ADRV9002 + ZCU102, Unable to get spectrum output in TES
Iam evaluating the ADRV9002 board with the following setup:
1. ZCU102 Rev 1.1 board
2. ADRV9002BBCZNP/W1=0.03-3GHz C0 silicon revision board
3. In order to work with ZCU102 the SD Card is re-imaged with the ADRV9001 Disk image utility Ver. 0.16.0
4. TES GUI Ver. 0.16.0 is installed and used
The ZCU102 board boots up correctly and iam able to connect and program the ADRV9002 board with TES GUI correctly.
But in Receive data capture, Iam not able to see the spectrum output and when stop button is clicked an error log mentioning "dma transfer has timed out" is coming.
I have attached the receiver configuration(RX Overview), error message from TES and Spectrum output screenshots.
How to solve this issue and evaluate the ADRV9002 with ZCU102 board.
    on Jun 24, 2021 9:18 AM
    Hello Saravanan,
    Unless I'm mistaken there appears to be some other issue with your setup. Every image except the one detailing the error message indicates that you're using a Zero-IF setup, however that image with the error message window shows an IF of 490kHz. That field should update immediately when you program the IF into the device, the fact that it isn't might indicate some other connection issue.
    Before we dive into SW issues I'd like to ask you to confirm that your physical setup has no issues (make sure the FMC connection to the FPGA is secure and straight, not shanked at all) and that your device clk input is either set to the on-board oscillator or connected securely to an external signal generator. In either case, be sure to match the frequency with the setting in the "Clocks" tab.
    You mentioned in your question that you just recently re-imaged your SD card with the latest imaging tool version. Sadly this tool does seem to be a bit finicky, so another attempt at re-imaging could solve your issue. Give it an attempt if the physical debugging efforts yield no benefits.
    Finally, if there are other people you could ask to attempt programming your setup on this platform with both Windows 7 and Windows 10 that would confirm wither the issue is with your computer / TES install or with TES itself.
    Give these bits of debug a try, if none of them work return here and we'll see what else we can do.
    Best Regards,
    Oisin.
  • Hello Oisin,
    I have re-imaged the SD card once again and i have installed the TES GUI in another PC, after these attempts also the problem is still there.
    Iam attaching the linux booting prints
    ZCU102_ADRV9002_BOOT_LOG.txt
    Xilinx Zynq MP First Stage Boot Loader
    Release 2019.2   Jan 24 2021  -  13:17:24
    NOTICE:  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
    NOTICE:  BL31: Secure code at 0x0
    NOTICE:  BL31: Non secure code at 0x8000000
    NOTICE:  BL31: v1.4(release):1db0406-dirty
    NOTICE:  BL31: Built : 13:28:10, Jan 24 2021
    PMUFW:  v1.1
    U-Boot 2018.01 (Jan 24 2021 - 13:25:30 -0500) Xilinx ZynqMP ZCU102 rev1.0
    I2C:   ready
    DRAM:  4 GiB
    EL Level:       EL2
    Chip ID:        zu9eg
    MMC:   sdhci@ff170000: 0 (SD)
    *** Warning - bad CRC, using default environment
    In:    serial@ff000000
    Out:   serial@ff000000
    Err:   serial@ff000000
    Bootmode: LVL_SHFT_SD_MODE1
    Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
    Warning: ethernet@ff0e0000 (eth0) using random MAC address - b2:38:0c:35:ff:d5
    eth0: ethernet@ff0e0000
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc0 is current device
    Device: sdhci@ff170000
    Manufacturer ID: 2
    OEM: 544d
    Tran Speed: 50000000
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 14.4 GiB
    Bus Width: 4-bit
    Erase Group Size: 512 Bytes
    reading uEnv.txt
    188 bytes read in 10 ms (17.6 KiB/s)
    Loaded environment from uEnv.txt
    Importing environment from SD ...
    reading system.dtb
    37339 bytes read in 17 ms (2.1 MiB/s)
    reading Image
    16116224 bytes read in 1072 ms (14.3 MiB/s)
    ## Flattened Device Tree blob at 04000000
       Booting using the fdt blob at 0x4000000
       Loading Device Tree to 000000000fff3000, end 000000000ffff1da ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.14.0 (rkutty@rkutty-lx01.adsdesign.analog.com) (gcc version 8.2.0 (GCC)) #1 SMP Sun Jan 24 14:11:29 EST 2021
    [    0.000000] Boot CPU: AArch64 Processor [410fd034]
    [    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] efi: UEFI not found.
    [    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] random: fast init done
    [    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff67000 s45080 r8192 d32744 u86016
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: enabling workaround for ARM erratum 845719
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1034240
    [    0.000000] Kernel command line: console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait uio_pdrv_genirq.of_id=generic-uio ip=192.168.1.10 root=/dev/mmcblk0p2 rw rootwait
    [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
    [    0.000000] software IO TLB [mem 0x6bfff000-0x6ffff000] (64MB) mapped at [ffffffc06bfff000-ffffffc06fffefff]
    [    0.000000] Memory: 3784120K/4194304K available (9468K kernel code, 634K rwdata, 5108K rodata, 512K init, 2152K bss, 148040K reserved, 262144K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
    [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
    [    0.000000]       .text : 0xffffff8008080000 - 0xffffff80089c0000   (  9472 KB)
    [    0.000000]     .rodata : 0xffffff80089c0000 - 0xffffff8008ec0000   (  5120 KB)
    [    0.000000]       .init : 0xffffff8008ec0000 - 0xffffff8008f40000   (   512 KB)
    [    0.000000]       .data : 0xffffff8008f40000 - 0xffffff8008fdea00   (   635 KB)
    [    0.000000]        .bss : 0xffffff8008fdea00 - 0xffffff80091f8a68   (  2153 KB)
    [    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
    [    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
    [    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
    [    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 MB actual)
    [    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 MB)
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000]  RCU event tracing is enabled.
    [    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
    [    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
    [    0.000318] Console: colour dummy device 80x25
    [    0.000339] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
    [    0.000347] pid_max: default: 32768 minimum: 301
    [    0.000449] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.000463] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.001040] ASID allocator initialised with 65536 entries
    [    0.001086] Hierarchical SRCU implementation.
    [    0.001436] EFI services will not be available.
    [    0.001482] zynqmp_plat_init Platform Management API v1.1
    [    0.001487] zynqmp_plat_init Trustzone version v1.0
    [    0.001584] smp: Bringing up secondary CPUs ...
    [    0.001828] Detected VIPT I-cache on CPU1
    [    0.001857] CPU1: Booted secondary processor [410fd034]
    [    0.002127] Detected VIPT I-cache on CPU2
    [    0.002145] CPU2: Booted secondary processor [410fd034]
    [    0.002402] Detected VIPT I-cache on CPU3
    [    0.002419] CPU3: Booted secondary processor [410fd034]
    [    0.002460] smp: Brought up 1 node, 4 CPUs
    [    0.002474] SMP: Total of 4 processors activated.
    [    0.002480] CPU features: detected feature: 32-bit EL0 Support
    [    0.002487] CPU: All CPU(s) started at EL2
    [    0.002500] alternatives: patching kernel code
    [    0.003240] devtmpfs: initialized
    [    0.008125] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.008140] futex hash table entries: 1024 (order: 5, 131072 bytes)
    [    0.013648] xor: measuring software checksum speed
    [    0.052010]    8regs     :  2375.000 MB/sec
    [    0.092038]    8regs_prefetch:  2052.000 MB/sec
    [    0.132068]    32regs    :  2724.000 MB/sec
    [    0.172096]    32regs_prefetch:  2308.000 MB/sec
    [    0.172101] xor: using function: 32regs (2724.000 MB/sec)
    [    0.172165] pinctrl core: initialized pinctrl subsystem
    [    0.172697] NET: Registered protocol family 16
    [    0.173581] cpuidle: using governor menu
    [    0.174257] vdso: 2 pages (1 code @ ffffff80089c6000, 1 data @ ffffff8008f44000)
    [    0.174267] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.174725] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.206981] zynqmp-pinctrl pinctrl: zynqmp pinctrl initialized
    [    0.207777] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
    [    0.208359] ARM CCI_400_r1 PMU driver probed
    [    0.218272] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.284258] raid6: int64x1  gen()   452 MB/s
    [    0.352293] raid6: int64x1  xor()   438 MB/s
    [    0.420336] raid6: int64x2  gen()   675 MB/s
    [    0.488370] raid6: int64x2  xor()   586 MB/s
    [    0.556470] raid6: int64x4  gen()   973 MB/s
    [    0.624467] raid6: int64x4  xor()   725 MB/s
    [    0.692520] raid6: int64x8  gen()  1157 MB/s
    [    0.760593] raid6: int64x8  xor()   744 MB/s
    [    0.828655] raid6: neonx1   gen()   736 MB/s
    [    0.896666] raid6: neonx1   xor()   853 MB/s
    [    0.964740] raid6: neonx2   gen()  1127 MB/s
    [    1.032769] raid6: neonx2   xor()  1144 MB/s
    [    1.100817] raid6: neonx4   gen()  1506 MB/s
    [    1.168881] raid6: neonx4   xor()  1395 MB/s
    [    1.236951] raid6: neonx8   gen()  1540 MB/s
    [    1.304963] raid6: neonx8   xor()  1452 MB/s
    [    1.304967] raid6: using algorithm neonx8 gen() 1540 MB/s
    [    1.304970] raid6: .... xor() 1452 MB/s, rmw enabled
    [    1.304974] raid6: using neon recovery algorithm
    [    1.306334] SCSI subsystem initialized
    [    1.306490] usbcore: registered new interface driver usbfs
    [    1.306520] usbcore: registered new interface driver hub
    [    1.306554] usbcore: registered new device driver usb
    [    1.306609] media: Linux media interface: v0.10
    [    1.306629] Linux video capture interface: v2.00
    [    1.306668] pps_core: LinuxPPS API ver. 1 registered
    [    1.306672] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.306684] PTP clock support registered
    [    1.306705] EDAC MC: Ver: 3.0.0
    [    1.306995] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
    [    1.307139] FPGA manager framework
    [    1.307238] fpga-region fpga-full: FPGA Region probed
    [    1.307319] Advanced Linux Sound Architecture Driver Initialized.
    [    1.307562] Bluetooth: Core ver 2.22
    [    1.307588] NET: Registered protocol family 31
    [    1.307592] Bluetooth: HCI device and connection manager initialized
    [    1.307600] Bluetooth: HCI socket layer initialized
    [    1.307607] Bluetooth: L2CAP socket layer initialized
    [    1.307620] Bluetooth: SCO socket layer initialized
    [    1.308223] clocksource: Switched to clocksource arch_sys_counter
    [    1.308292] VFS: Disk quotas dquot_6.6.0
    [    1.308332] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    1.312177] NET: Registered protocol family 2
    [    1.312471] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
    [    1.312674] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
    [    1.313074] TCP: Hash tables configured (established 32768 bind 32768)
    [    1.313140] UDP hash table entries: 2048 (order: 4, 65536 bytes)
    [    1.313213] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
    [    1.313361] NET: Registered protocol family 1
    [    1.313534] RPC: Registered named UNIX socket transport module.
    [    1.313539] RPC: Registered udp transport module.
    [    1.313542] RPC: Registered tcp transport module.
    [    1.313546] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.314089] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    1.314232] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    1.314842] audit: initializing netlink subsys (disabled)
    [    1.315183] audit: type=2000 audit(1.304:1): state=initialized audit_enabled=0 res=1
    [    1.315218] workingset: timestamp_bits=62 max_order=20 bucket_order=0
    [    1.315889] NFS: Registering the id_resolver key type
    [    1.315908] Key type id_resolver registered
    [    1.315912] Key type id_legacy registered
    [    1.315920] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.315936] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
    [    1.339670] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    1.339678] io scheduler noop registered
    [    1.339682] io scheduler deadline registered
    [    1.339699] io scheduler cfq registered (default)
    [    1.339704] io scheduler mq-deadline registered
    [    1.339708] io scheduler kyber registered
    [    1.340361] nwl-pcie fd0e0000.pcie: Link is DOWN
    [    1.340401] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges:
    [    1.340418] OF: PCI:   MEM 0xe0000000..0xefffffff -> 0xe0000000
    [    1.340426] OF: PCI:   MEM 0x600000000..0x7ffffffff -> 0x600000000
    [    1.340551] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
    [    1.340560] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.340566] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
    [    1.340572] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
    [    1.340822] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
    [    1.341599] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
    [    1.341987] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
    [    1.342144] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
    [    1.342299] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
    [    1.342455] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
    [    1.342611] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
    [    1.342768] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
    [    1.342932] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
    [    1.343088] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
    [    1.367442] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    1.370388] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    1.374427] brd: module loaded
    [    1.377727] loop: module loaded
    [    1.378493] ahci-ceva fd0c0000.ahci: couldn't get PHY in node ahci: -517
    [    1.378645] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    1.379458] m25p80 spi0.0: found n25q512a, expected m25p80
    [    1.379678] m25p80 spi0.0: n25q512a (131072 Kbytes)
    [    1.379697] 4 ofpart partitions found on MTD device spi0.0
    [    1.379702] Creating 4 MTD partitions on "spi0.0":
    [    1.379709] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    [    1.380102] 0x000000100000-0x000000600000 : "qspi-linux"
    [    1.380507] 0x000000600000-0x000000620000 : "qspi-device-tree"
    [    1.380892] 0x000000620000-0x000000c00000 : "qspi-rootfs"
    [    1.382069] libphy: Fixed MDIO Bus: probed
    [    1.382993] tun: Universal TUN/TAP device driver, 1.6
    [    1.383134] CAN device driver interface
    [    1.385232] macb ff0e0000.ethernet: Not enabling partial store and forward
    [    1.385598] libphy: MACB_mii_bus: probed
    [    1.387237] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 23 (00:0a:35:00:01:22)
    [    1.387244] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
    [    1.387748] usbcore: registered new interface driver asix
    [    1.387792] usbcore: registered new interface driver ax88179_178a
    [    1.387816] usbcore: registered new interface driver cdc_ether
    [    1.387841] usbcore: registered new interface driver net1080
    [    1.387866] usbcore: registered new interface driver cdc_subset
    [    1.387890] usbcore: registered new interface driver zaurus
    [    1.387923] usbcore: registered new interface driver cdc_ncm
    [    1.388501] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
    [    1.389814] usbcore: registered new interface driver uas
    [    1.389846] usbcore: registered new interface driver usb-storage
    [    1.390305] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
    [    1.390350] i2c /dev entries driver
    [    1.391335] IR NEC protocol handler initialized
    [    1.391339] IR RC5(x/sz) protocol handler initialized
    [    1.391343] IR RC6 protocol handler initialized
    [    1.391347] IR JVC protocol handler initialized
    [    1.391350] IR Sony protocol handler initialized
    [    1.391354] IR SANYO protocol handler initialized
    [    1.391357] IR Sharp protocol handler initialized
    [    1.391361] IR MCE Keyboard/mouse protocol handler initialized
    [    1.391364] IR XMP protocol handler initialized
    [    1.392299] usbcore: registered new interface driver uvcvideo
    [    1.392303] USB Video Class driver (1.1.1)
    [    1.392776] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff800926d000 with timeout 10s
    [    1.392934] Bluetooth: HCI UART driver ver 2.3
    [    1.392940] Bluetooth: HCI UART protocol H4 registered
    [    1.392944] Bluetooth: HCI UART protocol BCSP registered
    [    1.392965] Bluetooth: HCI UART protocol LL registered
    [    1.392969] Bluetooth: HCI UART protocol ATH3K registered
    [    1.392974] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    1.393010] Bluetooth: HCI UART protocol Intel registered
    [    1.393014] Bluetooth: HCI UART protocol QCA registered
    [    1.393046] usbcore: registered new interface driver bcm203x
    [    1.393073] usbcore: registered new interface driver bpa10x
    [    1.393102] usbcore: registered new interface driver bfusb
    [    1.393129] usbcore: registered new interface driver btusb
    [    1.393133] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
    [    1.393176] usbcore: registered new interface driver ath3k
    [    1.393287] EDAC MC: ECC not enabled
    [    1.393424] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
    [    1.394244] sdhci: Secure Digital Host Controller Interface driver
    [    1.394249] sdhci: Copyright(c) Pierre Ossman
    [    1.394252] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.395427] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.395548] usbcore: registered new interface driver usbhid
    [    1.395552] usbhid: USB HID core driver
    [    1.397295] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
    [    1.397972] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    1.398211] Netfilter messages via NETLINK v0.30.
    [    1.398323] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.398448] Initializing XFRM netlink socket
    [    1.398507] NET: Registered protocol family 10
    [    1.398900] Segment Routing with IPv6
    [    1.398939] ip6_tables: (C) 2000-2006 Netfilter Core Team
    [    1.399051] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.399354] NET: Registered protocol family 17
    [    1.399365] NET: Registered protocol family 15
    [    1.399381] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    1.399386] Ebtables v2.0 registered
    [    1.399463] can: controller area network core (rev 20170425 abi 9)
    [    1.399491] NET: Registered protocol family 29
    [    1.399502] can: raw protocol (rev 20170425)
    [    1.399507] can: broadcast manager protocol (rev 20170425 t)
    [    1.399513] can: netlink gateway (rev 20170425) max_hops=1
    [    1.399698] Bluetooth: RFCOMM TTY layer initialized
    [    1.399709] Bluetooth: RFCOMM socket layer initialized
    [    1.399723] Bluetooth: RFCOMM ver 1.11
    [    1.399730] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.399734] Bluetooth: BNEP filters: protocol multicast
    [    1.399740] Bluetooth: BNEP socket layer initialized
    [    1.399745] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.399751] Bluetooth: HIDP socket layer initialized
    [    1.399847] 9pnet: Installing 9P2000 support
    [    1.399862] Key type dns_resolver registered
    [    1.400357] registered taskstats version 1
    [    1.400654] Btrfs loaded, crc32c=crc32c-generic
    [    1.405972] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 39, base_baud = 6249999) is a xuartps
    [    2.935611] console [ttyPS0] enabled
    [    2.939839] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 40, base_baud = 6249999) is a xuartps
    [    2.950538] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
    [    2.958665] PLL: shutdown
    [    2.961350] PLL: shutdown
    [    2.964286] PLL: enable
    [    2.966785] PLL: shutdown
    [    2.970738] PLL: enable
    [    2.973215] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
    [    2.983800] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
    [    2.991761] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
    [    3.000027] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
    [    3.012376] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
    [    3.024948] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
    [    3.035037] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
    [    3.041946] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.048478] [drm] No driver support for vblank timestamp query.
    [    3.054437] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008a77628)
    [    4.140237] [drm] Cannot find any crtc or sizes
    [    4.144848] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
    [    4.152868] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
    [    4.161830] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
    [    4.169636] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
    [    4.178524] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
    [    4.188842] scsi host0: ahci-ceva
    [    4.192264] scsi host1: ahci-ceva
    [    4.195593] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
    [    4.203428] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
    [    4.213080] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
    [    4.221062] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    4.226479] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    4.234307] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
    [    4.242947] xhci-hcd xhci-hcd.0.auto: irq 45, io mem 0xfe200000
    [    4.248941] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    4.255645] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    4.262845] usb usb1: Product: xHCI Host Controller
    [    4.267705] usb usb1: Manufacturer: Linux 4.14.0 xhci-hcd
    [    4.273087] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    4.278219] hub 1-0:1.0: USB hub found
    [    4.281903] hub 1-0:1.0: 1 port detected
    [    4.285959] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    4.291370] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    4.299053] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    4.307145] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [    4.313847] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    4.321050] usb usb2: Product: xHCI Host Controller
    [    4.325910] usb usb2: Manufacturer: Linux 4.14.0 xhci-hcd
    [    4.331293] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    4.336384] hub 2-0:1.0: USB hub found
    [    4.340061] hub 2-0:1.0: 1 port detected
    [    4.345095] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
    [    4.355207] GPIO line 322 (sel0) hogged as output/low
    [    4.360515] GPIO line 323 (sel1) hogged as output/high
    [    4.365900] GPIO line 324 (sel2) hogged as output/high
    [    4.371288] GPIO line 325 (sel3) hogged as output/high
    [    4.376440] pca953x 0-0020: interrupt support not compiled in
    [    4.382195] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator
    [    4.392097] pca953x 0-0021: interrupt support not compiled in
    [    4.398554] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.405249] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.411946] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.418638] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.425327] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.432015] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.438702] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.445394] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.452084] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.458780] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.465078] i2c i2c-0: Added multiplexed i2c bus 3
    [    4.470422] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
    [    4.477116] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.483807] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.490494] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.497181] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.503876] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.510567] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.517262] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
    [    4.523558] i2c i2c-0: Added multiplexed i2c bus 4
    [    4.526431] ata2: SATA link down (SStatus 0 SControl 330)
    [    4.530416] ata1: SATA link down (SStatus 0 SControl 330)
    [    4.580151] i2c i2c-0: Added multiplexed i2c bus 5
    [    4.584985] i2c i2c-0: Added multiplexed i2c bus 6
    [    4.589692] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
    [    4.597003] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 25
    [    4.604578] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
    [    4.611226] i2c i2c-1: Added multiplexed i2c bus 7
    [    4.616155] i2c i2c-1: Added multiplexed i2c bus 8
    [    4.622868] si570 9-005d: registered, current frequency 300000000 Hz
    [    4.629165] i2c i2c-1: Added multiplexed i2c bus 9
    [    4.635135] si570 10-005d: clock registration failed
    [    4.640072] si570: probe of 10-005d failed with error -17
    [    4.645416] i2c i2c-1: Added multiplexed i2c bus 10
    [    4.650436] i2c i2c-1: Added multiplexed i2c bus 11
    [    4.655340] i2c i2c-1: Added multiplexed i2c bus 12
    [    4.660247] i2c i2c-1: Added multiplexed i2c bus 13
    [    4.665168] i2c i2c-1: Added multiplexed i2c bus 14
    [    4.669962] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
    [    4.678142] at24 15-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
    [    4.684788] i2c i2c-1: Added multiplexed i2c bus 15
    [    4.689744] i2c i2c-1: Added multiplexed i2c bus 16
    [    4.694650] i2c i2c-1: Added multiplexed i2c bus 17
    [    4.699553] i2c i2c-18: of_i2c: modalias failure on /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@19
    [    4.708082] i2c i2c-18: Failed to create I2C device for /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@19
    [    4.717021] i2c i2c-18: of_i2c: modalias failure on /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@30
    [    4.725613] i2c i2c-18: Failed to create I2C device for /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@30
    [    4.734555] i2c i2c-18: of_i2c: modalias failure on /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@35
    [    4.743150] i2c i2c-18: Failed to create I2C device for /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@35
    [    4.752091] i2c i2c-18: of_i2c: modalias failure on /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@36
    [    4.760684] i2c i2c-18: Failed to create I2C device for /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@36
    [    4.769628] i2c i2c-18: of_i2c: modalias failure on /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@51
    [    4.778219] i2c i2c-18: Failed to create I2C device for /amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@51
    [    4.787166] i2c i2c-1: Added multiplexed i2c bus 18
    [    4.792143] i2c i2c-1: Added multiplexed i2c bus 19
    [    4.797054] i2c i2c-1: Added multiplexed i2c bus 20
    [    4.801964] i2c i2c-1: Added multiplexed i2c bus 21
    [    4.806883] i2c i2c-1: Added multiplexed i2c bus 22
    [    4.811677] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
    [    4.819251] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 26
    [    4.868233] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
    [    4.882994] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    4.889804] rtc_zynqmp ffa60000.rtc: setting system clock to 2021-06-28 12:18:48 UTC (1624882728)
    [    4.903112] pps pps0: new PPS source ptp0
    [    4.907042] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
    [    4.913678] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    4.955136] mmc0: new high speed SDHC card at address 1234
    [    4.960721] mmcblk0: mmc0:1234 SA16G 14.4 GiB
    [    4.966721]  mmcblk0: p1 p2
    [    5.328236] [drm] Cannot find any crtc or sizes
    [    5.924553] macb ff0e0000.ethernet eth0: link up (1000/Full)
    [    5.936239] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [    5.956230] IP-Config: Guessing netmask 255.255.255.0
    [    5.961194] IP-Config: Complete:
    [    5.964409]      device=eth0, hwaddr=00:0a:35:00:01:22, ipaddr=192.168.1.10, mask=255.255.255.0, gw=255.255.255.255
    [    5.974822]      host=192.168.1.10, domain=, nis-domain=(none)
    [    5.980640]      bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
    [    5.988265] clk: Not disabling unused clocks
    [    5.992697] ALSA device list:
    [    5.995573]   #0: DisplayPort monitor
    [    7.352507] EXT4-fs (mmcblk0p2): recovery complete
    [    7.473750] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    7.481784] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    7.495879] devtmpfs: mounted
    [    7.498873] Freeing unused kernel memory: 512K
    Welcome to Ubuntu 15.04!
    Cannot add dependency job for unit org.freedesktop.resolve1.busname, ignoring: Unit org.freedesktop.resolve1.busname failed to load: No such file or directory.
    Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
    [  OK  ] Reached target Swap.
    [  OK  ] Created slice Root Slice.
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket.
    [  OK  ] Listening on Delayed Shutdown Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Control Socket.
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Created slice System Slice.
             Starting Load Kernel Modules...
    [  OK  ] Started Read required files in advance.
             Starting Read required files in advance...
             Mounting Huge Pages File System...
    [  OK  ] Started Boot Process Profiler.
             Starting Boot Process Profiler...
             Starting Increase datagram queue length...
    [  OK  ] Reached target Slices.
    [  OK  ] Listening on Journal Audit Socket.
    [  OK  ] Reached target Remote File Systems (Pre).
             Starting Remount Root and Kernel File Systems...
             Starting Nameserver information manager...
             Mounting Debug File System...
             Mounting Temporary Directory...
    [  OK  ] Reached target Encrypted Volumes.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [  OK  ] Listening on networkd rtnetlink socket.
    [  OK  ] Reached target Paths.
             Mounting POSIX Message Queue File System...
             Starting udev Coldplug all Devices...
    [  OK  ] Created slice system-getty.slice.
             Starting Create Static Device Nodes in /dev...
    systemd-bootchart.service failed.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Starting Load/Save Random Seed...
    [  OK  ] Started Load Kernel Modules.
             Mounting Configuration File System...
             Starting Apply Kernel Variables...
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Mounted Debug File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted Configuration File System.
    [  OK  ] Mounted Temporary Directory.
    [  OK  ] Started Increase datagram queue length.
    [  OK  ] Started Nameserver information manager.
    [  OK  ] Started Create Static Device Nodes in /dev.
    ureadahead.service failed.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Reached target Local File Systems (Pre).
             Starting udev Kernel Device Manager...
    [  OK  ] Listening on Syslog Socket.
             Starting Journal Service...
    [  OK  ] Reached target Local File Systems.
    [  OK  ] Reached target Remote File Systems.
             Starting LSB: Raise network interfaces....
             Starting Wait for all "auto" /etc/n... up for network-online.target...
    [  OK  ] Started Wait for all "auto" /etc/ne...be up for network-online.target.
    [  OK  ] Started Journal Service.
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Started udev Kernel Device Manager.
             Starting Copy rules generated while the root was ro...
    [  OK  ] Started Copy rules generated while the root was ro.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Found device /dev/ttyPS0.
             Starting Create Volatile Files and Directories...
    [  OK  ] Reached target Sound Card.
    [  OK  ] Started Create Volatile Files and Directories.
    [  OK  ] Created slice system-ifup.slice.
    [  OK  ] Started ifup for sit0.
             Starting ifup for sit0...
    [  OK  ] Started ifup for can0.
             Starting ifup for can0...
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started ifup for eth0.
             Starting ifup for eth0...
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started LSB: Raise network interfaces..
    [  OK  ] Reached target System Initialization.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on OpenBSD Secure Shell server socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting D-Bus System Message Bus...
             Starting Initialize hardware monitoring sensors...
             Starting WPA supplicant...
    [  OK  ] Started Regular background program processing daemon.
             Starting Regular background program processing daemon...
             Starting Permit User Sessions...
             Starting LSB: Set the CPU Frequency Scaling governor to "ondemand"...
             Starting System Logging Service...
             Starting Network Manager...
    [  OK  ] Reached target Containers.
             Starting LSB: Load kernel modules needed to enable cpufreq scaling...
             Starting LSB: Xen daemons...
             Starting LSB: Platform initscript...
             Starting Provide limited super user privileges to specific users...
             Starting Login Service...
    [  OK  ] Reached target Timers.
    [  OK  ] Started D-Bus System Message Bus.
    Running Platform Init
    [  OK  ] Started WPA supplicant.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started LSB: Set the CPU Frequency Scaling governor to "ondemand".
    [  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
    [  OK  ] Started LSB: Xen daemons.
    [  OK  ] Started Provide limited super user privileges to specific users.
    [  OK  ] Started Initialize hardware monitoring sensors.
    [  OK  ] Started System Logging Service.
    [  OK  ] Started Login Service.
             Starting LSB: Start/stop secondary xen domains...
             Starting LSB: set CPUFreq kernel parameters...
             Starting Network Service...
    [  OK  ] Started LSB: set CPUFreq kernel parameters.
    [  OK  ] Started LSB: Start/stop secondary xen domains.
    [  OK  ] Started Network Service.
             Starting Authenticate and Authorize Users to Run Privileged Tasks...
             Starting Network Name Resolution...
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started Authenticate and Authorize Users to Run Privileged Tasks.
    [  OK  ] Started Network Manager.
             Starting Network Manager Wait Online...
    [  OK  ] Reached target Network.
             Starting /etc/rc.local Compatibility...
    [  OK  ] Started Network Manager Wait Online.
    [  OK  ] Stopped OpenBSD Secure Shell server.
    [  OK  ] Started OpenBSD Secure Shell server.
             Starting OpenBSD Secure Shell server...
    [  OK  ] Reached target Network is Online.
             Starting LSB: start Samba daemons for the AD DC...
             Starting LSB: start Samba NetBIOS nameserver (nmbd)...
    [  OK  ] Stopped LSB: start Samba SMB/CIFS daemon (smbd).
             Starting LSB: start Samba SMB/CIFS daemon (smbd)...
    [  OK  ] Closed OpenBSD Secure Shell server socket.
    [  OK  ] Started LSB: start Samba daemons for the AD DC.
    [  OK  ] Started LSB: start Samba NetBIOS nameserver (nmbd).
    [  OK  ] Started LSB: start Samba SMB/CIFS daemon (smbd).
    [  OK  ] Started /etc/rc.local Compatibility.
    [  OK  ] Started Serial Getty on ttyPS0.
             Starting Serial Getty on ttyPS0...
    [  OK  ] Started Getty on tty1.
             Starting Getty on tty1...
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Started LSB: Platform initscript.
    [  OK  ] Reached target Multi-User System.
    [  OK  ] Reached target Graphical Interface.
             Starting Update UTMP about System Runlevel Chan
    Ubuntu 15.04 linaro-developer ttyPS0
    linaro-developer login: root (automatic login)
    Last login: Mon Jun 28 12:13:46 UTC 2021 on ttyPS0
    root@linaro-developer:~#
    and the TES GUI log.
    log-file-2021-6-28-7582.txt
    Session log file
    Created on Monday, June 28, 2021 at 07:58:02.1618191, Greenwich Mean Time.
    Processing command-line arguments:
    Booting up Argo 0.16.0.5284 from C:\Program Files\Analog Devices\ADRV9001 Transceiver Evaluation Software.
    Temp files will be stored in C:\Users\YEC2259\AppData\Local\Temp\Argo.
    Attempting to initialize Windows Forms elements.
    Located user settings file at C:\Users\YEC2259\AppData\Local\Temp\Argo\Navassa.Periplous.json.
    Located default config file for plugin at C:\Program Files\Analog Devices\ADRV9001 Transceiver Evaluation Software\Navassa.Periplous.taxidi.
    Creating load-save object with file C:\Program Files\Analog Devices\ADRV9001 Transceiver Evaluation Software\Navassa.Periplous.taxidi.
    Loading plugin Navassa v0.16.0.
    Connection attempt initiated.
    Last resource version sync was v0.16.0
    Performing platform resource sync.
    Preparing to kill any existing server(s).
    Preparing to kill server.
    Host: root@192.168.1.10, Server: Adrv9001Server* located in /home/analog/adrv9001_server/resources/Adi.Adrv9001.Server/
    Preparing to start server.
    Host: root@192.168.1.10, Server: Adrv9001Server_C0 located in /home/analog/adrv9001_server/resources/Adi.Adrv9001.Server/
    Starting server.
    Server is running.
    Loaded resources:
    Transceiver Name ADRV9002
    Silicon Revision C0
    Evaluation Board Revision 2B
    Tx / Rx optimal carrier frequencies 30 MHz to 3 GHz
    External LO optimal frequencies 60 MHz to 6 GHz
    FPGA v8.2.17
    Device Driver API v48.8.7
    Device Driver Client v48.8.7
    Firmware v0.16.3.8
    Profile Generator v0.42.1.0
    Stream Generator Assembly v0.7.3.0
    Transceiver Evaluation Software v0.16.0
    ADRV9001 Plugin v0.16.0
    Attempting to generate profile from blueprint:
      "expandedSearchEnable": false,
      "isDesigned": false,
      "isViable": true,
      "processorClockDivisor": 1,
      "pllCalibration": 0,
      "duplex": 0,
      "diversity": true,
      "deviceClockInput_kHz": 38400,
      "clockPllPower": 2,
      "clockPllMode": 0,
      "allowPllRetuning": false,
      "adcRate": 3,
      "txChannel2": {
        "operationalBandwidth": 1,
        "ssiType": 2,
        "ssiStrobeType": 0,
        "ssiRefClockPin": 0,
        "ssiNumLane": 1,
        "ssiDataRate": 1,
        "ssiDataFormat": 4,
        "samplingRate_Hz": 61440000,
        "rfChannelBandwidth_Hz": 38000000,
        "peakLoopbackPower_dBm": -18,
        "orxEnabled": false,
        "lowPassFilterPower": 2,
        "loSource": 0,
        "frequencyOffsetCorrectionEnable": false,
        "frequencyDeviation_Hz": 648,
        "enabled": false,
        "elbType": 0,
        "channelSignalType": 0,
        "channelFilterType": 0,
        "channelFilterInterpolation": 1,
        "channelFilter": [
          0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
      "txChannel1": {
        "ssiType": 2,
        "ssiStrobeType": 0,
        "ssiNumLane": 1,
        "ssiDataRate": 1,
        "ssiDataFormat": 4,
        "loSource": 0,
        "enabled": false,
        "elbType": 0,
        "channelFilter": [
      "rxChannel2": {
        "ssiType": 2,
        "ssiStrobeType": 0,
        "ssiNumLane": 1,
        "ssiDataRate": 1,
        "ssiDataFormat": 4,
        "rfInput": 0,
        "loSource": 0,
        "intermediateFrequency_Hz": 0,
        "intermediateFrequencyEnable": false,
        "frequencyDeviation_Hz": 0,
        "enabled": false,
        "channelSignalSetup": 0,
        "channelFilterType": 2,
        "channelFilter": [
          475, 312, -782, -39, 1201, -777, -1182, 1981, 177, -2874, 1941, 2393, -4416, 225, 5594, -4581, -3668, 8650, -1992, -9342, 9646, 4213, -15137, 6404, 13615, -18199, -2610, 23969, -15142, -17198, 31204, -3269, -34604, 30213, 17955, -49337, 16361, 45636, -53954, -12567, 72920, -40769, -54562, 89506, -4148, -102269, 83183, 57280, -142874, 41767, 139213, -158628, -45955, 231679, -125964, -193870, 320642, -4532, -442087, 390927, 347244, -1055854, 429729, 4391599, 4391599, 429729, -1055854, 347244, 390927, -442087, -4532, 320642, -193870, -125964, 231679, -45955, -158628, 139213, 41767, -142874, 57280, 83183, -102269, -4148, 89506, -54562, -40769, 72920, -12567, -53954, 45636, 16361, -49337, 17955, 30213, -34604, -3269, 31204, -17198, -15142, 23969, -2610, -18199, 13615, 6404, -15137, 4213, 9646, -9342, -1992, 8650, -3668, -4581, 5594, 225, -4416, 2393, 1941, -2874, 177, 1981, -1182, -777, 1201, -39, -782, 312, 0
        "analogFilterOrder": 1,
        "analogFilterCorner_kHz": 40000,
        "adcType": 1
      "rxChannel1": {
        "ssiType": 2,
        "ssiStrobeType": 0,
        "ssiNumLane": 1,
        "ssiDataRate": 1,
        "ssiDataFormat": 4,
        "rfInput": 0,
        "loSource": 0,
        "enabled": true,
        "channelFilter": [
        "adcType": 1
      "loExternal2": {
        "loSignalingType": 0,
        "loDivisor": 2
      "loExternal1": {
        "loDivisor": 2
    Generated profile:
      "clocks": {
        "deviceClock_kHz": 38400,
        "clkPllVcoFreq_daHz": 884736000,
        "clkPllHsDiv": 0,
        "clkPllMode": 0,
        "clk1105Div": 2,
        "armClkDiv": 6,
        "armPowerSavingClkDiv": 1,
        "refClockOutEnable": true,
        "auxPllPower": 2,
        "clkPllPower": 2,
        "padRefClkDrv": 0,
        "extLo1OutFreq_kHz": 0,
        "extLo2OutFreq_kHz": 0,
        "rfPll1LoMode": 0,
        "rfPll2LoMode": 0,
        "ext1LoType": 0,
        "ext2LoType": 0,
        "rx1RfInputSel": 0,
        "rx2RfInputSel": 0,
        "extLo1Divider": 2,
        "extLo2Divider": 2,
        "rfPllPhaseSyncMode": 0,
        "rx1LoSelect": 1,
        "rx2LoSelect": 2,
        "tx1LoSelect": 1,
        "tx2LoSelect": 2,
        "rx1LoDivMode": 1,
        "rx2LoDivMode": 1,
        "tx1LoDivMode": 1,
        "tx2LoDivMode": 1,
        "loGen1Select": 1,
        "loGen2Select": 1
      "rx": {
        "rxInitChannelMask": 1,
        "rxChannelCfg": [
            "profile": {
              "primarySigBandwidth_Hz": 38000000,
              "rxOutputRate_Hz": 61440000,
              "rxInterfaceSampleRate_Hz": 61440000,
              "rxOffsetLo_kHz": 0,
              "rxSignalOnLo": 0,
              "outputSignaling": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 20000000,
              "lpAdcCorner": 0,
              "adcClk_kHz": 2211840,
              "rxCorner3dB_kHz": 40000,
              "rxCorner3dBLp_kHz": 40000,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 1,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "scicBlk23DivFactor": 1,
                  "scicBlk23LowRippleEn": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 1,
                  "decBy2Hb3Blk17p1En": 0,
                  "decBy2Hb4Blk17p2En": 0,
                  "decBy2Hb5Blk19p1En": 0,
                  "decBy2Hb6Blk19p2En": 0
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 4,
                  "hbMux": 4,
                  "isGainCompEnabled": 0,
                  "gainComp9GainI": [
                    16384, 16384, 16384, 16384, 16384, 16384
                  "gainComp9GainQ": [
                    0, 0, 0, 0, 0, 0
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                    "dpInFifoTestDataSel": 0
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                    "rxWbNbCompPFirInMuxSel": 0,
                    "rxWbNbCompPFirEn": 1
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "rxSsiConfig": {
                "ssiType": 2,
                "ssiDataFormatSel": 4,
                "numLaneSel": 1,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "lvdsIBitInversion": false,
                "lvdsQBitInversion": false,
                "lvdsStrobeBitInversion": false,
                "lvdsUseLsbIn12bitMode": 0,
                "lvdsTxFullRefClkEn": false,
                "lvdsRxClkInversionEn": false,
                "cmosTxDdrNegStrobeEn": false,
                "cmosDdrPosClkEn": false,
                "cmosDdrClkInversionEn": false,
                "cmosDdrEn": false,
                "rxMaskStrobeEn": false
            "profile": {
              "primarySigBandwidth_Hz": 12500,
              "rxOutputRate_Hz": 0,
              "rxInterfaceSampleRate_Hz": 0,
              "rxSignalOnLo": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "rxCorner3dB_kHz": 0,
              "rxCorner3dBLp_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "scicBlk23DivFactor": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                  "gainComp9GainI": [
                  "gainComp9GainQ": [
                    0, 0, 0, 0, 0, 0
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "ssiDataFormatSel": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "cmosDdrEn": false,
            "profile": {
              "rxSignalOnLo": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                  "gainComp9GainI": [
                  "gainComp9GainQ": [
                    0, 0, 0, 0, 0, 0
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "cmosDdrEn": false,
            "profile": {
              "rxSignalOnLo": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                  "gainComp9GainI": [
                  "gainComp9GainQ": [
                    0, 0, 0, 0, 0, 0
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "cmosDdrEn": false,
            "profile": {
              "rxSignalOnLo": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                  "gainComp9GainI": [
                  "gainComp9GainQ": [
                    0, 0, 0, 0, 0, 0
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "cmosDdrEn": false,
            "profile": {
              "rxSignalOnLo": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                  "gainComp9GainI": [
                  "gainComp9GainQ": [
                    0, 0, 0, 0, 0, 0
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "cmosDdrEn": false,
            "profile": {
              "rxSignalOnLo": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                  "gainComp9GainI": [
                  "gainComp9GainQ": [
                    0, 0, 0, 0, 0, 0
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "cmosDdrEn": false,
            "profile": {
              "rxSignalOnLo": 0,
              "filterOrder": 1,
              "filterOrderLp": 1,
              "hpAdcCorner": 0,
              "lpAdcCorner": 0,
              "adcClk_kHz": 0,
              "tiaPower": 2,
              "tiaPowerLp": 2,
              "channelType": 0,
              "adcType": 1,
              "lpAdcCalMode": 0,
              "rxDpProfile": {
                "rxNbDecTop": {
                  "scicBlk23En": 0,
                  "decBy2Blk35En": 0,
                  "decBy2Blk37En": 0,
                  "decBy2Blk39En": 0,
                  "decBy2Blk41En": 0,
                  "decBy2Blk43En": 0,
                  "decBy3Blk45En": 0,
                  "decBy2Blk47En": 0
                "rxWbDecTop": {
                  "decBy2Blk25En": 0,
                  "decBy2Blk27En": 0,
                  "decBy2Blk29En": 0,
                  "decBy2Blk31En": 0,
                  "decBy2Blk33En": 0,
                  "wbLpfBlk33p1En": 0
                "rxDecTop": {
                  "decBy3Blk15En": 0,
                "rxSincHBTop": {
                  "sincGainMux": 1,
                  "sincMux": 0,
                  "hbMux": 4,
                  "gainComp9GainI": [
                  "gainComp9GainQ": [
                    0, 0, 0, 0, 0, 0
                "rxNbDem": {
                  "dpInFifo": {
                    "dpInFifoEn": 0,
                    "dpInFifoMode": 0,
                  "rxNbNco": {
                    "rxNbNcoEn": 0,
                    "rxNbNcoConfig": {
                      "freq": 0,
                      "sampleFreq": 0,
                      "phase": 0,
                      "realOut": 0
                  "rxWbNbCompPFir": {
                    "bankSel": 0,
                  "resamp": {
                    "rxResampEn": 0,
                    "resampPhaseI": 0,
                    "resampPhaseQ": 0
                  "gsOutMuxSel": 1,
                  "rxOutSel": 0,
                  "rxRoundMode": 0,
                  "dpArmSel": 0
              "rxSsiConfig": {
                "ssiType": 0,
                "numLaneSel": 0,
                "strobeType": 0,
                "lsbFirst": 0,
                "qFirst": 0,
                "txRefClockPin": 0,
                "cmosDdrEn": false,
      "tx": {
        "txInitChannelMask": 0,
        "txProfile": [
            "txInputRate_Hz": 0,
            "txInterfaceSampleRate_Hz": 0,
            "txOffsetLo_kHz": 0,
            "validDataDelay": 0,
            "txBbf3dBCorner_kHz": 33000,
            "txPdBiasCurrent": 0,
            "txPdGainEnable": 0,
            "txPrePdRealPole_kHz": 0,
            "txPostPdRealPole_kHz": 0,
            "txBbfPower": 2,
            "txExtLoopBackType": 0,
            "txExtLoopBackForInitCal": 0,
            "txPeakLoopBackPower": 0,
            "txDpProfile": {
              "txPreProc": {
                "txPreProcSymbol0": 0,
                "txPreProcSymbol1": 0,
                "txPreProcSymbol2": 0,
                "txPreProcSymbol3": 0,
                "txPreProcSymMapDivFactor": 1,
                "txPreProcMode": 1,
                "txPreProcWbNbPfirIBankSel": 0,
                "txPreProcWbNbPfirQBankSel": 1
              "txWbIntTop": {
                "txInterpBy2Blk30En": 0,
                "txInterpBy2Blk28En": 0,
                "txInterpBy2Blk26En": 0,
                "txInterpBy2Blk24En": 0,
                "txInterpBy2Blk22En": 0,
                "txWbLpfBlk22p1En": 0
              "txNbIntTop": {
                "txInterpBy2Blk20En": 0,
                "txInterpBy2Blk18En": 0,
                "txInterpBy2Blk16En": 0,
                "txInterpBy2Blk14En": 0,
                "txInterpBy2Blk12En": 0,
                "txInterpBy3Blk10En": 0,
                "txInterpBy2Blk8En": 0,
                "txScicBlk32En": 0,
                "txScicBlk32DivFactor": 0
              "txIntTop": {
                "interpBy3Blk44p1En": 0,
                "sinc3Blk44En": 0,
                "sinc2Blk42En": 0,
                "interpBy3Blk40En": 0,
                "interpBy2Blk38En": 0,
                "interpBy2Blk36En": 0
              "txIntTopFreqDevMap": {
                "rrc2Frac": 0,
                "mpll": 0,
                "nchLsw": 0,
                "nchMsb": 0,
                "freqDevMapEn": 0,
                "txRoundEn": 1
              "txIqdmDuc": {
                "iqdmDucMode": 0,
                "iqdmDev": 0,
                "iqdmDevOffset": 0,
                "iqdmScalar": 0,
                "iqdmThreshold": 0,
                "iqdmNco": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
            "txSsiConfig": {
              "ssiType": 0,
              "numLaneSel": 0,
              "strobeType": 0,
              "lsbFirst": 0,
              "qFirst": 0,
              "txRefClockPin": 0,
              "cmosDdrEn": false,
            "txBbfPower": 2,
            "txDpProfile": {
              "txPreProc": {
                "txPreProcMode": 1,
                "txPreProcWbNbPfirIBankSel": 2,
                "txPreProcWbNbPfirQBankSel": 3
              "txWbIntTop": {
              "txNbIntTop": {
                "txScicBlk32En": 0,
              "txIntTop": {
                "sinc3Blk44En": 0,
                "sinc2Blk42En": 0,
                "rrc2Frac": 0,
                "mpll": 0,
                "nchLsw": 0,
                "nchMsb": 0,
                "freqDevMapEn": 0,
                "txRoundEn": 1
              "txIqdmDuc": {
                "iqdmDucMode": 0,
                "iqdmDev": 0,
                "iqdmDevOffset": 0,
                "iqdmScalar": 0,
                "iqdmThreshold": 0,
                "iqdmNco": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
            "txSsiConfig": {
              "ssiType": 0,
              "numLaneSel": 0,
              "strobeType": 0,
              "lsbFirst": 0,
              "qFirst": 0,
              "txRefClockPin": 0,
              "cmosDdrEn": false,
      "sysConfig": {
        "duplexMode": 0,
        "fhModeOn": 0,
        "numDynamicProfile": 1,
        "mcsMode": 0,
        "mcsInterfaceType": 0,
        "adcTypeMonitor": 1,
        "pllLockTime_us": 750,
        "pllPhaseSyncWait_us": 0,
        "pllModulus": {
          "modulus": [
            8388593, 8388593, 8388593, 8388593, 8388593
          "dmModulus": [
            8388593, 8388593
      "pfirBuffer": {
        "pfirRxWbNbChFilterCoeff_A": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
          "coefficients": [
        "pfirRxWbNbChFilterCoeff_B": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
          "coefficients": [
            0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
        "pfirRxWbNbChFilterCoeff_C": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
          "coefficients": [
        "pfirRxWbNbChFilterCoeff_D": {
          "numCoeff": 128,
          "symmetricSel": 0,
          "tapsSel": 3,
          "gainSel": 2,
          "coefficients": [
        "pfirTxWbNbPulShpCoeff_A": {
          "numCoeff": 0,
          "symmetricSel": 0,
          "tapsSel": 0,
          "gainSel": 0,
          "coefficients": [
        "pfirTxWbNbPulShpCoeff_B": {
          "numCoeff": 0,
          "symmetricSel": 0,
          "tapsSel": 0,
          "gainSel": 0,
          "coefficients": [
        "pfirTxWbNbPulShpCoeff_C": {
          "numCoeff": 0,
          "symmetricSel": 0,
          "tapsSel": 0,
          "gainSel": 0,
          "coefficients": [
        "pfirTxWbNbPulShpCoeff_D": {
          "numCoeff": 0,
          "symmetricSel": 0,
          "tapsSel": 0,
          "gainSel": 0,
          "coefficients": [
        "pfirRxNbPulShp": [
            "numCoeff": 128,
            "symmetricSel": 0,
            "taps": 128,
            "gainSel": 2,
            "coefficients": [
            "numCoeff": 0,
            "symmetricSel": 0,
            "taps": 0,
            "gainSel": 0,
            "coefficients": [
        "pfirRxMagLowTiaLowSRHp": [
            "numCoeff": 21,
            "coefficients": [
              -12, 83, -293, 734, -1489, 2594, -3965, 5403, -6516, 5868, 27957, 5868, -6516, 5403, -3965, 2594, -1489, 734, -293, 83, -12
            "numCoeff": 0,
            "coefficients": [
        "pfirRxMagLowTiaHighSRHp": [
            "numCoeff": 21,
            "coefficients": [
              -62, 194, 80, -829, 201, 1857, -179, -4602, -1259, 11431, 19102, 11431, -1259, -4602, -179, 1857, 201, -829, 80, 194, -62
            "numCoeff": 0,
            "coefficients": [
        "pfirRxMagHighTiaHighSRHp": [
            "numCoeff": 21,
            "coefficients": [
              39, -229, 714, -1485, 2134, -1844, -219, 4147, -8514, 8496, 26292, 8496, -8514, 4147, -219, -1844, 2134, -1485, 714, -229, 39
            "numCoeff": 0,
            "coefficients": [
        "pfirRxMagLowTiaLowSRLp": [
            "numCoeff": 21,
            "coefficients": [
              -12, 83, -293, 733, -1488, 2593, -3963, 5401, -6514, 5870, 27953, 5870, -6514, 5401, -3963, 2593, -1488, 733, -293, 83, -12
            "numCoeff": 0,
            "coefficients": [
        "pfirRxMagLowTiaHighSRLp": [
            "numCoeff": 21,
            "coefficients": [
              -62, 194, 80, -828, 201, 1855, -180, -4597, -1254, 11428, 19093, 11428, -1254, -4597, -180, 1855, 201, -828, 80, 194, -62
            "numCoeff": 0,
            "coefficients": [
        "pfirRxMagHighTiaHighSRLp": [
            "numCoeff": 21,
            "coefficients": [
              39, -229, 712, -1481, 2128, -1841, -215, 4131, -8490, 8497, 26266, 8497, -8490, 4131, -215, -1841, 2128, -1481, 712, -229, 39
            "numCoeff": 0,
            "coefficients": [
        "pfirTxMagComp1": {
          "numCoeff": 0,
          "coefficients": [
        "pfirTxMagComp2": {
          "numCoeff": 0,
          "coefficients": [
        "pfirTxMagCompNb": [
            "numCoeff": 0,
            "coefficients": [
            "numCoeff": 0,
            "coefficients": [
        "pfirRxMagCompNb": [
            "numCoeff": 13,
            "coefficients": [
            "numCoeff": 0,
            "coefficients": [
    Device driver error
    Remote procedure call returned non-zero error code.
    Error source 0, Error number 3, Recovery action -6. in function adi_fpga9001_DataChain_PerformTransfer, on line 377, Error message: axi_dma_finish: dma transfer has timed out, low time out value or inactive interface.
    Error source 0, Error number 3, Recovery action -6. In file C:/Jenkins/workspace/device-driver_api-dll_master/c_src/devices/fpga9001/public/src/adi_fpga9001_datachain.c, in function adi_fpga9001_DataChain_PerformTransfer, on line 377, variable name NULL. Error message: axi_dma_finish: dma transfer has timed out, low time out value or inactive interface.
    You can go through these files to find if any helpful information is available to debug the issue.
  • +1
    on Jun 29, 2021 2:53 PM in reply to krsaravanan
    Hello Saravanan,
    I brought your issue to FPGA and SD card image experts in our team, their thoughts on the matter are:
    1. It is not clear how the GUI is being configured. Try:
      • Open GUI
      • Connect
      • Program
      • Receive->Play
      If that still gives a timeout then there is some issue with the hardware that will need to be debugged further. If that passes then you got the error with some custom TES configurations steps on your side
    2. Error indicates a wait on dma to complete has timed out and the call gave up. The timeout is likely based on 24ksps * dma-length, so most likely the interface is dead. The next stage of debug for you is likely to try a different EVB and different FPGA with your current EVB and FPGA (So try:   current EVB with new FPGA   AND  new EVB with current FPGA). This should help narrow down where the issue is coming from.
    Best Regards,
    Oisín.
    on Aug 4, 2021 2:19 PM in reply to OWatkins
    Closing this issue due to inactivity.
