Hi all,
In the ADRV9029 System Development User Guide_DPDCFRCLGC_v1, there are two options for configuring path delay in step 4.
Either by launching the adi_adrv9025_InitCalsRun command, or to set them by adi_adrv9025_ExternalPathDelaySet() and adi_adrv9025_ClgcExternalPathDelaySet() commands, if parameters are already known.
So I made two scripts to run steps 1 to 17, the first with calibration and the second with setting parameters.
With the first version, everything is functional (CFR, DPD, CLGC).
With the second version, the fifo and interpolation parameters seem programmed but at the end of step 17, the DPD is not functional or disabled..
Here is an extract from the script for step 4
def runExtPathDelaySet(txCh,fifo,interpol): extPathDelay = Types.adi_adrv9010_ExternalPathDelay_t() extPathDelay.fifoDelay = fifo extPathDelay.interpolationIndex = interpol retVal = link.platform.board.Adrv9010Device.Cals.ExternalPathDelaySet(txCh, extPathDelay) print "retval", retVal def getExtPathDelay(txCh): extPathDelay = Types.adi_adrv9010_ExternalPathDelay_t() retVal = link.platform.board.Adrv9010Device.Cals.ExternalPathDelayGet(txCh, extPathDelay) extPathDelay = retVal[1] print "fifoDelay:",extPathDelay.fifoDelay print "interpolationIndex:", extPathDelay.interpolationIndex def runClgcExtPathDelaySet(txCh,fifo,interpol): extPathDelay = Types.adi_adrv9010_ExternalPathDelay_t() extPathDelay.fifoDelay = fifo extPathDelay.interpolationIndex = interpol retVal = link.platform.board.Adrv9010Device.Cals.ClgcExternalPathDelaySet(txCh, extPathDelay) def getClgcExtPathDelay(txCh): extPathDelay = Types.adi_adrv9010_ExternalPathDelay_t() retVal = link.platform.board.Adrv9010Device.Cals.ClgcExternalPathDelayGet(txCh, extPathDelay) extPathDelay = retVal[1] print "fifoDelay:",extPathDelay.fifoDelay print "interpolationIndex:", extPathDelay.interpolationIndex
print"***************************************" print " Step 4 : Set Path delay " print"***************************************" TxChannel = Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3 fifoDelay = 120 interpolationIndex = 10 runExtPathDelaySet(TxChannel,fifoDelay,interpolationIndex) runClgcExtPathDelaySet(TxChannel,fifoDelay,interpolationIndex) time.sleep(1) getExtPathDelay(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3) getClgcExtPathDelay(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3)
Is there another command to launch for enabling the DPD ?
Thanks.
