Tx interpolation filter THB0/THBO
According to UG-992 Figure 80, page 166,there is a THBO in the Tx signal path (strangely with letter 'O', instead of digit '0'), but I found no other reference of it.
How can it be configured?
Is it related to the <txInputHbInterpolation=1> from the Filter Wizard?
What about the API? I guess: txInputHbInterpolation;     /*!< Interpolation of half band filter before the programmable FIR (valid 1,2,4) */
But in the code generated by the TES, the comment is slightly different: /* TxInputHbInterpolation (1,2)*/
Thank you
    on Aug 6, 2019 6:27 AM
    This is somehow missed in our UG-992 document. Thanks for pointing this out. We will add this info to UG-992 in next revision.
    THB0 (AD9375 only)
    The Transmit Half Band 0 (THB0) is a fixed coefficient half band interpolating filter. The THB0 is only available in the AD9375 product variants of the Mykonos family. The THB0 can interpolate by a factor of 2 or it can be bypassed. The full-scale value of this filter is 32768 (215).
    THB0 Filter Coefficients: [33, 0, -159, 0, 493, 0, -1216, 0, 2677, 0, -5944, 0, 20503, 32768, 20503, 0, -5944, 0, 2677, 0, -1216, 0, 492, 0, -159, 0, 33]
  • Has there been any updates to this? The filter wizard nor TES  takes advantage of this either. Is there an MYKONOS structure for this or API?
    on Apr 19, 2021 11:10 AM in reply to Jpayne
    Are you using AD9375 device? What is the profile you are using?
    If you are using AD9375, To enable the THB0 for AD9375, "2, /* TxInputHbInterpolation (1,2)*/" has to be set to 2 manually and  to enbale DPD "1 /* Enable DPD, only valid for AD9373*/" has to be set to 1 manually.
    For example,
    static mykonosTxProfile_t txProfile =
    { /* TxDPD 40/200MHz, IQrate 122.88MSPS, Dec5 */
    DACDIV_2p5, /* The divider used to generate the DAC clock*/
    &txFir, /* Pointer to Tx FIR filter structure*/
    1, /* The Tx digital FIR filter interpolation (1,2,4)*/
    2, /* Tx Halfband1 filter interpolation (1,2)*/
    1, /* Tx Halfband2 filter interpolation (1,2)*/
    122880, /* Tx IQ data rate in kHz*/
    60000000, /* Primary Signal BW*/
    200000000, /* The Tx RF passband bandwidth for the profile*/
    189477, /* The DAC filter 3dB corner in kHz*/
    100000, /* Tx BBF 3dB corner in kHz*/
