How to change AD9371 transmission gain?
We use ADRV9371-W and ZC706 with No-OS Setup.
We want to set as high transmit gain as possible without an external PA.
Although 1 [MHz] and 0 [dBFS] CW were prepared and transmitted as transmission data, only an output of 0 [dBm] was obtained.
(This value takes into consideration the attenuation from the ADRV9371 TX1 terminal to the measuring instrument.)
However, according to the answer of following URL, 0 dBFS corresponds to 7 dBm for a CW tone and for any other digital input output power will be relative to 0 dBFS.
https://analogdevices.telligenthosting.net/wide-band-rf-transceivers/design-support-ad9371/f/q-a/79542/ad9371-transceiver-output-power-dbm-vs-digital-signal-power-dbfs
Where does this difference in output power occur?
And how can it be changed?
