ADRV9009 Tx1 using "One CW Tone" shows FM modulation in output spectrum?
I am using a Xilinx ZCU102 board + ADRV9009 to transmit a CW RF signal via a cable, split between RX1 and RX2 on a second ZCU102 + ADRV9008-1 where I measure the phase difference between Rx1 and RX2 over 256 K captured samples.  I am using IIO Oscilloscope and the latest SD card image on the Transmit setup.  I have the 30.72 MHz ref connected as required.  The 9009 is set to 600 MHz TRX LO and a 1 MHz single CW tone (actual 999390 Hz), 0dB, 90 degrees.  Profile is 100 MHz bandwidth 122.88 MHz sample rate.  I have different length cables between the splitter and RX1, RX2 to cause a frequency dependent phase difference.  I am measuring the phase difference using cross correlation using a window of 198 samples, sliding this window along by 64 samples at a time and re-evaluating within my captured samples.
Using the 9009 as a source, I see +/- 9 degrees of phase variation appearing as a regular sine wave in time.  Using an external Signal Generator set at 601 MHz, with the same 9008-1 receive setup, I see around +/-0.1 degrees.
Phase Difference Plot
Is it possible that the ADRV9009 is generating the 600 + 1MHz CW signal with a small amount of FM modulation?
Possible FM
I have not enabled any tracking, or applied any calibrations, just loaded up IIO Oscilloscope and entered the frequencies required.
Are there any settings required to generate a purer sine wave ?  Should I use I/Q waveform mode instead ?
Many thanks for any suggestions,
Keith
  • After consultation and testing with an RF expert, we fixed this issue by inserting a suitable bandpass filter.  The RX1 to RX2 phase measurement was then stable.  The 9009 and 9008 development boards quite reasonably do not have RF filter components.  I am surprised that there was sufficient out of band energy to cause this error, but am very happy to see the problem solved.
    Keith
