Hi folks,
I find the specification and relevant document, it doesn't mention about EVM measurement .
Could you help to provide the EVM measurement result , the condition of measurement is 1024QAM@7.2GHz.
Thanks.
Hi folks,
Thanks.
Hi, please see the prelim results collected on single AD9082 board. AD9988/AD9082 are same product family. please refer to the Datasheet/UG to understand the difference.
test item | connections | results | |
1 | ADC- DAC Loopback EVM |
►Single Channel Loopback EVM
Complex mode EVM is expected to be 3dB lower than the single channel EVM |
2 |
ADC-DAC Loopback (5G NR 30kHz-100MHz) Waveform: 5G NR 30kHz 100MHz Wide |
3 |
ADC-DAC Loopback (IEEE 802.11BE) Device Settings DAC sampling rate = 12GSPS ADC sampling rate = 6GSPS Waveform Settings IEEE 802.11BE, 320MHz, 4096 QAM Test configuration DAC/ADC loopback |
4 |
Direct DAC RF in 1st and 2nd Nyquist DAC 11796.48Msps & 9830.4Msps AD9082-FMCB-EBZ 4D2A Data Rate = 491.52Msps, Vector: 80MHz IEEE 802.11AX 1024 QAM |
5 |
AD9082/AD9213 Direct RF in 2nd Nyquist Vector: 80MHz IEEE 802.11AX 1024 QAM |
