ADRV9025 initcal error related questions
I created the initdata.c file by selecting usecase51_NLS in the ADRV9025 GUI.
During operation, an error occurs in the initcal, but even if the external VSWR is improved, the initcal does not operate normally.
Below is the message that appears during booting, and the error occurred as shown below.
[A] adi_adrv9025_HwOpen(...)
[A] adi_adrv9025_HwReset(...)
[A] adi_adrv9025_SpiCfgSet(...)
[A] adi_adrv9025_SpiVerify(...)
[A] adi_adrv9025_PreMcsInit_v2(...)
[A] adi_adrv9025_Initialize(...)
[A] adrv9025_MasterBiasSet(...)
[A] adrv9025_PadConfigsSet(...)
[A] adi_adrv9025_ProfilesVerify(...)
[A] adi_adrv9025_StreamImageLoad(...)
[A] adi_adrv9025_CpuImageLoad(...)
[A] adrv9025_CpuStackPtrWrite(...)
[A] adrv9025_CpuBootAddrWrite(...)
[A] adi_adrv9025_CpuAdcProfilesWrite(...)
[A] adi_adrv9025_CpuProfileWrite(...)
[A] adi_adrv9025_CpuStart(...)
[A] adi_adrv9025_PreMcsInit_NonBroadCast(...)
[A] adi_adrv9025_CpuStartStatusCheck(...)
[A] adi_adrv9025_CpuChecksumTableGet(...)
[A] adi_adrv9025_CpuMemRead(...)
[A] adi_adrv9025_DeviceRevGet(...)
[A] adi_adrv9025_ProductIdGet(...)
[A] adi_adrv9025_TxAttenCfgSet(...)
[A] adi_adrv9025_TxAttenModeSet(...)
[A] adrv9025_TxAttenUpdateGpioPinCtrlCfgSet(...)
[A] adrv9025_TxAttenPinCtrlCfgSet(...)
[A] adi_adrv9025_TxAttenSet(...)
[A] adi_adrv9025_TxAttenuationRampUpStickyModeEnable(...)
[A] adi_adrv9025_DacFullScaleSet(...)
[A] adi_adrv9025_MultichipSyncSet(...)
[A] adi_adrv9025_MultichipSyncStatusGet(...)
[A] adi_adrv9025_PllLoopFilterSet(...)
[A] adi_adrv9025_PllLoopFilterSetRangeCheck(...)
[A] adi_adrv9025_PostMcsInit(...)
[A] adi_adrv9025_RxTxEnableSet(...)
[A] adi_adrv9025_RadioCtrlCfgSet(...)
[A] adi_adrv9025_PllFrequencySet(...)
[A] adi_adrv9025_InitCalsCheckCompleteGet(...)
[A] adi_adrv9025_TxToOrxMappingSet(...)
[A] adi_adrv9025_StreamGpioConfigSet(...)
[A] adi_adrv9025_InitCalsRun(...)
[A] adrv9025_InitCalStructureCheck(...)
[A] adi_adrv9025_InitCalsWait(...)
[E] Error number  3 (0x00000003), Recovery action -2.In file adi_adrv9025_cpu.c, in function adi_adrv9025_CpuCmdStatusWait, in line  1055, variable name device.Error message CpuCmdStatusWait() failed due to thrown CPU error. Is device in correct state for calling command?.
[A] adi_common_ErrorClear(...)
[E] Error number  131086 (0x0002000e), Recovery action -3.In file adrv9025_cpu.c, in function adrv9025_CpuCmdErrorHandler, in line  2503, variable name detErr.Error message ADRV9025 CPU Command Error
[E] Error number  3 (0x00000003), Recovery action -3.In file adrv9025_cpu.c, in function adrv9025_CpuCmdErrorHandler, in line  2515, variable name mailboxErrCode.Error message TXBBF:Calibration results are invalid.
[E] Error number  3 (0x00000003), Recovery action -3.In file adi_adrv9025_utilities.c, in function adi_adrv9025_PostMcsInit, in line  2052, variable name ((void *)0).Error message TXBBF:Calibration results are invalid.
The above error message is the content tested by setting the calMask bit to 1.
Table71 of the UG1727 document lists the calMask bit.
The part where the error occurs is D12: TX QEC, D0: TX BB Filter, D18: ORX QEC.
If the calmask bit of the part where the error occurs is set to 0 and executed, initcal is executed.
In this case, the PLL lock is also normal, and the signal level is abnormal because the initcal is not normally performed when loopback to RX->TX, but the signal output is in a state.
Please advise me which part is the problem with the above error.
