- while checking the jesd204 interface status by the function axi_jesd204_rx_laneinfo_read( ) sometimes get "error: 1" should I care about the errors? I attached a file
Please wait...
IF : AD9528_ADDR_STATUS_READBACK0(Reg508) : f2
WARNING: AD9528_initialize() issues. Possible cause: REF_CLK not connected.
rx_clkgen: MMCM-PLL locked (122880000 Hz)
tx_clkgen: MMCM-PLL locked (122880000 Hz)
rx_os_clkgen: MMCM-PLL locked (122880000 Hz)
MCS successful
CLKPLL locked
AD9371 ARM version 5.2.2
PLLs locked
Calibrations completed successfully
tx_adxcvr: OK (4915200 kHz)
rx_adxcvr: OK (4915200 kHz)
rx_os_adxcvr: OK (4915200 kHz)
rx_jesd status:
Link is enabled
Measured Link Clock: 122.874 MHz
Reported Link Clock: 122.880 MHz
Lane rate: 4915.200 MHz
Lane rate / 40: 122.880 MHz
LMFC rate: 3.840 MHz
Link status: DATA
SYSREF captured: Yes
SYSREF alignment error: No
rx_jesd lane 0 status:
Errors: 0
CGS state: DATA
Initial Frame Synchronization: Yes
Lane Latency: 1 Multi-frames and 73 Octets
Initial Lane Alignment Sequence: Yes
DID: 0, BID: 0, LID: 0, L: 2, SCR: 1, F: 4
K: 32, M: 4, N: 16, CS: 0, N': 16, S: 1, HD: 0
FCHK: 0x47, CF: 0
ADJCNT: 0, PHADJ: 0, ADJDIR: 0, JESDV: 1, SUBCLASS: 1
FC: 4915200 kHz
rx_jesd lane 1 status:
Errors: 1
CGS state: DATA
DID: 0, BID: 0, LID: 1, L: 2, SCR: 1, F: 4
FCHK: 0x48, CF: 0
FC: 4915200 kHz
tx_jesd status:
Link is enabled
Measured Link Clock: 122.876 MHz
LMFC rate: 7.680 MHz
SYNC~: deasserted
Link status: DATA
rx_os_jesd status:
Link is enabled
Link status: DATA
rx_os_jesd lane 0 status:
Errors: 0
CGS state: DATA
Lane Latency: 2 Multi-frames and 5 Octets
DID: 0, BID: 0, LID: 0, L: 2, SCR: 1, F: 2
K: 32, M: 2, N: 16, CS: 0, N': 16, S: 1, HD: 0
FCHK: 0x43, CF: 0
FC: 4915200 kHz
rx_os_jesd lane 1 status:
Errors: 0
CGS state: DATA
Lane Latency: 2 Multi-frames and 6 Octets
DID: 0, BID: 0, LID: 1, L: 2, SCR: 1, F: 2
FCHK: 0x44, CF: 0
FC: 4915200 kHz
tx_dac: Successfully initialized (245751953 Hz)
rx_adc: Successfully initialized (122874450 Hz)
rx_obs_adc: Successfully initialized (245748901 Hz)
Done
- I checked the Framer Status = 0x3E and deframer Status = 0x28, and
- when I executed the function MYKONOS_jesd204bIlasCheck() I got mismatch value is 0x0 So, this is expected or not ?
uint16_t mismatch; mykError = MYKONOS_jesd204bIlasCheck(&mykDevice, &mismatch); if (mykError == MYKONOS_ERR_OK) printf("mismatch = 0x%x\n", mismatch);
- While running the code AD9375 and observing that clock mismatch, means that the AD9375 clock and FPGA-related clock are different. So this is expected or not?
- AD9375:
- tx_clkgen: MMCM-PLL locked (122880000 Hz)
- rx_clkgen: MMCM-PLL locked (122880000 Hz)
- rx_os_clkgen: MMCM-PLL locked (122880000 Hz)
- FPGA:
- tx_dac: Successfully initialized (245751953 Hz)
- rx_adc: Successfully initialized (122874450 Hz)
- rx_obs_adc: Successfully initialized (245748901 Hz)
