter interpolation (1,2)*/
            .thb3Interpolation = 1,                    /* Tx Halfband3 filter interpolation (1,2)*/
            .txInt5Interpolation = 1,                    /* Tx Int5 filter interpolation (1,5) */
            .txInputRate_kHz = 491520,                    /* Primary Signal BW */
            .primarySigBandwidth_Hz = 200000000,    /* The Rx RF passband bandwidth for the profile */
            .rfBandwidth_Hz = 450000000,            /* The Tx RF passband bandwidth for the profile */
            .txDac3dBCorner_kHz = 450000,                /* The DAC filter 3dB corner in kHz */
            .txBbf3dBCorner_kHz = 225000,                /* The BBF 3dB corner in kHz */
            .loopBackAdcProfile = {150, 178, 181, 90, 1280, 1338, 1699, 493, 1386, 162, 934, 4, 48, 46, 35, 201, 0, 0, 0, 0, 50, 0, 0, 6, 24, 0, 0, 6, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905}
        .deframerSel = TAL_DEFRAMER_A,                    /* Talise JESD204b deframer config for the Tx data path */
        .txChannels = TAL_TX1TX2,                            /* The desired Tx channels to enable during initialization */
        .txAttenStepSize = TAL_TXATTEN_0P05_DB,            /* Tx Attenuation step size */
        .tx1Atten_mdB = 0,                            /* Initial Tx1 Attenuation */
        .tx2Atten_mdB = 0,                            /* Initial Tx2 Attenuation */
        .disTxDataIfPllUnlock = TAL_TXDIS_TX_RAMP_DOWN_TO_ZERO    /* Options to disable the transmit data when the RFPLL unlocks. */
    /* ObsRx settings */
    .obsRx =
        .orxProfile =
            .rxFir =
                .numFirCoefs = 24,            /* number of coefficients in the FIR filter */
                .coefs = &obsrxFirCoefs[0]
            .rxFirDecimation = 1,            /* Rx FIR decimation (1,2,4) */
            .rhb1Decimation = 1,            /* RX Half band 1 decimation (1 or 2) */
            .orxOutputRate_kHz = 491520,            /* Rx IQ data rate in kHz */
            .rfBandwidth_Hz = 450000000,    /* The Rx RF passband bandwidth for the profile */
            .rxBbf3dBCorner_kHz = 225000,    /* Rx BBF 3dB corner in kHz */
            .orxLowPassAdcProfile = {155, 163, 181, 90, 1280, 1254, 1572, 340, 1431, 142, 973, 8, 48, 47, 36, 205, 0, 0, 0, 0, 51, 0, 0, 6, 24, 0, 0, 6, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905},
            .orxBandPassAdcProfile = {124, 131, 154, 90, 1280, 2779, 1986, 0, 1037, 839, 988, 109, 11, 15, 28, 179, 0, 0, 0, 0, 45, 0, 0, 0, 24, 0, 0, 0, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905},
            .orxDdcMode = TAL_ORXDDC_DISABLED,   /* ORx DDC mode */
            .orxMergeFilter  = {-167, 419, -208, -498, 968, -320, -1273, 2154, -402, -4155, 9170, 21413}
        .orxGainCtrl =
            .orx1GainIndex = 255,
            .orx2GainIndex = 255,
            .orx1MaxGainIndex = 255,
            .orx1MinGainIndex = 195,
            .orx2MaxGainIndex = 255,
            .orx2MinGainIndex = 195
        .framerSel = TAL_FRAMER_B,                /* ObsRx JESD204b framer configuration */
        .obsRxChannelsEnable = TAL_ORX1,        /* The desired ObsRx Channels to enable during initialization */
        .obsRxLoSource = TAL_OBSLO_RF_PLL                /* The ORx mixers can use the TX_PLL */
    /* Digital Clock Settings */
    .clocks =
        .deviceClock_kHz = 245760,            /* CLKPLL and device reference clock frequency in kHz */
        .clkPllVcoFreq_kHz = 9830400,        /* CLKPLL VCO frequency in kHz */
        .clkPllHsDiv = TAL_HSDIV_2P5,            /* CLKPLL high speed clock divider */
        .rfPllUseExternalLo = 0,                /* 1= Use external LO for RF PLL, 0 = use internal LO generation for RF PLL */
        .rfPllPhaseSyncMode = TAL_RFPLLMCS_INIT_AND_CONTTRACK                /* RFPLL MCS (Phase sync) mode */
    /* JESD204B settings */
    .jesd204Settings =
        /* Framer A settings */
        .framerA =
            .bankId = 1,                    /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
            .deviceId = 0,                    /* JESD204B Configuration Device ID - link identification number. (Valid 0..255) */
            .lane0Id = 0,                    /* JESD204B Configuration starting Lane ID.  If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31) */
            .M = 4,                            /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
            .K = 32,                        /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes) */
            .F = 8,                            /* F (number of bytes per frame) */
            .Np = 16,                            /* Np (converter sample resolution) */
            .scramble = 1,                    /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled. */
            .externalSysref = 1,            /* 0=use internal SYSREF, 1= use external SYSREF */
            .serializerLanesEnabled = 0x01,    /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
            .serializerLaneCrossbar = 0xE4,    /* serializerLaneCrossbar */
            .lmfcOffset = 31,                /* lmfcOffset - LMFC offset value for deterministic latency setting */
            .newSysrefOnRelink = 0,            /* newSysrefOnRelink */
            .syncbInSelect = 0,                /* syncbInSelect; */
            .overSample = 0,                    /* 1=overSample, 0=bitRepeat */
            .syncbInLvdsMode = 1,
            .syncbInLvdsPnInvert = 0,
            .enableManualLaneXbar = 0 /* 0=auto, 1=manual */
        /* Framer B settings */
        .framerB =
            .bankId = 0,                    /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
            .M = 2,                            /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
            .F = 2,                            /* F (number of bytes per frame) */
            .serializerLanesEnabled = 0x0C,    /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
            .syncbInSelect = 1,                /* syncbInSelect; */
        /* Deframer A settings */
        .deframerA =
            .bankId = 0,                    /* bankId extension to Device ID (Valid 0..15) */
            .deviceId = 0,                    /* deviceId  link identification number. (Valid 0..255) */
            .lane0Id = 0,                    /* lane0Id Lane0 ID. (Valid 0..31) */
            .M = 4,                            /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
            .K = 32,                        /* K  #frames in a multiframe (default=32), F*K=multiple of 4. (F=2*M/numberOfLanes) */
            .scramble = 1,                    /* scramble  scrambling off if scramble= 0 */
            .externalSysref = 1,            /* externalSysref  0= use internal SYSREF, 1= external SYSREF */
            .deserializerLanesEnabled = 0x0F,    /* deserializerLanesEnabled  bit per lane, [0] = Lane0 enabled */
            .deserializerLaneCrossbar = 0xE4,    /* deserializerLaneCrossbar */
            .lmfcOffset = 31,                /* lmfcOffset	 LMFC offset value to adjust deterministic latency */
            .syncbOutSelect = 0,                /* SYNCBOUT0/1 select */
            .syncbOutLvdsMode = 1,
            .syncbOutLvdsPnInvert = 0,
            .syncbOutCmosSlewRate = 0,
            .syncbOutCmosDriveLevel = 0,
        /* Deframer B settings */
        .deframerB =
            .M = 0,                            /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
            .deserializerLanesEnabled = 0x00,    /* deserializerLanesEnabled  bit per lane, [0] = Lane0 enabled */
            .lmfcOffset = 0,                /* lmfcOffset	 LMFC offset value to adjust deterministic latency */
            .syncbOutSelect = 1,                /* SYNCBOUT0/1 select */
        .serAmplitude = 15,                    /* Serializer amplitude setting. Default = 15. Range is 0..15 */
        .serPreEmphasis = 1,                /* Serializer pre-emphasis setting. Default = 1 Range is 0..4 */
        .serInvertLanePolarity = 0,            /* Serializer Lane PN inversion select. Default = 0. Where, bit[0] = 1 will invert lane [0], bit[1] = 1 will invert lane 1, etc. */
        .desInvertLanePolarity = 0,            /* Deserializer Lane PN inversion select.  bit[0] = 1 Invert PN of Lane 0, bit[1] = Invert PN of Lane 1, etc */
        .desEqSetting = 1,                    /* Deserializer Equalizer setting. Applied to all deserializer lanes. Range is 0..4 */
        .sysrefLvdsMode = 1,                /* Use LVDS inputs on Talise for SYSREF */
        .sysrefLvdsPnInvert = 0              /*0= Do not PN invert SYSREF */
//Only needs to be called if user wants to setup AGC parameters
static taliseAgcCfg_t rxAgcCtrl =
    4,
    255,
    195,
    255,
    195,
    30720,  /* AGC gain update time in us (125us-250us - based on IQ data rate - set for 125us @ 245.76 Mhz) */
    10,
    10,
    16,
    0,
    1,
    0,
    0,
    0,
    1,
    31,
    246,
    4,
    1,          /*!<1- bit field to enable the multiple time constants in AGC loop for fast attack and fast recovery to max gain. */
    /* agcPower */
        1,      /*!<1-bit field, enables the Rx power measurement block. */
        1,      /*!<1-bit field, allows using Rx PFIR for power measurement. */
        0,      /*!<1-bit field, allows to use the output of the second digital offset block in the Rx datapath for power measurement. */
        9,      /*!<AGC power measurement detect lower 0 threshold. Default = -12dBFS == 5, 7-bit register value where max = 0x7F, min = 0x00 */
        2,      /*!<AGC power measurement detect lower 1 threshold. Default = (offset) 4dB == 0, 4-bit register value where  max = 0xF, min = 0x00 */
        4,      /*!<AGC power measurement detect lower 0 recovery gain step. Default = 2dB - based on gain table step  size, 5-bit register value where max = 0x1F, min = 0x00 */
        4,      /*!<AGC power measurement detect lower 1 recovery gain step. Default = 4dB - based on gain table step size, 5-bit register value where max = 0x1F, min = 0x00 */
        5,      /*!< power measurement duration used by the decimated power block. Default = 0x05, 5-bit register value where max = 0x1F, min = 0x00 */
        5,      /*!<Allows power detection of data for a specific slice of the gain update counter. 16-bit register value (currently not used) */
        1,      /*!<Allows power detection of data for a specific slice of the gain update counter. 16-bit register value (currently not used) */
        2,      /*!<Default value should be 2*/
        0,
        0
    /* agcPeak */
        205,        /*!<1st update interval for the multiple time constant in AGC loop mode, Default:205. */
        2,          /*!<sets the 2nd update interval for the multiple time constant in AGC loop mode. Calculated as a multiple of  agcUnderRangeLowInterval  , Default: 4 */
        4,          /*!<sets the 3rd update interval for the multiple time constant in AGC loop mode. Calculated as a multiple of agcUnderRangeMidInterval and agcUnderRangeLowInterval, Default: 4 */
        39,         /*!<AGC APD high threshold. Default=0x1F, 6-bit register value where max=0x3F, min =0x00 */
        49,         /*!<AGC APD peak detect high threshold. default = 0x1F, 6-bit register value where max = 0x3F, min = 0x00.  Set to 3dB below apdHighThresh */
        23,         /*!<AGC APD peak detect low threshold. default = 3dB below high threshold, 6-bit register value where max =0x3F, min = 0x00 */
        19,         /*!<AGC APD peak detect low threshold. default = 3dB below high threshold, 6-bit register value where max = 0x3F, min = 0x00 . Set to 3dB below apdLowThresh  */
        6,          /*!<AGC APD peak detect upper threshold count. Default = 0x06 8-bit register value where max = 0xFF, min = 0x20  */
        3,          /*!<AGC APD peak detect lower threshold count. Default = 0x03, 8-bit register value where max = 0xFF, min = 0x00  */
        4,          /*!<AGC APD peak detect attack gain step. Default = 2dB step - based on gain table step size, 5-bit register  value, where max = 0x1F, min = 0x00  */
        2,          /*!<AGC APD gain index step size. Recommended to be same as hb2GainStepRecovery. Default = 0x00, 5-bit register value where max = 0x1F, min = 0x00  */
        1,          /*!<1-bit field, enables or disables the HB2 overload detector.  */
        1,          /*!<3-bit field. Sets the window of clock cycles (at the HB2 output rate) to meet the overload count. */
        1,          /*!<4-bit field. Sets the number of actual overloads required to trigger the overload signal.  */
        181,        /*!<AGC decimator output high threshold. Default = 0xB5, 8-bit register value where max = 0xFF, min = 0x00 */
        45,         /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
        90,         /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
        128,        /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
        6,          /*!<AGC HB2 output upper threshold count. Default = 0x06, 8-bit register value where max = 0xFF, min =  0x20 */
        3,          /*!<AGC HB2 output lower threshold count. Default = 0x03, 8-bit register value where max = 0xFF, min = 0x00 */
        2,          /*!<AGC decimator gain index step size. Default = 0x00, 5-bit register value where max = 0x1F, min = 0x00 */
        4,          /*!<AGC HB2 gain index step size, when the HB2 Low Overrange interval 0 triggers a programmable number  of times. Default = 0x08, 5-bit register value where max = 0x1F, min = 0x00 */
        8,          /*!<AGC HB2 gain index step size, when the HB2 Low Overrange interval 1 triggers a programmable number of times. Default = 0x04, 5-bit register value where max = 0x1F, min = 0x00 */
        4,          /*!<AGC decimator output attack gain step. Default = 2dB step - based on gain table step size, 5-bit register value, where max = 0x1F, min = 0x00 */
        1,
        0,
        0
Thanks and Best Regards.
