ADRV9002 TES crash 0.20
Hi AD experts,
I have an issue when I Press "Program" in TES. The green progress indicator goes almost to the right.
Unfortunately, the TES window (program) suddenly disappears. I can't find any hint in the LOG file.
Connect is ok, Shutdown in FIle menu works allsow
LEDs are also ok. As described in  TES Connection Issues
LOG File:
Session log file
Created on Donnerstag, 17. Februar 2022 at 09:52:42.8264473, Greenwich Mean Time.
Processing command-line arguments:
Booting up Argo 0.20.0.2095 from C:\Users\Tichy.BPS\Analog Devices\ADRV9001 Transceiver Evaluation Software_0_20.
Temp files will be stored in k:\Temp\Analog Devices\Argo.
User files will be stored in C:\Users\Tichy.BPS\AppData\Roaming\Analog Devices\Argo.
Attempting to initialize Windows Forms elements.
Located user settings file at C:\Users\Tichy.BPS\AppData\Roaming\Analog Devices\Argo\Navassa.Periplous.json.
Located default config file for plugin at C:\Users\Tichy.BPS\Analog Devices\ADRV9001 Transceiver Evaluation Software_0_20\Navassa.Periplous.taxidi.
Creating load-save object with file C:\Users\Tichy.BPS\Analog Devices\ADRV9001 Transceiver Evaluation Software_0_20\Navassa.Periplous.taxidi.
Loading plugin Navassa v0.20.0.
Connection attempt initiated.
Last resource version sync was v0.20.0
Performing platform resource sync.
Preparing to kill any existing server(s).
Preparing to kill server.
Host: root@192.168.1.10, Server: Adrv9001Server* located in /home/analog/adrv9001_server/resources/Adi.Adrv9001.Server/
Preparing to start server.
Host: root@192.168.1.10, Server: Adrv9001Server_C0 located in /home/analog/adrv9001_server/resources/Adi.Adrv9001.Server/
Starting server.
Server is running.
Loaded resources:
Transceiver Name ADRV9002
Silicon Revision B0
Evaluation Board Revision 2B
Tx / Rx optimal carrier frequencies 30 MHz to 3 GHz
External LO optimal frequencies 60 MHz to 6 GHz
FPGA v8.2.21
Device Driver API v48.49.2
Device Driver Client v48.49.2
Firmware v0.20.0.10
Profile Generator v0.50.5.0
Stream Generator Assembly v0.7.9.0
Transceiver Evaluation Software v0.20.0
ADRV9001 Plugin v0.20.0
Attempting to generate profile from blueprint:
  "expandedSearchEnable": false,
  "isDesigned": false,
  "isViable": true,
  "warmBootEnable": false,
  "processorClockDivisor": 4,
  "pllCalibration": 0,
  "duplex": 0,
  "diversity": true,
  "deviceClockInput_kHz": 38400,
  "clockPllPower": 2,
  "clockPllMode": 1,
  "allowPllRetuning": false,
  "adcRate": 1,
  "txChannel2": {
    "operationalBandwidth": 2,
    "ssiType": 2,
    "ssiStrobeType": 0,
    "ssiRefClockPin": 1,
    "ssiNumLane": 1,
    "ssiInterfaceRate_Hz": 24000,
    "ssiDataRate": 1,
    "ssiDataFormat": 4,
    "samplingRate_Hz": 24000,
    "rfChannelBandwidth_Hz": 12000,
    "peakLoopbackPower_dBm": -18,
    "orxEnabled": false,
    "lowPassFilterPower": 0,
    "loSource": 0,
    "frequencyOffsetCorrectionEnable": false,
    "frequencyDeviation_Hz": 1500,
    "enabled": false,
    "elbType": 0,
    "channelSignalType": 0,
    "channelFilterType": 0,
    "channelFilterInterpolation": 1,
    "channelFilter": [
      0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  "txChannel1": {
    "ssiType": 2,
    "ssiStrobeType": 0,
    "ssiNumLane": 1,
    "ssiInterfaceRate_Hz": 96000,
    "ssiDataRate": 1,
    "ssiDataFormat": 2,
    "samplingRate_Hz": 96000,
    "loSource": 0,
    "enabled": true,
    "elbType": 0,
    "channelSignalType": 1,
    "channelFilter": [
  "rxChannel2": {
    "ssiType": 2,
    "ssiStrobeType": 0,
    "ssiNumLane": 1,
    "ssiDataRate": 1,
    "ssiDataFormat": 4,
    "rfInput": 0,
    "ncoEnable": true,
    "loSource": 0,
    "intermediateFrequency_Hz": 490000,
    "gainTableType": 0,
    "frequencyDeviation_Hz": 0,
    "enabled": false,
    "channelSignalSetup": 2,
    "channelFilterType": 2,
    "channelFilter": [
    "analogFilterOrder": 1,
    "analogFilterCorner_kHz": 10000,
    "adcType": 0
  "rxChannel1": {
    "ssiType": 2,
    "ssiStrobeType": 0,
    "ssiNumLane": 1,
    "ssiDataRate": 1,
    "ssiDataFormat": 4,
    "rfInput": 0,
    "ncoEnable": true,
    "loSource": 0,
    "gainTableType": 0,
    "enabled": true,
    "channelFilter": [
      1, -5, -2, 12, 7, -24, -22, 37, 56, -47, -119, 37, 218, 21, -352, -169, 501, 459, -611, -944, 581, 1659, -252, -2592, -606, 3641, 2295, -4564, -5239, 4868, 10405, -2150, -16860, -7184, 17284, 16170, -15978, -28242, 8754, 41070, 6970, -50243, -31684, 50215, 63113, -35486, -95952, 1919, 122118, 52081, -131402, -124789, 112154, 210975, -51173, -302406, -69399, 388963, 286340, -460206, -731028, 507073, 2617033, 3674001, 2617033, 507073, -731028, -460206, 286340, 388963, -69399, -302406, -51173, 210975, 112154, -124789, -131402, 52081, 122118, 1919, -95952, -35486, 63113, 50215, -31684, -50243, 6970, 41070, 8754, -28242, -15978, 16170, 17284, -7184, -16860, -2150, 10405, 4868, -5239, -4564, 2295, 3641, -606, -2592, -252, 1659, 581, -944, -611, 459, 501, -169, -352, 21, 218, 37, -119, -47, 56, 37, -22, -24, 7, 12, -2, -5, 1, 0
    "adcType": 0
  "loExternal2": {
    "loSignalingType": 0,
    "loDivisor": 2
  "loExternal1": {
    "loDivisor": 2
Generated profile:
  "clocks": {
    "deviceClock_kHz": 38400,
    "clkPllVcoFreq_daHz": 442368000,
    "clkPllHsDiv": 0,
    "clkPllMode": 1,
    "clk1105Div": 2,
    "armClkDiv": 6,
    "armPowerSavingClkDiv": 4,
    "refClockOutEnable": true,
    "auxPllPower": 2,
    "clkPllPower": 2,
    "padRefClkDrv": 0,
    "extLo1OutFreq_kHz": 0,
    "extLo2OutFreq_kHz": 0,
    "rfPll1LoMode": 0,
    "rfPll2LoMode": 0,
    "ext1LoType": 0,
    "ext2LoType": 0,
    "rx1RfInputSel": 0,
    "rx2RfInputSel": 0,
    "extLo1Divider": 2,
    "extLo2Divider": 2,
    "rfPllPhaseSyncMode": 0,
    "rx1LoSelect": 2,
    "rx2LoSelect": 2,
    "tx1LoSelect": 1,
    "tx2LoSelect": 1,
    "rx1LoDivMode": 1,
    "rx2LoDivMode": 1,
    "tx1LoDivMode": 0,
    "tx2LoDivMode": 0,
    "loGen1Select": 1,
    "loGen2Select": 1
  "rx": {
    "rxInitChannelMask": 65,
    "rxChannelCfg": [
        "profile": {
          "primarySigBandwidth_Hz": 12000,
          "rxOutputRate_Hz": 24000,
          "rxInterfaceSampleRate_Hz": 24000,
          "rxOffsetLo_kHz": 490,
          "rxNcoEnable": true,
          "outputSignaling": 0,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 20000000,
          "lpAdcCorner": 0,
          "adcClk_kHz": 1105920,
          "rxCorner3dB_kHz": 10000,
          "rxCorner3dBLp_kHz": 10000,
          "tiaPower": 0,
          "tiaPowerLp": 0,
          "channelType": 1,
          "adcType": 0,
          "lpAdcCalMode": 0,
          "gainTableType": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 1,
              "scicBlk23DivFactor": 10,
              "scicBlk23LowRippleEn": 0,
              "decBy2Blk35En": 1,
              "decBy2Blk37En": 1,
              "decBy2Blk39En": 1,
              "decBy2Blk41En": 1,
              "decBy2Blk43En": 1,
              "decBy3Blk45En": 1,
              "decBy2Blk47En": 1
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
              "decBy2Hb3Blk17p1En": 0,
              "decBy2Hb4Blk17p2En": 1,
              "decBy2Hb5Blk19p1En": 0,
              "decBy2Hb6Blk19p2En": 1
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 1,
              "hbMux": 4,
              "isGainCompEnabled": 0,
              "gainComp9GainI": [
                16384, 16384, 16384, 16384, 16384, 16384
              "gainComp9GainQ": [
                0, 0, 0, 0, 0, 0
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
                "dpInFifoTestDataSel": 0
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
                "rxWbNbCompPFirInMuxSel": 0,
                "rxWbNbCompPFirEn": 1
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "lnaConfig": {
            "externalLnaPresent": false,
            "gpioSourceSel": 0,
            "externalLnaPinSel": 0,
            "settlingDelay": 0,
            "numberLnaGainSteps": 0,
            "lnaGainSteps_mdB": [
              0, 0, 0, 0
            "lnaDigitalGainDelay": 0,
            "minGainIndex": 0
          "rxSsiConfig": {
            "ssiType": 2,
            "ssiDataFormatSel": 4,
            "numLaneSel": 1,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "lvdsIBitInversion": false,
            "lvdsQBitInversion": false,
            "lvdsStrobeBitInversion": false,
            "lvdsUseLsbIn12bitMode": 0,
            "lvdsRxClkInversionEn": false,
            "cmosDdrPosClkEn": false,
            "cmosClkInversionEn": false,
            "ddrEn": true,
            "rxMaskStrobeEn": false
        "profile": {
          "primarySigBandwidth_Hz": 12500,
          "rxOutputRate_Hz": 0,
          "rxInterfaceSampleRate_Hz": 0,
          "rxOffsetLo_kHz": 0,
          "rxNcoEnable": false,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 0,
          "lpAdcCorner": 0,
          "adcClk_kHz": 0,
          "rxCorner3dB_kHz": 0,
          "rxCorner3dBLp_kHz": 0,
          "tiaPower": 2,
          "tiaPowerLp": 2,
          "channelType": 0,
          "adcType": 1,
          "lpAdcCalMode": 0,
          "gainTableType": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 0,
              "scicBlk23DivFactor": 0,
              "decBy2Blk35En": 0,
              "decBy2Blk37En": 0,
              "decBy2Blk39En": 0,
              "decBy2Blk41En": 0,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 0,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
              "decBy2Hb4Blk17p2En": 0,
              "decBy2Hb6Blk19p2En": 0
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 0,
              "hbMux": 4,
              "gainComp9GainI": [
              "gainComp9GainQ": [
                0, 0, 0, 0, 0, 0
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
                "rxWbNbCompPFirEn": 0
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "lnaConfig": {
            "gpioSourceSel": 0,
            "settlingDelay": 0,
              0, 0, 0, 0
            "minGainIndex": 0
          "rxSsiConfig": {
            "ssiType": 0,
            "ssiDataFormatSel": 0,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "ddrEn": false,
        "profile": {
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 0,
          "lpAdcCorner": 0,
          "adcClk_kHz": 0,
          "tiaPower": 2,
          "tiaPowerLp": 2,
          "channelType": 0,
          "adcType": 1,
          "lpAdcCalMode": 0,
          "gainTableType": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 0,
              "decBy2Blk35En": 0,
              "decBy2Blk37En": 0,
              "decBy2Blk39En": 0,
              "decBy2Blk41En": 0,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 0,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 0,
              "hbMux": 4,
              "gainComp9GainI": [
              "gainComp9GainQ": [
                0, 0, 0, 0, 0, 0
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "lnaConfig": {
            "gpioSourceSel": 0,
            "settlingDelay": 0,
              0, 0, 0, 0
            "minGainIndex": 0
          "rxSsiConfig": {
            "ssiType": 0,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "ddrEn": false,
        "profile": {
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 0,
          "lpAdcCorner": 0,
          "adcClk_kHz": 0,
          "tiaPower": 2,
          "tiaPowerLp": 2,
          "channelType": 0,
          "adcType": 1,
          "lpAdcCalMode": 0,
          "gainTableType": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 0,
              "decBy2Blk35En": 0,
              "decBy2Blk37En": 0,
              "decBy2Blk39En": 0,
              "decBy2Blk41En": 0,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 0,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 0,
              "hbMux": 4,
              "gainComp9GainI": [
              "gainComp9GainQ": [
                0, 0, 0, 0, 0, 0
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "lnaConfig": {
            "gpioSourceSel": 0,
            "settlingDelay": 0,
              0, 0, 0, 0
            "minGainIndex": 0
          "rxSsiConfig": {
            "ssiType": 0,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "ddrEn": false,
        "profile": {
          "rxOutputRate_Hz": 96000,
          "rxInterfaceSampleRate_Hz": 96000,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "lpAdcCorner": 0,
          "tiaPower": 0,
          "tiaPowerLp": 0,
          "channelType": 64,
          "adcType": 0,
          "lpAdcCalMode": 0,
          "gainTableType": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 1,
              "decBy2Blk35En": 1,
              "decBy2Blk37En": 1,
              "decBy2Blk39En": 1,
              "decBy2Blk41En": 1,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 1,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
              "decBy2Hb3Blk17p1En": 1,
              "decBy2Hb5Blk19p1En": 1,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 1,
              "hbMux": 4,
              "gainComp9GainI": [
              "gainComp9GainQ": [
                0, 0, 0, 0, 0, 0
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 1,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "lnaConfig": {
            "gpioSourceSel": 0,
            "settlingDelay": 0,
              0, 0, 0, 0
            "minGainIndex": 0
          "rxSsiConfig": {
            "ssiType": 2,
            "numLaneSel": 1,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "ddrEn": true,
        "profile": {
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 0,
          "lpAdcCorner": 0,
          "adcClk_kHz": 0,
          "tiaPower": 2,
          "tiaPowerLp": 2,
          "channelType": 0,
          "adcType": 1,
          "lpAdcCalMode": 0,
          "gainTableType": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 0,
              "decBy2Blk35En": 0,
              "decBy2Blk37En": 0,
              "decBy2Blk39En": 0,
              "decBy2Blk41En": 0,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 0,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 0,
              "hbMux": 4,
              "gainComp9GainI": [
              "gainComp9GainQ": [
                0, 0, 0, 0, 0, 0
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "lnaConfig": {
            "gpioSourceSel": 0,
            "settlingDelay": 0,
              0, 0, 0, 0
            "minGainIndex": 0
          "rxSsiConfig": {
            "ssiType": 0,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "ddrEn": false,
        "profile": {
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 0,
          "lpAdcCorner": 0,
          "adcClk_kHz": 0,
          "tiaPower": 2,
          "tiaPowerLp": 2,
          "channelType": 0,
          "adcType": 1,
          "lpAdcCalMode": 0,
          "gainTableType": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 0,
              "decBy2Blk35En": 0,
              "decBy2Blk37En": 0,
              "decBy2Blk39En": 0,
              "decBy2Blk41En": 0,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 0,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 0,
              "hbMux": 4,
              "gainComp9GainI": [
              "gainComp9GainQ": [
                0, 0, 0, 0, 0, 0
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "lnaConfig": {
            "gpioSourceSel": 0,
            "settlingDelay": 0,
              0, 0, 0, 0
            "minGainIndex": 0
          "rxSsiConfig": {
            "ssiType": 0,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "ddrEn": false,
        "profile": {
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 0,
          "lpAdcCorner": 0,
          "adcClk_kHz": 0,
          "tiaPower": 2,
          "tiaPowerLp": 2,
          "channelType": 0,
          "adcType": 1,
          "lpAdcCalMode": 0,
          "gainTableType": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 0,
              "decBy2Blk35En": 0,
              "decBy2Blk37En": 0,
              "decBy2Blk39En": 0,
              "decBy2Blk41En": 0,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 0,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 0,
              "hbMux": 4,
              "gainComp9GainI": [
              "gainComp9GainQ": [
                0, 0, 0, 0, 0, 0
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "lnaConfig": {
            "gpioSourceSel": 0,
            "settlingDelay": 0,
              0, 0, 0, 0
            "minGainIndex": 0
          "rxSsiConfig": {
            "ssiType": 0,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "ddrEn": false,
  "tx": {
    "txInitChannelMask": 4,
    "txProfile": [
        "txInputRate_Hz": 96000,
        "txInterfaceSampleRate_Hz": 96000,
        "txOffsetLo_kHz": 0,
        "validDataDelay": 0,
        "txBbf3dBCorner_kHz": 33000,
        "outputSignaling": 1,
        "txPdBiasCurrent": 1,
        "txPdGainEnable": 0,
        "txPrePdRealPole_kHz": 1000000,
        "txPostPdRealPole_kHz": 530000,
        "txBbfPower": 0,
        "txExtLoopBackType": 0,
        "txExtLoopBackForInitCal": 0,
        "txPeakLoopBackPower": 0,
        "txDpProfile": {
          "txPreProc": {
            "txPreProcSymbol0": 0,
            "txPreProcSymbol1": 0,
            "txPreProcSymbol2": 0,
            "txPreProcSymbol3": 0,
            "txPreProcSymMapDivFactor": 1,
            "txPreProcMode": 0,
            "txPreProcWbNbPfirIBankSel": 0,
            "txPreProcWbNbPfirQBankSel": 1
          "txWbIntTop": {
            "txInterpBy2Blk30En": 0,
            "txInterpBy2Blk28En": 0,
            "txInterpBy2Blk26En": 0,
            "txInterpBy2Blk24En": 0,
            "txInterpBy2Blk22En": 0,
            "txWbLpfBlk22p1En": 0
          "txNbIntTop": {
            "txInterpBy2Blk20En": 1,
            "txInterpBy2Blk18En": 1,
            "txInterpBy2Blk16En": 1,
            "txInterpBy2Blk14En": 1,
            "txInterpBy2Blk12En": 0,
            "txInterpBy3Blk10En": 1,
            "txInterpBy2Blk8En": 0,
            "txScicBlk32En": 1,
            "txScicBlk32DivFactor": 10
          "txIntTop": {
            "interpBy3Blk44p1En": 0,
            "sinc3Blk44En": 0,
            "sinc2Blk42En": 0,
            "interpBy3Blk40En": 0,
            "interpBy2Blk38En": 1,
            "interpBy2Blk36En": 1
          "txIntTopFreqDevMap": {
            "rrc2Frac": 0,
            "mpll": 0,
            "nchLsw": 0,
            "nchMsb": 0,
            "freqDevMapEn": 0,
            "txRoundEn": 1
          "txIqdmDuc": {
            "iqdmDucMode": 1,
            "iqdmDev": 60397,
            "iqdmDevOffset": 0,
            "iqdmScalar": 32767,
            "iqdmThreshold": 131071,
            "iqdmNco": {
              "freq": 0,
              "sampleFreq": 46080000,
              "phase": 0,
              "realOut": 0
        "txSsiConfig": {
          "ssiType": 2,
          "ssiDataFormatSel": 2,
          "numLaneSel": 1,
          "strobeType": 0,
          "lsbFirst": 0,
          "qFirst": 0,
          "txRefClockPin": 1,
          "ddrEn": true,
        "txInputRate_Hz": 0,
        "txInterfaceSampleRate_Hz": 0,
        "txPdBiasCurrent": 0,
        "txPrePdRealPole_kHz": 0,
        "txPostPdRealPole_kHz": 0,
        "txBbfPower": 2,
        "txDpProfile": {
          "txPreProc": {
            "txPreProcMode": 1,
            "txPreProcWbNbPfirIBankSel": 2,
            "txPreProcWbNbPfirQBankSel": 3
          "txWbIntTop": {
          "txNbIntTop": {
            "txInterpBy2Blk20En": 0,
            "txInterpBy2Blk18En": 0,
            "txInterpBy2Blk16En": 0,
            "txInterpBy2Blk14En": 0,
            "txInterpBy3Blk10En": 0,
            "txScicBlk32En": 0,
            "txScicBlk32DivFactor": 0
          "txIntTop": {
            "sinc3Blk44En": 0,
            "sinc2Blk42En": 0,
            "interpBy2Blk38En": 0,
            "interpBy2Blk36En": 0
            "rrc2Frac": 0,
            "mpll": 0,
            "nchLsw": 0,
            "nchMsb": 0,
            "freqDevMapEn": 0,
            "txRoundEn": 1
          "txIqdmDuc": {
            "iqdmDucMode": 0,
            "iqdmDev": 0,
            "iqdmDevOffset": 0,
            "iqdmScalar": 0,
            "iqdmThreshold": 0,
            "iqdmNco": {
              "freq": 0,
              "sampleFreq": 0,
              "phase": 0,
              "realOut": 0
        "txSsiConfig": {
          "ssiType": 0,
          "numLaneSel": 0,
          "strobeType": 0,
          "lsbFirst": 0,
          "qFirst": 0,
          "txRefClockPin": 0,
          "ddrEn": false,
  "sysConfig": {
    "duplexMode": 0,
    "fhModeOn": 0,
    "numDynamicProfiles": 1,
    "mcsMode": 0,
    "mcsInterfaceType": 0,
    "adcTypeMonitor": 0,
    "pllLockTime_us": 750,
    "pllPhaseSyncWait_us": 0,
    "pllModulus": {
      "modulus": [
        8388593, 8388593, 8388593, 8388593, 8388593
      "dmModulus": [
        8388593, 8388593
  "pfirBuffer": {
    "pfirRxWbNbChFilterCoeff_A": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [
    "pfirRxWbNbChFilterCoeff_B": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [
        0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
    "pfirRxWbNbChFilterCoeff_C": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [
    "pfirRxWbNbChFilterCoeff_D": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [
    "pfirTxWbNbPulShpCoeff_A": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [
    "pfirTxWbNbPulShpCoeff_B": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [
    "pfirTxWbNbPulShpCoeff_C": {
      "numCoeff": 0,
      "symmetricSel": 0,
      "tapsSel": 0,
      "gainSel": 0,
      "coefficients": [
    "pfirTxWbNbPulShpCoeff_D": {
      "numCoeff": 0,
      "symmetricSel": 0,
      "tapsSel": 0,
      "gainSel": 0,
      "coefficients": [
    "pfirRxNbPulShp": [
        "numCoeff": 128,
        "symmetricSel": 0,
        "taps": 128,
        "gainSel": 2,
        "coefficients": [
        "numCoeff": 0,
        "symmetricSel": 0,
        "taps": 0,
        "gainSel": 0,
        "coefficients": [
    "pfirRxMagLowTiaLowSRHp": [
        "numCoeff": 21,
        "coefficients": [
          -31, 59, 257, -779, -8, 1745, 30, -4301, -1291, 11248, 18911, 11248, -1291, -4301, 30, 1745, -8, -779, 257, 59, -31
        "numCoeff": 0,
        "coefficients": [
    "pfirRxMagLowTiaHighSRHp": [
        "numCoeff": 21,
        "coefficients": [
          -940, -178, 1792, 2565, -566, -5836, -7722, -2815, 6471, 14694, 17836, 14694, 6471, -2815, -7722, -5836, -566, 2565, 1792, -178, -940
        "numCoeff": 0,
        "coefficients": [
    "pfirRxMagHighTiaHighSRHp": [
        "numCoeff": 21,
        "coefficients": [
          41, -241, 750, -1559, 2236, -1920, -262, 4378, -8850, 8452, 26718, 8452, -8850, 4378, -262, -1920, 2236, -1559, 750, -241, 41
        "numCoeff": 0,
        "coefficients": [
    "pfirRxMagLowTiaLowSRLp": [
        "numCoeff": 21,
        "coefficients": [
          -31, 59, 257, -779, -8, 1745, 30, -4300, -1289, 11247, 18908, 11247, -1289, -4300, 30, 1745, -8, -779, 257, 59, -31
        "numCoeff": 0,
        "coefficients": [
    "pfirRxMagLowTiaHighSRLp": [
        "numCoeff": 21,
        "coefficients": [
          -960, -177, 1876, 2631, -710, -6092, -7709, -2400, 6813, 14477, 17273, 14477, 6813, -2400, -7709, -6092, -710, 2631, 1876, -177, -960
        "numCoeff": 0,
        "coefficients": [
    "pfirRxMagHighTiaHighSRLp": [
        "numCoeff": 21,
        "coefficients": [
          41, -237, 739, -1536, 2208, -1908, -229, 4283, -8730, 8455, 26600, 8455, -8730, 4283, -229, -1908, 2208, -1536, 739, -237, 41
        "numCoeff": 0,
        "coefficients": [
    "pfirTxMagComp1": {
      "numCoeff": 21,
      "coefficients": [
        178, -1042, 3271, -6913, 10209, -9581, 1555, 14717, -24411, 7373, 42061, 7373, -24411, 14717, 1555, -9581, 10209, -6913, 3271, -1042, 178
    "pfirTxMagComp2": {
      "numCoeff": 0,
      "coefficients": [
    "pfirTxMagCompNb": [
        "numCoeff": 13,
        "coefficients": [
          54, -468, 1339, -836, -3842, 9293, 21689, 9293, -3842, -836, 1339, -468, 54
        "numCoeff": 0,
        "coefficients": [
    "pfirRxMagCompNb": [
        "numCoeff": 13,
        "coefficients": [
        "numCoeff": 0,
        "coefficients": [
Could you help us?
Stefan
