adrv9009 calibration
I use adrv9009 with zcu102 no os library I can't understand some notions such as:
orxLowPassAdcProfile and orxBandPassAdcProfile
1- What exactly does this represent? and can you tell me what is their location in the diagram?
and regarding the calibration and tracking
2-how I can eliminate the TX LO LEAKAGE and ORx LO LEAKAGE?
3-how I can activate and deactivate the calibration?
knowing that I connected the tx path to Orx and  I use a 100MHz bandwidth tram with a sampling frequency of 491.52 MHz ( i use this profil https://github.com/analogdevicesinc/no-OS/tree/master/projects/adrv9009/profiles/tx_bw400_ir491p52_rx_bw200_or245p76_orx_bw400_or491p52_dc245p76 )
I'm looking forward to your answers.
Thanks.
    on Dec 9, 2020 12:26 PM 2 months ago
    It is not possible to eliminate the LOL completely as the transceiver uses a direct conversion type architecture. The LOL can be reduced by running the internal LOL init, external LOL init(which requires tx-orx feedback path) alongwith tracking cal.
    You can enable or disable the required TXLOL tracking cals using EnableTrackingCals() API in radio off state.
  • perfect ,
    Thank you for your prompt response,
    So in your opinion how I can do to correct the noise floor in my signal below?
    I mean what is the necessary calibration to eliminate this noise?
    I have already read recently that it comes from the adc sigma delta (but we lose 26 db), however you certainly have calluses to correct this noise,
    beacause  I will use that for the DPD.knowing that it represents ORx signal below ,and my tx  is placed on the ORx.
    2- could you tell me please what are exactely this 2 parametres orxLowPassAdcProfile and orxBandPassAdcProfile  in talise_config.c?
    Thank you in advance !
    on Dec 11, 2020 9:08 AM 2 months ago in reply to opokoy
    If you are using a profile with ORX bandwidth higher that 200MHz, you need to enable ORX stiching.
    In configuration wizard. There is an option to enable same when using ORx bandwidth higher than 200MHz.
    In stiching mode we combine the ORx1 and ORX2 ADC's together to achieve a max bandwidth of 450MHz. For that we use the ORx low pass profile and ORx high pass profile.
    If you want your noise floor to be flat for higher bandwidth , increase the bandwidth and generate a profile from filter wizard.
    FYR.https://ez.analog.com/wide-band-rf-transceivers/design-support-adrv9008-1-adrv9008-2-adrv9009/f/q-a/108993/adrv9009-profile-configuration-wizard/322709#322709
    https://ez.analog.com/wide-band-rf-transceivers/design-support-adrv9008-1-adrv9008-2-adrv9009/f/q-a/163124/adrv9008-2-problem-with-491-52-msps-profile/372295#372295
  • If you want your noise floor to be flat for higher bandwidth , increase the bandwidth??
    which bandwidth i have to increase??
    what is the difference between the tracking cal and calibration ?
    take a look you will find attached my 450 MHz profile that I use
     * \file talise_config.c
     * \brief Contains Talise configuration settings for the Talise API
     * Copyright 2015-2017 Analog Devices Inc.
     * Released under the AD9378-AD9379 API license, for more information see the "LICENSE.txt" file in this zip file.
     * The top level structure taliseDevice_t talDevice uses keyword
     * extern to allow the application layer main() to have visibility
     * to these settings.
     * This file may not be fully complete for the end user application and
     * may need to updated for AGC, GPIO, and DAC full scale settings.
     * To create a full initialisation routine, the user should also refer to the
     * Iron Python initialisation routine generated by the GUI, and also the Talise User Guide.
    #include "talise_types.h"
    #include "talise_config.h"
    #include "talise_error.h"
    #include "talise_agc.h"
    #ifdef ADI_ZYNQ_PLATFORM
    #include "zynq_platform.h"
    #endif
    int16_t txFirCoefs[20] = {-3, 9, -28, 69, -131, 246, -507, 1182, -2648, 19449, -2648, 1182, -507, 246, -131, 69, -28, 9, -3, 0};
    int16_t rxFirCoefs[48] = {-7, -23, 33, 50, -70, -110, 144, 205, -259, -356, 437, 581, -698, -916, 1082, 1415, -1655, -2209, 2567, 3615, -4351, -7169, 9329, 31129, 31129, 9329, -7169, -4351, 3615, 2567, -2209, -1655, 1415, 1082, -916, -698, 581, 437, -356, -259, 205, 144, -110, -70, 50, 33, -23, -7};
    int16_t obsrxFirCoefs[24] = {61, -9, 8, -6, -2, 12, -55, 91, -192, 460, -1719, 19205, -1719, 460, -192, 91, -55, 12, -2, -6, 8, -9, 61, 0};
    #ifdef ADI_ZYNQ_PLATFORM /** < Insert Customer Platform HAL State Container here>*/
     * Platform Layer SPI settings - this structure is specific to ADI's platform layer code.
     * User should replace with their own structure or settings for their hardware
    zynqSpiSettings_t spiDev1 =
    	.chipSelectIndex = 1,
    	.writeBitPolarity = 0,
    	.longInstructionWord = 1,
    	.CPHA = 0,
    	.CPOL = 0,
    	.mode = 0,
    	.spiClkFreq_Hz = 25000000
     * Platform Layer settings - this structure is specific to ADI's platform layer code.
     * The structure is held in taliseDevice_t below as a void pointer, allowing
     * the customer to pass any information for their specific hardware down to the
     * hardware layer code.
    zynqAdiDev_t talDevHalInfo =
    	.devIndex = 1,
    	.spiSettings = &spiDev1,
    	.spiErrCode = 0,
    	.timerErrCode = 0,
    	.gpioErrCode = 0,
    	.logLevel = ADIHAL_LOG_ALL
    #endif
     *  TalDevice a structure used by the Talise API to hold the platform hardware
     *  structure information, as well as an internal Talise API state container
     *  (devStateInfo) of runtime information used by the API.
    taliseDevice_t talDevice =
        /* Void pointer of users platform HAL settings to pass to HAL layer calls
         * Talise API does not use the devHalInfo member */
    	.devHalInfo = &talDevHalInfo,
    #else
    	.devHalInfo = NULL,     /*/** < Insert Customer Platform HAL State Container here>*/
    #endif
    	/* devStateInfo is maintained internal to the Talise API, just create the memory */
    	.devStateInfo = {0}
    taliseInit_t talInit =
    	/* SPI settings */
        .spiSettings =
    		.MSBFirst            = 1,  /* 1 = MSBFirst, 0 = LSBFirst */
    		.enSpiStreaming      = 0,  /* Not implemented in ADIs platform layer. SW feature to improve SPI throughput */
    		.autoIncAddrUp       = 1,  /* Not implemented in ADIs platform layer. For SPI Streaming, set address increment direction. 1= next addr = addr+1, 0:addr=addr-1 */
    		.fourWireMode        = 1,  /* 1: Use 4-wire SPI, 0: 3-wire SPI (SDIO pin is bidirectional). NOTE: ADI's FPGA platform always uses 4-wire mode */
    		.cmosPadDrvStrength  = TAL_CMOSPAD_DRV_2X /* Drive strength of CMOS pads when used as outputs (SDIO, SDO, GP_INTERRUPT, GPIO 1, GPIO 0) */
        /* Rx settings */
        .rx =
            .rxProfile =
                .rxFir =
                    .gain_dB = -6,                /* filter gain */
                    .numFirCoefs = 48,            /* number of coefficients in the FIR filter */
                    .coefs = &rxFirCoefs[0]
                .rxFirDecimation = 2,            /* Rx FIR decimation (1,2,4) */
                .rxDec5Decimation = 4,            /* Decimation of Dec5 or Dec4 filter (5,4) */
                .rhb1Decimation = 1,            /* RX Half band 1 decimation (1 or 2) */
                .rxOutputRate_kHz = 245760,            /* Rx IQ data rate in kHz */
                .rfBandwidth_Hz = 200000000,    /* The Rx RF passband bandwidth for the profile */
                .rxBbf3dBCorner_kHz = 200000,    /* Rx BBF 3dB corner in kHz */
                .rxAdcProfile = {185, 141, 172, 90, 1280, 942, 1332, 90, 1368, 46, 1016, 19, 48, 48, 37, 208, 0, 0, 0, 0, 52, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},            /* pointer to custom ADC profile */
                .rxDdcMode = TAL_RXDDC_BYPASS,   /* Rx DDC mode */
                .rxNcoShifterCfg =
                    .bandAInputBandWidth_kHz = 0,
                    .bandAInputCenterFreq_kHz = 0,
                    .bandANco1Freq_kHz = 0,
                    .bandANco2Freq_kHz = 0,
                    .bandBInputBandWidth_kHz = 0,
                    .bandBInputCenterFreq_kHz = 0,
                    .bandBNco1Freq_kHz = 0,
                    .bandBNco2Freq_kHz = 0
            .framerSel = TAL_FRAMER_A,            /* Rx JESD204b framer configuration */
            .rxGainCtrl =
                .gainMode = TAL_MGC,            /* taliserxGainMode_t gainMode */
                .rx1GainIndex = 255,            /* uint8_t rx1GainIndex */
                .rx2GainIndex = 255,            /* uint8_t rx2GainIndex */
                .rx1MaxGainIndex = 255,            /* uint8_t rx1MaxGainIndex */
                .rx1MinGainIndex = 195,            /* uint8_t rx1MinGainIndex */
                .rx2MaxGainIndex = 255,            /* uint8_t rx2MaxGainIndex */
                .rx2MinGainIndex = 195            /* uint8_t rx2MinGainIndex */
            .rxChannels = 0,                /* The desired Rx Channels to enable during initialization */
        /* Tx settings */
        .tx =
            .txProfile =
                .dacDiv = 1,                        /* The divider used to generate the DAC clock */
                .txFir =
                    .gain_dB = 0,                        /* filter gain */
                    .numFirCoefs = 20,                    /* number of coefficients in the FIR filter */
                    .coefs = &txFirCoefs[0]
                .txFirInterpolation = 1,                    /* The Tx digital FIR filter interpolation (1,2,4) */
                .thb1Interpolation = 2,                    /* Tx Halfband1 filter interpolation (1,2) */
                .thb2Interpolation = 2,                    /* Tx Halfband2 filter interpolation (1,2)*/
                .thb3Interpolation = 1,                    /* Tx Halfband3 filter interpolation (1,2)*/
                .txInt5Interpolation = 1,                    /* Tx Int5 filter interpolation (1,5) */
                .txInputRate_kHz = 491520,                    /* Primary Signal BW */
                .primarySigBandwidth_Hz = 200000000,    /* The Rx RF passband bandwidth for the profile */
                .rfBandwidth_Hz = 450000000,            /* The Tx RF passband bandwidth for the profile */
                .txDac3dBCorner_kHz = 450000,                /* The DAC filter 3dB corner in kHz */
                .txBbf3dBCorner_kHz = 225000,                /* The BBF 3dB corner in kHz */
                .loopBackAdcProfile = {150, 178, 181, 90, 1280, 1338, 1699, 493, 1386, 162, 934, 4, 48, 46, 35, 201, 0, 0, 0, 0, 50, 0, 0, 6, 24, 0, 0, 6, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905}
            .deframerSel = TAL_DEFRAMER_A,                    /* Talise JESD204b deframer config for the Tx data path */
            .txChannels = TAL_TX1TX2,                            /* The desired Tx channels to enable during initialization */
            .txAttenStepSize = TAL_TXATTEN_0P05_DB,            /* Tx Attenuation step size */
            .tx1Atten_mdB = 0,                            /* Initial Tx1 Attenuation */
            .tx2Atten_mdB = 0,                            /* Initial Tx2 Attenuation */
            .disTxDataIfPllUnlock = TAL_TXDIS_TX_RAMP_DOWN_TO_ZERO    /* Options to disable the transmit data when the RFPLL unlocks. */
        /* ObsRx settings */
        .obsRx =
            .orxProfile =
                .rxFir =
                    .gain_dB = 6,                /* filter gain */
                    .numFirCoefs = 24,            /* number of coefficients in the FIR filter */
                    .coefs = &obsrxFirCoefs[0]
                .rxFirDecimation = 1,            /* Rx FIR decimation (1,2,4) */
                .orxOutputRate_kHz = 491520,            /* Rx IQ data rate in kHz */
                .rfBandwidth_Hz = 450000000,    /* The Rx RF passband bandwidth for the profile */
                .rxBbf3dBCorner_kHz = 225000,    /* Rx BBF 3dB corner in kHz */
                .orxLowPassAdcProfile = {155, 163, 181, 90, 1280, 1254, 1572, 340, 1431, 142, 973, 8, 48, 47, 36, 205, 0, 0, 0, 0, 51, 0, 0, 6, 24, 0, 0, 6, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905},
                .orxBandPassAdcProfile = {124, 131, 154, 90, 1280, 2779, 1986, 0, 1037, 839, 988, 109, 11, 15, 28, 179, 0, 0, 0, 0, 45, 0, 0, 0, 24, 0, 0, 0, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905},
                .orxDdcMode = TAL_ORXDDC_DISABLED,   /* ORx DDC mode */
                .orxMergeFilter  = {-167, 419, -208, -498, 968, -320, -1273, 2154, -402, -4155, 9170, 21413}
            .orxGainCtrl =
                .orx1GainIndex = 255,
                .orx2GainIndex = 255,
                .orx1MaxGainIndex = 255,
                .orx1MinGainIndex = 195,
                .orx2MaxGainIndex = 255,
                .orx2MinGainIndex = 195
            .framerSel = TAL_FRAMER_B,                /* ObsRx JESD204b framer configuration */
            .obsRxChannelsEnable = TAL_ORX1,        /* The desired ObsRx Channels to enable during initialization */
            .obsRxLoSource = TAL_OBSLO_RF_PLL                /* The ORx mixers can use the TX_PLL */
        /* Digital Clock Settings */
        .clocks =
            .deviceClock_kHz = 245760,            /* CLKPLL and device reference clock frequency in kHz */
            .clkPllVcoFreq_kHz = 9830400,        /* CLKPLL VCO frequency in kHz */
            .clkPllHsDiv = TAL_HSDIV_2P5,            /* CLKPLL high speed clock divider */
            .rfPllUseExternalLo = 0,                /* 1= Use external LO for RF PLL, 0 = use internal LO generation for RF PLL */
            .rfPllPhaseSyncMode = TAL_RFPLLMCS_NOSYNC                /* RFPLL MCS (Phase sync) mode */
        /* JESD204B settings */
        .jesd204Settings =
            /* Framer A settings */
            .framerA =
                .bankId = 1,                    /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
                .deviceId = 0,                    /* JESD204B Configuration Device ID - link identification number. (Valid 0..255) */
                .lane0Id = 0,                    /* JESD204B Configuration starting Lane ID.  If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31) */
                .M = 4,                            /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
                .K = 32,                        /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes) */
                .F = 4,                            /* F (number of bytes per frame) */
                .Np = 16,                            /* Np (converter sample resolution) */
                .scramble = 1,                    /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled. */
                .externalSysref = 1,            /* 0=use internal SYSREF, 1= use external SYSREF */
                .serializerLanesEnabled = 0x03,    /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
                .serializerLaneCrossbar = 0xE4,    /* serializerLaneCrossbar */
                .lmfcOffset = 31,                /* lmfcOffset - LMFC offset value for deterministic latency setting */
                .newSysrefOnRelink = 0,            /* newSysrefOnRelink */
                .syncbInSelect = 0,                /* syncbInSelect; */
                .overSample = 0,                    /* 1=overSample, 0=bitRepeat */
                .syncbInLvdsMode = 1,
                .syncbInLvdsPnInvert = 0,
                .enableManualLaneXbar = 0 /* 0=auto, 1=manual */
            /* Framer B settings */
            .framerB =
                .bankId = 0,                    /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
                .M = 2,                            /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
                .F = 2,                            /* F (number of bytes per frame) */
                .serializerLanesEnabled = 0x0C,    /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
                .syncbInSelect = 1,                /* syncbInSelect; */
            /* Deframer A settings */
            .deframerA =
                .bankId = 0,                    /* bankId extension to Device ID (Valid 0..15) */
                .deviceId = 0,                    /* deviceId  link identification number. (Valid 0..255) */
                .lane0Id = 0,                    /* lane0Id Lane0 ID. (Valid 0..31) */
                .M = 4,                            /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
                .K = 32,                        /* K  #frames in a multiframe (default=32), F*K=multiple of 4. (F=2*M/numberOfLanes) */
                .scramble = 1,                    /* scramble  scrambling off if scramble= 0 */
                .externalSysref = 1,            /* externalSysref  0= use internal SYSREF, 1= external SYSREF */
                .deserializerLanesEnabled = 0x0F,    /* deserializerLanesEnabled  bit per lane, [0] = Lane0 enabled */
                .deserializerLaneCrossbar = 0xE4,    /* deserializerLaneCrossbar */
                .lmfcOffset = 17,                /* lmfcOffset	 LMFC offset value to adjust deterministic latency */
                .syncbOutSelect = 0,                /* SYNCBOUT0/1 select */
                .syncbOutLvdsMode = 1,
                .syncbOutLvdsPnInvert = 0,
                .syncbOutCmosSlewRate = 0,
                .syncbOutCmosDriveLevel = 0,
            /* Deframer B settings */
            .deframerB =
                .M = 0,                            /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
                .deserializerLanesEnabled = 0x00,    /* deserializerLanesEnabled  bit per lane, [0] = Lane0 enabled */
                .lmfcOffset = 0,                /* lmfcOffset	 LMFC offset value to adjust deterministic latency */
                .syncbOutSelect = 1,                /* SYNCBOUT0/1 select */
            .serAmplitude = 15,                    /* Serializer amplitude setting. Default = 15. Range is 0..15 */
            .serPreEmphasis = 1,                /* Serializer pre-emphasis setting. Default = 1 Range is 0..4 */
            .serInvertLanePolarity = 0,            /* Serializer Lane PN inversion select. Default = 0. Where, bit[0] = 1 will invert lane [0], bit[1] = 1 will invert lane 1, etc. */
            .desInvertLanePolarity = 0,            /* Deserializer Lane PN inversion select.  bit[0] = 1 Invert PN of Lane 0, bit[1] = Invert PN of Lane 1, etc */
            .desEqSetting = 1,                    /* Deserializer Equalizer setting. Applied to all deserializer lanes. Range is 0..4 */
            .sysrefLvdsMode = 1,                /* Use LVDS inputs on Talise for SYSREF */
            .sysrefLvdsPnInvert = 0              /*0= Do not PN invert SYSREF */
    //Only needs to be called if user wants to setup AGC parameters
    static taliseAgcCfg_t rxAgcCtrl =
        4,
        255,
        195,
        255,
        195,
        30720,  /* AGC gain update time in us (125us-250us - based on IQ data rate - set for 125us @ 245.76 Mhz) */
        10,
        10,
        16,
        0,
        1,
        0,
        0,
        0,
        1,
        31,
        246,
        4,
        1,          /*!<1- bit field to enable the multiple time constants in AGC loop for fast attack and fast recovery to max gain. */
        /* agcPower */
            1,      /*!<1-bit field, enables the Rx power measurement block. */
            1,      /*!<1-bit field, allows using Rx PFIR for power measurement. */
            0,      /*!<1-bit field, allows to use the output of the second digital offset block in the Rx datapath for power measurement. */
            9,      /*!<AGC power measurement detect lower 0 threshold. Default = -12dBFS == 5, 7-bit register value where max = 0x7F, min = 0x00 */
            2,      /*!<AGC power measurement detect lower 1 threshold. Default = (offset) 4dB == 0, 4-bit register value where  max = 0xF, min = 0x00 */
            4,      /*!<AGC power measurement detect lower 0 recovery gain step. Default = 2dB - based on gain table step  size, 5-bit register value where max = 0x1F, min = 0x00 */
            4,      /*!<AGC power measurement detect lower 1 recovery gain step. Default = 4dB - based on gain table step size, 5-bit register value where max = 0x1F, min = 0x00 */
            5,      /*!< power measurement duration used by the decimated power block. Default = 0x05, 5-bit register value where max = 0x1F, min = 0x00 */
            5,      /*!<Allows power detection of data for a specific slice of the gain update counter. 16-bit register value (currently not used) */
            1,      /*!<Allows power detection of data for a specific slice of the gain update counter. 16-bit register value (currently not used) */
            2,      /*!<Default value should be 2*/
            0,
            0
        /* agcPeak */
            205,        /*!<1st update interval for the multiple time constant in AGC loop mode, Default:205. */
            2,          /*!<sets the 2nd update interval for the multiple time constant in AGC loop mode. Calculated as a multiple of  agcUnderRangeLowInterval  , Default: 4 */
            4,          /*!<sets the 3rd update interval for the multiple time constant in AGC loop mode. Calculated as a multiple of agcUnderRangeMidInterval and agcUnderRangeLowInterval, Default: 4 */
            39,         /*!<AGC APD high threshold. Default=0x1F, 6-bit register value where max=0x3F, min =0x00 */
            49,         /*!<AGC APD peak detect high threshold. default = 0x1F, 6-bit register value where max = 0x3F, min = 0x00.  Set to 3dB below apdHighThresh */
            23,         /*!<AGC APD peak detect low threshold. default = 3dB below high threshold, 6-bit register value where max =0x3F, min = 0x00 */
            19,         /*!<AGC APD peak detect low threshold. default = 3dB below high threshold, 6-bit register value where max = 0x3F, min = 0x00 . Set to 3dB below apdLowThresh  */
            6,          /*!<AGC APD peak detect upper threshold count. Default = 0x06 8-bit register value where max = 0xFF, min = 0x20  */
            3,          /*!<AGC APD peak detect lower threshold count. Default = 0x03, 8-bit register value where max = 0xFF, min = 0x00  */
            4,          /*!<AGC APD peak detect attack gain step. Default = 2dB step - based on gain table step size, 5-bit register  value, where max = 0x1F, min = 0x00  */
            2,          /*!<AGC APD gain index step size. Recommended to be same as hb2GainStepRecovery. Default = 0x00, 5-bit register value where max = 0x1F, min = 0x00  */
            1,          /*!<1-bit field, enables or disables the HB2 overload detector.  */
            1,          /*!<3-bit field. Sets the window of clock cycles (at the HB2 output rate) to meet the overload count. */
            1,          /*!<4-bit field. Sets the number of actual overloads required to trigger the overload signal.  */
            181,        /*!<AGC decimator output high threshold. Default = 0xB5, 8-bit register value where max = 0xFF, min = 0x00 */
            45,         /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
            90,         /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
            128,        /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
            6,          /*!<AGC HB2 output upper threshold count. Default = 0x06, 8-bit register value where max = 0xFF, min =  0x20 */
            3,          /*!<AGC HB2 output lower threshold count. Default = 0x03, 8-bit register value where max = 0xFF, min = 0x00 */
            2,          /*!<AGC decimator gain index step size. Default = 0x00, 5-bit register value where max = 0x1F, min = 0x00 */
            4,          /*!<AGC HB2 gain index step size, when the HB2 Low Overrange interval 0 triggers a programmable number  of times. Default = 0x08, 5-bit register value where max = 0x1F, min = 0x00 */
            8,          /*!<AGC HB2 gain index step size, when the HB2 Low Overrange interval 1 triggers a programmable number of times. Default = 0x04, 5-bit register value where max = 0x1F, min = 0x00 */
            4,          /*!<AGC decimator output attack gain step. Default = 2dB step - based on gain table step size, 5-bit register value, where max = 0x1F, min = 0x00 */
            1,
            0,
            0
    Thank you!
