Fir and sampling rate issue in ad9361
I have downloaded latest drivers from github. AD9361 driver is  configured for rxpath_clks as {975360000, 243840000, 121920000, 60960000, 30480000, 30480000} and  for tx path as
{975360000,  121920000, 60960000, 30480000, 30480000,30480000}. FiR filter is bypassed (true) bandwidth is 11Mhz. Always it is showing RX tuning failed because of the sampling rate. Is there any constraint on using 30480000 sampling rate?
Even i have checked this https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/interface_timing_validation
in debug mode everywhere it is printing(#) . So please suggest me some workaround to fix this.
    on Oct 19, 2020 8:29 AM 1 month ago
    Did you use the filter wizard tool to generate the profile? Download the filter wizard from the below link and then load it and check. What is the ref_clk frequency?
    https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/filters
  • YES I HAVE AD9361 FILTER WIZARD TOOL AS PER THAT ONLY I HAVE GENERATED EVERYTHING.
  • These are the settings
    AD9361_InitParam default_init_param = {
    /* Device selection */
    ID_AD9361, // dev_sel
    /* Identification number */
    0, //id_no
    /* Reference Clock */
    40000000UL, //reference_clk_rate
    /* Base Configuration */
    1, //two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
    0, //one_rx_one_tx_mode_use_rx_num *** adi,1rx-1tx-mode-use-rx-num
    0, //one_rx_one_tx_mode_use_tx_num *** adi,1rx-1tx-mode-use-tx-num
    1, //frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
    0, //frequency_division_duplex_independent_mode_enable *** adi,frequency-division-duplex-independent-mode-enable
    0, //tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable
    0, //tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable
    0, //tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns
    0, //rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns
    0, //rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable
    0, //tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable
    0, //external_rx_lo_enable *** adi,external-rx-lo-enable
    0, //external_tx_lo_enable *** adi,external-tx-lo-enable
    5, //dc_offset_tracking_update_event_mask *** adi,dc-offset-tracking-update-event-mask
    6, //dc_offset_attenuation_high_range *** adi,dc-offset-attenuation-high-range
    5, //dc_offset_attenuation_low_range *** adi,dc-offset-attenuation-low-range
    0x28, //dc_offset_count_high_range *** adi,dc-offset-count-high-range
    0x32, //dc_offset_count_low_range *** adi,dc-offset-count-low-range
    0, //split_gain_table_mode_enable *** adi,split-gain-table-mode-enable
    MAX_SYNTH_FREF, //trx_synthesizer_target_fref_overwrite_hz *** adi,trx-synthesizer-target-fref-overwrite-hz
    0, // qec_tracking_slow_mode_enable *** adi,qec-tracking-slow-mode-enable
    /* ENSM Control */
    0, //ensm_enable_pin_pulse_mode_enable *** adi,ensm-enable-pin-pulse-mode-enable
    0, //ensm_enable_txnrx_control_enable *** adi,ensm-enable-txnrx-control-enable
    /* LO Control */
    2400000000UL, //rx_synthesizer_frequency_hz *** adi,rx-synthesizer-frequency-hz
    2400000000UL, //tx_synthesizer_frequency_hz *** adi,tx-synthesizer-frequency-hz
    1, //tx_lo_powerdown_managed_enable *** adi,tx-lo-powerdown-managed-enable
    /* Rate & BW Control */
    {975360000, 243840000, 121920000, 60960000, 30480000, 30480000},// rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
    {975360000,121920000,60960000,30480000,30480000,30480000},// tx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
    11000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
    11000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
    /* RF Port Control */
    0, //rx_rf_port_input_select *** adi,rx-rf-port-input-select
    0, //tx_rf_port_input_select *** adi,tx-rf-port-input-select
    /* TX Attenuation Control */
    10000, //tx_attenuation_mdB *** adi,tx-attenuation-mdB
    0, //update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable
    /* Reference Clock Control */
    0, //xo_disable_use_ext_refclk_enable *** adi,xo-disable-use-ext-refclk-enable
    {8, 5920}, //dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune
    CLKOUT_DISABLE, //clk_output_mode_select *** adi,clk-output-mode-select
    /* Gain Control */
    1, //gc_rx1_mode *** adi,gc-rx1-mode
    1, //gc_rx2_mode *** adi,gc-rx2-mode
    58, //gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh
    4, //gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size
    47, //gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh
    8192, //gc_dec_pow_measurement_duration *** adi,gc-dec-pow-measurement-duration
    0, //gc_dig_gain_enable *** adi,gc-dig-gain-enable
    800, //gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh //800
    704, //gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh //704
    24, //gc_low_power_thresh *** adi,gc-low-power-thresh
    15, //gc_max_dig_gain *** adi,gc-max-dig-gain
    /* Gain MGC Control */
    2, //mgc_dec_gain_step *** adi,mgc-dec-gain-step
    2, //mgc_inc_gain_step *** adi,mgc-inc-gain-step
    0, //mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable
    0, //mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable
    0, //mgc_split_table_ctrl_inp_gain_mode *** adi,mgc-split-table-ctrl-inp-gain-mode
    /* Gain AGC Control */
    10, //agc_adc_large_overload_exceed_counter *** adi,agc-adc-large-overload-exceed-counter
    2, //agc_adc_large_overload_inc_steps *** adi,agc-adc-large-overload-inc-steps
    0, //agc_adc_lmt_small_overload_prevent_gain_inc_enable *** adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable
    10, //agc_adc_small_overload_exceed_counter *** adi,agc-adc-small-overload-exceed-counter
    4, //agc_dig_gain_step_size *** adi,agc-dig-gain-step-size
    3, //agc_dig_saturation_exceed_counter *** adi,agc-dig-saturation-exceed-counter
    1000, // agc_gain_update_interval_us *** adi,agc-gain-update-interval-us
    0, //agc_immed_gain_change_if_large_adc_overload_enable *** adi,agc-immed-gain-change-if-large-adc-overload-enable
    0, //agc_immed_gain_change_if_large_lmt_overload_enable *** adi,agc-immed-gain-change-if-large-lmt-overload-enable
    10, //agc_inner_thresh_high *** adi,agc-inner-thresh-high 10
    1, //agc_inner_thresh_high_dec_steps *** adi,agc-inner-thresh-high-dec-steps
    12, //agc_inner_thresh_low *** adi,agc-inner-thresh-low 12
    1, //agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps
    10, //agc_lmt_overload_large_exceed_counter *** adi,agc-lmt-overload-large-exceed-counter
    2, //agc_lmt_overload_large_inc_steps *** adi,agc-lmt-overload-large-inc-steps
    10, //agc_lmt_overload_small_exceed_counter *** adi,agc-lmt-overload-small-exceed-counter
    5, //agc_outer_thresh_high *** adi,agc-outer-thresh-high 5
    2, //agc_outer_thresh_high_dec_steps *** adi,agc-outer-thresh-high-dec-steps
    18, //agc_outer_thresh_low *** adi,agc-outer-thresh-low 18
    2, //agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps
    1, //agc_attack_delay_extra_margin_us; *** adi,agc-attack-delay-extra-margin-us
    0, //agc_sync_for_gain_counter_enable *** adi,agc-sync-for-gain-counter-enable
    /* Fast AGC */
    64, //fagc_dec_pow_measuremnt_duration *** adi,fagc-dec-pow-measurement-duration
    260, //fagc_state_wait_time_ns *** adi,fagc-state-wait-time-ns
    /* Fast AGC - Low Power */
    0, //fagc_allow_agc_gain_increase *** adi,fagc-allow-agc-gain-increase-enable
    5, //fagc_lp_thresh_increment_time *** adi,fagc-lp-thresh-increment-time
    1, //fagc_lp_thresh_increment_steps *** adi,fagc-lp-thresh-increment-steps
    /* Fast AGC - Lock Level (Lock Level is set via slow AGC inner high threshold) */
    1, //fagc_lock_level_lmt_gain_increase_en *** adi,fagc-lock-level-lmt-gain-increase-enable
    5, //fagc_lock_level_gain_increase_upper_limit *** adi,fagc-lock-level-gain-increase-upper-limit
    /* Fast AGC - Peak Detectors and Final Settling */
    1, //fagc_lpf_final_settling_steps *** adi,fagc-lpf-final-settling-steps
    1, //fagc_lmt_final_settling_steps *** adi,fagc-lmt-final-settling-steps
    3, //fagc_final_overrange_count *** adi,fagc-final-overrange-count
    /* Fast AGC - Final Power Test */
    0, //fagc_gain_increase_after_gain_lock_en *** adi,fagc-gain-increase-after-gain-lock-enable
    /* Fast AGC - Unlocking the Gain */
    0, //fagc_gain_index_type_after_exit_rx_mode *** adi,fagc-gain-index-type-after-exit-rx-mode
    1, //fagc_use_last_lock_level_for_set_gain_en *** adi,fagc-use-last-lock-level-for-set-gain-enable
    1, //fagc_rst_gla_stronger_sig_thresh_exceeded_en *** adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable
    5, //fagc_optimized_gain_offset *** adi,fagc-optimized-gain-offset
    10, //fagc_rst_gla_stronger_sig_thresh_above_ll *** adi,fagc-rst-gla-stronger-sig-thresh-above-ll
    1, //fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en *** adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable
    1, //fagc_rst_gla_engergy_lost_goto_optim_gain_en *** adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable
    10, //fagc_rst_gla_engergy_lost_sig_thresh_below_ll *** adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll
    8, //fagc_energy_lost_stronger_sig_gain_lock_exit_cnt *** adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt
    1, //fagc_rst_gla_large_adc_overload_en *** adi,fagc-rst-gla-large-adc-overload-enable
    1, //fagc_rst_gla_large_lmt_overload_en *** adi,fagc-rst-gla-large-lmt-overload-enable
    0, //fagc_rst_gla_en_agc_pulled_high_en *** adi,fagc-rst-gla-en-agc-pulled-high-enable
    0, //fagc_rst_gla_if_en_agc_pulled_high_mode *** adi,fagc-rst-gla-if-en-agc-pulled-high-mode
    64, //fagc_power_measurement_duration_in_state5 *** adi,fagc-power-measurement-duration-in-state5
    /* RSSI Control */
    1, //rssi_delay *** adi,rssi-delay
    1000, //rssi_duration *** adi,rssi-duration
    3, //rssi_restart_mode *** adi,rssi-restart-mode
    0, //rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable
    1, //rssi_wait *** adi,rssi-wait
    /* Aux ADC Control */
    256, //aux_adc_decimation *** adi,aux-adc-decimation
    40000000UL, //aux_adc_rate *** adi,aux-adc-rate
    /* AuxDAC Control */
    1, //aux_dac_manual_mode_enable *** adi,aux-dac-manual-mode-enable
    0, //aux_dac1_default_value_mV *** adi,aux-dac1-default-value-mV
    0, //aux_dac1_active_in_rx_enable *** adi,aux-dac1-active-in-rx-enable
    0, //aux_dac1_active_in_tx_enable *** adi,aux-dac1-active-in-tx-enable
    0, //aux_dac1_active_in_alert_enable *** adi,aux-dac1-active-in-alert-enable
    0, //aux_dac1_rx_delay_us *** adi,aux-dac1-rx-delay-us
    0, //aux_dac1_tx_delay_us *** adi,aux-dac1-tx-delay-us
    0, //aux_dac2_default_value_mV *** adi,aux-dac2-default-value-mV
    0, //aux_dac2_active_in_rx_enable *** adi,aux-dac2-active-in-rx-enable
    0, //aux_dac2_active_in_tx_enable *** adi,aux-dac2-active-in-tx-enable
    0, //aux_dac2_active_in_alert_enable *** adi,aux-dac2-active-in-alert-enable
    0, //aux_dac2_rx_delay_us *** adi,aux-dac2-rx-delay-us
    0, //aux_dac2_tx_delay_us *** adi,aux-dac2-tx-delay-us
    /* Temperature Sensor Control */
    256, //temp_sense_decimation *** adi,temp-sense-decimation
    1000, //temp_sense_measurement_interval_ms *** adi,temp-sense-measurement-interval-ms
    0xCE, //temp_sense_offset_signed *** adi,temp-sense-offset-signed
    1, //temp_sense_periodic_measurement_enable *** adi,temp-sense-periodic-measurement-enable
    /* Control Out Setup */
    0xFF, //ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask
    0, //ctrl_outs_index *** adi,ctrl-outs-index
    /* External LNA Control */
    0, //elna_settling_delay_ns *** adi,elna-settling-delay-ns
    0, //elna_gain_mdB *** adi,elna-gain-mdB
    0, //elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB
    0, //elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable
    0, //elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable
    0, //elna_gaintable_all_index_enable *** adi,elna-gaintable-all-index-enable
    /* Digital Interface Control */
    0, //digital_interface_tune_skip_mode *** adi,digital-interface-tune-skip-mode
    0, //digital_interface_tune_fir_disable *** adi,digital-interface-tune-fir-disable
    1, //pp_tx_swap_enable *** adi,pp-tx-swap-enable
    1, //pp_rx_swap_enable *** adi,pp-rx-swap-enable
    0, //tx_channel_swap_enable *** adi,tx-channel-swap-enable
    0, //rx_channel_swap_enable *** adi,rx-channel-swap-enable
    1, //rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable
    0, //two_t_two_r_timing_enable *** adi,2t2r-timing-enable
    0, //invert_data_bus_enable *** adi,invert-data-bus-enable
    0, //invert_data_clk_enable *** adi,invert-data-clk-enable
    0, //fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable
    0, //invert_rx_frame_enable *** adi,invert-rx-frame-enable
    0, //fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable
    0, //swap_ports_enable *** adi,swap-ports-enable
    0, //single_data_rate_enable *** adi,single-data-rate-enable
    1, //lvds_mode_enable *** adi,lvds-mode-enable
    0, //half_duplex_mode_enable *** adi,half-duplex-mode-enable
    0, //single_port_mode_enable *** adi,single-port-mode-enable
    0, //full_port_enable *** adi,full-port-enable
    0, //full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable
    0, //delay_rx_data *** adi,delay-rx-data
    0, //rx_data_clock_delay *** adi,rx-data-clock-delay
    15, //rx_data_delay *** adi,rx-data-delay
    0, //tx_fb_clock_delay *** adi,tx-fb-clock-delay
    0, //tx_data_delay *** adi,tx-data-delay
    #ifdef ALTERA_PLATFORM
    300, //lvds_bias_mV *** adi,lvds-bias-mV
    #else
    150, //lvds_bias_mV *** adi,lvds-bias-mV
    #endif
    1, //lvds_rx_onchip_termination_enable *** adi,lvds-rx-onchip-termination-enable
    0, //rx1rx2_phase_inversion_en *** adi,rx1-rx2-phase-inversion-enable
    0xFF, //lvds_invert1_control *** adi,lvds-invert1-control
    0x0F, //lvds_invert2_control *** adi,lvds-invert2-control
    /* GPO Control */
    0, //gpo0_inactive_state_high_enable *** adi,gpo0-inactive-state-high-enable
    0, //gpo1_inactive_state_high_enable *** adi,gpo1-inactive-state-high-enable
    0, //gpo2_inactive_state_high_enable *** adi,gpo2-inactive-state-high-enable
    0, //gpo3_inactive_state_high_enable *** adi,gpo3-inactive-state-high-enable
    0, //gpo0_slave_rx_enable *** adi,gpo0-slave-rx-enable
    0, //gpo0_slave_tx_enable *** adi,gpo0-slave-tx-enable
    0, //gpo1_slave_rx_enable *** adi,gpo1-slave-rx-enable
    0, //gpo1_slave_tx_enable *** adi,gpo1-slave-tx-enable
    0, //gpo2_slave_rx_enable *** adi,gpo2-slave-rx-enable
    0, //gpo2_slave_tx_enable *** adi,gpo2-slave-tx-enable
    0, //gpo3_slave_rx_enable *** adi,gpo3-slave-rx-enable
    0, //gpo3_slave_tx_enable *** adi,gpo3-slave-tx-enable
    0, //gpo0_rx_delay_us *** adi,gpo0-rx-delay-us
    0, //gpo0_tx_delay_us *** adi,gpo0-tx-delay-us
    0, //gpo1_rx_delay_us *** adi,gpo1-rx-delay-us
    0, //gpo1_tx_delay_us *** adi,gpo1-tx-delay-us
    0, //gpo2_rx_delay_us *** adi,gpo2-rx-delay-us
    0, //gpo2_tx_delay_us *** adi,gpo2-tx-delay-us
    0, //gpo3_rx_delay_us *** adi,gpo3-rx-delay-us
    0, //gpo3_tx_delay_us *** adi,gpo3-tx-delay-us
    /* Tx Monitor Control */
    37000, //low_high_gain_threshold_mdB *** adi,txmon-low-high-thresh
    0, //low_gain_dB *** adi,txmon-low-gain
    24, //high_gain_dB *** adi,txmon-high-gain
    0, //tx_mon_track_en *** adi,txmon-dc-tracking-enable
    0, //one_shot_mode_en *** adi,txmon-one-shot-mode-enable
    511, //tx_mon_delay *** adi,txmon-delay
    8192, //tx_mon_duration *** adi,txmon-duration
    2, //tx1_mon_front_end_gain *** adi,txmon-1-front-end-gain
    2, //tx2_mon_front_end_gain *** adi,txmon-2-front-end-gain
    48, //tx1_mon_lo_cm *** adi,txmon-1-lo-cm
    48, //tx2_mon_lo_cm *** adi,txmon-2-lo-cm
    /* GPIO definitions */
    -1, //gpio_resetb *** reset-gpios
    /* MCS Sync */
    -1, //gpio_sync *** sync-gpios
    -1, //gpio_cal_sw1 *** cal-sw1-gpios
    -1, //gpio_cal_sw2 *** cal-sw2-gpios
    /* External LO clocks */
    NULL, //(*ad9361_rfpll_ext_recalc_rate)()
    NULL, //(*ad9361_rfpll_ext_round_rate)()
    NULL //(*ad9361_rfpll_ext_set_rate)()
    AD9361_RXFIRConfig rx_fir_config = {
    3, // rx
    -6, // rx_gain
    1, // rx_dec
    {23,-105,-218,-507,-661,-705,-416,26,471,573,271,-309,-726,-644,-5,764,1075,553,-547,-1453,-1350,-76,1615,2398,1335,-1288,-3791,-3941,-347,6440,13907,18778,18778,13907,6440,-347,-3941,-3791,-1288,1335,2398,1615,-76,-1350,-1453,-547,553,1075,764,-5,-644,-726,-309,271,573,471,26,-416,-705,-661,-507,-218,-105,23,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, // rx_coef[128]
    64, // rx_coef_size
    //{0, 0, 0, 0, 0, 0},
    {975360000,243840000,121920000,60960000,30480000,30480000}, // rx_path_clks[6]
    11000000 // rx_bandwidth
    //0
    AD9361_TXFIRConfig tx_fir_config = {
    3, // tx
    -6, // tx_gain
    1, // tx_int
    {17,-67,-174,-401,-568,-619,-407,-17,388,523,277,-239,-651,-614,-55,672,1003,561,-460,-1342,-1297,-123,1488,2275,1301,-1194,-3605,-3756,-268,6346,13642,18408,18408,13642,6346,-268,-3756,-3605,-1194,1301,2275,1488,-123,-1297,-1342,-460,561,1003,672,-55,-614,-651,-239,277,523,388,-17,-407,-619,-568,-401,-174,-67,17,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, // tx_coef[128]
    64, // tx_coef_size
    {975360000,121920000,60960000,30480000,30480000,30480000}, // tx_path_clks[6]
    11000000 // tx_bandwidth
    //0
    Please try this settings at your end and suggest me some work around.
    on Oct 19, 2020 11:40 AM 1 month ago in reply to Chuppa
    Can you share with us the filter file that you have generated from filter wizard in IIO format so that I can directly load it into the GUI and check? Hope you have directly loaded the generated file without modifying any parameter inside it.
