AD9371/AD9375 alternative sampling frequency, Error code: 364 and 261
I am having difficulties changing the ADC/DAC sampling rate. We have designed a custom board with two AD9375’s. I began with a baseline profile template and was able to get waveforms to transmit and receive. The template uses a 122.88MHz DEV Clock and ADC/DAC clock – see attached. My final design requires a sampling rate of 81.81…MHz. To change the sampling frequency I performed the following steps:
  1. Using the filter wizard to generate a profile with sampling rates of 82MHz.
  2. I then open the profile in TES and finish the configuration.
  3. Using TES I generated Scripting files in C.
  4. I imported the C files into my design.
The issue I am having is when I change the sampling rates. I get errors when I run MYKONOS_setRfPllFrequency.
After a lot of troubleshooting and revisions of the profiles. I have narrowed the issue down to simply the deviceClock_khz parameter. I have tried a deviceClock of 82mhz, 164mhz, 122.88mhz and 125mhz. The table below illustrates the only parameters I change and the resulting output.
deviceClock_khz
82000
164000
125000
122880
clkPllVcoFreq_kHz
9840000
9840000
10000000
9830400
clkPllVcoDiv
VCODIV_3
VCODIV_3
VCODIV_2
VCODIV_2
TX.iqRate_kHz
82000
82000
125000
122880
TX.primarySigBandwidth_Hz
20500000
20500000
20000000
20000000
TX.rfBandwidth_Hz
41000000
41000000
102000000
100000000
TX.txDac3dBCorner_kHz
92000
92000
722000
710539
TX.txBbf3dBCorner_kHz
20500
20500
51000
50000
RX.iqRate_kHz
82000
82000
125000
122880
RX.rxBbf3dBCorner_kHz
20500
20500
102000
100000
ORX.iqRate_kHz
82000
82000
125000
122880
ORX.rxBbf3dBCorner_kHz
20500
20500
102000
100000
Status
FAIL
FAIL
PASS
PASS
Any guidance to help narrow the problem would be appreciated!
I have discovered that with a TX Input sampling rate of 82. The resulting DAC Clock is 328Mhz which is 640MHz. Therefore these sampling rates can't be attained without the use of another interpolator THBO which has no reference in the UG-992. Analog please confirm this is my issue and make a recommendation for a solution.
[edited by: Jpayne at 3:28 AM (GMT -4) on 7 Apr 2021]
  • ad937x_default_config_12288.txt
    // Copyright 2017 Ettus Research, a National Instruments Company
    // SPDX-License-Identifier: GPL-3.0-or-later
    #pragma once
    #include "../adi/t_mykonos.h"
    // This file is more or less the static config provided by a run of the eval software
    // except all pointers have been changed to nullptr
    // Hopefully this helps the compiler use these as purely constants
    // The pointers should be filled in if these data structures are to be actually used with
    // the API
    static const mykonosRxSettings_t DEFAULT_RX_SETTINGS_12288 = {
        nullptr, // Rx datapath profile, 3dB corner frequencies, and digital filter enables
        nullptr, // Rx JESD204b framer configuration structure
        nullptr, // Rx Gain control settings structure
        nullptr, // Rx AGC control settings structure
        RX1,              /* The desired Rx Channels to enable during initialization*/
        0,              /* Internal LO = 0, external LO*2 = 1*/
        2100000000U,    /* Rx PLL LO Frequency (internal or external LO)*/
        0               /* Flag to choose if complex baseband or real IF data are selected for Rx and ObsRx paths. Where, if > 0 = real IF data, '0' = zero IF (IQ) data*/
    static const mykonosRxProfile_t DEFAULT_RX_PROFILE_12288 = {
        // Rx 100MHz, IQrate 125MSPS, Dec5
        1,              /* The divider used to generate the ADC clock*/
        nullptr, // Pointer to Rx FIR filter structure
        2,              /* Rx FIR decimation (1,2,4)*/
        5,              /* Decimation of Dec5 or Dec4 filter (5,4)*/
        1,              /* If set, and DEC5 filter used, will use a higher rejection DEC5 FIR filter (1=Enabled, 0=Disabled)*/
        1,              /* RX Half band 1 decimation (1 or 2)*/
        122880,         /* Rx IQ data rate in kHz*/
        100000000,      /* The Rx RF passband bandwidth for the profile*/
        100000,         /* Rx BBF 3dB corner in kHz*/
        nullptr            /* pointer to custom ADC profile*/
    static const mykonosJesd204bFramerConfig_t DEFAULT_FRAMER_12288 = {
        0,              /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15)*/
        0,              /* JESD204B Configuration Device ID - link identification number. (Valid 0..255)*/
        0,              /* JESD204B Configuration starting Lane ID.  If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31)*/
        2,              /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain*/
        32,             /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes)*/
        0,              /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled.*/
        1,              /* 0=use internal SYSREF, 1= use external SYSREF*/
        0x01,           /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled*/
        0xE4,           /* serializerLaneCrossbar*/ //possibly 0xE4
        22,             /* serializerAmplitude - default 22 (valid (0-31)*/
        4,              /* preEmphasis - < default 4 (valid 0 - 7)*/
        0,              /* invertLanePolarity - default 0 ([0] will invert lane [0], bit1 will invert lane1)*/
        0,              /* lmfcOffset - LMFC_Offset offset value for deterministic latency setting*/
        0,              /* Flag for determining if SYSREF on relink should be set. Where, if > 0 = set, 0 = not set*/
        0,              /* Flag for determining if auto channel select for the xbar should be set. Where, if > 0 = set, '0' = not set*/
        0,              /* Selects SYNCb input source. Where, 0 = use RXSYNCB for this framer, 1 = use OBSRX_SYNCB for this framer*/
        0,              /* Flag for determining if CMOS mode for RX Sync signal is used. Where, if > 0 = CMOS, '0' = LVDS*/
        0,              /* Selects framer bit repeat or oversampling mode for lane rate matching. Where, 0 = bitRepeat mode (changes effective lanerate), 1 = overSample (maintains same lane rate between ObsRx framer and Rx framer and oversamples the ADC samples)*/
        0               /* Flag for determining if API will calculate the appropriate settings for framer lane outputs to physical lanes. Where, if '0' = API will set automatic lane crossbar, '1' = set to manual mode and the value in serializerLaneCrossbar will be used*/
    static const mykonosRxGainControl_t DEFAULT_RX_GAIN_12288 = {
        MGC,            /* Current Rx gain control mode setting*/
        255,            /* Rx1 Gain Index, can be used in different ways for manual and AGC gain control*/
        255,            /* Rx2 Gain Index, can be used in different ways for manual and AGC gain control*/
        255,            /* Max gain index for the currently loaded Rx1 Gain table*/
        195,            /* Min gain index for the currently loaded Rx1 Gain table*/
        255,            /* Max gain index for the currently loaded Rx2 Gain table*/
        195,            /* Min gain index for the currently loaded Rx2 Gain table*/
        0,              /* Stores Rx1 RSSI value read back from the Mykonos*/
        0               /* Stores Rx2 RSSI value read back from the Mykonos*/
    static const mykonosPeakDetAgcCfg_t DEFAULT_RX_PEAK_AGC_12288 = {
        0x1A,   /* apdHighThresh: */
        0x10,   /* apdLowThresh */
        0xB5,   /* hb2HighThresh */
        0x48,   /* hb2LowThresh */
        0x28,   /* hb2VeryLowThresh */
        0x06,   /* apdHighThreshExceededCnt */
        0x04,   /* apdLowThreshExceededCnt */
        0x06,   /* hb2HighThreshExceededCnt */
        0x04,   /* hb2LowThreshExceededCnt */
        0x04,   /* hb2VeryLowThreshExceededCnt */
        0x4,    /* apdHighGainStepAttack */
        0x2,    /* apdLowGainStepRecovery */
        0x4,    /* hb2HighGainStepAttack */
        0x2,    /* hb2LowGainStepRecovery */
        0x4,    /* hb2VeryLowGainStepRecovery */
        0x1,    /* apdFastAttack */
        0x1,    /* hb2FastAttack */
        0x1,    /* hb2OverloadDetectEnable */
        0x1,    /* hb2OverloadDurationCnt */
        0x1 /* hb2OverloadThreshCnt */
    static const mykonosPowerMeasAgcCfg_t DEFAULT_RX_POWER_AGC_12288 = {
        0x01,   /* pmdUpperHighThresh */
        0x03,   /* pmdUpperLowThresh */
        0x0C,   /* pmdLowerHighThresh */
        0x00,   /* pmdLowerLowThresh */
        0x4,    /* pmdUpperHighGainStepAttack */
        0x2,    /* pmdUpperLowGainStepAttack */
        0x2,    /* pmdLowerHighGainStepRecovery */
        0x4,    /* pmdLowerLowGainStepRecovery */
        0x00,   /* pmdMeasDuration */  // MRB10_tag differs from John P's TES output config of 0x08
        0x02    /* pmdMeasConfig */
    static const mykonosAgcCfg_t DEFAULT_RX_AGC_CTRL_12288 = {
        255,    /* agcRx1MaxGainIndex */
        195,    /* agcRx1MinGainIndex */
        255,    /* agcRx2MaxGainIndex */
        195,    /* agcRx2MinGainIndex: */
        255,    /* agcObsRxMaxGainIndex */
        203,    /* agcObsRxMinGainIndex */
        1,      /* agcObsRxSelect */
        1,      /* agcPeakThresholdMode */
        1,      /* agcLowThsPreventGainIncrease */
        9,  /* agcGainUpdateCounter */  // MRB10_tag differs from John P's TES output config of 0
        4,  /* agcSlowLoopSettlingDelay */
        2,  /* agcPeakWaitTime */
        1,  /* agcResetOnRxEnable */
        0,  /* agcEnableSyncPulseForGainCounter */
        nullptr, // *peakAgc
        nullptr // *powerAgc
    static const mykonosTxSettings_t DEFAULT_TX_SETTINGS_12288 = {
        nullptr, // Tx datapath profile, 3dB corner frequencies, and digital filter enables
        nullptr, // Mykonos JESD204b deframer config for the Tx data path
        TX1,            /* The desired Tx channels to enable during initialization*/
        0,              /* Internal LO=0, external LO*2 if =1*/
        2100000000U,    /* Tx PLL LO frequency (internal or external LO)*/
        TXATTEN_0P05_DB,/* Initial and current Tx1 Attenuation*/
        10000,          /* Initial and current Tx1 Attenuation mdB*/
        10000,          /* Initial and current Tx2 Attenuation mdB*/
        nullptr, // DPD,CLGC,VSWR settings. Only valid for AD9373 device, set pointer to NULL
                 // otherwise
        nullptr, // CLGC Config Structure. Only valid for AD9373 device, set pointer to NULL
                 // otherwise
        nullptr // VSWR Config Structure. Only valid for AD9373 device, set pointer to NULL
                // otherwise
    static const mykonosTxProfile_t DEFAULT_TX_PROFILE_12288 = {
        /* Tx 20/100MHz, IQrate 122.88MSPS, Dec5 */
        DACDIV_2p5,     /* The divider used to generate the DAC clock*/
        nullptr, // Pointer to Tx FIR filter structure
        2,              /* The Tx digital FIR filter interpolation (1,2,4)*/
        2,              /* Tx Halfband1 filter interpolation (1,2)*/
        1,              /* Tx Halfband2 filter interpolation (1,2)*/
        1,              /* TxInputHbInterpolation (1,2)*/
        122880,         /* Tx IQ data rate in kHz*/
        20000000,       /* Primary Signal BW*/
        100000000,      /* The Tx RF passband bandwidth for the profile*/
        710539,         /* The DAC filter 3dB corner in kHz*/
        50000,          /* Tx BBF 3dB corner in kHz*/
        0               /* Enable DPD, only valid for AD9373*/
    static const mykonosJesd204bDeframerConfig_t DEFAULT_DEFRAMER_12288 = {
        0,              /* bankId extension to Device ID (Valid 0..15)*/
        0,              /* deviceId  link identification number. (Valid 0..255)*/
        0,              /* lane0Id Lane0 ID. (Valid 0..31)*/
        2,              /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
        32,             /* K  #frames in a multiframe (default=32), F*K=multiple of 4. (F=2*M/numberOfLanes)*/
        0,              /* scramble  scrambling off if scramble= 0.*/
        1,              /* External SYSREF select. 0 = use internal SYSREF, 1 = external SYSREF*/
        0x01,           /* Deserializer lane select bit field. Where, [0] = Lane0 enabled, [1] = Lane1 enabled, etc */
        0xE4,           /* Lane crossbar to map physical lanes to deframer lane inputs [1:0] = Deframer Input 0 Lane section, [3:2] = Deframer Input 1 lane select, etc */
                        /* MRB10_tag This crossbar value is overwritten from set value hardcoded in deserializer_lane_xbar variable in mpm/python/usrp_mpm/dboard_manager/magnesium.py */
        1,              /* Equalizer setting. Applied to all deserializer lanes. Range is 0..4*/
        0,              /* PN inversion per each lane.  bit[0] = 1 Invert PN of Lane 0, bit[1] = Invert PN of Lane 1, etc).*/
        0,              /* LMFC_Offset offset value to adjust deterministic latency. Range is 0..31*/
        0,              /* Flag for determining if SYSREF on relink should be set. Where, if > 0 = set, '0' = not set*/
        0,              /* Flag for determining if CMOS mode for TX Sync signal is used. Where, if > 0 = CMOS, '0' = LVDS*/
        1               /* Flag for determining if API will calculate the appropriate settings for deframer lane in to physical lanes. Where, if '0' = API will set automatic lane crossbar, '1' = set to manual mode and the value in deserializerLaneCrossbar will be used*/
    static const mykonosObsRxSettings_t DEFAULT_ORX_SETTINGS_12288 = {
        nullptr, // ORx datapath profile, 3dB corner frequencies, and digital filter enables
        nullptr, // ObsRx gain control settings structure
        nullptr, // ORx AGC control settings structure
        nullptr, // Sniffer datapath profile, 3dB corner frequencies, and digital filter
                 // enables
        nullptr, // SnRx gain control settings structure
        nullptr, // ObsRx JESD204b framer configuration structure
        //(MYK_ORX1_ORX2 | MYK_SNRXA_B_C),/* obsRxChannel */ // MRB10_tag New ENUM below
        MYK_ORX1,/* obsRxChannel */
        OBSLO_TX_PLL,   /* (obsRxLoSource) The Obs Rx mixer can use the Tx Synth(TX_PLL) or Sniffer Synth (SNIFFER_PLL) */
        2100000000U,    /* SnRx PLL LO frequency in Hz */
        0,              /* Flag to choose if complex baseband or real IF data are selected for Rx and ObsRx paths. Where if > 0 = real IF data, '0' = complex data*/
        nullptr, // Custom Loopback ADC profile to set the bandwidth of the ADC response
        OBS_RX1_TXLO       /* Default ObsRx channel to enter when radioOn called */
        //OBS_RXOFF       /* Default ObsRx channel to enter when radioOn called */
    static const mykonosJesd204bFramerConfig_t DEFAULT_ORX_FRAMER_12288 = {
        0x02,           /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled*/
        0xE4,           /* Lane crossbar to map framer lane outputs to physical lanes*/
        1,              /* Selects SYNCb input source. Where, 0 = use RXSYNCB for this framer, 1 = use OBSRX_SYNCB for this framer*/
        1,              /* Selects framer bit repeat or oversampling mode for lane rate matching. Where, 0 = bitRepeat mode (changes effective lanerate), 1 = overSample (maintains same lane rate between ObsRx framer and Rx framer and oversamples the ADC samples)*/
    static const mykonosORxGainControl_t DEFAULT_ORX_GAIN_12288 = {
        MGC,            /* Current ORx gain control mode setting*/
        237,            /* ORx1 Gain Index, can be used in different ways for manual and AGC gain control*/
        255,            /* ORx2 Gain Index, can be used in different ways for manual and AGC gain control*/
        255,            /* Max gain index for the currently loaded ORx Gain table*/
        237             /* Min gain index for the currently loaded ORx Gain table*/
    static const mykonosAgcCfg_t DEFAULT_ORX_AGC_CTRL_12288 = {
    static const mykonosPeakDetAgcCfg_t DEFAULT_ORX_PEAK_AGC_12288 = {
    static const mykonosPowerMeasAgcCfg_t DEFAULT_ORX_POWER_AGC_12288 = {
    static const mykonosSnifferGainControl_t DEFAULT_SNIFFER_GAIN_12288 = {
        MGC,            /* Current Sniffer gain control mode setting*/
        255,            /* Current Sniffer gain index. Can be used differently for MANUAL Gain control/AGC*/
        255,            /* Max gain index for the currently loaded Sniffer Gain table*/
        203             /* Min gain index for the currently loaded Sniffer Gain table*/
    static const mykonosRxProfile_t DEFAULT_ORX_PROFILE_12288 = {
        /* ORX 100MHz, IQrate 122.88MSPS, Dec5 */
        nullptr, // Pointer to Rx FIR filter structure or NULL
        0,              /* If set, and DEC5 filter used, will use a higher rejection DEC5 FIR filter (1=Enabled, 0=Disabled)*/
    static mykonosRxProfile_t DEFAULT_SNIFFER_PROFILE_12288 =
    { /* SRx 20MHz, IQrate 30.72MSPS, Dec5 */
        nullptr,        /* Pointer to Rx FIR filter structure or NULL*/
        4,              /* Rx FIR decimation (1,2,4)*/
        2,              /* RX Half band 1 decimation (1 or 2)*/
        30720,          /* Rx IQ data rate in kHz*/
        20000000,       /* The Rx RF passband bandwidth for the profile*/
    static const mykonosArmGpioConfig_t DEFAULT_ARM_GPIO_12288 = {
        0,  // useRx2EnablePin; /*!< 0= RX1_ENABLE controls RX1 and RX2, 1 = separate RX1_ENABLE/RX2_ENABLE pins */
        0,  // useTx2EnablePin; /*!< 0= TX1_ENABLE controls TX1 and TX2, 1 = separate TX1_ENABLE/TX2_ENABLE pins */
        0,  // txRxPinMode;     /*!< 0= ARM command mode, 1 = Pin mode to power up Tx/Rx chains */
        0,  // orxPinMode;      /*!< 0= ARM command mode, 1 = Pin mode to power up ObsRx receiver*/
        /*Mykonos ARM input GPIO pins -- Only valid if orxPinMode = 1 */
        0,  // orxTriggerPin; /*!< Select desired GPIO pin (valid 4-15) */
        0,  // orxMode2Pin;   /*!< Select desired GPIO pin (valid 0-18) */
        0,  // orxMode1Pin;   /*!< Select desired GPIO pin (valid 0-18) */
        0,  // orxMode0Pin;   /*!< Select desired GPIO pin (valid 0-18) */
        /* Mykonos ARM output GPIO pins  --  always available, even when pin mode not enabled*/
        0,  // rx1EnableAck;  /*!< Select desired GPIO pin (0-15), [4] = Output Enable */
        0,  // rx2EnableAck;  /*!< Select desired GPIO pin (0-15), [4] = Output Enable */
        0,  // tx1EnableAck;  /*!< Select desired GPIO pin (0-15), [4] = Output Enable */
        0,  // tx2EnableAck;  /*!< Select desired GPIO pin (0-15), [4] = Output Enable */
        0,  // orx1EnableAck;  /*!< Select desired GPIO pin (0-15), [4] = Output Enable */
        0,  // orx2EnableAck;  /*!< Select desired GPIO pin (0-15), [4] = Output Enable */
        0,  // srxEnableAck;  /*!< Select desired GPIO pin (0-15), [4] = Output Enable */
        0   // txObsSelect;   /*!< Select desired GPIO pin (0-15), [4] = Output Enable */
        /* When 2Tx are used with only 1 ORx input, this GPIO tells the BBIC which Tx channel is   */
        /* active for calibrations, so BBIC can route correct RF Tx path into the single ORx input*/
    static const mykonosGpio3v3_t DEFAULT_GPIO_3V3_12288 = {
        //3962,             /*!< Oe per pin, 1=output, 0 = input */ // MRB10_tag changed from 0 to enable 3v3 gpio pins on ad9375
        0b001000000000,         /*!< Oe per pin, 1=output, 0 = input */ // MRB10_tag changed from 0 to enable 3v3 gpio pins on ad9375
        GPIO3V3_BITBANG_MODE,   /*!< Mode for GPIO3V3[3:0] */
        GPIO3V3_BITBANG_MODE,   /*!< Mode for GPIO3V3[7:4] */
        GPIO3V3_BITBANG_MODE,   /*!< Mode for GPIO3V3[11:8] */
    static const mykonosGpioLowVoltage_t DEFAULT_GPIO_12288 = {
        //524287,/* Oe per pin, 1=output, 0 = input */
        0b0,                /* Oe per pin, 1=output, 0 = input */
        GPIO_BITBANG_MODE,/* Mode for GPIO[3:0] */
        GPIO_BITBANG_MODE,/* Mode for GPIO[7:4] */
        GPIO_BITBANG_MODE,/* Mode for GPIO[11:8] */
        GPIO_BITBANG_MODE,/* Mode for GPIO[15:12] */
        GPIO_BITBANG_MODE,/* Mode for GPIO[18:16] */
    static const mykonosAuxIo_t DEFAULT_AUX_IO_12288 = {
        0b0000010010,                //auxDacEnableMask uint16_t //MRB10_tag changed from 0 to enable DAC 1 & 4
        {0,0,0,0,0,1023,0,0,0,0},    //AuxDacValue uint16[10]
        {0,0,0,0,0,0,0,0,0,0},   //AuxDacSlope uint8[10]
        {0,0,0,0,0,3,0,0,3,0},   //AuxDacVref uint8[10]
        nullptr, // *mykonosGpio3v3_t
        nullptr, // *mykonosGpioLowVoltage_t
        nullptr // *mykonosArmGpioConfig_t
    static const mykonosDigClocks_t DEFAULT_CLOCKS_12288 = {
        122880,         /* CLKPLL and device reference clock frequency in kHz*/
        9830400,        /* CLKPLL VCO frequency in kHz*/
        VCODIV_2,       /* CLKPLL VCO divider*/
        4               /* CLKPLL high speed clock divider*/
    on Apr 8, 2021 5:50 PM in reply to Jpayne
    When you are changing the dev_clk frequency, are you changing the AD9528 VCXO accordingly? The VCXO frequency should be an integer multiple of the dev_clk frequency. refer the below link:
    https://ez.analog.com/wide-band-rf-transceivers/design-support-ad9371/w/documents/10080/ad9371-evaluation-board-vcxo-selection
