ADRV9009 DAC (TX) output Issues
Product Number: ADRV9009
Software Version: Vivado 2018.3
Hi Team,
              We are using a custom ADRV9009 with evaluation ZCU102. In custom ADRV9009 design has HMC7044 PLL clock source instead of AD9528 PLL. The ADRV9009 initializations are done and the no-os prints are as expected.
 But we observed that the DAC output of ADRV9009 contains LO leakage issues. The DAC outputs of ADRV9009 contain LO, fm+LO , fm-LO frequencies. Let's say, ADRV9009 LO is tuned to 2.5GHz and we are providing 1MHz offset from DDS then the DAC output has 2499MHz, 2500MHz and 2501MHz frequencies.
 When we are used TALISE_enableTxNCO() API, we observed only LO+fm frequency. But as per TALISE_enableTxNCO() API is used,  fm+LO and fm-LO frequencies are present.
When we are used ADI DDS from SDK, we observed fm+LO and fm-LO frequencies in the DAC output.
What could be the reason for fm-LO (Image frequency) in he DAC output of ADRV9009 ?
Here I'm attaching the no-os prints:
Thanks in Advance
Goli Ganesh
