ADRV9002_Channel State Error
            We found the error during the communication with ADRV9002.Pls refer below. Herewith i have attached the detailed log for EVM module and our module as well as chip configuration and screenshot. Pls give the solution to resolve this issue.
Our module log: adi_adrv9001_Radio_Channel_State_Get parameter 'channelState' read back as '2'
EVM Module log: adi_adrv9001_Radio_Channel_State_Get parameter 'channelState' read back as '3'
4478.ADRV9002 Query.zip
Regards
James A
  • Hi James,
    Im looking into this now and will try re-create the issue here to help debug.
    Regards
  • Hi Ruairi,
    ADC noise floor data is captured when FPGA & C API driver code created using adrv9001-sdk-eval-software Configuration. Configuration log file is attached in the previous query.
    Data clock RX_DCLK_OUT & RX_STROBE_OUT is not generated from ADRV device when new FPGA design is implemented(SPI logic alone same as in adrv9001-sdk-eval-software ) & AXI_ADRV_9001 Macro calls disabled in C API driver code is used. Configuration log file is attached for your reference (File Name: Config File Case2).
    adi_adrv9001_ApiVersion_Get parameter 'apiVersion' read back as '{
                    major: 48,
                    minor: 26,
                    patch: 4
    adi_fpga9001_VersionGet parameter 'fpgaVersion' read back as '{
                    major: 0,
                    minor: 0,
                    patch: 0
    Preparing to initialize ADRV9001.VENDOR_ID_0 Success
    SCRATCH_PAD_1 Success
    VENDOR_ID_0 Success
    adi_fpga9001_clock_Status_Get parameter 'status' read back as '{
                    locked: true,
                    mcsClock_kHz: 0,
                    observationGpiosClock_kHz: 0,
                    tddClock_kHz: 0,
                    refClock_kHz: 0
    Initialization successful.
     initialize Success
    Preparing to calibrate. Turn your signal source OFF, then press Enter.
    adi_adrv9001_spi_Byte_Read parameter 'readData' read back as '86'
    adi_adrv9001_cals_InternalPathDelay_Get parameter 'internalPathDelays_ns' read back as '{ 2311, 0, 0, 0, 0, 0 }
    adi_adrv9001_Rx_GainControl_MinMaxGainIndex_Get parameter 'minGainIndex' read back as '187'
    adi_adrv9001_Rx_GainControl_MinMaxGainIndex_Get parameter 'maxGainIndex' read back as '255'
    adi_adrv9001_Rx_GainTable_Read parameter 'gainTableRows' read back as '{ {
                    rxFeGain: 55834575099,
                    extControl: 0,
                    adcTiaGain: 2819380227726861153,
                    digGain: 7070761784448262183,
                    phaseOffset: 187651156551015
                    rxFeGain: 98784248059,
                    extControl: 0,
                    adcTiaGain: 281473673776912,
                    digGain: 187650746166626,
                    phaseOffset: 187651156550975
                    rxFeGain: 281457796841722,
                    extControl: 0,
                    digGain: 187650746166730,
                    rxFeGain: 25769804026,
                    extControl: 0,
                    rxFeGain: 68719476986,
                    extControl: 0,
                    rxFeGain: 281444911939833,
                    extControl: 0,
                    rxFeGain: 12884902137,
                    extControl: 0,
                    rxFeGain: 281423437103352,
                    extControl: 0,
                    rxFeGain: 281466386776312,
                    extControl: 0,
                    rxFeGain: 281401962266871,
                    extControl: 0,
                    rxFeGain: 281444911939831,
                    extControl: 0,
                    rxFeGain: 281406257234166,
                    extControl: 0,
                    rxFeGain: 281449206907126,
                    extControl: 0,
                    rxFeGain: 281410552201461,
                    extControl: 0,
                    rxFeGain: 281453501874421,
                    extControl: 0,
                    rxFeGain: 281432027037940,
                    extControl: 0,
                    rxFeGain: 281406257234163,
                    extControl: 0,
                    rxFeGain: 281393372332274,
                    extControl: 0,
                    rxFeGain: 281432027037938,
                    extControl: 0,
                    rxFeGain: 281419142136049,
                    extControl: 0,
                    rxFeGain: 281414847168752,
                    extControl: 0,
                    rxFeGain: 281406257234159,
                    extControl: 0,
                    rxFeGain: 281406257234158,
                    extControl: 0,
                    rxFeGain: 281406257234157,
                    extControl: 0,
                    rxFeGain: 281410552201452,
                    extControl: 0,
                    rxFeGain: 281380487430378,
                    extControl: 0,
                    rxFeGain: 281389077364969,
                    extControl: 0,
                    rxFeGain: 281401962266856,
                    extControl: 0,
                    rxFeGain: 281380487430374,
                    extControl: 0,
                    rxFeGain: 281393372332261,
                    extControl: 0,
                    rxFeGain: 281384782397667,
                    extControl: 0,
                    rxFeGain: 281401962266850,
                    extControl: 0,
                    rxFeGain: 281397667299552,
                    extControl: 0,
                    rxFeGain: 281397667299550,
                    extControl: 0,
                    rxFeGain: 281397667299548,
                    extControl: 0,
                    rxFeGain: 281401962266842,
                    extControl: 0,
                    rxFeGain: 281384782397655,
                    extControl: 0,
                    rxFeGain: 281393372332245,
                    extControl: 0,
                    rxFeGain: 281384782397650,
                    extControl: 0,
                    rxFeGain: 281397667299536,
                    extControl: 0,
                    rxFeGain: 281397667299533,
                    extControl: 0,
                    rxFeGain: 281397667299530,
                    extControl: 0,
                    rxFeGain: 281401962266823,
                    extControl: 0,
                    rxFeGain: 281393372332227,
                    extControl: 0,
                    rxFeGain: 281401962266816,
                    extControl: 0,
                    rxFeGain: 281406257234108,
                    extControl: 0,
                    rxFeGain: 281406257234104,
                    extControl: 0,
                    rxFeGain: 281410552201396,
                    extControl: 0,
                    rxFeGain: 281406257234095,
                    extControl: 0,
                    rxFeGain: 281410552201386,
                    extControl: 0,
                    rxFeGain: 281410552201381,
                    extControl: 0,
                    rxFeGain: 281414847168672,
                    extControl: 0,
                    rxFeGain: 281414847168666,
                    extControl: 0,
                    rxFeGain: 281419142135956,
                    extControl: 0,
                    rxFeGain: 281423437103246,
                    extControl: 0,
                    rxFeGain: 281423437103239,
                    extControl: 0,
                    rxFeGain: 281427732070528,
                    extControl: 0,
                    rxFeGain: 281432027037816,
                    extControl: 0,
                    rxFeGain: 281432027037808,
                    extControl: 0,
                    rxFeGain: 281440616972392,
                    extControl: 0,
                    rxFeGain: 281436322005086,
                    extControl: 0,
                    rxFeGain: 281444911939669,
                    extControl: 0,
                    rxFeGain: 281449206906955,
                    extControl: 0,
                    rxFeGain: 281453501874240,
                    extControl: 0,
                    rxFeGain: 281457796841525,
                    extControl: 0,
                    rxFeGain: 281462091808809,
                    extControl: 0,
                    rxFeGain: 281466386776092,
                    extControl: 0,
                    rxFeGain: 281470681743374,
                    extControl: 0,
                    rxFeGain: 0,
                    extControl: 0,
    adi_adrv9001_Rx_GainTable_Read parameter 'numGainIndicesRead' read back as '69'
    Calibrations complete.
     calibrate Success
    Configuring features.adi_adrv9001_gpio_GpIntMask_Get parameter 'gpIntMask' read back as '253755377'
     configure Success
    Priming channels.
     prime Success
    Ready to capture Rx data. Turn your signal source ON, then press Enter.
     beginReceiving Success
    Is it required your FPGA design from adrv9001-sdk-eval-software for ADRV9002 configuration & data capture?
    Or Can we use our own implementation in FPGA for ADRV9002 configuration & data capture?
    Pls find the Filter Co-eff file in the attachment  and it is missed in the previous query.
    -2837
    -1655
    11640
    15537
    -626
    -2768
    7084
    -2307
    -4286
    7568
    -3014
    -5551
    9630
    -3854
    -7242
    12492
    -5010
    -9342
    16129
    -6588
    -11793
    20642
    -8742
    -14577
    26149
    -11667
    -17642
    32859
    -15563
    -20963
    40941
    -20716
    -24454
    50677
    -27503
    -28062
    62429
    -36396
    -31694
    76720
    -48091
    -35265
    94357
    -63629
    -38675
    116680
    -84718
    -41826
    146091
    -114443
    -44622
    187363
    -159058
    -46981
    251390
    -233640
    -48820
    369376
    -386198
    -50081
    679872
    -895383
    -50722
    4649418
    4649418
    -50722
    -895383
    679872
    -50081
    -386198
    369376
    -48820
    -233640
    251390
    -46981
    -159058
    187363
    -44622
    -114443
    146091
    -41826
    -84718
    116680
    -38675
    -63629
    94357
    -35265
    -48091
    76720
    -31694
    -36396
    62429
    -28062
    -27503
    50677
    -24454
    -20716
    40941
    -20963
    -15563
    32859
    -17642
    -11667
    26149
    -14577
    -8742
    20642
    -11793
    -6588
    16129
    -9342
    -5010
    12492
    -7242
    -3854
    9630
    -5551
    -3014
    7568
    -4286
    -2307
    7084
    -2768
    -626
    15537
    11640
    -1655
    -2837
    Regards
    James A
  • Hi James,
    This error looks like there might be an issue with the sequence that you are calling API functions to mode the RF channel from 'Standby' through to 'RF On'. There are some requirements before you can call some of the RF channel states. Check the UG section API INITIALIZATION SEQUENCE. Also the Driver Debugger in the TES can be used to study exactly how and in what sequence the API functions should be called.
    Have you compared your code to the driver debugger output?
    Regards
  • Hi Ruairi,
    As u suggested, sequence is updated and working fine. We can able to access the digital data.
    Now we are using the independent  three wire configuration for connect 2nos of ADRV9002 chip as well as 4 wire configuration is also used for 2 no of ADRV9002 chip. The four wire configuration is working fine. When we are trying to connect with 3 wire configuration, the signals are attenuated which is received from the ADRV9002.Pls refer the attachment and give the feedback.
    Regards
    James A
  • Hi James,
    Is there anything on the SPI line that would drop the level of the data?
    In the SPI setting API function there is a setting to change the drive strength of the SPI. You can find all the details of the API functions in the Doxygen file in the SDK available on the product page.
    Search for the adi_adrv9001_SpiSettings in the Doxygen file to find info about the SPI data structure.
    adi_adrv9001_CmosPadDrvStr has a Weak and a Strong setting this is used for the SPI drive strength too.
     Regards
  • Closing this due to inactivity. Please let me know if there any more questions.
    Regards
