D3 LED does NOT go OFF
I have the ADRV9026 MB MATCH board connected to the ADS9-V2EBZ board connected as per the User Guide.
The steps were followed as described in the User Guide. The red LED D3 does NOT go OFF. It is always ON. The TRX MICROSD card is used. The S1 switch is in the OFF position.
The logs from the boot up is attached below. Is there a way to reset the software on the ADS9 board to fix this problem? Could the update device caused a problem with firmware ?
Welcome to Ubuntu 15.04!
Cannot add dependency job for unit org.freedesktop.resolve1.busname, ignoring: Unit org.freedesktop.resolve1.busname failed to load: No such file or directory.
Cannot add dependency job for unit cups.service, ignoring: Unit cups.service failed to load: No such file or directory.
[ OK ] Reached target Encrypted Volumes.
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Swap.
[ OK ] Created slice Root Slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Listening on Journal Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Created slice System Slice.
Starting Create list of required st... nodes for the current kernel...
[ OK ] Created slice system-getty.slice.
Starting Nameserver information manager...
[ OK ] Started Boot Process Profiler.
Starting Boot Process Profiler...
Starting Load Kernel Modules...
[ OK ] Reached target Slices.
[ OK ] Started Braille Device Support.
Starting Braille Device Support...
Starting Remount Root and Kernel File Systems...
Starting Increase datagram queue length...
[ OK ] Started Read required files in advance.
Starting Read required files in advance...
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
Mounting Temporary Directory...
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on networkd rtnetlink socket.
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Setup Virtual Console...
[ OK ] Listening on Journal Socket (/dev/log).
Starting udev Coldplug all Devices...
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
systemd-bootchart.service failed.
[FAILED] Failed to start Load Kernel Modules.
See "systemctl status systemd-modules-load.service" for details.
systemd-modules-load.service failed.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Increase datagram queue length.
ureadahead.service failed.
[ OK ] Mounted Temporary Directory.
[ OK ] Started Nameserver information manager.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Listening on Syslog Socket.
Starting Journal Service...
Starting Load/Save Random Seed...
Starting Apply Kernel Variables...
Mounting Configuration File System...
Starting Create Static Device Nodes in /dev...
[ OK ] Started Load/Save Random Seed.
[ OK ] Mounted Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Journal Service.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
[ OK ] Reached target Remote File Systems.
Starting Set console keymap...
Starting Tell Plymouth To Write Out Runtime Data...
Starting Wait for all "auto" /etc/n... up for network-online.target...
Starting Flush Journal to Persistent Storage...
Starting LSB: Raise network interfaces....
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
Starting Copy rules generated while the root was ro...
[ OK ] Reached target Paths.
[ OK ] Started Set console keymap.
[ OK ] Started Copy rules generated while the root was ro.
[ OK ] Found device /dev/ttyPS0.
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Created slice system-ifup.slice.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started ifup for eth0.
Starting ifup for eth0...
[ OK ] Started Network Time Synchronization.
[ OK ] Started ifup for sit0.
Starting ifup for sit0...
[ OK ] Reached target System Time Synchronized.
[ OK ] Started LSB: Raise network interfaces..
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on OpenBSD Secure Shell server socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting D-Bus System Message Bus...
[ OK ] Started Cgroup management daemon.
Starting Cgroup management daemon...
Starting LSB: Platform initscript...
[ OK ] Reached target Containers.
Running Platform Init
Starting LSB: automatic crash report generation...
Starting Enable support for additional executable binary formats...
Starting Restore /etc/resolv.conf i...e the ppp link was shut down....
Starting LSB: Speech Dispatcher...
Starting Accounts Service...
Starting Avahi mDNS/DNS-SD Stack...
Starting Network Manager...
Starting System Logging Service...
Starting Provide limited super user privileges to specific users...
Starting Permit User Sessions...
[ OK ] Started Run anacron jobs.
Starting Run anacron jobs...
Starting Initialize hardware monitoring sensors...
Starting Login Service...
Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Starting LSB: Set the CPU Frequency Scaling governor to "ondemand"...
[ OK ] Started Regular background program processing daemon.
Starting Regular background program processing daemon...
Starting WPA supplicant...
Starting LSB: Xen daemons...
[ OK ] Started System Logging Service.
[ OK ] Started Wait for all "auto" /etc/ne...be up for network-online.target.
[ OK ] Started D-Bus System Message Bus.
Programming Motherboard FPGA
[ OK ] Started WPA supplicant.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started Enable support for additional executable binary formats.
[ OK ] Started Restore /etc/resolv.conf if...ore the ppp link was shut down..
[ OK ] Started LSB: Speech Dispatcher.
[ OK ] Started Provide limited super user privileges to specific users.
[ OK ] Started Permit User Sessions.
[ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[ OK ] Started LSB: Set the CPU Frequency Scaling governor to "ondemand".
[ OK ] Started LSB: Xen daemons.
[ OK ] Started Initialize hardware monitoring sensors.
[ OK ] Started Login Service.
Starting Authenticate and Authorize Users to Run Privileged Tasks...
Starting LSB: Start/stop secondary xen domains...
Starting LSB: set CPUFreq kernel parameters...
Starting Light Display Manager...
[ OK ] Started Make remote CUPS printers available locally.
Starting Make remote CUPS printers available locally...
Starting Network Service...
[ OK ] Started LSB: set CPUFreq kernel parameters.
[ OK ] Started Network Service.
[ OK ] Started LSB: Start/stop secondary xen domains.
[ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks.
[ OK ] Started Accounts Service.
[ OK ] Started Network Manager.
[ OK ] Started Light Display Manager.
Starting Network Manager Wait Online...
Starting Network Name Resolution...
[ OK ] Reached target Network.
Starting /etc/rc.local Compatibility...
[ OK ] Started Network Name Resolution.
[ OK ] Started Network Manager Wait Online.
[ OK ] Reached target Network is Online.
Starting LSB: start Samba NetBIOS nameserver (nmbd)...
Starting LSB: simple distributed compiler server...
Starting LSB: Tool to automatically...ubmit kernel crash signatures...
Starting LSB: start Samba daemons for the AD DC...
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started LSB: simple distributed compiler server.
Starting Wait for Plymouth Boot Screen to Quit...
[ OK ] Started Wait for Plymouth Boot Screen to Quit.
[ OK ] Started Serial Getty on ttyPS0.
Starting Serial Getty on ttyPS0...
[ OK ] Started Getty on tty1.
Starting Getty on tty1...
[ OK ] Reached target Login Prompts.
[ OK ] Started LSB: Tool to automatically ... submit kernel crash signatures.
[ OK ] Stopped Light Display Manager.
[ OK ] Started LSB: start Samba daemons for the AD DC.
[ OK ] Started LSB: start Samba NetBIOS nameserver (nmbd).
Starting LSB: start Samba SMB/CIFS daemon (smbd)...
Ubuntu 15.04 analog ttyPS0
analog login: root (automatic login)
Last login: Tue Jun 13 01:16:39 UTC 2017 on ttyPS0
