EVAL-ADRV9002 ZCU702 External LO
Hello.
I have an EVAL-ADRV9002 + ZCU702 running on TES 0.14.0.
Set EXTLO1 900MHz on the surface of the following TES image.
I input 900MHz to the connector of EXT_LO1 from ADF4372.
Then the following message is output and the program ends in failure
remote procedure call returned non-zero error code.
error source 0, error number 8960, recovery action -2, in function adi_adrv9001_cals_initcals_run, on line 105, error message:
error occured during an init calibration. check that no signal is being applied to the rx ports.
check that correct external los are applied , and synchronized, where appropriate.
the calibration routines returned error code 7.
Troubleshooting
(1):
If a signal generator is connected to an Rx input, make sure it is turned off.
(2):
Click File --> Force Update Platform and then try again. If This does not resolve the issue, please document your steps to get to this point and contact our support staff for further assistance.
I tried troubleshooting but none of them improved the situation
(1) It was confirmed that the SG signal was not connected to the RX input.
(2) The same result was obtained even after executing Force Update Platform.
Below is the profile of TES.
  "clocks": {
    "deviceClock_kHz": 38400,
    "clkPllVcoFreq_daHz": 884736000,
    "clkPllHsDiv": 0,
    "clkPllMode": 0,
    "clk1105Div": 2,
    "armClkDiv": 6,
    "armPowerSavingClkDiv": 1,
    "refClockOutEnable": true,
    "auxPllPower": 2,
    "clkPllPower": 2,
    "padRefClkDrv": 0,
    "extLo1OutFreq_kHz": 0,
    "extLo2OutFreq_kHz": 0,
    "rfPll1LoMode": 2,
    "rfPll2LoMode": 0,
    "ext1LoType": 0,
    "ext2LoType": 0,
    "rx1RfInputSel": 0,
    "rx2RfInputSel": 0,
    "extLo1Divider": 1,
    "extLo2Divider": 2,
    "rfPllPhaseSyncMode": 0,
    "rx1LoSelect": 2,
    "rx2LoSelect": 2,
    "tx1LoSelect": 1,
    "tx2LoSelect": 1,
    "rx1LoDivMode": 1,
    "rx2LoDivMode": 1,
    "tx1LoDivMode": 1,
    "tx2LoDivMode": 1,
    "loGen1Select": 1,
    "loGen2Select": 1
  "rx": {
    "rxInitChannelMask": 243,
    "rxChannelCfg": [ {
        "profile": {
          "primarySigBandwidth_Hz": 12000,
          "rxOutputRate_Hz": 48000,
          "rxInterfaceSampleRate_Hz": 48000,
          "rxOffsetLo_kHz": 490,
          "rxSignalOnLo": 1,
          "outputSignaling": 0,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 20000000,
          "lpAdcCorner": 0,
          "adcClk_kHz": 2211840,
          "rxCorner3dB_kHz": 40000,
          "rxCorner3dBLp_kHz": 40000,
          "tiaPower": 0,
          "tiaPowerLp": 0,
          "channelType": 1,
          "adcType": 0,
          "lpAdcCalMode": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 1,
              "scicBlk23DivFactor": 10,
              "scicBlk23LowRippleEn": 0,
              "decBy2Blk35En": 1,
              "decBy2Blk37En": 1,
              "decBy2Blk39En": 1,
              "decBy2Blk41En": 1,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 1,
              "decBy2Blk47En": 1
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
              "decBy2Hb3Blk17p1En": 0,
              "decBy2Hb4Blk17p2En": 1,
              "decBy2Hb5Blk19p1En": 0,
              "decBy2Hb6Blk19p2En": 1
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 4,
              "hbMux": 4,
              "isGainCompEnabled": 0,
              "gainComp9GainI": [ 16384, 16384, 16384, 16384, 16384, 16384 ],
              "gainComp9GainQ": [ 0, 0, 0, 0, 0, 0 ]
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
                "dpInFifoTestDataSel": 0
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
                "rxWbNbCompPFirInMuxSel": 0,
                "rxWbNbCompPFirEn": 1
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "rxSsiConfig": {
            "ssiType": 1,
            "ssiDataFormatSel": 4,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "lvdsBitInversion": 0,
            "lvdsUseLsbIn12bitMode": 0,
            "lvdsTxFullRefClkEn": false,
            "lvdsRxClkInversionEn": false,
            "cmosTxDdrNegStrobeEn": false,
            "cmosDdrPosClkEn": false,
            "cmosDdrClkInversionEn": false,
            "cmosDdrEn": false,
            "rxMaskStrobeEn": false
        "profile": {
          "rxSignalOnLo": 1,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "lpAdcCorner": 0,
          "tiaPower": 0,
          "tiaPowerLp": 0,
          "channelType": 2,
          "adcType": 0,
          "lpAdcCalMode": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 1,
              "decBy2Blk35En": 1,
              "decBy2Blk37En": 1,
              "decBy2Blk39En": 1,
              "decBy2Blk41En": 1,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 1,
              "decBy2Blk47En": 1
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 4,
              "hbMux": 4,
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 2,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "rxSsiConfig": {
            "ssiType": 1,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "cmosDdrEn": false,
        "profile": {
          "rxOffsetLo_kHz": 0,
          "rxSignalOnLo": 1,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "lpAdcCorner": 0,
          "rxCorner3dB_kHz": 100000,
          "rxCorner3dBLp_kHz": 100000,
          "tiaPower": 0,
          "tiaPowerLp": 0,
          "channelType": 16,
          "adcType": 0,
          "lpAdcCalMode": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 1,
              "decBy2Blk35En": 1,
              "decBy2Blk37En": 1,
              "decBy2Blk39En": 1,
              "decBy2Blk41En": 1,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 1,
              "decBy2Blk47En": 1
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
              "decBy2Hb3Blk17p1En": 1,
              "decBy2Hb4Blk17p2En": 0,
              "decBy2Hb5Blk19p1En": 1,
              "decBy2Hb6Blk19p2En": 0
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 4,
              "hbMux": 4,
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 1,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "rxSsiConfig": {
            "ssiType": 1,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "cmosDdrEn": false,
        "profile": {
          "rxSignalOnLo": 1,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "lpAdcCorner": 0,
          "tiaPower": 0,
          "tiaPowerLp": 0,
          "channelType": 32,
          "adcType": 0,
          "lpAdcCalMode": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 1,
              "decBy2Blk35En": 1,
              "decBy2Blk37En": 1,
              "decBy2Blk39En": 1,
              "decBy2Blk41En": 1,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 1,
              "decBy2Blk47En": 1
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 4,
              "hbMux": 4,
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 3,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "rxSsiConfig": {
            "ssiType": 1,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "cmosDdrEn": false,
        "profile": {
          "rxSignalOnLo": 1,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "lpAdcCorner": 0,
          "tiaPower": 0,
          "tiaPowerLp": 0,
          "channelType": 64,
          "adcType": 0,
          "lpAdcCalMode": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 1,
              "decBy2Blk35En": 1,
              "decBy2Blk37En": 1,
              "decBy2Blk39En": 1,
              "decBy2Blk41En": 1,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 1,
              "decBy2Blk47En": 1
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 4,
              "hbMux": 4,
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 1,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "rxSsiConfig": {
            "ssiType": 1,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "cmosDdrEn": false,
        "profile": {
          "rxSignalOnLo": 1,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "lpAdcCorner": 0,
          "tiaPower": 0,
          "tiaPowerLp": 0,
          "channelType": 128,
          "adcType": 0,
          "lpAdcCalMode": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 1,
              "decBy2Blk35En": 1,
              "decBy2Blk37En": 1,
              "decBy2Blk39En": 1,
              "decBy2Blk41En": 1,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 1,
              "decBy2Blk47En": 1
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 4,
              "hbMux": 4,
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 3,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "rxSsiConfig": {
            "ssiType": 1,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "cmosDdrEn": false,
        "profile": {
          "primarySigBandwidth_Hz": 12500,
          "rxOutputRate_Hz": 0,
          "rxInterfaceSampleRate_Hz": 0,
          "rxSignalOnLo": 0,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 0,
          "lpAdcCorner": 0,
          "adcClk_kHz": 0,
          "rxCorner3dB_kHz": 0,
          "rxCorner3dBLp_kHz": 0,
          "tiaPower": 2,
          "tiaPowerLp": 2,
          "channelType": 0,
          "adcType": 1,
          "lpAdcCalMode": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 0,
              "scicBlk23DivFactor": 0,
              "decBy2Blk35En": 0,
              "decBy2Blk37En": 0,
              "decBy2Blk39En": 0,
              "decBy2Blk41En": 0,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 0,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 0,
              "hbMux": 4,
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "rxSsiConfig": {
            "ssiType": 0,
            "ssiDataFormatSel": 0,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "cmosDdrEn": false,
        "profile": {
          "rxSignalOnLo": 0,
          "filterOrder": 1,
          "filterOrderLp": 1,
          "hpAdcCorner": 0,
          "lpAdcCorner": 0,
          "adcClk_kHz": 0,
          "tiaPower": 2,
          "tiaPowerLp": 2,
          "channelType": 0,
          "adcType": 1,
          "lpAdcCalMode": 0,
          "rxDpProfile": {
            "rxNbDecTop": {
              "scicBlk23En": 0,
              "decBy2Blk35En": 0,
              "decBy2Blk37En": 0,
              "decBy2Blk39En": 0,
              "decBy2Blk41En": 0,
              "decBy2Blk43En": 0,
              "decBy3Blk45En": 0,
              "decBy2Blk47En": 0
            "rxWbDecTop": {
              "decBy2Blk25En": 0,
              "decBy2Blk27En": 0,
              "decBy2Blk29En": 0,
              "decBy2Blk31En": 0,
              "decBy2Blk33En": 0,
              "wbLpfBlk33p1En": 0
            "rxDecTop": {
              "decBy3Blk15En": 0,
            "rxSincHBTop": {
              "sincGainMux": 1,
              "sincMux": 0,
              "hbMux": 4,
            "rxNbDem": {
              "dpInFifo": {
                "dpInFifoEn": 0,
                "dpInFifoMode": 0,
              "rxNbNco": {
                "rxNbNcoEn": 0,
                "rxNbNcoConfig": {
                  "freq": 0,
                  "sampleFreq": 0,
                  "phase": 0,
                  "realOut": 0
              "rxWbNbCompPFir": {
                "bankSel": 0,
              "resamp": {
                "rxResampEn": 0,
                "resampPhaseI": 0,
                "resampPhaseQ": 0
              "gsOutMuxSel": 1,
              "rxOutSel": 0,
              "rxRoundMode": 0,
              "dpArmSel": 0
          "rxSsiConfig": {
            "ssiType": 0,
            "numLaneSel": 0,
            "strobeType": 0,
            "lsbFirst": 0,
            "qFirst": 0,
            "txRefClockPin": 0,
            "cmosDdrEn": false,
  "tx": {
    "txInitChannelMask": 12,
    "txProfile": [ {
        "txInputRate_Hz": 48000,
        "txInterfaceSampleRate_Hz": 48000,
        "txOffsetLo_kHz": 0,
        "validDataDelay": 0,
        "txBbf3dBCorner_kHz": 33000,
        "txPdBiasCurrent": 1,
        "txPdGainEnable": 0,
        "txPrePdRealPole_kHz": 1000000,
        "txPostPdRealPole_kHz": 530000,
        "txBbfPower": 0,
        "txExtLoopBackType": 0,
        "txExtLoopBackForInitCal": 0,
        "txPeakLoopBackPower": 0,
        "frequencyDeviation_Hz": 0,
        "txDpProfile": {
          "txPreProc": {
            "txPreProcSymbol0": 0,
            "txPreProcSymbol1": 0,
            "txPreProcSymbol2": 0,
            "txPreProcSymbol3": 0,
            "txPreProcSymMapDivFactor": 1,
            "txPreProcMode": 1,
            "txPreProcWbNbPfirIBankSel": 0,
            "txPreProcWbNbPfirQBankSel": 1
          "txWbIntTop": {
            "txInterpBy2Blk30En": 0,
            "txInterpBy2Blk28En": 0,
            "txInterpBy2Blk26En": 0,
            "txInterpBy2Blk24En": 0,
            "txInterpBy2Blk22En": 0,
            "txWbLpfBlk22p1En": 0
          "txNbIntTop": {
            "txInterpBy2Blk20En": 1,
            "txInterpBy2Blk18En": 1,
            "txInterpBy2Blk16En": 1,
            "txInterpBy2Blk14En": 1,
            "txInterpBy2Blk12En": 0,
            "txInterpBy3Blk10En": 1,
            "txInterpBy2Blk8En": 1,
            "txScicBlk32En": 1,
            "txScicBlk32DivFactor": 10
          "txIntTop": {
            "interpBy3Blk44p1En": 0,
            "sinc3Blk44En": 0,
            "sinc2Blk42En": 0,
            "interpBy3Blk40En": 0,
            "interpBy2Blk38En": 1,
            "interpBy2Blk36En": 1
          "txIntTopFreqDevMap": {
            "rrc2Frac": 0,
            "mpll": 0,
            "nchLsw": 0,
            "nchMsb": 0,
            "freqDevMapEn": 0,
            "txRoundEn": 1
          "txIqdmDuc": {
            "iqdmDucMode": 0,
            "iqdmDev": 0,
            "iqdmDevOffset": 0,
            "iqdmScalar": 0,
            "iqdmThreshold": 0,
            "iqdmNco": {
              "freq": 0,
              "sampleFreq": 46080000,
              "phase": 0,
              "realOut": 0
        "txSsiConfig": {
          "ssiType": 1,
          "numLaneSel": 0,
          "strobeType": 0,
          "lsbFirst": 0,
          "qFirst": 0,
          "txRefClockPin": 1,
          "cmosDdrEn": false,
        "txBbfPower": 0,
        "txDpProfile": {
          "txPreProc": {
            "txPreProcMode": 1,
            "txPreProcWbNbPfirIBankSel": 2,
            "txPreProcWbNbPfirQBankSel": 3
          "txWbIntTop": {
          "txNbIntTop": {
            "txScicBlk32En": 1,
          "txIntTop": {
            "sinc3Blk44En": 0,
            "sinc2Blk42En": 0,
            "rrc2Frac": 0,
            "mpll": 0,
            "nchLsw": 0,
            "nchMsb": 0,
            "freqDevMapEn": 0,
            "txRoundEn": 1
          "txIqdmDuc": {
            "iqdmDucMode": 0,
            "iqdmDev": 0,
            "iqdmDevOffset": 0,
            "iqdmScalar": 0,
            "iqdmThreshold": 0,
            "iqdmNco": {
              "freq": 0,
              "phase": 0,
              "realOut": 0
        "txSsiConfig": {
          "ssiType": 1,
          "numLaneSel": 0,
          "strobeType": 0,
          "lsbFirst": 0,
          "qFirst": 0,
          "txRefClockPin": 1,
          "cmosDdrEn": false,
  "sysConfig": {
    "duplexMode": 1,
    "fhModeOn": 0,
    "numDynamicProfile": 1,
    "mcsMode": 0,
    "adcTypeMonitor": 0,
    "pllLockTime_us": 750,
    "pllModulus": {
      "modulus": [ 8388593, 8388593, 8388593, 8388593, 8388593 ],
      "dmModulus": [ 8388593, 8388593 ]
  "pfirBuffer": {
    "pfirRxWbNbChFilterCoeff_A": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [ 1, 4, 10, 14, 10, -8, -36, -56, -43, 18, 110, 176, 140, -36, -296, -477, -385, 65, 717, 1164, 945, -116, -1630, -2655, -2161, 224, 3612, 5917, 4823, -660, -8930, -15835, -16492, -8267, 6681, 21178, 26054, 15428, -8503, -34452, -46572, -33192, 4645, 50326, 77802, 65235, 9575, -66663, -122526, -118715, -41686, 81623, 189288, 211654, 109809, -93600, -309489, -411032, -287232, 101328, 691337, 1327974, 1817574, 2001178, 1817574, 1327974, 691337, 101328, -287232, -411032, -309489, -93600, 109809, 211654, 189288, 81623, -41686, -118715, -122526, -66663, 9575, 65235, 77802, 50326, 4645, -33192, -46572, -34452, -8503, 15428, 26054, 21178, 6681, -8267, -16492, -15835, -8930, -660, 4823, 5917, 3612, 224, -2161, -2655, -1630, -116, 945, 1164, 717, 65, -385, -477, -296, -36, 140, 176, 110, 18, -43, -56, -36, -8, 10, 14, 10, 4, 1, 0 ]
    "pfirRxWbNbChFilterCoeff_B": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ]
    "pfirRxWbNbChFilterCoeff_C": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
    "pfirRxWbNbChFilterCoeff_D": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
    "pfirTxWbNbPulShpCoeff_A": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
      "coefficients": [ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ]
    "pfirTxWbNbPulShpCoeff_B": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
    "pfirTxWbNbPulShpCoeff_C": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
    "pfirTxWbNbPulShpCoeff_D": {
      "numCoeff": 128,
      "symmetricSel": 0,
      "tapsSel": 3,
      "gainSel": 2,
    "pfirRxNbPulShp": [ {
        "numCoeff": 128,
        "symmetricSel": 0,
        "taps": 128,
        "gainSel": 2,
        "numCoeff": 128,
        "symmetricSel": 0,
        "taps": 128,
        "gainSel": 2,
    "pfirRxMagLowTiaLowSRHp": [ {
        "numCoeff": 21,
        "coefficients": [ 28, -55, 108, -198, 345, -592, 1020, -1742, 2810, -4594, 38525, -4594, 2810, -1742, 1020, -592, 345, -198, 108, -55, 28 ]
        "numCoeff": 21,
    "pfirRxMagLowTiaHighSRHp": [ {
        "numCoeff": 21,
        "coefficients": [ -27, 14, 422, -1035, 109, 1789, 267, -4738, -1617, 11376, 19649, 11376, -1617, -4738, 267, 1789, 109, -1035, 422, 14, -27 ]
        "numCoeff": 21,
    "pfirRxMagHighTiaHighSRHp": [ {
        "numCoeff": 21,
        "coefficients": [ 28, -160, 472, -885, 984, -36, -2594, 6779, -11030, 10718, 24218, 10718, -11030, 6779, -2594, -36, 984, -885, 472, -160, 28 ]
        "numCoeff": 21,
    "pfirRxMagLowTiaLowSRLp": [ {
        "numCoeff": 21,
        "coefficients": [ 28, -55, 108, -198, 345, -591, 1020, -1741, 2809, -4590, 38520, -4590, 2809, -1741, 1020, -591, 345, -198, 108, -55, 28 ]
        "numCoeff": 21,
    "pfirRxMagLowTiaHighSRLp": [ {
        "numCoeff": 21,
        "coefficients": [ -28, 14, 420, -1033, 109, 1787, 264, -4732, -1611, 11374, 19637, 11374, -1611, -4732, 264, 1787, 109, -1033, 420, 14, -28 ]
        "numCoeff": 21,
    "pfirRxMagHighTiaHighSRLp": [ {
        "numCoeff": 21,
        "coefficients": [ 28, -160, 472, -887, 988, -48, -2570, 6741, -10987, 10702, 24208, 10702, -10987, 6741, -2570, -48, 988, -887, 472, -160, 28 ]
        "numCoeff": 21,
    "pfirTxMagComp1": {
      "numCoeff": 21,
      "coefficients": [ 27, -129, 284, -160, -1076, 4542, -10947, 19272, -21373, 8600, 34691, 8600, -21373, 19272, -10947, 4542, -1076, -160, 284, -129, 27 ]
    "pfirTxMagComp2": {
      "numCoeff": 21,
    "pfirTxMagCompNb": [ {
        "numCoeff": 13,
        "coefficients": [ 73, -599, 1738, -1469, -3395, 9432, 21210, 9432, -3395, -1469, 1738, -599, 73 ]
        "numCoeff": 13,
    "pfirRxMagCompNb": [ {
        "numCoeff": 13,
        "coefficients": [ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ]
        "numCoeff": 13,
I want to ask if there is any good idea
regards,
  • +1
    on May 17, 2021 11:22 AM
    Hello Ryo,
    There a re a few things I would recommend trying:
    1. Updating TES and SD card image to latest releases. TES v0.14 did not support the ZCU102, that platform has only become support recently. Updating may fix some issues for you.
    2. Synchronising the LO to the Device Clk. If you have a second signal generator on hand, set the Clk selector switch on the EVB to External, connect your second signal generator and sync it to the LO signal generator.
    3. Attempt to use the Internal LO first as a proof of concept. This should eliminate the possibility of there being a different issue in the setup that you're not aware of, or pinpoint where it is if it exists.
    Do give these bits of debug a try and let us know how you get on.
    Best Regards,
    Oisín.
  • Hi Oisin.
    Thank you for your reply.
    I'm sorry, I made a mistake in describing the type of the evaluation board.
    The description of the correct evaluation board combination is EVAL-ADRV9002 + ZC706.
    Should I try the bits presented in this combination as well ?
    I apologize for making mistakes and taking time.
    Best Regards,
    Ryo.
    on May 18, 2021 7:40 AM in reply to OWatkins
    Hi Ryo,
    Not to worry, I would still attempt the debug steps outlined above. It's likely that one of them will fix the issue, but if they don't fix anything they should highlight where the issue is.
    Best Regards,
    Oisín.
  • Hi Oisin
    Thank you for your prompt and polite reply.
    Your words will wipe out my worries and try your suggestions.
    I will return here when the result comes out.
    thanks so much.
    Ryo.
  • Hi Oisin
    Sorry for being late.
    I tried the suggested bits and it worked, so I will report it.
    1. There was no change in the situation.
    2. I used the EVAL-ADF4351 to synchronize the clock I was able to confirm the operation by putting it in EXT_LO and DEV_CLK_IN.
    3. Operation was confirmed in the internal LO.
    We appreciate your help resolving the problem!
    Ryo
