ADRV9026 EVAL - Receive JESD profile
For 4TX, I have chosen LMFS - 4841, which has 4 Serdes lanes, with 245.76MSPS rate and should address 4 DAC's.
Similarly for Receive I intend to have a profile with 4R with 4 lanes(no link sharing) and max sample rate 184.32MSPS.
So, in ADRVTRX GUI only few profiles have been listed, which I chose 13_NLS profile.
Later, Since I need to have 4 lanes, I modified framer 0 to have 4 lanes and other fields automatically updated from GUI. So, this makes up LMFS - 4841
Then I took this init.c script from GUI and trying to bringup link between fpga and ADRV.
TX link is up and I could see waveforms on TXA and TXB, not sure TX3 and TX4 I am not seeing any waveforms, it has just junk coming on both ports.
On ADC side, Sync is toggling, CGS->ILAS phase is in repeat mode, not sure why!
Is everything okay with above described profile and configs?
  • Hi @Vinod, I understand from your explanation that my assumption of 4lanes/Dac is right. I have mapped 4 serdes lanes in fpga both on transmit and receive. Similarly, on ADRV have enabled 4 Lanes for deframer_0, deframer_1 is unused. Tx link is up, sync is continuously high passing all CGS, ILAS phases. I could see all these in *Vivado ILA*.
    One clarification regarding your point, you mean try sending data like this
    {Tx4IQ,Tx3IQ,32'd0,32'd0} ? How I will be able to observe data on Tx1/2 If I am not sending any? Do I have to check the same or have to change some crossbar settings to route this data to Tx1 and Tx2 ?
    Another thing I can test is that interchanging gt lanes 12 with 34 and see what happens. Will update this.
    Hi @srimoyi, forgot to add one point. I am working on getting deframer status api which might give hint about any jesd link errors.
    Thanks and Regards.
  • Hi  , I a able to see both the TX/RX SYNC high in vivado ILA which confirms JESD link is up on both sides. Also, I tried printing the deframer and framer jesd link status along with channel mask return values.
    Since I am using only deframer_0 for 4 lanes, deframer0 status = 87 = 1000 0111.
    framer0 status for 2 lanes RX @9.8gbps, 122.88rate = 0a = 0000 1111.
    Hi @vinod, with IQ data on all the lanes at jesd input I tried interchanging data of GT 1,2 lanes with 3,4 lanes of TX jesd output but still same issue. I could able to see waveforms on TX1 and Tx2 not on Tx3 and TX4.
    Here I have attached init.c in 2 snips taken from TES. Please tell if there is any discrepancy. Thanks in advance
    # include "initdata.h"
    adi_adrv9025_ApiVersion_t initStructApiVersion = {2, 0, 0, 9};
    adi_adrv9025_Init_t deviceInitStruct =
        { // clocks
            245760,  // deviceClock_kHz
            9830400,  // clkPllVcoFreq_kHz
            9830400,  // serdesPllVcoFreq_kHz
            0,  // ldoSelect
            0,  // extLoFreq1_kHz
            0,  // extLoFreq2_kHz
            ADI_ADRV9025_INTLO_NOOUTPUT,  // rfPll1LoMode
            ADI_ADRV9025_INTLO_NOOUTPUT,  // rfPll2LoMode
            0,  // rfPll1LoOutDivider
            0,  // rfPll2LoOutDivider
            ADI_ADRV9025_RFPLLMCS_NOSYNC,  // rfPllPhaseSyncMode
            ADI_ADRV9025_LOSEL_LO1,  // rx12LoSelect
            ADI_ADRV9025_LOSEL_LO1,  // rx34LoSelect
            ADI_ADRV9025_LOSEL_LO2,  // tx12LoSelect
            ADI_ADRV9025_LOSEL_LO2,  // tx34LoSelect
            ADI_ADRV9025_ORXLOSEL_TXLO,  // orx12LoSelect
            ADI_ADRV9025_ORXLOSEL_TXLO,  // orx34LoSelect
        { // gpInterrupts
            0xFFFFFFFFFFFFFFFF,  // gpIntMaskPin0
            0xFFFFFFFFFFFFFFFF,  // gpIntMaskPin1
        { // rx
            0x3FF,  // rxInitChannelMask
            {  // rxChannelCfg (array)
            {  // rxChannelCfg[0]
                { // profile
                    ADI_ADRV9025_RX1,  // channelType
                    1,  // rxFirDecimation
                    1,  // rxDec5Decimation
                    2,  // rhb1Decimation
                    1,  // rhb1WideBandMode
                    2,  // rhb2Decimation
                    2,  // rhb3Decimation
                    2,  // rxFir1Decimation
                    1,  // rxFir2Decimation
                    122880,  // rxOutputRate_kHz
                    100000,  // rfBandwidth_kHz
                    100000,  // rxBbf3dBCorner_kHz
                    50000,  // rxAdcBandWidth_kHz
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                        {-12, 4, -2, -2, 10, -18, 25, -25, 8, 73, -587, 17346, -587, 73, 8, -25, 25, -18, 10, -2, -2, 4, -12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
                    ADI_ADRV9025_RXDDC_BYPASS,  // rxDdcMode
                    { // rxNcoShifterCfg
                        0,  // bandAInputBandWidth_kHz
                        0,  // bandAInputCenterFreq_kHz
                        0,  // bandANco1Freq_kHz
                        0,  // bandANco2Freq_kHz
                        0,  // bandBInputBandWidth_kHz
                        0,  // bandBInputCenterFreq_kHz
                        0,  // bandBNco1Freq_kHz
                        0,  // bandBNco2Freq_kHz
                        0,  // bandAbCombinedEnable
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x01,  // rxChannelMask
                        ADI_ADRV9025_GAIN_COMPENSATION_DISABLED,  // formatSelect
                        { // floatingPointConfig
                            ADI_ADRV9025_FP_FORMAT_SIGN_EXP_SIGNIFICAND,  // fpDataFormat
                            ADI_ADRV9025_ROUND_TO_EVEN,  // fpRoundMode
                            ADI_ADRV9025_2_EXPONENTBITS,  // fpNumExpBits
                            ADI_ADRV9025_FPATTEN_0DB,  // fpAttenSteps
                            ADI_ADRV9025_FP_FORMAT_HIDE_LEADING_ONE_DISABLE,  // fpHideLeadingOne
                            ADI_ADRV9025_FP_FORMAT_NAN_ENCODE_DISABLE,  // fpEncodeNan
                        { // integerConfigSettings
                            ADI_ADRV9025_NO_EMBEDDED_SLICER_BITS,  // intEmbeddedBits
                            ADI_ADRV9025_INTEGER_16BIT_2SCOMP,  // intSampleResolution
                            ADI_ADRV9025_NO_PARITY,  // intParity
                            ADI_ADRV9025_LOWER_NIBBLE_ON_Q,  // intEmbeddedPos
                        { // slicerConfigSettings
                            ADI_ADRV9025_EXTSLICER_STEPSIZE_1DB,  // extSlicerStepSize
                            ADI_ADRV9025_INTSLICER_STEPSIZE_1DB,  // intSlicerStepSize
                            ADI_ADRV9025_EXTSLICER_RX_GPIO_DISABLE,  // rx1ExtSlicerGpioSelect
                            ADI_ADRV9025_EXTSLICER_RX_GPIO_DISABLE,  // rx2ExtSlicerGpioSelect
                            ADI_ADRV9025_EXTSLICER_RX_GPIO_DISABLE,  // rx3ExtSlicerGpioSelect
                            ADI_ADRV9025_EXTSLICER_RX_GPIO_DISABLE,  // rx4ExtSlicerGpioSelect
                        { // embOvldMonitorSettings
                            ADI_ADRV9025_RX_EMB_MON_SRC_NO_MON_DATA_EMBEDDED,  // embeddedMonitorSrcLsbI
                            ADI_ADRV9025_RX_EMB_MON_SRC_NO_MON_DATA_EMBEDDED,  // embeddedMonitorSrcLsbQ
                            ADI_ADRV9025_RX_EMB_MON_SRC_NO_MON_DATA_EMBEDDED,  // embeddedMonitorSrcLsbPlusOneI
                            ADI_ADRV9025_RX_EMB_MON_SRC_NO_MON_DATA_EMBEDDED,  // embeddedMonitorSrcLsbPlusOneQ
                            ADI_ADRV9025_HB2_LOW_SRC_OVRG_LOW_INT1_THRESH_CNTR_EXCEEDED,  // embeddedMonitorHb2LowSrcSel
                            ADI_ADRV9025_HB2_HIGH_SRC_INVALID,  // embeddedMonitorHb2HighSrcSel
                            ADI_ADRV9025_APD_LOW_SRC_INVALID,  // embeddedMonitorApdLowSrcSel
                            ADI_ADRV9025_APD_HIGH_SRC_INVALID,  // embeddedMonitorApdHighSrcSel
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
                        0,  // externalLnaGain
                        0,  // tempCompensationEnable
            {  // rxChannelCfg[1]
                { // profile
                    ADI_ADRV9025_RX2,  // channelType
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x02,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            {  // rxChannelCfg[2]
                { // profile
                    ADI_ADRV9025_RX3,  // channelType
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x04,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            {  // rxChannelCfg[3]
                { // profile
                    ADI_ADRV9025_RX4,  // channelType
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x08,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            {  // rxChannelCfg[4]
                { // profile
                    ADI_ADRV9025_ORX1,  // channelType
                    5,  // rxDec5Decimation
                    0,  // rhb1WideBandMode
                    1,  // rhb3Decimation
                    1,  // rxFir1Decimation
                    245760,  // rxOutputRate_kHz
                    225000,  // rfBandwidth_kHz
                    225000,  // rxBbf3dBCorner_kHz
                    112500,  // rxAdcBandWidth_kHz
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                        {6, 0, 2, -1, 1, 4, -8, 17, -36, 100, -446, 17182, -446, 100, -36, 17, -8, 4, 1, -1, 2, 0, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x10,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            {  // rxChannelCfg[5]
                { // profile
                    ADI_ADRV9025_ORX2,  // channelType
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x20,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            {  // rxChannelCfg[6]
                { // profile
                    ADI_ADRV9025_ORX3,  // channelType
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x40,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            {  // rxChannelCfg[7]
                { // profile
                    ADI_ADRV9025_ORX4,  // channelType
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x80,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            {  // rxChannelCfg[8]
                { // profile
                    ADI_ADRV9025_LB12,  // channelType
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x100,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            {  // rxChannelCfg[9]
                { // profile
                    ADI_ADRV9025_LB34,  // channelType
                    { // rxFir
                        6,  // gain_dB
                        24,  // numFirCoefs
                    4,  // tiaPowerMode
                    { // rxDataFormat
                        0x200,  // rxChannelMask
                            0,  // invertHb2Flag
                            0,  // invertApdFlag
            }, // rxChannelCfg (end of array)
        { // tx
            0x0F,  // txInitChannelMask
            {  // txChannelCfg (array)
            {  // txChannelCfg[0]
                { // profile
                    245760,  // txInputRate_kHz
                    100000,  // primarySigBandwidth_kHz
                    225000,  // txDac3dBCorner_kHz
                    112500,  // txBbf3dBCorner_kHz
                    1,  // dpdHb1Interpolation
                    1,  // dpdHb2Interpolation
                    1,  // txFirInterpolation
                    2,  // thb1Interpolation
                    2,  // thb2Interpolation
                    2,  // thb3Interpolation
                    1,  // txInt5Interpolation
                    { // txFir
                        6,  // gain_dB
                        20,  // numFirCoefs
                        {-18, 26, -48, 93, -159, 280, -551, 1251, -2759, 20155, -2759, 1251, -551, 280, -159, 93, -48, 26, -18, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
                    8,  // txBbfPowerMode
                { // txAttenCtrl
                    ADI_ADRV9025_TXATTEN_0P05_DB,  // txAttenStepSize
                    63,  // txRampDownEvents
                    0,  // reserved
                    ADI_ADRV9025_TXATTEN_SPI_MODE,  // attenMode
                    ADI_ADRV9025_TX_DACFS_0DB,  // dacFullScale
                    10000,  // txAttenInit_mdB
            {  // txChannelCfg[1]
                { // profile
                    { // txFir
                        6,  // gain_dB
                        20,  // numFirCoefs
                { // txAttenCtrl
                    0,  // reserved
            {  // txChannelCfg[2]
                { // profile
                    { // txFir
                        6,  // gain_dB
                        20,  // numFirCoefs
                { // txAttenCtrl
                    0,  // reserved
            {  // txChannelCfg[3]
                { // profile
                    { // txFir
                        6,  // gain_dB
                        20,  // numFirCoefs
                { // txAttenCtrl
                    0,  // reserved
            }, // txChannelCfg (end of array)
        { // dataInterface
            {  // framer (array)
            {  // framer[0]
                0,  // enableJesd204C
                0,  // bankId
                1,  // deviceId
                0,  // lane0Id
                8,  // jesd204M
                32,  // jesd204K
                8,  // jesd204F
                16,  // jesd204Np
                0,  // jesd204E
                1,  // scramble
                3,  // serializerLanesEnabled
                0,  // lmfcOffset
                0,  // syncbInSelect
                0,  // overSample
                1,  // syncbInLvdsMode
                0,  // syncbInLvdsPnInvert
                { // serializerLaneCrossbar
                    0,  // lane0FramerOutSel
                    1,  // lane1FramerOutSel
                    4,  // lane2FramerOutSel
                    4,  // lane3FramerOutSel
                { // adcCrossbar
                    ADI_ADRV9025_ADC_RX1_I,  // conv0
                    ADI_ADRV9025_ADC_RX1_Q,  // conv1
                    ADI_ADRV9025_ADC_RX2_I,  // conv2
                    ADI_ADRV9025_ADC_RX2_Q,  // conv3
                    ADI_ADRV9025_ADC_DUALBAND_RX3_BAND_A_I,  // conv4
                    ADI_ADRV9025_ADC_RX3_Q,  // conv5
                    ADI_ADRV9025_ADC_DUALBAND_RX4_BAND_A_I,  // conv6
                    ADI_ADRV9025_ADC_RX4_Q,  // conv7
                    ADI_ADRV9025_ADC_DISABLE,  // conv8
                    ADI_ADRV9025_ADC_DISABLE,  // conv9
                    ADI_ADRV9025_ADC_DISABLE,  // conv10
                    ADI_ADRV9025_ADC_DISABLE,  // conv11
                    ADI_ADRV9025_ADC_DISABLE,  // conv12
                    ADI_ADRV9025_ADC_DISABLE,  // conv13
                    ADI_ADRV9025_ADC_DISABLE,  // conv14
                    ADI_ADRV9025_ADC_DISABLE,  // conv15
                    ADI_ADRV9025_ADC_DISABLE,  // conv16
                    ADI_ADRV9025_ADC_DISABLE,  // conv17
                    ADI_ADRV9025_ADC_DISABLE,  // conv18
                    ADI_ADRV9025_ADC_DISABLE,  // conv19
                    ADI_ADRV9025_ADC_DISABLE,  // conv20
                    ADI_ADRV9025_ADC_DISABLE,  // conv21
                    ADI_ADRV9025_ADC_DISABLE,  // conv22
                    ADI_ADRV9025_ADC_DISABLE,  // conv23
                0,  // newSysrefOnRelink
                1,  // sysrefForStartup
                0,  // sysrefNShotEnable
                0,  // sysrefNShotCount
                0,  // sysrefIgnoreWhenLinked
            {  // framer[1]
                0,  // bankId
                1,  // deviceId
                0,  // lane0Id
                2,  // jesd204M
                32,  // jesd204K
                0,  // jesd204F
                16,  // jesd204Np
                0,  // jesd204E
                1,  // scramble
                0,  // serializerLanesEnabled
                0,  // lmfcOffset
                1,  // syncbInSelect
                0,  // overSample
                    4,  // lane0FramerOutSel
                    4,  // lane1FramerOutSel
                { // adcCrossbar
                    ADI_ADRV9025_ADC_DISABLE,  // conv0
                    ADI_ADRV9025_ADC_DISABLE,  // conv3
                    ADI_ADRV9025_ADC_DISABLE,  // conv4
                    ADI_ADRV9025_ADC_DISABLE,  // conv5
                    ADI_ADRV9025_ADC_DISABLE,  // conv6
                    ADI_ADRV9025_ADC_DISABLE,  // conv7
                0,  // sysrefForStartup
            {  // framer[2]
                0,  // bankId
                0,  // deviceId
                0,  // lane0Id
                0,  // jesd204M
                0,  // jesd204K
                0,  // jesd204F
                0,  // jesd204Np
                0,  // jesd204E
                0,  // scramble
                0,  // lmfcOffset
                0,  // syncbInSelect
                0,  // overSample
                0,  // syncbInLvdsMode
                { // adcCrossbar
            }, // framer (end of array)
    { // dataInterface
            {  // framer (array)
            {  // framer[0]
                0,  // bankId
                1,  // deviceId
                0,  // lane0Id
                8,  // jesd204M
                32,  // jesd204K
                8,  // jesd204F
                16,  // jesd204Np
                0,  // jesd204E
                1,  // scramble
                0,  // lmfcOffset
                0,  // syncbInSelect
                0,  // overSample
                { // adcCrossbar
            {  // framer[1]
                0,  // bankId
                1,  // deviceId
                0,  // lane0Id
                2,  // jesd204M
                32,  // jesd204K
                0,  // jesd204F
                16,  // jesd204Np
                0,  // jesd204E
                1,  // scramble
                0,  // lmfcOffset
                1,  // syncbInSelect
                0,  // overSample
                { // adcCrossbar
            {  // framer[2]
                0,  // bankId
                0,  // deviceId
                0,  // lane0Id
                0,  // jesd204M
                0,  // jesd204K
                0,  // jesd204F
                0,  // jesd204Np
                0,  // jesd204E
                0,  // scramble
                0,  // lmfcOffset
                0,  // syncbInSelect
                0,  // overSample
                { // adcCrossbar
            {  // deframer (array)
            {  // deframer[0]
                0,  // bankId
                1,  // deviceId
                0,  // lane0Id
                8,  // jesd204M
                32,  // jesd204K
                4,  // jesd204F
                16,  // jesd204Np
                0,  // jesd204E
                1,  // scramble
                15,  // deserializerLanesEnabled
                0,  // lmfcOffset
                0,  // syncbOutSelect
                1,  // syncbOutLvdsMode
                0,  // syncbOutLvdsPnInvert
                0,  // syncbOutCmosSlewRate
                0,  // syncbOutCmosDriveLevel
                { // deserializerLaneCrossbar
                    0,  // deframerInput0LaneSel
                    1,  // deframerInput1LaneSel
                    2,  // deframerInput2LaneSel
                    3,  // deframerInput3LaneSel
                { // dacCrossbar
                    ADI_ADRV9025_DEFRAMER_OUT0,  // tx1DacChanI
                    ADI_ADRV9025_DEFRAMER_OUT1,  // tx1DacChanQ
                    ADI_ADRV9025_DEFRAMER_OUT2,  // tx2DacChanI
                    ADI_ADRV9025_DEFRAMER_OUT3,  // tx2DacChanQ
                    ADI_ADRV9025_DEFRAMER_OUT4,  // tx3DacChanI
                    ADI_ADRV9025_DEFRAMER_OUT5,  // tx3DacChanQ
                    ADI_ADRV9025_DEFRAMER_OUT6,  // tx4DacChanI
                    ADI_ADRV9025_DEFRAMER_OUT7,  // tx4DacChanQ
            {  // deframer[1]
                0,  // bankId
                0,  // deviceId
                0,  // lane0Id
                0,  // jesd204M
                0,  // jesd204K
                0,  // jesd204F
                0,  // jesd204Np
                0,  // jesd204E
                0,  // scramble
                0,  // deserializerLanesEnabled
                0,  // lmfcOffset
                0,  // syncbOutLvdsMode
                    4,  // deframerInput0LaneSel
                    4,  // deframerInput1LaneSel
                    4,  // deframerInput2LaneSel
                    4,  // deframerInput3LaneSel
                { // dacCrossbar
                    127,  // tx1DacChanI
                    127,  // tx1DacChanQ
                    127,  // tx2DacChanI
                    127,  // tx2DacChanQ
                    127,  // tx3DacChanI
                    127,  // tx3DacChanQ
                    127,  // tx4DacChanI
                    127,  // tx4DacChanQ
            }, // deframer (end of array)
            {  // serCfg (array)
            {  // serCfg[0]
                0,  // serAmplitude
                1,  // serPreEmphasis
                3,  // serPostEmphasis
                0,  // serInvertLanePolarity
            {  // serCfg[1]
                0,  // serAmplitude
            {  // serCfg[2]
                0,  // serAmplitude
            {  // serCfg[3]
                0,  // serAmplitude
            }, // serCfg (end of array)
            {  // desCfg (array)
            {  // desCfg[0]
                0,  // desInvertLanePolarity
                0,  // highBoost
                0,  // configOption1
                0,  // configOption2
                0,  // configOption3
                0,  // configOption4
                0,  // configOption5
                0,  // configOption6
                0,  // configOption7
                0,  // configOption8
                0,  // configOption9
                0,  // configOption10
            {  // desCfg[1]
                0,  // highBoost
                0,  // configOption1
                0,  // configOption2
                0,  // configOption3
                0,  // configOption4
                0,  // configOption5
                0,  // configOption6
                0,  // configOption7
                0,  // configOption8
                0,  // configOption9
            {  // desCfg[2]
                0,  // highBoost
                0,  // configOption1
                0,  // configOption2
                0,  // configOption3
                0,  // configOption4
                0,  // configOption5
                0,  // configOption6
                0,  // configOption7
                0,  // configOption8
                0,  // configOption9
            {  // desCfg[3]
                0,  // highBoost
                0,  // configOption1
                0,  // configOption2
                0,  // configOption3
                0,  // configOption4
                0,  // configOption5
                0,  // configOption6
                0,  // configOption7
                0,  // configOption8
                0,  // configOption9
            }, // desCfg (end of array)
            { // linkSharingCfg
                0,  // linkSharingEnabled
                0,  // linkSharingM
                1,  // linkSharingS
                0,  // linkSharingNp
                { // linkSharingAdcCrossbar
            { // dataCfg
                0,  // enable
                0,  // configOption1
                0,  // configOption2
            0,  // channelSelect
            0,  // channelMode
    adi_adrv9025_PostMcsInit_t adrv9025PostMcsInitInst =
        { // radioCtrlInit
            { // radioCtrlModeCfg
                { // txRadioCtrlModeCfg
                    ADI_ADRV9025_TX_EN_SPI_MODE,  // txEnableMode
                    0x0F,  // txChannelMask
                { // rxRadioCtrlModeCfg
                    ADI_ADRV9025_RX_EN_SPI_MODE,  // rxEnableMode
                    0xFF,  // rxChannelMask
                { // orxRadioCtrlModeCfg
                    ADI_ADRV9025_ORX_EN_SPI_MODE,  // orxEnableMode
                    0,  // orxPinSelectSettlingDelay_armClkCycles
                    ADI_ADRV9025_SINGLE_CH_PIN_MODE_ORX1_FE,  // singleChannel1PinModeOrxSel
                    ADI_ADRV9025_SINGLE_CH_PIN_MODE_ORX1_FE,  // singleChannel2PinModeLowOrxSel
                    ADI_ADRV9025_SINGLE_CH_PIN_MODE_ORX1_FE,  // singleChannel2PinModeHighOrxSel
                    ADI_ADRV9025_DUAL_CH_PIN_MODE_ORX1_ORX3_SEL,  // dualChannel2PinModeOrxSel
            { // txToOrxMapping
                ADI_ADRV9025_MAP_NONE_ORX1,  // orx1Map
                ADI_ADRV9025_MAP_TX2_ORX2,  // orx2Map
                ADI_ADRV9025_MAP_TX3_ORX3,  // orx3Map
                ADI_ADRV9025_MAP_TX4_ORX4,  // orx4Map
            { // streamGpioCfg
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput0
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput1
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput2
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput3
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput4
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput5
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput6
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput7
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput8
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput9
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput10
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput11
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput12
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput13
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput14
                ADI_ADRV9025_GPIO_INVALID,  // streamGpInput15
            3500000000U,  // lo1PllFreq_Hz
            3550000000U,  // lo2PllFreq_Hz
            0U,  // auxPllFreq_Hz
        { // initCals
            0x823FF,  // calMask
            0x0F,  // channelMask
            0,  // warmBoot
        { // calRsltsFile
        0,  // checkFwVer
  • Hi @srimoyi and @vinod, I figured out the issue which is with SERDES lane inversion. Other 2 lanes were not inverted. Now I am able to see outputs on ALL 4 DAC's.
    Thanks for the help.
    regards,
    Rakshi
