Discrepancies in Rx BW and Sampling Rate in IIO vs Talise Configuration Wizard
I set up the Rx BW to 20 MHz and Sampling Rate to 50MHz in Talise Configuration Wizard like this:
Then I import the config file to IIO but the BW is 100MHz and sampling rate is 122.88 MSPS:
Would appreciate if anyone give me any idea to set up IIO correctly.
Henry
    on May 2, 2019 9:28 PM
    The profile is likely not loading correctly. Once it loads the rates will be reflected in IIO-Scope. I can even see <error> in your screen shots, so it didn't load correctly.
    With such a low sample rate you may also have to modify the JESD rates: https://ez.analog.com/wide-band-rf-transceivers/design-support-adrv9008-1-adrv9008-2-adrv9009/f/q-a/109020/adrv9009-tx-sample-rate/324967#324967
    -Travis
  • Hi Travis,
    I don't think it is the BW problem.  I regenerated a profile, BW 100MHz, very similar to an example in IIO but, still, error pops up when loading to IIO.  I have attached both my profile and the example profile for your analysis.  The only difference are in the device clock and the number of terms in the FIR filter.  I am wondering what is missed.  Here is the setting in the Profile Configuration Wizard.
    Thanks
    My_Profile_Tx_BW200_IR245p76_Rx_BW100_OR122p88_ORx_BW200_OR245p76.txt
    <profile Talise version=1 name=Tx_BW200_IR245p76_Rx_BW100_OR122p88_ORx_BW200_OR245p76>
     <clocks>
      <deviceClock_kHz=65536>
      <clkPllVcoFreq_kHz=9830400>
      <clkPllHsDiv=2.5>
     </clocks>
     <rx name=Rx 100.00MHz, OutputRate 122.88MHz, TotalDecimation 16>
      <rxChannels=TAL_RX1RX2>
      <rxFirDecimation=2>
      <rxDec5Decimation=4>
      <rhb1Decimation=2>
      <rxOutputRate_kHz=122880>
      <rfBandwidth_Hz=100000000>
      <rxBbf3dBCorner_kHz=100000>
      <rxDdcMode=0>
      <rxNcoShifterCfg>
       <bandAInputBandWidth_kHz=0>
       <bandAInputCenterFreq_kHz=0>
       <bandANco1Freq_kHz=0>
       <bandANco2Freq_kHz=0>
       <bandBInputBandWidth_kHz=0>
       <bandBInputCenterFreq_kHz=0>
       <bandBNco1Freq_kHz=0>
       <bandBNco2Freq_kHz=0>
      </rxNcoShifterCfg>
      <filter FIR gain_dB=-6 numFirCoefs=72>
      0
      -1
      2
      3
      -4
      -7
      10
      16
      -21
      -31
      40
      56
      -71
      -96
      119
      157
      -187
      -241
      288
      363
      -431
      -538
      622
      772
      -891
      -1105
      1264
      1582
      -1819
      -2335
      2710
      3697
      -4461
      -7201
      9397
      31111
      31111
      9397
      -7201
      -4461
      3697
      2710
      -2335
      -1819
      1582
      1264
      -1105
      -891
      772
      622
      -538
      -431
      363
      288
      -241
      -187
      157
      119
      -96
      -71
      56
      40
      -31
      -21
      16
      10
      -7
      -4
      3
      2
      -1
      0
      </filter>
      <rxAdcProfile num=42>
      265
      146
      181
      90
      1280
      366
      1257
      27
      1258
      17
      718
      39
      48
      46
      27
      161
      0
      0
      0
      0
      40
      0
      7
      6
      42
      0
      7
      6
      42
      0
      25
      27
      0
      0
      25
      27
      0
      0
      165
      44
      31
      905
      </rxAdcProfile>
     </rx>
     <obsRx name=Rx 200.00MHz, OutputRate 245.76MHz, TotalDecimation 8>
      <obsRxChannelsEnable=TAL_ORX1ORX2>
      <enAdcStitching=0>
      <rxFirDecimation=2>
      <rhb1Decimation=1>
      <orxOutputRate_kHz=245760>
      <rfBandwidth_Hz=200000000>
      <rxBbf3dBCorner_kHz=225000>
      <orxDdcMode=0>
      <filter FIR gain_dB=-6 numFirCoefs=48>
      -7
      -21
      31
      48
      -67
      -106
      124
      164
      -275
      -334
      440
      552
      -694
      -872
      1069
      1351
      -1633
      -2111
      2541
      3477
      -4295
      -6877
      9433
      30825
      30825
      9433
      -6877
      -4295
      3477
      2541
      -2111
      -1633
      1351
      1069
      -872
      -694
      552
      440
      -334
      -275
      164
      124
      -106
      -67
      48
      31
      -21
      -7
      </filter>
      <orxLowPassAdcProfile num=42>
      185
      141
      172
      90
      1280
      942
      1332
      90
      1368
      46
      1016
      19
      48
      48
      37
      208
      0
      0
      0
      0
      52
      0
      7
      6
      42
      0
      7
      6
      42
      0
      25
      27
      0
      0
      25
      27
      0
      0
      165
      44
      31
      905
      </orxLowPassAdcProfile>
      <orxBandPassAdcProfile num=42>
      185
      141
      172
      90
      1280
      942
      1332
      90
      1368
      46
      1016
      19
      48
      48
      37
      208
      0
      0
      0
      0
      52
      0
      7
      6
      42
      0
      7
      6
      42
      0
      25
      27
      0
      0
      25
      27
      0
      0
      165
      44
      31
      905
      </orxBandPassAdcProfile>
     </obsRx>
     <lpbk>
      <rxFirDecimation=2>
      <rhb1Decimation=1>
      <outputRate_kHz=245760>
      <rfBandwidth_Hz=75000000>
      <filter FIR gain_dB=-6 num=48>
      -7
      -21
      31
      48
      -67
      -106
      124
      164
      -275
      -334
      440
      552
      -694
      -872
      1069
      1351
      -1633
      -2111
      2541
      3477
      -4295
      -6877
      9433
      30825
      30825
      9433
      -6877
      -4295
      3477
      2541
      -2111
      -1633
      1351
      1069
      -872
      -694
      552
      440
      -334
      -275
      164
      124
      -106
      -67
      48
      31
      -21
      -7
      </filter>
      <lpbkAdcProfile num=42>
      243
      143
      181
      90
      1280
      485
      1275
      37
      1317
      23
      797
      35
      48
      48
      30
      174
      0
      0
      0
      0
      44
      0
      7
      6
      42
      0
      7
      6
      42
      0
      25
      27
      0
      0
      25
      27
      0
      0
      165
      44
      31
      905
      </lpbkAdcProfile>
     </lpbk>
     <tx name=Tx 200.00MHz, InputRate 245.76MHz, TotalInterpolation 8>
      <txChannels=TAL_TX1TX2>
      <dacDiv=1>
      <txFirInterpolation=1>
      <thb1Interpolation=2>
      <thb2Interpolation=2>
      <thb3Interpolation=2>
      <txInt5Interpolation=1>
      <txInputRate_kHz=245760>
      <primarySigBandwidth_Hz=75000000>
      <txDac3dBCorner_kHz=200000>
      <txBbf3dBCorner_kHz=100000>
      <filter FIR gain_dB=0 numFirCoefs=20>
      33
      -77
      123
      -158
      171
      -112
      -155
      1040
      -3011
      20121
      -3011
      1040
      -155
      -112
      171
      -158
      123
      -77
      33
      0
      </filter>
     </tx>
    </profile>
    Example_Profile_Tx_BW200_IR245p76_Rx_BW100_OR122p88_ORx_BW200_OR245p76_DC245p76.txt
    <profile Talise version=1 name=Tx_BW200_IR245p76_Rx_BW100_OR122p88_ORx_BW200_OR245p76_DC245p76>
     <clocks>
      <deviceClock_kHz=245760>
      <clkPllHsDiv=2.5>
     </clocks>
      <rxFirDecimation=2>
      <rhb1Decimation=2>
      <rxDdcMode=0>
      <rxNcoShifterCfg>
      </rxNcoShifterCfg>
      -8
      -22
      32
      50
      -68
      -106
      141
      199
      -258
      -352
      430
      572
      -691
      -903
      1069
      1392
      -1644
      -2172
      2569
      3574
      -4364
      -7129
      9355
      31095
      31095
      9355
      -7129
      -4364
      3574
      2569
      -2172
      -1644
      1392
      1069
      -903
      -691
      572
      430
      -352
      -258
      199
      141
      -106
      -68
      50
      32
      -22
      -8
      </filter>
      265
      146
      181
      90
      1280
      366
      1257
      27
      1258
      17
      718
      39
      48
      46
      27
      161
      0
      0
      0
      0
      40
      0
      7
      6
      42
      0
      7
      6
      42
      0
      25
      27
      0
      0
      25
      27
      0
      0
      165
      44
      31
      905
      </rxAdcProfile>
     </rx>
      <enAdcStitching=0>
      <rxFirDecimation=2>
      <rhb1Decimation=1>
      <orxDdcMode=0>
      -7
      -21
      31
      48
      -67
      -106
      124
      164
      -275
      -334
      440
      552
      -694
      -872
      1069
      1351
      -1633
      -2111
      2541
      3477
      -4295
      -6877
      9433
      30825
      30825
      9433
      -6877
      -4295
      3477
      2541
      -2111
      -1633
      1351
      1069
      -872
      -694
      552
      440
      -334
      -275
      164
      124
      -106
      -67
      48
      31
      -21
      -7
      </filter>
      185
      141
      172
      90
      1280
      942
      1332
      90
      1368
      46
      1016
      19
      48
      48
      37
      208
      0
      0
      0
      0
      52
      0
      7
      6
      42
      0
      7
      6
      42
      0
      25
      27
      0
      0
      25
      27
      0
      0
      165
      44
      31
      905
      185
      141
      172
      90
      1280
      942
      1332
      90
      1368
      46
      1016
      19
      48
      48
      37
      208
      0
      0
      0
      0
      52
      0
      7
      6
      42
      0
      7
      6
      42
      0
      25
      27
      0
      0
      25
      27
      0
      0
      165
      44
      31
      905
     </obsRx>
     <lpbk>
      <rxFirDecimation=2>
      <rhb1Decimation=1>
      -7
      -21
      31
      48
      -67
      -106
      124
      164
      -275
      -334
      440
      552
      -694
      -872
      1069
      1351
      -1633
      -2111
      2541
      3477
      -4295
      -6877
      9433
      30825
      30825
      9433
      -6877
      -4295
      3477
      2541
      -2111
      -1633
      1351
      1069
      -872
      -694
      552
      440
      -334
      -275
      164
      124
      -106
      -67
      48
      31
      -21
      -7
      </filter>
      243
      143
      181
      90
      1280
      485
      1275
      37
      1317
      23
      797
      35
      48
      48
      30
      174
      0
      0
      0
      0
      44
      0
      7
      6
      42
      0
      7
      6
      42
      0
      25
      27
      0
      0
      25
      27
      0
      0
      165
      44
      31
      905
      </lpbkAdcProfile>
     </lpbk>
      <dacDiv=1>
      33
      -77
      123
      -158
      171
      -112
      -155
      1040
      -3011
      20121
      -3011
      1040
      -155
      -112
      171
      -158
      123
      -77
      33
      0
      </filter>
     </tx>
    </profile>
