Run initialization calibrations Error,use external LO, 9008-2
I use 9008-2 on my custom board, Use no-os driver,API version is 3.6.0.5,When I use internal Lo,in "talise_config.c" file , I set parameter "rfPllUseExternalLo = 0", means using internal LO, Then, According to the Reference Manual initialization sequence, config 9008, it can pass initialization calibrations.
When I set parameter "rfPllUseExternalLo = 1"  in "talise_config.c" file , means using external LO, and, input the LO signal to the RF_EXT_LO_I/O pin,the input signal is 2× the desired LO,Then, run the program;
When I call the API : "TALISE_runInitCals(talDev, initCalMask & ~TAL_TX_LO_LEAKAGE_EXTERNAL);", Then, call "TALISE_waitInitCals(talDev, 20000, &errorFlag);" API, wait Cals, but  this function return 5, and errorFlag is 0, I entered the function and found that this error refers to "TALACT_ERR_RESET_ARM"error, I do not know why this is so? Is this a software problem or a hardware problem?
The following codes are part of my configuration file and initialization process code, and part of the hardware schematic diagram of TX and ORX. :
talise_config.c:
taliseInit_t talInit_tx =
	/* SPI settings */
    .spiSettings =
		.MSBFirst            = 1,  /* 1 = MSBFirst, 0 = LSBFirst */
		.enSpiStreaming      = 0,  /* Not implemented in ADIs platform layer. SW feature to improve SPI throughput */
		.autoIncAddrUp       = 1,  /* Not implemented in ADIs platform layer. For SPI Streaming, set address increment direction. 1= next addr = addr+1, 0:addr=addr-1 */
		.fourWireMode        = 1,  /* 1: Use 4-wire SPI, 0: 3-wire SPI (SDIO pin is bidirectional). NOTE: ADI's FPGA platform always uses 4-wire mode */
		.cmosPadDrvStrength  = TAL_CMOSPAD_DRV_2X /* Drive strength of CMOS pads when used as outputs (SDIO, SDO, GP_INTERRUPT, GPIO 1, GPIO 0) */
    /* Tx settings */
    .tx =
        .txProfile =
            .dacDiv = 1,                        /* The divider used to generate the DAC clock */
            .txFir =
                .gain_dB = 6,                        /* filter gain */
                .numFirCoefs = 40,                    /* number of coefficients in the FIR filter */
                .coefs = &txFirCoefs[0]
            .txFirInterpolation = 1,                    /* The Tx digital FIR filter interpolation (1,2,4) */
            .thb1Interpolation = 2,                    /* Tx Halfband1 filter interpolation (1,2) */
            .thb2Interpolation = 2,                    /* Tx Halfband2 filter interpolation (1,2)*/
            .thb3Interpolation = 2,                    /* Tx Halfband3 filter interpolation (1,2)*/
            .txInt5Interpolation = 1,                    /* Tx Int5 filter interpolation (1,5) */
            .txInputRate_kHz = 245760,                    /* Primary Signal BW */
            .primarySigBandwidth_Hz = 100000000,    /* The Rx RF passband bandwidth for the profile */
            .rfBandwidth_Hz = 225000000,            /* The Tx RF passband bandwidth for the profile */
            .txDac3dBCorner_kHz = 225000,                /* The DAC filter 3dB corner in kHz */
            .txBbf3dBCorner_kHz = 113000,                /* The BBF 3dB corner in kHz */
            .loopBackAdcProfile = {212, 140, 175, 90, 1280, 699, 1304, 59, 1343, 33, 913, 27, 48, 48, 34, 192, 0, 0, 0, 0, 48, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905}
        .deframerSel = TAL_DEFRAMER_A,                    /* Talise JESD204b deframer config for the Tx data path */
        .txChannels = TAL_TX1,                            /* The desired Tx channels to enable during initialization */
        .txAttenStepSize = TAL_TXATTEN_0P05_DB,            /* Tx Attenuation step size */
        .tx1Atten_mdB = 5000,                            /* Initial Tx1 Attenuation */
        .tx2Atten_mdB = 0,                            /* Initial Tx2 Attenuation */
        .disTxDataIfPllUnlock = TAL_TXDIS_TX_RAMP_DOWN_TO_ZERO    /* Options to disable the transmit data when the RFPLL unlocks. */
    /* ObsRx settings */
    .obsRx =
        .orxProfile =
            .rxFir =
                .numFirCoefs = 24,            /* number of coefficients in the FIR filter */
                .coefs = &obsrxFirCoefs[0]
            .rxFirDecimation = 1,            /* Rx FIR decimation (1,2,4) */
            .rxDec5Decimation = 4,            /* Decimation of Dec5 or Dec4 filter (5,4) */
            .rhb1Decimation = 2,            /* RX Half band 1 decimation (1 or 2) */
            .orxOutputRate_kHz = 245760,            /* Rx IQ data rate in kHz */
            .rfBandwidth_Hz = 200000000,    /* The Rx RF passband bandwidth for the profile */
            .rxBbf3dBCorner_kHz = 225000,    /* Rx BBF 3dB corner in kHz */
            .orxLowPassAdcProfile = {185, 141, 172, 90, 1280, 942, 1332, 90, 1368, 46, 1016, 19, 48, 48, 37, 208, 0, 0, 0, 0, 52, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},
            .orxBandPassAdcProfile = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
            .orxDdcMode = TAL_ORXDDC_DISABLED,   /* ORx DDC mode */
            .orxMergeFilter  = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
        .orxGainCtrl =
            .gainMode = TAL_MGC,
            .orx1GainIndex = 255,
            .orx2GainIndex = 255,
            .orx1MaxGainIndex = 255,
            .orx1MinGainIndex = 195,
            .orx2MaxGainIndex = 255,
            .orx2MinGainIndex = 195
        .framerSel = TAL_FRAMER_A,                /* ObsRx JESD204b framer configuration */
        .obsRxChannelsEnable = TAL_ORX1,//TAL_ORXOFF,        /* The desired ObsRx Channels to enable during initialization */
        .obsRxLoSource = TAL_OBSLO_RF_PLL                /* The ORx mixers can use the TX_PLL */
    /* Digital Clock Settings */
    .clocks =
        .deviceClock_kHz = 122880,            /* CLKPLL and device reference clock frequency in kHz */
        .clkPllVcoFreq_kHz = 9830400,        /* CLKPLL VCO frequency in kHz */
        .clkPllHsDiv = TAL_HSDIV_2P5,            /* CLKPLL high speed clock divider */
        .rfPllUseExternalLo = 1,                /* 1= Use external LO for RF PLL, 0 = use internal LO generation for RF PLL */
        .rfPllPhaseSyncMode = TAL_RFPLLMCS_NOSYNC                /* RFPLL MCS (Phase sync) mode */
    /* JESD204B settings */
    .jesd204Settings =
        /* Framer A settings */
        .framerA =
            .bankId = 0,                    /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
            .deviceId = 0,                    /* JESD204B Configuration Device ID - link identification number. (Valid 0..255) */
            .lane0Id = 0,                    /* JESD204B Configuration starting Lane ID.  If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31) */
            .M = 2,                            /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
            .K = 32,                        /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes) */
            .F = 8,                            /* F (number of bytes per frame) */
            .Np = 16,                            /* Np (converter sample resolution) */
            .scramble = 1,                    /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled. */
            .externalSysref = 1,            /* 0=use internal SYSREF, 1= use external SYSREF */
            .serializerLanesEnabled = 0x01,    /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
            .serializerLaneCrossbar = 0xE4,    /* serializerLaneCrossbar */
            .lmfcOffset = 31,                /* lmfcOffset - LMFC offset value for deterministic latency setting */
            .newSysrefOnRelink = 0,            /* newSysrefOnRelink */
            .syncbInSelect = 0,                /* syncbInSelect; */
            .overSample = 0,                    /* 1=overSample, 0=bitRepeat */
            .syncbInLvdsMode = 1,
            .syncbInLvdsPnInvert = 0,
            .enableManualLaneXbar = 0 /* 0=auto, 1=manual */
        /* Framer B settings */
        .framerB =
            .F = 0,                            /* F (number of bytes per frame) */
            .serializerLanesEnabled = 0x0C,    /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
            .syncbInSelect = 1,                /* syncbInSelect; */
        /* Deframer A settings */
        .deframerA =
            .bankId = 0,                    /* bankId extension to Device ID (Valid 0..15) */
            .deviceId = 0,                    /* deviceId  link identification number. (Valid 0..255) */
            .lane0Id = 0,                    /* lane0Id Lane0 ID. (Valid 0..31) */
            .M = 2,                            /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
            .K = 32,                        /* K  #frames in a multiframe (default=32), F*K=multiple of 4. (F=2*M/numberOfLanes) */
            .scramble = 1,                    /* scramble  scrambling off if scramble= 0 */
            .externalSysref = 1,            /* externalSysref  0= use internal SYSREF, 1= external SYSREF */
            .deserializerLanesEnabled = 0x01,    /* deserializerLanesEnabled  bit per lane, [0] = Lane0 enabled */
            .deserializerLaneCrossbar = 0xE4,    /* deserializerLaneCrossbar */
            .lmfcOffset = 17,                /* lmfcOffset	 LMFC offset value to adjust deterministic latency */
            .newSysrefOnRelink = 1,            /* newSysrefOnRelink */
            .syncbOutSelect = 0,                /* SYNCBOUT0/1 select */
            .syncbOutLvdsMode = 1,
            .syncbOutLvdsPnInvert = 0,
            .syncbOutCmosSlewRate = 0,
            .syncbOutCmosDriveLevel = 0,
        /* Deframer B settings */
        .deframerB =
            .M = 0,                            /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
            .deserializerLanesEnabled = 0x00,    /* deserializerLanesEnabled  bit per lane, [0] = Lane0 enabled */
            .lmfcOffset = 0,                /* lmfcOffset	 LMFC offset value to adjust deterministic latency */
            .syncbOutSelect = 1,                /* SYNCBOUT0/1 select */
        .serAmplitude = 15,                    /* Serializer amplitude setting. Default = 15. Range is 0..15 */
        .serPreEmphasis = 1,                /* Serializer pre-emphasis setting. Default = 1 Range is 0..4 */
        .serInvertLanePolarity = 0,            /* Serializer Lane PN inversion select. Default = 0. Where, bit[0] = 1 will invert lane [0], bit[1] = 1 will invert lane 1, etc. */
        .desInvertLanePolarity = 0,            /* Deserializer Lane PN inversion select.  bit[0] = 1 Invert PN of Lane 0, bit[1] = Invert PN of Lane 1, etc */
        .desEqSetting = 1,                    /* Deserializer Equalizer setting. Applied to all deserializer lanes. Range is 0..4 */
        .sysrefLvdsMode = 1,                /* Use LVDS inputs on Talise for SYSREF */
        .sysrefLvdsPnInvert = 0              /*0= Do not PN invert SYSREF */
process .c
int ADRV9008_Init(taliseDevice_t *talDev)
	/*Open Talise Hw Device*/
	talAction = TALISE_openHw(talDev);
	if(talAction != TALACT_NO_ACTION) {
		return -1;
	/* Toggle RESETB pin on Talise device */
	talAction = TALISE_resetDevice(talDev);
	if (talAction != TALACT_NO_ACTION) {
		return -2;
	mdelay(100);
	talAction = TALISE_initialize(talDev,p_talInit);
		return -3;
	/***** CLKPLL Status Check *****/
	talAction = TALISE_getPllsLockStatus(talDev, &pllLockStatus);
		return -4;
	/* Assert that Talise CLKPLL is locked */
	if ((pllLockStatus & 0x01) == 0) {
		return -5;
    initCalMask = TAL_TX_BB_FILTER | TAL_ADC_TUNER | \
			TAL_TIA_3DB_CORNER | TAL_DC_OFFSET | TAL_FLASH_CAL | \
			TAL_PATH_DELAY | TAL_TX_LO_LEAKAGE_INTERNAL | TAL_TX_QEC_INIT \
			| TAL_LOOPBACK_RX_LO_DELAY | TAL_LOOPBACK_RX_RX_QEC_INIT | \
			TAL_ORX_QEC_INIT | TAL_TX_DAC;
	/**** Prepare Talise Arm binary and Load Arm and	****/
	/**** Stream processor Binaryes 					****/
	talAction = TALISE_initArm(talDev, p_talInit);
		return -7;
		talAction = TALISE_loadStreamFromBinary(talDev, &streamBinary[0]);
		/*** < User: decide what to do based on Talise recovery action returned > ***/
		return -8;
	talAction = TALISE_loadArmFromBinary(talDev, &armBinary[0], count);
		return -9;
	talAction = TALISE_verifyArmChecksum(talDev);
	if (talAction != TAL_ERR_OK) {
		return -10;
	/**Set RF PLL LO Frequencies ***/
	TALISE_setRfPllLoopFilter(talDev, 300, 3);
	talAction = TALISE_setRfPllFrequency(talDev, TAL_RF_PLL, 2000000000);
		return -12;
	mdelay(200);
	if ((pllLockStatus & 0x07) != 0x07) {
		return -13;
	/**** Run Talise ARM Initialization Calibrations ***/
	talAction = TALISE_runInitCals(talDev, initCalMask & ~TAL_TX_LO_LEAKAGE_EXTERNAL);
		return -14;
	while(1){
		talAction = TALISE_waitInitCals(talDev, 20000, &errorFlag);
		if(talAction == TALACT_NO_ACTION)
			break;
		talAction = TALISE_getInitCalStatus(talDev, &calsSincePowerUp, &calsLastRun, &calsMinimum, &initErrCal, &initErrCode);
schematic:
