Myknos AD9371 error 364:MYKNOS_waitARMcmdStatus() in TDD
Hi Sir,
After we configured AD9371 driver TDD mode by setting these parameters to “1”:
  • useRx2EnablePin
  • useTx2EnablePin
  • txRxPinMode
  • orxPinMode
It seems that AD9371 cannot be initialized successful, would you kind to recommend if any ignored ? Thanks.
20210503_pin_ctrl_test_boot_log.txt
U-Boot 2018.01 (May 03 2021 - 09:30:37 +0000) Xilinx ZynqMP ZCU102 rev1.0
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu9cg
SF: Detected n25q1024 with page size 512 Bytes, erase size 128 KiB, total 256 MiB
*** Warning - bad CRC, using default environment
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
Bootmode: QSPI_MODE
Net:   ZYNQ GEM: ff0b0000, phyaddr ffffffff, interface rgmii-id
PHY is not detected
GEM PHY init failed
No ethernet found.
U-BOOT for Alpha_RU
mdio_register: non unique device name 'eth0'
No ethernet found.
Hit any key to stop autoboot:  0
device 0 offset 0x2e40000, size 0x3500000
SF: 55574528 bytes @ 0x2e40000 Read: OK
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x100000e0
     Data Size:    7542578 Bytes = 7.2 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   d5a0ff0363d82f03ea09a3676ef88c47b0542cb2
   Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  petalinux-user-image
     Type:         RAMDisk Image
     Data Start:   0x1073f22c
     Data Size:    16488620 Bytes = 15.7 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   6152e46da15c378368123ff40ed6e2317fcda96e
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x10731918
     Data Size:    55375 Bytes = 54.1 KiB
     Hash algo:    sha1
     Hash value:   7dcf11cf271329cd66e90998752bd8e0c379cf29
   Booting using the fdt blob at 0x10731918
   Uncompressing Kernel Image ... OK
   Loading Ramdisk to 07046000, end 07fff8ac ... OK
   Loading Device Tree to 0000000007035000, end 000000000704584e ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0 (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP Mon May 3 09:30:23 UTC 2021
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] random: fast init done
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff88000 s45080 r8192 d32744 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1034240
[    0.000000] Kernel command line: earlycon=cdns,mmio,0xFF000000,115200n8  console=ttyPS0,115200 uio_pdrv_genirq.of_id=generic-uio
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0x6bfff000-0x6ffff000] (64MB) mapped at [ffffffc06bfff000-ffffffc06fffefff]
[    0.000000] Memory: 3768272K/4194304K available (10364K kernel code, 750K rwdata, 3908K rodata, 512K init, 2157K bss, 163888K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008aa0000   ( 10368 KB)
[    0.000000]     .rodata : 0xffffff8008aa0000 - 0xffffff8008e80000   (  3968 KB)
[    0.000000]       .init : 0xffffff8008e80000 - 0xffffff8008f00000   (   512 KB)
[    0.000000]       .data : 0xffffff8008f00000 - 0xffffff8008fbba00   (   751 KB)
[    0.000000]        .bss : 0xffffff8008fbba00 - 0xffffff80091d6eb8   (  2158 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU event tracing is enabled.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024c8b6, max_idle_ns: 440795202285 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511100ns
[    0.008327] Console: colour dummy device 80x25
[    0.012389] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399999)
[    0.022754] pid_max: default: 32768 minimum: 301
[    0.027435] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.034012] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.041737] ASID allocator initialised with 65536 entries
[    0.046506] Hierarchical SRCU implementation.
[    0.051124] EFI services will not be available.
[    0.055298] zynqmp_plat_init Platform Management API v1.1
[    0.060642] zynqmp_plat_init Trustzone version v1.0
[    0.065549] smp: Bringing up secondary CPUs ...
[    0.070236] Detected VIPT I-cache on CPU1
[    0.070269] CPU1: Booted secondary processor [410fd034]
[    0.070327] smp: Brought up 1 node, 2 CPUs
[    0.083218] SMP: Total of 2 processors activated.
[    0.087890] CPU features: detected feature: 32-bit EL0 Support
[    0.093687] CPU: All CPU(s) started at EL2
[    0.097758] alternatives: patching kernel code
[    0.102990] devtmpfs: initialized
[    0.110986] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.115148] futex hash table entries: 512 (order: 4, 65536 bytes)
[    0.126766] xor: measuring software checksum speed
[    0.165281]    8regs     :  2303.000 MB/sec
[    0.205310]    8regs_prefetch:  2053.000 MB/sec
[    0.245340]    32regs    :  2830.000 MB/sec
[    0.285372]    32regs_prefetch:  2379.000 MB/sec
[    0.285401] xor: using function: 32regs (2830.000 MB/sec)
[    0.289786] pinctrl core: initialized pinctrl subsystem
[    0.295426] NET: Registered protocol family 16
[    0.300164] cpuidle: using governor menu
[    0.303742] vdso: 2 pages (1 code @ ffffff8008aa6000, 1 data @ ffffff8008f04000)
[    0.310563] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.317764] DMA: preallocated 256 KiB pool for atomic allocations
[    0.345248] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.347182] ARM CCI_400_r1 PMU driver probed
[    0.351435] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.373167] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.439201] raid6: int64x1  gen()   402 MB/s
[    0.507184] raid6: int64x1  xor()   446 MB/s
[    0.575276] raid6: int64x2  gen()   689 MB/s
[    0.643288] raid6: int64x2  xor()   603 MB/s
[    0.711370] raid6: int64x4  gen()  1043 MB/s
[    0.779407] raid6: int64x4  xor()   742 MB/s
[    0.847469] raid6: int64x8  gen()   980 MB/s
[    0.915511] raid6: int64x8  xor()   745 MB/s
[    0.983585] raid6: neonx1   gen()   726 MB/s
[    1.051619] raid6: neonx1   xor()   854 MB/s
[    1.119661] raid6: neonx2   gen()  1168 MB/s
[    1.187721] raid6: neonx2   xor()  1203 MB/s
[    1.255804] raid6: neonx4   gen()  1503 MB/s
[    1.323825] raid6: neonx4   xor()  1437 MB/s
[    1.391897] raid6: neonx8   gen()  1649 MB/s
[    1.459946] raid6: neonx8   xor()  1526 MB/s
[    1.459974] raid6: using algorithm neonx8 gen() 1649 MB/s
[    1.463938] raid6: .... xor() 1526 MB/s, rmw enabled
[    1.468868] raid6: using neon recovery algorithm
[    1.474493] SCSI subsystem initialized
[    1.477338] usbcore: registered new interface driver usbfs
[    1.482653] usbcore: registered new interface driver hub
[    1.487924] usbcore: registered new device driver usb
[    1.492974] media: Linux media interface: v0.10
[    1.497436] Linux video capture interface: v2.00
[    1.502032] pps_core: LinuxPPS API ver. 1 registered
[    1.506928] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.516020] PTP clock support registered
[    1.520103] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.526881] FPGA manager framework
[    1.530211] fpga-region fpga-full: FPGA Region probed
[    1.535232] Advanced Linux Sound Architecture Driver Initialized.
[    1.541436] Bluetooth: Core ver 2.22
[    1.544741] NET: Registered protocol family 31
[    1.549142] Bluetooth: HCI device and connection manager initialized
[    1.555459] Bluetooth: HCI socket layer initialized
[    1.560301] Bluetooth: L2CAP socket layer initialized
[    1.565332] Bluetooth: SCO socket layer initialized
[    1.571461] clocksource: Switched to clocksource arch_sys_counter
[    1.576305] VFS: Disk quotas dquot_6.6.0
[    1.580165] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.590929] NET: Registered protocol family 2
[    1.591593] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.598647] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.605510] TCP: Hash tables configured (established 32768 bind 32768)
[    1.611584] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.617545] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.624022] NET: Registered protocol family 1
[    1.628481] RPC: Registered named UNIX socket transport module.
[    1.634090] RPC: Registered udp transport module.
[    1.638757] RPC: Registered tcp transport module.
[    1.643427] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.649938] Trying to unpack rootfs image as initramfs...
[    2.358919] Freeing initrd memory: 16100K
[    2.359338] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    2.364510] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.372853] audit: initializing netlink subsys (disabled)
[    2.378073] audit: type=2000 audit(2.336:1): state=initialized audit_enabled=0 res=1
[    2.385188] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    2.392210] NFS: Registering the id_resolver key type
[    2.396583] Key type id_resolver registered
[    2.400752] Key type id_legacy registered
[    2.404702] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.411370] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    2.447175] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.448957] io scheduler noop registered
[    2.452816] io scheduler deadline registered
[    2.457067] io scheduler cfq registered (default)
[    2.461725] io scheduler mq-deadline registered
[    2.466223] io scheduler kyber registered
[    2.473529] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    2.477280] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    2.484181] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    2.491104] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    2.498023] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    2.504947] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    2.511862] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    2.518799] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    2.525753] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    2.532623] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    2.539551] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    2.546461] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    2.553380] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    2.560302] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    2.567224] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    2.574153] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    2.607734] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.611884] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.618555] brd: module loaded
[    2.619823] PLL: shutdown
[    2.620131] zynqmp_pll_disable() clock disable failed for apll_int, ret = -13
[    2.625888] loop: module loaded
[    2.626721] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.639094] m25p80 spi0.0: SPI-NOR-UniqueID 104000e660000019150018001f7a32ee38
[    2.643938] m25p80 spi0.0: found n25q00, expected n25q512a
[    2.650389] m25p80 spi0.0: n25q00 (262144 Kbytes)
[    2.654058] 5 ofpart partitions found on MTD device spi0.0
[    2.659516] Creating 5 MTD partitions on "spi0.0":
[    2.664244] 0x000000000000-0x000002e00000 : "boot"
[    2.669524] 0x000002e00000-0x000002e40000 : "bootenv"
[    2.674394] 0x000002e40000-0x000006340000 : "kernel"
[    2.679432] 0x000006740000-0x000006840000 : "Calibration"
[    2.684831] 0x000006840000-0x000006d40000 : "Config_Log"
[    2.690948] libphy: Fixed MDIO Bus: probed
[    2.694720] tun: Universal TUN/TAP device driver, 1.6
[    2.698874] CAN device driver interface
[    2.703248] macb ff0b0000.ethernet: Not enabling partial store and forward
[    2.709333] macb ff0b0000.ethernet: invalid hw address, using random
[    2.716067] libphy: MACB_mii_bus: probed
[    2.719914] macb ff0b0000.ethernet eth0: no PHY found
[    2.748482] xilinx_axienet 80000000.ethernet: couldn't find phy i/f
[    2.749532] usbcore: registered new interface driver asix
[    2.754517] usbcore: registered new interface driver ax88179_178a
[    2.760548] usbcore: registered new interface driver cdc_ether
[    2.766340] usbcore: registered new interface driver net1080
[    2.771967] usbcore: registered new interface driver cdc_subset
[    2.777845] usbcore: registered new interface driver zaurus
[    2.783394] usbcore: registered new interface driver cdc_ncm
[    2.789550] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    2.795848] usbcore: registered new interface driver uas
[    2.800517] usbcore: registered new interface driver usb-storage
[    2.806951] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    2.813696] i2c /dev entries driver
[    2.817882] IR NEC protocol handler initialized
[    2.821593] IR RC5(x/sz) protocol handler initialized
[    2.826608] IR RC6 protocol handler initialized
[    2.831105] IR JVC protocol handler initialized
[    2.835604] IR Sony protocol handler initialized
[    2.840187] IR SANYO protocol handler initialized
[    2.844859] IR Sharp protocol handler initialized
[    2.849530] IR MCE Keyboard/mouse protocol handler initialized
[    2.855325] IR XMP protocol handler initialized
[    2.860723] usbcore: registered new interface driver uvcvideo
[    2.865534] USB Video Class driver (1.1.1)
[    2.870125] Bluetooth: HCI UART driver ver 2.3
[    2.874018] Bluetooth: HCI UART protocol H4 registered
[    2.879114] Bluetooth: HCI UART protocol BCSP registered
[    2.884390] Bluetooth: HCI UART protocol ATH3K registered
[    2.889753] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.896022] Bluetooth: HCI UART protocol Intel registered
[    2.901344] Bluetooth: HCI UART protocol QCA registered
[    2.906564] usbcore: registered new interface driver bcm203x
[    2.912183] usbcore: registered new interface driver bpa10x
[    2.917719] usbcore: registered new interface driver bfusb
[    2.923169] usbcore: registered new interface driver btusb
[    2.928592] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.934260] usbcore: registered new interface driver ath3k
[    2.940428] sdhci: Secure Digital Host Controller Interface driver
[    2.945806] sdhci: Copyright(c) Pierre Ossman
[    2.950129] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.956083] ledtrig-cpu: registered to indicate activity on CPUs
[    2.961858] usbcore: registered new interface driver usbhid
[    2.967258] usbhid: USB HID core driver
[    2.972012] ad9371 spi1.0: ad9371_probe : enter
[    2.975561] enter
[    2.977481] devm_clk_get
[    2.980012] ad9371 spi1.1: ad9371_probe : enter
[    2.984470] enter
[    2.986382] devm_clk_get
[    2.991672] si5382 spi2.0: Rev.  si5382 probed chip select:0
[    3.660893] si5382_dev_create function is calling.
[    3.660931] I was assigned major number 244. To talk to
[    3.665237] the driver, create a dev file with
[    3.669647] 'mknod /dev/si5382_dev c 244 0'.
[    3.673884] Try various minor numbers. Try to cat and echo to
[    3.679592] the device file.
[    3.682442] Remove the device file and module when done.
[    3.687727] si5382 spi2.0: Rev.  si5382 probed end
[    3.695121] axi_adxcvr 84a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using GTH4 at 0x84A60000 mapped to 0xffffff8009275000. Number of lanes: 2.
[    3.707135] axi_adxcvr 84a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using GTH4 at 0x84A50000 mapped to 0xffffff800927d000. Number of lanes: 2.
[    3.719121] axi_adxcvr 84a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using GTH4 at 0x84A80000 mapped to 0xffffff8009285000. Number of lanes: 4.
[    3.733165] axi_adxcvr 84b60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.01.a) using GTH4 at 0x84B60000 mapped to 0xffffff800928d000. Number of lanes: 2.
[    3.746337] axi_adxcvr 84b50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.01.a) using GTH4 at 0x84B50000 mapped to 0xffffff8009295000. Number of lanes: 2.
[    3.758327] axi_adxcvr 84b80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.01.a) using GTH4 at 0x84B80000 mapped to 0xffffff800929d000. Number of lanes: 4.
[    3.773556] axi_sysid 85000000.axi-sysid-0: system ID header version mismatch. Expected 1, Reported 0
[    3.780370] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    3.787380] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    3.794066] Netfilter messages via NETLINK v0.30.
[    3.798742] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.804009] Initializing XFRM netlink socket
[    3.808191] NET: Registered protocol family 10
[    3.812972] Segment Routing with IPv6
[    3.816222] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.821653] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.827753] NET: Registered protocol family 17
[    3.831845] NET: Registered protocol family 15
[    3.836258] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.849136] Ebtables v2.0 registered
[    3.852759] can: controller area network core (rev 20170425 abi 9)
[    3.858851] NET: Registered protocol family 29
[    3.863238] can: raw protocol (rev 20170425)
[    3.867472] can: broadcast manager protocol (rev 20170425 t)
[    3.873098] can: netlink gateway (rev 20170425) max_hops=1
[    3.878684] Bluetooth: RFCOMM TTY layer initialized
[    3.883400] Bluetooth: RFCOMM socket layer initialized
[    3.888501] Bluetooth: RFCOMM ver 1.11
[    3.892216] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.897490] Bluetooth: BNEP filters: protocol multicast
[    3.902682] Bluetooth: BNEP socket layer initialized
[    3.907609] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.913493] Bluetooth: HIDP socket layer initialized
[    3.918447] 8021q: 802.1Q VLAN Support v1.8
[    3.922675] 9pnet: Installing 9P2000 support
[    3.926825] Key type dns_resolver registered
[    3.931431] registered taskstats version 1
[    3.935432] Btrfs loaded, crc32c=crc32c-generic
▒▒rʪ▒▒▒▒ꁍ▒▒ͽ▒▒▒m▒▒▒AM▒u▒▒▒▒▒▒▒▒5)m▒▒▒▒͹▒▒▒▒▒▒u▒▒▒▒ͽ▒▒▒m▒▒▒AM▒u▒▒▒▒▒▒▒▒5)m▒▒▒▒͹▒▒▒▒▒▒u▒▒▒▒э▒▒ͽ▒▒▒m▒▒▒▒▒u▒▒▒ͅ▒▒▒▒5)m▒▒▒▒͹▒▒▒▒▒▒u▒▒▒▒э▒▒ͽ▒▒▒m▒▒▒▒▒u▒▒▒ͅ▒▒▒▒5)m▒▒▒▒͹▒▒▒▒▒▒u▒▒ɍ▒▒ɍ▒▒▒▒▒▒▒▒▒ձѥ▒▒ᕑ▒▒ɍ▒▒▒́▒5)▒[    3.974008] i2c i2c-0: Added multiplexed i2c bus 3
[    3.978912] i2c i2c-0: Added multiplexed i2c bus 4
[    3.983819] i2c i2c-0: Added multiplexed i2c bus 5
[    3.988604] pca954x 0-0070: registered 4 multiplexed busses for I2C mux pca9544
[    3.995933] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 31
[    4.002827] ad9371 spi1.0: ad9371_probe : enter
[    4.007348] enter
[    4.009289] devm_clk_get
[    4.011828] devm_iio_device_alloc
[    4.015141] ad9371_alloc_mykonos_device
[    4.019562] [ALPHA DBG] useRx2EnablePin = 1
[    4.023734] [ALPHA DBG] useTx2EnablePin = 1
[    4.027908] [ALPHA DBG] txRxPinMode = 1
[    4.031740] [ALPHA DBG] orxPinMode = 1
[    4.035617] ad9371_phy_parse_dt
[    4.048758] phy->reset_gpio
[    4.051550] phy->sysref_req_gpio
[    4.054778] phy->jesd_rx_clk
[    4.057671] phy->jesd_rx_os_clk
[    4.060834] dev_clk
[    4.062947] fmc_clk
[    4.065117] ad9371_setup: dev_clk=153600000 ,fmc_clk=153600000
[    4.070946] rx->rxProfile->iqRate_kHz=153600
[    4.075207] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[    4.080770] obsRx->orxProfile->iqRate_kHz=307200
[    4.085379] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[    4.090942] tx->txProfile->iqRate_kHz=307200
[    4.095205] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[    4.110779] wait 10 us after reset
[    4.841461] MYKONOS_checkPllsLockStatus: pllLock=1
[    4.846363] ad9371_sysref_req:ad9371_sysref_req_mode=2
[    4.851498] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
[    5.099409] random: crng init done
[    5.291465] MYKONOS_setRfPllFrequency: rxpllLock=3
[    5.319465] MYKONOS_setRfPllFrequency: txpllLock=7
[    5.347465] WT:obsRxpllfreq=555032704
[    5.351195] MYKONOS_setRfPllFrequency: obspllLock=15
[    5.356318] MYKONOS_checkPllsLockStatus: pllLock=15
[   13.435466] [ALPHA DBG] errorFlag = 0, errorCode = 0
[   15.563465] [ALPHA DBG] errorFlag = 0, errorCode = 0
[   15.568422] TX_LO_LEAKAGE_INTERNAL1 ok
[   15.574444] ad9371_sysref_req:ad9371_sysref_req_mode=0
[   15.579580] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
[   15.589066] ad9371_sysref_req:ad9371_sysref_req_mode=1
[   15.594194] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
[   15.599723] Check Mykonos Framer Status: framerStatus=62
[   15.605165] WT: Check Mykonos OrxFramer Status: framerStatus=62
[   15.611215] Check Mykonos Framer Status: deframerStatus=40
[   15.653252] [ALPHA DBG] MYKONOS_sendArmCommand(MYKONOS_ARM_RADIOON_OPCODE) retVal = 0
[   15.661101] ERROR: 364: MYKONOS_waitArmCmdStatus() exited due to ARM error for the desired ARM opcode
[   15.670308] [ALPHA DBG] MYKONOS_waitArmCmdStatus(MYKONOS_ARM_RADIOON_OPCODE), retVal = 364
[   15.678562] ERROR: 145: ARM command to move to radioOn state failed.
[   15.684996] ad9371 spi1.0: ARM command to move to radioOn state failed.
[   15.684996]  (145)
[   15.693685] ad9371_setup
[   15.698383] ad9371 spi1.0: ad9371_probe : AD9370 Rev 4, Firmware 5.2.2 API version: 1.5.2.3566 successfully initialized
[   15.719282] ad9371 spi1.1: ad9371_probe : enter
[   15.723803] enter
[   15.725755] devm_clk_get
[   15.728295] devm_iio_device_alloc
[   15.731620] ad9371_alloc_mykonos_device
[   15.736035] [ALPHA DBG] useRx2EnablePin = 1
[   15.740208] [ALPHA DBG] useTx2EnablePin = 1
[   15.744382] [ALPHA DBG] txRxPinMode = 1
[   15.748209] [ALPHA DBG] orxPinMode = 1
[   15.752088] ad9371_phy_parse_dt
[   15.765237] phy->reset_gpio
[   15.768025] phy->sysref_req_gpio
[   15.771262] phy->jesd_rx_clk
[   15.774164] phy->jesd_rx_os_clk
[   15.777329] dev_clk
[   15.779448] fmc_clk
[   15.781629] ad9371_setup: dev_clk=153600000 ,fmc_clk=153600000
[   15.787460] rx->rxProfile->iqRate_kHz=153600
[   15.791724] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[   15.797287] obsRx->orxProfile->iqRate_kHz=307200
[   15.801896] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[   15.807460] tx->txProfile->iqRate_kHz=307200
[   15.811722] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
[   15.827296] wait 10 us after reset
[   16.553950] MYKONOS_checkPllsLockStatus: pllLock=1
[   16.558861] ad9371_sysref_req:ad9371_sysref_req_mode=2
[   16.563996] ad9371 spi1.1: ad9371_sysref_req: failed (-19)
[   17.007509] MYKONOS_setRfPllFrequency: rxpllLock=3
[   17.035466] MYKONOS_setRfPllFrequency: txpllLock=7
[   17.063465] WT:obsRxpllfreq=555032704
[   17.067200] MYKONOS_setRfPllFrequency: obspllLock=15
[   17.072351] MYKONOS_checkPllsLockStatus: pllLock=15
[   25.331467] [ALPHA DBG] errorFlag = 0, errorCode = 0
[   27.459466] [ALPHA DBG] errorFlag = 0, errorCode = 0
[   27.464424] TX_LO_LEAKAGE_INTERNAL1 ok
[   27.470444] ad9371_sysref_req:ad9371_sysref_req_mode=0
[   27.475574] ad9371 spi1.1: ad9371_sysref_req: failed (-19)
[   27.485069] ad9371_sysref_req:ad9371_sysref_req_mode=1
[   27.490196] ad9371 spi1.1: ad9371_sysref_req: failed (-19)
[   27.495727] Check Mykonos Framer Status: framerStatus=62
[   27.501167] WT: Check Mykonos OrxFramer Status: framerStatus=62
[   27.507217] Check Mykonos Framer Status: deframerStatus=40
[   27.549251] [ALPHA DBG] MYKONOS_sendArmCommand(MYKONOS_ARM_RADIOON_OPCODE) retVal = 0
[   27.557099] ERROR: 364: MYKONOS_waitArmCmdStatus() exited due to ARM error for the desired ARM opcode
[   27.566312] [ALPHA DBG] MYKONOS_waitArmCmdStatus(MYKONOS_ARM_RADIOON_OPCODE), retVal = 364
[   27.574564] ERROR: 145: ARM command to move to radioOn state failed.
[   27.580998] ad9371 spi1.1: ARM command to move to radioOn state failed.
[   27.580998]  (145)
[   27.589687] ad9371_setup
[   27.594296] ad9371 spi1.1: ad9371_probe : AD9370 Rev 4, Firmware 5.2.2 API version: 1.5.2.3566 successfully initialized
[   27.635872] cf_axi_dds 84a04000.axi-ad9371-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0xffffff800b0f0000, probed DDS AD9371
[   27.650234] cf_axi_dds 84b04000.axi-ad9371-tx-hpc: interpolation gpio error
[   27.675876] cf_axi_dds 84b04000.axi-ad9371-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84B04000 mapped to 0xffffff800b0f8000, probed DDS AD9371
[   27.710441] cf_axi_adc 84a00000.axi-ad9371-rx-hpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0xffffff800b148000, probed ADC AD9371 as MASTER
[   27.743222] cf_axi_adc 84b00000.axi-ad9371-rx-hpc: decimation gpio error
[   27.750137] cf_axi_adc 84b00000.axi-ad9371-rx-hpc: ADI AIM (10.01.b) at 0x84B00000 mapped to 0xffffff800b158000, probed ADC AD9371 as MASTER
[   27.763693] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   27.770637] rtc_zynqmp ffa60000.rtc: setting system clock to 2035-10-16 20:28:38 UTC (2076179318)
[   27.779904] PLL: shutdown
[   27.783375] ALSA device list:
[   27.786331]   No soundcards found.
[   27.790296] Freeing unused kernel memory: 512K
INIT: version 2.88 booting
Starting udev
[   27.900545] udevd[1808]: starting version 3.2.2
[   27.910407] udevd[1809]: starting eudev-3.2.2
Starting internet superserver: inetd.
Trigger PL
[   28.871851] Bad mode in Error handler detected on CPU0, code 0xbf000000 -- SError
[   28.879324] Internal error: Oops - bad mode: 0 [#1] SMP
[   28.884538] Modules linked in:
[   28.887579] CPU: 0 PID: 2207 Comm: busybox Not tainted 4.14.0 #1
[   28.893573] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[   28.898522] task: ffffffc87add6400 task.stack: ffffff800b7e0000
[   28.904426] PC is at 0x407c40
[   28.907374] LR is at 0x406df4
[   28.910326] pc : [<0000000000407c40>] lr : [<0000000000406df4>] pstate: 60000000
[   28.917703] sp : 0000007fceda5d30
[   28.921002] x29: 0000007fceda5e40 x28: 0000000000000000
[   28.926296] x27: 0000000000000000 x26: 0000000000000000
[   28.931591] x25: 0000000000000000 x24: 00000000004aa000
[   28.936886] x23: 00000000004aa000 x22: 0000007fceda5f80
[   28.942181] x21: 0000000000000004 x20: 000000000000001d
[   28.947476] x19: 0000007fceda5f80 x18: 0000000000000141
[   28.952770] x17: 00000000004aa978 x16: 0000007f98a4ec18
[   28.958065] x15: 0000007f98989d00 x14: 0000007f98996d98
[   28.963360] x13: 0000007f98ad1aa8 x12: 0000000000000000
[   28.968655] x11: 0000000000000000 x10: 0101010101010101
[   28.973950] x9 : 0000007f98a91b58 x8 : 00000000000000de
[   28.979244] x7 : 0000007f98a92458 x6 : 0000007fceda6f0c
[   28.984539] x5 : 0000000080003000 x4 : 0000000000000003
[   28.989834] x3 : 0000000000000001 x2 : 0000000000000003
[   28.995129] x1 : 0000007fceda6f0c x0 : 00000000004aa000
[   29.000424] Process busybox (pid: 2207, stack limit = 0xffffff800b7e0000)
[   29.007196] ---[ end trace b0802c9ea759d6c0 ]---
Unseal it.
Mountingflash:: Mounting /dev/mtdblock3 as /mnt/CalData
[   29.036802] jffs2: notice: (2209) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Mountingflash:: Mounting /dev/mtdblock4 as /mnt/Config_Log
mount: can't find /dev/mtdblock4/mnt/Config_Log in /etc/fstab
[   30.176601] jffs2: notice: (2215) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[checkFiles] Check necessary files...
[checkFiles] calData.txt exist.
[checkFiles] deviceInfo.txt exist.
[checkFiles] config.txt exist.
PetaLinux create files
PetaLinux create files End
ifconfig eth0 192.168.13.22 netmask 255.255.255.0
MAC = 8899AABBCCDD
ifdown: interface eth0 not configured
[   30.538141] xilinx_axienet 80000000.ethernet eth0: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration
udhcpc: started, v1.27.2
udhcpc: sending discover
[   30.983518] PLL: shutdown
udhcpc: no lease, forking to background
VLAN ID=564
Configure VLAN eth0.564 10.101.131.128/8
##PetaLinux insmod procfile.ko module##
insmod: can't insert '/lib/modules/4.14.0-xilinx-v2018.3/extra/procfile.ko': No such file or directory
PetaLinux insmod procfile.ko module completed!!!
Starting elogd ...
Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
INIT: Entering runlevel: 5
Configuring network interfaces... ifup: interface eth0 already configured
done.
Starting system message bus: dbus.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCbn2b3Ge8x/EOgJ5fbh0qnXDvv99I3lidLLSbt9Ip/Hz5nTLylpQj5vAh+WSaA/g+PBHKTK5KLlIItPJhaD+aAR2WN/ze061nFXFpa2mgQU1V/4y6UEcWW+WrpeGGUyQbCcvF74PICMXjlCRktTZr3+IAZh9eTiAUS9eXHNjykF8TR54q7VTjskpY/DQzxumRZzhr/nlUzdeN+FBdoH63lr09NSi5u0Hd40gy+eebhrTDSCx5SqhAgrlBtdwy/YqpQlk1+fYQxNY5LhXDImDakm6tXuEdWoRRksQHaQOinXsGwYJJRtb2+qOuNk6X+I0LgjhJHUcViBFbO+9P8rd3l root@Alpha_RU
Fingerprint: md5 d2:13:04:0b:1e:5b:16:85:68:e5:3a:55:f9:57:99:19
dropbear.
Starting IIO Daemon: iiod
Starting ntpd: done
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2018.3 Alpha_RU /dev/ttyPS0
Alpha_RU login:
[ 15.533376] ERROR: 364: MYKONOS_waitArmCmdStatus() exited due to ARM error for the desired ARM opcode
[ 15.542591] ERROR: 145: ARM command to move to radioOn state failed.
[ 15.549023] ad9371 spi1.0: ARM command to move to radioOn state failed.
    on May 7, 2021 4:51 AM
    During initialization and executing initial calibration we recommend to keep the Rx/Tx/Orx enable in ARM/SPI mode instead of pin mode.
    After completing the initialization user shall configure the pin mode and use the baseband controls to toggle between Rx/Tx.
    • useRx2EnablePin
    • useTx2EnablePin
    • txRxPinMode
    • orxPinMode
  • H Sir,
    We modified as your comments below. Is any ignored or not ?
       [    3.995578] ad9371 spi1.0: ad9371_probe : enter
    [    4.000100] enter
    [    4.002029] devm_clk_get
    [    4.004561] devm_iio_device_alloc
    [    4.007880] ad9371_alloc_mykonos_device
    [    4.012287] [ALPHA DBG 0] useRx2EnablePin = 0
    [    4.016632] [ALPHA DBG 0] useTx2EnablePin = 0
    [    4.020979] [ALPHA DBG 0] txRxPinMode = 0
    [    4.024980] [ALPHA DBG] orxPinMode = 0
    [    4.028865] ad9371_phy_parse_dt
    [    4.042009] phy->reset_gpio
    [    4.044795] phy->sysref_req_gpio
    [    4.048027] phy->jesd_rx_clk
    [    4.050918] phy->jesd_rx_os_clk
    [    4.054078] dev_clk
    [    4.056199] fmc_clk
    [    4.058365] ad9371_setup: dev_clk=153600000 ,fmc_clk=153600000
    [    4.064191] rx->rxProfile->iqRate_kHz=153600
    [    4.068452] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
    [    4.074015] obsRx->orxProfile->iqRate_kHz=307200
    [    4.078624] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
    [    4.084187] tx->txProfile->iqRate_kHz=307200
    [    4.088449] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
    [    4.104024] wait 10 us after reset
    [    4.841800] MYKONOS_checkPllsLockStatus: pllLock=1
    [    4.846706] ad9371_sysref_req:ad9371_sysref_req_mode=2
    [    4.851835] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
    [    5.291497] MYKONOS_setRfPllFrequency: rxpllLock=3
    [    5.319497] MYKONOS_setRfPllFrequency: txpllLock=7
    [    5.347496] WT:obsRxpllfreq=555032704
    [    5.351229] MYKONOS_setRfPllFrequency: obspllLock=15
    [    5.356383] MYKONOS_checkPllsLockStatus: pllLock=15
    [   11.395532] random: crng init done
    [   13.027498] [ALPHA DBG] MYKONOS_waitInitCals, errorFlag = 0, errorCode = 0
    [   13.043963] [ALPHA DBG] MYKONOS_getInitCalStatus, mykError = 0
    [   15.183498] [ALPHA DBG] MYKONOS_waitInitCals, errorFlag = 0, errorCode = 0
    [   15.199962] [ALPHA DBG] MYKONOS_getInitCalStatus, mykError = 0
    [   15.205788] TX_LO_LEAKAGE_INTERNAL1 ok
    [   15.211836] ad9371_sysref_req:ad9371_sysref_req_mode=0
    [   15.216972] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
    [   15.226456] ad9371_sysref_req:ad9371_sysref_req_mode=1
    [   15.231586] ad9371 spi1.0: ad9371_sysref_req: failed (-19)
    [   15.237122] Check Mykonos Framer Status: framerStatus=62
    [   15.242574] WT: Check Mykonos OrxFramer Status: framerStatus=62
    [   15.248633] Check Mykonos Framer Status: deframerStatus=40
    [   15.293544] [ALPHA DBG] MYKONOS_sendArmCommand(MYKONOS_ARM_RADIOON_OPCODE) retVal = 0
    [   15.311498] [ALPHA DBG] MYKONOS_waitArmCmdStatus(MYKONOS_ARM_RADIOON_OPCODE), retVal = 0
    [   15.343973] ad9371_setup
    [   15.348751] ad9371 spi1.0: ad9371_probe : AD9370 Rev 4, Firmware 5.2.2 API version: 1.5.2.3566 successfully initialized
    [   15.359537] [ALPHA DBG] useRx2EnablePin = 1
    [   15.363711] [ALPHA DBG] useTx2EnablePin = 1
    [   15.367885] [ALPHA DBG] txRxPinMode = 1
    [   15.371713] [ALPHA DBG] orxPinMode = 1
    [   15.385580] ad9371 spi1.1: ad9371_probe : enter
    [   15.390099] enter
    [   15.392057] devm_clk_get
    [   15.394593] devm_iio_device_alloc
    [   15.397917] ad9371_alloc_mykonos_device
    [   15.402330] [ALPHA DBG 0] useRx2EnablePin = 0
    [   15.406678] [ALPHA DBG 0] useTx2EnablePin = 0
    [   15.411025] [ALPHA DBG 0] txRxPinMode = 0
    [   15.415025] [ALPHA DBG] orxPinMode = 0
    [   15.418905] ad9371_phy_parse_dt
    [   15.432059] phy->reset_gpio
    [   15.434845] phy->sysref_req_gpio
    [   15.438083] phy->jesd_rx_clk
    [   15.440981] phy->jesd_rx_os_clk
    [   15.444146] dev_clk
    [   15.446265] fmc_clk
    [   15.448443] ad9371_setup: dev_clk=153600000 ,fmc_clk=153600000
    [   15.454270] rx->rxProfile->iqRate_kHz=153600
    [   15.458531] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
    [   15.464095] obsRx->orxProfile->iqRate_kHz=307200
    [   15.468704] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
    [   15.474269] tx->txProfile->iqRate_kHz=307200
    [   15.478529] ad9371_set_jesd_lanerate: lane_rate_kHz=6144000
    [   15.494104] wait 10 us after reset
    [   16.234368] MYKONOS_checkPllsLockStatus: pllLock=1
    [   16.239282] ad9371_sysref_req:ad9371_sysref_req_mode=2
    [   16.244414] ad9371 spi1.1: ad9371_sysref_req: failed (-19)
    [   16.687497] MYKONOS_setRfPllFrequency: rxpllLock=3
    [   16.715498] MYKONOS_setRfPllFrequency: txpllLock=7
    [   16.743501] WT:obsRxpllfreq=555032704
    [   16.747237] MYKONOS_setRfPllFrequency: obspllLock=15
    [   16.752411] MYKONOS_checkPllsLockStatus: pllLock=15
    [   24.555498] [ALPHA DBG] MYKONOS_waitInitCals, errorFlag = 0, errorCode = 0
    [   24.571966] [ALPHA DBG] MYKONOS_getInitCalStatus, mykError = 0
    [   26.711498] [ALPHA DBG] MYKONOS_waitInitCals, errorFlag = 0, errorCode = 0
    [   26.727969] [ALPHA DBG] MYKONOS_getInitCalStatus, mykError = 0
    [   26.733793] TX_LO_LEAKAGE_INTERNAL1 ok
    [   26.739839] ad9371_sysref_req:ad9371_sysref_req_mode=0
    [   26.744975] ad9371 spi1.1: ad9371_sysref_req: failed (-19)
    [   26.754461] ad9371_sysref_req:ad9371_sysref_req_mode=1
    [   26.759590] ad9371 spi1.1: ad9371_sysref_req: failed (-19)
    [   26.765127] Check Mykonos Framer Status: framerStatus=62
    [   26.770577] WT: Check Mykonos OrxFramer Status: framerStatus=62
    [   26.776637] Check Mykonos Framer Status: deframerStatus=40
    [   26.821518] [ALPHA DBG] MYKONOS_sendArmCommand(MYKONOS_ARM_RADIOON_OPCODE) retVal = 0
    [   26.839498] [ALPHA DBG] MYKONOS_waitArmCmdStatus(MYKONOS_ARM_RADIOON_OPCODE), retVal = 0
    [   26.871975] ad9371_setup
    [   26.876679] ad9371 spi1.1: ad9371_probe : AD9370 Rev 4, Firmware 5.2.2 API version: 1.5.2.3566 successfully initialized
    [   26.887469] [ALPHA DBG] useRx2EnablePin = 1
    [   26.891647] [ALPHA DBG] useTx2EnablePin = 1
    [   26.895820] [ALPHA DBG] txRxPinMode = 1
    [   26.899647] [ALPHA DBG] orxPinMode = 1
    [   26.931905] cf_axi_dds 84a04000.axi-ad9371-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0xffffff800b108000, probed DDS AD9371
    [   26.946297] cf_axi_dds 84b04000.axi-ad9371-tx-hpc: interpolation gpio error
    [   26.971907] cf_axi_dds 84b04000.axi-ad9371-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84B04000 mapped to 0xffffff800b118000, probed DDS AD9371
    [   27.006472] cf_axi_adc 84a00000.axi-ad9371-rx-hpc: ADI AIM (10.01.b) at 0x84A00000 mapped to 0xffffff800b120000, probed ADC AD9371 as MASTER
    [   27.039257] cf_axi_adc 84b00000.axi-ad9371-rx-hpc: decimation gpio error
    [   27.046164] cf_axi_adc 84b00000.axi-ad9371-rx-hpc: ADI AIM (10.01.b) at 0x84B00000 mapped to 0xffffff800b130000, probed ADC AD9371 as MASTER
    [   27.059731] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [   27.066683] rtc_zynqmp ffa60000.rtc: setting system clock to 2035-10-16 20:28:38 UTC (2076179318)
    [   27.075946] PLL: shutdown
    [   27.079416] ALSA device list:
    [   27.082374]   No soundcards found.
    [   27.086329] Freeing unused kernel memory: 512K
