What information should I provide to help speed resolution of my issue?
While posting a query what details are required to provide fast and accurate response. Will provide steps to recreate the issue on Evaluation board help. ?
    on Nov 22, 2019 7:02 AM over 1 year ago
    Please provide as much detail as possible including all of the detail described in the table below
    Item
    Detail
    Comments
    Issue Summary
    Issue Details
    Provide any associated plots, screen captures, etc that will help ADI to understand the issue
    Workaround (if applicable)
    Describe any workaround you have found
    Sequence to reproduce issue
    Describe sequence that causes issue to occur
    Repeatability
    Does the issue occur all of the time or occasionally. If occasionally describe how often
    No. parts affected
    Does the issue occur on all parts or a sub-set of parts. If a sub-set, how many and what percentage?
    Use Case Details
    RF LO Frequency, Use Case No. TDD/FDD timing details
    Software Version(s)
    Detail software versions (API, Firmware and Stream versions) that show the issue
    API Log
    Attach API log if applicable
