AD9375_ORX Data Missing anamoly
Product Number: AD9375
While trying to verify the ORX perfromance, It is observed that the ADC data samples are getting missed every 315 samples(0.39uS).
Let me elaborate,
Hardware connection:
Only ORX1 and TX1 are routed out. TX1 is power divided and connected to spectrum & ORX with appropriate attenuator.
API profile from headless.c:
Device Clock:122.88MHz
Rx 100MHz, IQrate 122.88MSPS, Dec5
Tx 20/100MHz, IQrate 122.88MSPS, Dec5
ORX 100MHz, IQrate 122.88MSPS, Dec5
SRx 20MHz, IQrate 30.72MSPS, Dec5
initCalMask
            TX_BB_FILTER |
            ADC_TUNER |
            TIA_3DB_CORNER |
            DC_OFFSET |
            TX_ATTENUATION_DELAY |
            RX_GAIN_DELAY |
            FLASH_CAL |
            PATH_DELAY |
            LOOPBACK_RX_LO_DELAY |
            LOOPBACK_RX_RX_QEC_INIT |
            TX_LO_LEAKAGE_INTERNAL |
            TX_QEC_INIT |
            RX_LO_DELAY |
            RX_QEC_INIT;
trackingCalMask
            TRACK_TX1_LOL |
            TRACK_TX1_QEC |
            TRACK_ORX1_QEC;
JESD profile from init.c:
static mykonosJesd204bFramerConfig_t rxFramer =
    0,              /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15)*/
    0,              /* JESD204B Configuration Device ID - link identification number. (Valid 0..255)*/
    0,              /* JESD204B Configuration starting Lane ID.  If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31)*/
    4,              /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain*/
    32,             /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes)*/
    0,              /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled.*/
    1,              /* 0=use internal SYSREF, 1= use external SYSREF*/
    0x03,           /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled*/
    0x08,           /* serializerLaneCrossbar*/
    22,             /* serializerAmplitude - default 22 (valid (0-31)*/
    4,              /* preEmphasis - < default 4 (valid 0 - 7)*/
    0,              /* invertLanePolarity - default 0 ([0] will invert lane [0], bit1 will invert lane1)*/
    0,              /* lmfcOffset - LMFC_Offset offset value for deterministic latency setting*/
    0,              /* Flag for determining if SYSREF on relink should be set. Where, if > 0 = set, 0 = not set*/
    0,              /* Flag for determining if auto channel select for the xbar should be set. Where, if > 0 = set, '0' = not set*/
    1,              /* Selects SYNCb input source. Where, 0 = use RXSYNCB for this framer, 1 = use OBSRX_SYNCB for this framer*/
    0,              /* Flag for determining if CMOS mode for RX Sync signal is used. Where, if > 0 = CMOS, '0' = LVDS*/
    0,              /* Selects framer bit repeat or oversampling mode for lane rate matching. Where, 0 = bitRepeat mode (changes effective lanerate), 1 = overSample (maintains same lane rate between ObsRx framer and Rx framer and oversamples the ADC samples)*/
    0               /* Flag for determining if API will calculate the appropriate settings for framer lane outputs to physical lanes. Where, if '0' = API will set automatic lane crossbar, '1' = set to manual mode and the value in serializerLaneCrossbar will be used*/
static mykonosJesd204bFramerConfig_t obsRxFramer =
    2,              /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain*/
    0x04,           /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled*/
    0x00,           /* Lane crossbar to map framer lane outputs to physical lanes*/
    1,              /* Selects framer bit repeat or oversampling mode for lane rate matching. Where, 0 = bitRepeat mode (changes effective lanerate), 1 = overSample (maintains same lane rate between ObsRx framer and Rx framer and oversamples the ADC samples)*/
static mykonosJesd204bDeframerConfig_t deframer =
    0,              /* bankId extension to Device ID (Valid 0..15)*/
    0,              /* deviceId  link identification number. (Valid 0..255)*/
    0,              /* lane0Id Lane0 ID. (Valid 0..31)*/
    4,              /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
    32,             /* K  #frames in a multiframe (default=32), F*K=multiple of 4. (F=2*M/numberOfLanes)*/
    0,              /* scramble  scrambling off if scramble= 0.*/
    1,              /* External SYSREF select. 0 = use internal SYSREF, 1 = external SYSREF*/
    0x0F,           /* Deserializer lane select bit field. Where, [0] = Lane0 enabled, [1] = Lane1 enabled, etc */
    0xE4,           /* Lane crossbar to map physical lanes to deframer lane inputs [1:0] = Deframer Input 0 Lane section, [3:2] = Deframer Input 1 lane select, etc */
    1,              /* Equalizer setting. Applied to all deserializer lanes. Range is 0..4*/
    0,              /* PN inversion per each lane.  bit[0] = 1 Invert PN of Lane 0, bit[1] = Invert PN of Lane 1, etc).*/
    0,              /* LMFC_Offset offset value to adjust deterministic latency. Range is 0..31*/
    0,              /* Flag for determining if SYSREF on relink should be set. Where, if > 0 = set, '0' = not set*/
    0,              /* Flag for determining if CMOS mode for TX Sync signal is used. Where, if > 0 = CMOS, '0' = LVDS*/
    0               /* Flag for determining if API will calculate the appropriate settings for deframer lane in to physical lanes. Where, if '0' = API will set automatic lane crossbar, '1' = set to manual mode and the value in deserializerLaneCrossbar will be used*/
Issue:
In the ADC9375 when the ORX is enabled(only 1 channel is enabled) and after the JESD bonding is success, The data is recieved from the IP core, it is observed for every 351 sample cycles there is a anomaly in the sine wave (refer the attached pic of the sine wave).
If the ADC tracking  calibration is disabled, the same is observed for every 1521 samples.
Kindly help us in resolving the issue.
Thanks in-advance,
deva
