ADRV9009 channel phase coherency
Hi, we are having some trouble with phase coherence with the ADRV9009.
We are running profile:
.rx =
.rxProfile =
.rxFir =
.gain_dB = -6, /* filter gain */
.numFirCoefs = 48, /* number of coefficients in the FIR filter */
.coefs = &rxFirCoefs[0]
.rxFirDecimation = 2, /* Rx FIR decimation (1,2,4) */
.rxDec5Decimation = 4, /* Decimation of Dec5 or Dec4 filter (5,4) */
.rhb1Decimation = 2, /* RX Half band 1 decimation (1 or 2) */
.rxOutputRate_kHz = 122880, /* Rx IQ data rate in kHz */
.rfBandwidth_Hz = 60000000, /* The Rx RF passband bandwidth for the profile */
.rxBbf3dBCorner_kHz = 60000, /* Rx BBF 3dB corner in kHz */
.rxAdcProfile = {265, 146, 181, 90, 1280, 366, 1257, 27, 1258, 17, 718, 39, 48, 46, 27, 161, 0, 0, 0, 0, 40, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905}, /* pointer to custom ADC profile */
.rxDdcMode = TAL_RXDDC_BYPASS, /* Rx DDC mode */
.rxNcoShifterCfg =
.bandAInputBandWidth_kHz = 0,
.bandAInputCenterFreq_kHz = 0,
.bandANco1Freq_kHz = 0,
.bandANco2Freq_kHz = 0,
.bandBInputBandWidth_kHz = 0,
.bandBInputCenterFreq_kHz = 0,
.bandBNco1Freq_kHz = 0,
.bandBNco2Freq_kHz = 0
.framerSel = TAL_FRAMER_A, /* Rx JESD204b framer configuration */
.rxGainCtrl =
.gainMode = TAL_MGC, /* taliserxGainMode_t gainMode */
.rx1GainIndex = 255, /* uint8_t rx1GainIndex */
.rx2GainIndex = 255, /* uint8_t rx2GainIndex */
.rx1MaxGainIndex = 255, /* uint8_t rx1MaxGainIndex */
.rx1MinGainIndex = 195, /* uint8_t rx1MinGainIndex */
.rx2MaxGainIndex = 255, /* uint8_t rx2MaxGainIndex */
.rx2MinGainIndex = 195 /* uint8_t rx2MinGainIndex */
.rxChannels = TAL_RX1RX2, /* The desired Rx Channels to enable during initialization */
.clocks =
.deviceClock_kHz = 122880, /* CLKPLL and device reference clock frequency in kHz */
.clkPllVcoFreq_kHz = 9830400, /* CLKPLL VCO frequency in kHz */
.clkPllHsDiv = TAL_HSDIV_2P5, /* CLKPLL high speed clock divider */
.rfPllUseExternalLo = 0, /* 1= Use external LO for RF PLL, 0 = use internal LO generation for RF PLL */
.rfPllPhaseSyncMode = TAL_RFPLLMCS_INIT_AND_SYNC //TAL_RFPLLMCS_NOSYNC /* RFPLL MCS (Phase sync) mode */
.framerA =
.bankId = 1, /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
.deviceId = 0, /* JESD204B Configuration Device ID - link identification number. (Valid 0..255) */
.lane0Id = 0, /* JESD204B Configuration starting Lane ID. If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31) */
.M = 4, /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
.K = 32, /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes) */
.F = 4, /* F (number of bytes per frame) */
.Np = 16, /* Np (converter sample resolution) */
.scramble = 1, /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled. */
.externalSysref = 1, /* 0=use internal SYSREF, 1= use external SYSREF */
.serializerLanesEnabled = 0x03, /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
.serializerLaneCrossbar = 0xE4, /* serializerLaneCrossbar */
.lmfcOffset = 31, /* lmfcOffset - LMFC offset value for deterministic latency setting */
.newSysrefOnRelink = 1, /* newSysrefOnRelink */
.syncbInSelect = 0, /* syncbInSelect; */
.overSample = 0, /* 1=overSample, 0=bitRepeat */
.syncbInLvdsMode = 1,
.syncbInLvdsPnInvert = 0,
.enableManualLaneXbar = 0 /* 0=auto, 1=manual */
However, when monitoring a test sinewave from a signal generator in the receiver fpga, the channels are not in phase. Not even within the two channels on the same chip.
Strangely enough, when running the testpattern(TALISE_enableFramerTestData(pd, TAL_FRAMER_A, TAL_FTD_RAMP, TAL_FTD_FRAMERINPUT);) the data is in phase.
The issue is not with the test setup, since when changing inputs from the splitter, the phase offset stays the same.
Any ideas what we might do wrong?
Regards
Rikard
