We have a custom board around an AD9361 device that was qualified successfully at different temperatures (-40°C, 25°C & 80°C).
We have started to see some issues however at specific temperatures points (around -15°C to -5°C) where the AD9361 initialization fails due to the BBPLL lock (Calibration TIMEOUT (0x5E, 0x80)).
Reading back the 0x5E register after the init completes (1-2 secs) does indeed still show the BBPLL is not locked (readback 0x00).
Can you share any insight as to why the BBPLL lock could fail at lower temperature ?
Is there some settings we could play with to achieve a better lock stability ?
Here is the current configuration we are using:
AD9361_InitParam default_init_param = { /* Device selection */ ID_AD9361, // dev_sel /* Identification number */ 0, // id_no /* Reference Clock */ 25000000UL, // reference_clk_rate /* Base Configuration */ 1, // two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable 1, // one_rx_one_tx_mode_use_rx_num *** adi,1rx-1tx-mode-use-rx-num 1, // one_rx_one_tx_mode_use_tx_num *** adi,1rx-1tx-mode-use-tx-num 1, // frequency_division_duplex_mode_enable *** // adi,frequency-division-duplex-mode-enable 1, // frequency_division_duplex_independent_mode_enable *** // adi,frequency-division-duplex-independent-mode-enable 0, // tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable 0, // tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable 0, // tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns 0, // rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns 0, // rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable 0, // tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable 0, // external_rx_lo_enable *** adi,external-rx-lo-enable 0, // external_tx_lo_enable *** adi,external-tx-lo-enable 5, // dc_offset_tracking_update_event_mask *** // adi,dc-offset-tracking-update-event-mask 6, // dc_offset_attenuation_high_range *** // adi,dc-offset-attenuation-high-range 5, // dc_offset_attenuation_low_range *** // adi,dc-offset-attenuation-low-range 0x28, // dc_offset_count_high_range *** adi,dc-offset-count-high-range 0x32, // dc_offset_count_low_range *** adi,dc-offset-count-low-range 0, // split_gain_table_mode_enable *** adi,split-gain-table-mode-enable MAX_SYNTH_FREF, // trx_synthesizer_target_fref_overwrite_hz *** // adi,trx-synthesizer-target-fref-overwrite-hz 0, // qec_tracking_slow_mode_enable *** adi,qec-tracking-slow-mode-enable /* ENSM Control */ 0, // ensm_enable_pin_pulse_mode_enable *** // adi,ensm-enable-pin-pulse-mode-enable 0, // ensm_enable_txnrx_control_enable *** // adi,ensm-enable-txnrx-control-enable /* LO Control */ 2079000000UL, // rx_synthesizer_frequency_hz *** // adi,rx-synthesizer-frequency-hz 2245000000UL, // tx_synthesizer_frequency_hz *** // adi,tx-synthesizer-frequency-hz 1, // tx_lo_powerdown_managed_enable *** adi,tx-lo-powerdown-managed-enable /* Rate & BW Control */ {1024000000, 32000000, 16000000, 8000000, 4000000, 1000000}, // rx_path_clock_frequencies[6] *** // adi,rx-path-clock-frequencies {1024000000, 32000000, 16000000, 8000000, 4000000, 1000000}, // tx_path_clock_frequencies[6] *** // adi,tx-path-clock-frequencies 1000000, // rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz 6000000, // rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz /* RF Port Control */ 0, // rx_rf_port_input_select *** adi,rx-rf-port-input-select 0, // tx_rf_port_input_select *** adi,tx-rf-port-input-select /* TX Attenuation Control */ 10000, // tx_attenuation_mdB *** adi,tx-attenuation-mdB 0, // update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable /* Reference Clock Control */ 0, // xo_disable_use_ext_refclk_enable *** // adi,xo-disable-use-ext-refclk-enable {10, 185}, // dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune BUFFERED_XTALN_DCXO, // clk_output_mode_select *** // adi,clk-output-mode-select /* Gain Control */ 2, // gc_rx1_mode *** adi,gc-rx1-mode 2, // gc_rx2_mode *** adi,gc-rx2-mode 58, // gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh 4, // gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size 47, // gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh 8192, // gc_dec_pow_measurement_duration *** // adi,gc-dec-pow-measurement-duration 0, // gc_dig_gain_enable *** adi,gc-dig-gain-enable 800, // gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh 704, // gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh 24, // gc_low_power_thresh *** adi,gc-low-power-thresh 15, // gc_max_dig_gain *** adi,gc-max-dig-gain /* Gain MGC Control */ 2, // mgc_dec_gain_step *** adi,mgc-dec-gain-step 2, // mgc_inc_gain_step *** adi,mgc-inc-gain-step 0, // mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable 0, // mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable 0, // mgc_split_table_ctrl_inp_gain_mode *** // adi,mgc-split-table-ctrl-inp-gain-mode /* Gain AGC Control */ 10, // agc_adc_large_overload_exceed_counter *** // adi,agc-adc-large-overload-exceed-counter 2, // agc_adc_large_overload_inc_steps *** // adi,agc-adc-large-overload-inc-steps 0, // agc_adc_lmt_small_overload_prevent_gain_inc_enable *** // adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable 10, // agc_adc_small_overload_exceed_counter *** // adi,agc-adc-small-overload-exceed-counter 4, // agc_dig_gain_step_size *** adi,agc-dig-gain-step-size 3, // agc_dig_saturation_exceed_counter *** // adi,agc-dig-saturation-exceed-counter 1000, // agc_gain_update_interval_us *** adi,agc-gain-update-interval-us 0, // agc_immed_gain_change_if_large_adc_overload_enable *** // adi,agc-immed-gain-change-if-large-adc-overload-enable 0, // agc_immed_gain_change_if_large_lmt_overload_enable *** // adi,agc-immed-gain-change-if-large-lmt-overload-enable 10, // agc_inner_thresh_high *** adi,agc-inner-thresh-high 1, // agc_inner_thresh_high_dec_steps *** // adi,agc-inner-thresh-high-dec-steps 12, // agc_inner_thresh_low *** adi,agc-inner-thresh-low 1, // agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps 10, // agc_lmt_overload_large_exceed_counter *** // adi,agc-lmt-overload-large-exceed-counter 2, // agc_lmt_overload_large_inc_steps *** // adi,agc-lmt-overload-large-inc-steps 10, // agc_lmt_overload_small_exceed_counter *** // adi,agc-lmt-overload-small-exceed-counter 5, // agc_outer_thresh_high *** adi,agc-outer-thresh-high 2, // agc_outer_thresh_high_dec_steps *** // adi,agc-outer-thresh-high-dec-steps 18, // agc_outer_thresh_low *** adi,agc-outer-thresh-low 2, // agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps 1, // agc_attack_delay_extra_margin_us; *** // adi,agc-attack-delay-extra-margin-us 0, // agc_sync_for_gain_counter_enable *** // adi,agc-sync-for-gain-counter-enable /* Fast AGC */ 64, // fagc_dec_pow_measuremnt_duration *** // adi,fagc-dec-pow-measurement-duration 260, // fagc_state_wait_time_ns *** adi,fagc-state-wait-time-ns /* Fast AGC - Low Power */ 0, // fagc_allow_agc_gain_increase *** // adi,fagc-allow-agc-gain-increase-enable 5, // fagc_lp_thresh_increment_time *** adi,fagc-lp-thresh-increment-time 1, // fagc_lp_thresh_increment_steps *** adi,fagc-lp-thresh-increment-steps /* Fast AGC - Lock Level (Lock Level is set via slow AGC inner high threshold) */ 1, // fagc_lock_level_lmt_gain_increase_en *** // adi,fagc-lock-level-lmt-gain-increase-enable 5, // fagc_lock_level_gain_increase_upper_limit *** // adi,fagc-lock-level-gain-increase-upper-limit /* Fast AGC - Peak Detectors and Final Settling */ 1, // fagc_lpf_final_settling_steps *** adi,fagc-lpf-final-settling-steps 1, // fagc_lmt_final_settling_steps *** adi,fagc-lmt-final-settling-steps 3, // fagc_final_overrange_count *** adi,fagc-final-overrange-count /* Fast AGC - Final Power Test */ 0, // fagc_gain_increase_after_gain_lock_en *** // adi,fagc-gain-increase-after-gain-lock-enable /* Fast AGC - Unlocking the Gain */ 0, // fagc_gain_index_type_after_exit_rx_mode *** // adi,fagc-gain-index-type-after-exit-rx-mode 1, // fagc_use_last_lock_level_for_set_gain_en *** // adi,fagc-use-last-lock-level-for-set-gain-enable 1, // fagc_rst_gla_stronger_sig_thresh_exceeded_en *** // adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable 5, // fagc_optimized_gain_offset *** adi,fagc-optimized-gain-offset 10, // fagc_rst_gla_stronger_sig_thresh_above_ll *** // adi,fagc-rst-gla-stronger-sig-thresh-above-ll 1, // fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en *** // adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable 1, // fagc_rst_gla_engergy_lost_goto_optim_gain_en *** // adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable 10, // fagc_rst_gla_engergy_lost_sig_thresh_below_ll *** // adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll 8, // fagc_energy_lost_stronger_sig_gain_lock_exit_cnt *** // adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt 1, // fagc_rst_gla_large_adc_overload_en *** // adi,fagc-rst-gla-large-adc-overload-enable 1, // fagc_rst_gla_large_lmt_overload_en *** // adi,fagc-rst-gla-large-lmt-overload-enable 0, // fagc_rst_gla_en_agc_pulled_high_en *** // adi,fagc-rst-gla-en-agc-pulled-high-enable 0, // fagc_rst_gla_if_en_agc_pulled_high_mode *** // adi,fagc-rst-gla-if-en-agc-pulled-high-mode 64, // fagc_power_measurement_duration_in_state5 *** // adi,fagc-power-measurement-duration-in-state5 /* RSSI Control */ 1, // rssi_delay *** adi,rssi-delay 1000, // rssi_duration *** adi,rssi-duration 3, // rssi_restart_mode *** adi,rssi-restart-mode 0, // rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable 1, // rssi_wait *** adi,rssi-wait /* Aux ADC Control */ 256, // aux_adc_decimation *** adi,aux-adc-decimation 40000000UL, // aux_adc_rate *** adi,aux-adc-rate /* AuxDAC Control */ 1, // aux_dac_manual_mode_enable *** adi,aux-dac-manual-mode-enable 0, // aux_dac1_default_value_mV *** adi,aux-dac1-default-value-mV 0, // aux_dac1_active_in_rx_enable *** adi,aux-dac1-active-in-rx-enable 0, // aux_dac1_active_in_tx_enable *** adi,aux-dac1-active-in-tx-enable 0, // aux_dac1_active_in_alert_enable *** // adi,aux-dac1-active-in-alert-enable 0, // aux_dac1_rx_delay_us *** adi,aux-dac1-rx-delay-us 0, // aux_dac1_tx_delay_us *** adi,aux-dac1-tx-delay-us 0, // aux_dac2_default_value_mV *** adi,aux-dac2-default-value-mV 0, // aux_dac2_active_in_rx_enable *** adi,aux-dac2-active-in-rx-enable 0, // aux_dac2_active_in_tx_enable *** adi,aux-dac2-active-in-tx-enable 0, // aux_dac2_active_in_alert_enable *** // adi,aux-dac2-active-in-alert-enable 0, // aux_dac2_rx_delay_us *** adi,aux-dac2-rx-delay-us 0, // aux_dac2_tx_delay_us *** adi,aux-dac2-tx-delay-us /* Temperature Sensor Control */ 256, // temp_sense_decimation *** adi,temp-sense-decimation 1000, // temp_sense_measurement_interval_ms *** // adi,temp-sense-measurement-interval-ms 0xCE, // temp_sense_offset_signed *** adi,temp-sense-offset-signed 1, // temp_sense_periodic_measurement_enable *** // adi,temp-sense-periodic-measurement-enable /* Control Out Setup */ 0xFF, // ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask 9, // ctrl_outs_index *** adi,ctrl-outs-index /* External LNA Control */ 0, // elna_settling_delay_ns *** adi,elna-settling-delay-ns 0, // elna_gain_mdB *** adi,elna-gain-mdB 0, // elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB 0, // elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable 0, // elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable 0, // elna_gaintable_all_index_enable *** // adi,elna-gaintable-all-index-enable /* Digital Interface Control */ 2, // digital_interface_tune_skip_mode *** // adi,digital-interface-tune-skip-mode 0, // digital_interface_tune_fir_disable *** // adi,digital-interface-tune-fir-disable 1, // pp_tx_swap_enable *** adi,pp-tx-swap-enable 1, // pp_rx_swap_enable *** adi,pp-rx-swap-enable 0, // tx_channel_swap_enable *** adi,tx-channel-swap-enable 0, // rx_channel_swap_enable *** adi,rx-channel-swap-enable 1, // rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable 1, // two_t_two_r_timing_enable *** adi,2t2r-timing-enable 0, // invert_data_bus_enable *** adi,invert-data-bus-enable 0, // invert_data_clk_enable *** adi,invert-data-clk-enable 0, // fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable 0, // invert_rx_frame_enable *** adi,invert-rx-frame-enable 0, // fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable 1, // swap_ports_enable *** adi,swap-ports-enable 1, // single_data_rate_enable *** adi,single-data-rate-enable 0, // lvds_mode_enable *** adi,lvds-mode-enable 0, // half_duplex_mode_enable *** adi,half-duplex-mode-enable 0, // single_port_mode_enable *** adi,single-port-mode-enable 1, // full_port_enable *** adi,full-port-enable 0, // full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable 0, // delay_rx_data *** adi,delay-rx-data 0, // rx_data_clock_delay *** adi,rx-data-clock-delay 0xF, // rx_data_delay *** adi,rx-data-delay 0, // tx_fb_clock_delay *** adi,tx-fb-clock-delay 0, // tx_data_delay *** adi,tx-data-delay #ifdef ALTERA_PLATFORM 300, // lvds_bias_mV *** adi,lvds-bias-mV #else 150, // lvds_bias_mV *** adi,lvds-bias-mV #endif 1, // lvds_rx_onchip_termination_enable *** // adi,lvds-rx-onchip-termination-enable 0, // rx1rx2_phase_inversion_en *** adi,rx1-rx2-phase-inversion-enable 0xFF, // lvds_invert1_control *** adi,lvds-invert1-control 0x0F, // lvds_invert2_control *** adi,lvds-invert2-control /* GPO Control */ 0, // gpo0_inactive_state_high_enable *** // adi,gpo0-inactive-state-high-enable 0, // gpo1_inactive_state_high_enable *** // adi,gpo1-inactive-state-high-enable 0, // gpo2_inactive_state_high_enable *** // adi,gpo2-inactive-state-high-enable 0, // gpo3_inactive_state_high_enable *** // adi,gpo3-inactive-state-high-enable 0, // gpo0_slave_rx_enable *** adi,gpo0-slave-rx-enable 0, // gpo0_slave_tx_enable *** adi,gpo0-slave-tx-enable 0, // gpo1_slave_rx_enable *** adi,gpo1-slave-rx-enable 0, // gpo1_slave_tx_enable *** adi,gpo1-slave-tx-enable 0, // gpo2_slave_rx_enable *** adi,gpo2-slave-rx-enable 0, // gpo2_slave_tx_enable *** adi,gpo2-slave-tx-enable 0, // gpo3_slave_rx_enable *** adi,gpo3-slave-rx-enable 0, // gpo3_slave_tx_enable *** adi,gpo3-slave-tx-enable 0, // gpo0_rx_delay_us *** adi,gpo0-rx-delay-us 0, // gpo0_tx_delay_us *** adi,gpo0-tx-delay-us 0, // gpo1_rx_delay_us *** adi,gpo1-rx-delay-us 0, // gpo1_tx_delay_us *** adi,gpo1-tx-delay-us 0, // gpo2_rx_delay_us *** adi,gpo2-rx-delay-us 0, // gpo2_tx_delay_us *** adi,gpo2-tx-delay-us 0, // gpo3_rx_delay_us *** adi,gpo3-rx-delay-us 0, // gpo3_tx_delay_us *** adi,gpo3-tx-delay-us /* Tx Monitor Control */ 37000, // low_high_gain_threshold_mdB *** adi,txmon-low-high-thresh 0, // low_gain_dB *** adi,txmon-low-gain 24, // high_gain_dB *** adi,txmon-high-gain 0, // tx_mon_track_en *** adi,txmon-dc-tracking-enable 0, // one_shot_mode_en *** adi,txmon-one-shot-mode-enable 511, // tx_mon_delay *** adi,txmon-delay 8192, // tx_mon_duration *** adi,txmon-duration 2, // tx1_mon_front_end_gain *** adi,txmon-1-front-end-gain 2, // tx2_mon_front_end_gain *** adi,txmon-2-front-end-gain 48, // tx1_mon_lo_cm *** adi,txmon-1-lo-cm 48, // tx2_mon_lo_cm *** adi,txmon-2-lo-cm /* GPIO definitions */ 1, // gpio_resetb *** reset-gpios /* MCS Sync */ -1, // gpio_sync *** sync-gpios -1, // gpio_cal_sw1 *** cal-sw1-gpios -1, // gpio_cal_sw2 *** cal-sw2-gpios /* External LO clocks */ NULL, //(*ad9361_rfpll_ext_recalc_rate)() NULL, //(*ad9361_rfpll_ext_round_rate)() NULL //(*ad9361_rfpll_ext_set_rate)() }; AD9361_RXFIRConfig rx_fir_config = { 3, /* rx */ -12, /* rx_gain */ 4, /* rx_dec */ {258, 318, 374, 425, 469, 504, 528, 540, 538, 522, 489, 441, 376, 295, 198, 87, -37, -171, -314, -462, -613, -763, -908, -1044, -1168, -1275, -1362, -1423, -1456, -1457, -1424, -1352, -1241, -1088, -893, -655, -374, -53, 308, 705, 1137, 1597, 2083, 2589, 3109, 3637, 4168, 4694, 5209, 5706, 6179, 6622, 7028, 7392, 7709, 7975, 8186, 8338, 8431, 8462, 8431, 8338, 8186, 7975, 7709, 7392, 7028, 6622, 6179, 5706, 5209, 4694, 4168, 3637, 3109, 2589, 2083, 1597, 1137, 705, 308, -53, -374, -655, -893, -1088, -1241, -1352, -1424, -1457, -1456, -1423, -1362, -1275, -1168, -1044, -908, -763, -613, -462, -314, -171, -37, 87, 198, 295, 376, 441, 489, 522, 538, 540, 528, 504, 469, 425, 374, 318, 258, 0, 0, 0, 0, 0, 0, 0, 0, 0}, /* rx_coef[128] */ 128, /* rx_coef_size */ {1121280005, 140160000, 70080000, 35040000, 17520000, 4380000}, /* tx_path_clks[6] */ // {1121280005,70080000,35040000,17520000,4380000,4380000}, /* // rx_path_clks[6] */ 1000000 /* rx_bandwith */ }; AD9361_TXFIRConfig tx_fir_config = { 3, /* tx */ 6, /* tx_gain */ 4, /* tx_int */ {16, 25, 7, -19, -28, -6, 24, 31, 6, -29, -36, -8, 29, 36, 5, -35, -40, -1, 43, 48, 1, -52, -58, -5, 54, 56, -4, -67, -64, 13, 91, 85, -12, -109, -106, 7, 118, 103, -36, -163, -126, 76, 254, 208, -67, -324, -286, 56, 370, 265, -266, -708, -412, 712, 1817, 1588, -614, -3758, -5245, -2356, 5752, 16898, 26612, 30463, 26612, 16898, 5752, -2356, -5245, -3758, -614, 1588, 1817, 712, -412, -708, -266, 265, 370, 56, -286, -324, -67, 208, 254, 76, -126, -163, -36, 103, 118, 7, -106, -109, -12, 85, 91, 13, -64, -67, -4, 56, 54, -5, -58, -52, 1, 48, 43, -1, -40, -35, 5, 36, 29, -8, -36, -29, 6, 31, 24, -6, -28, -19, 7, 25, 16, 0}, /* tx_coef[128] */ 128, /* tx_coef_size */ //{1024000000, 32000000, 16000000, 8000000, 4000000, 1000000}, {1121280005, 140160000, 70080000, 35040000, 17520000, 4380000}, /* tx_path_clks[6] */ 6000000 /* tx_bandwith */ };
Thanks in advance for your help.
Antoine
