I am searching to use the AD9361 with a multichannels (3 or 5) signal; the whole band is 18 MHz at central frequency 125 MHz. Each channels are 25 kHz.
I have to demultiplex this signal... Have you a idea?
thanks
thanks
How are you generating this signal?
AD9361 can support a signal with 18MHz bandwidth, The different channel separations and modulations needs to be done in baseband,
thanks Vinod
No I am receiving this signal.
So the treatments should be done in Baseband processing unit. Have you some idea of a board able to connect easily with the AD9361?
Sorry if the questions are basics, I come from the analog, microwaves world...
Thanks again
For our evaluation boards we support below FPGA platforms.
https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/prerequisites
