A lot of scalar numbers are specified in ways that may be appropriate for one application but not another. For example, parts intended for switching usually have timing information rather than GBW or Ft: how I convert to make it useful?
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
Timing specifications do not typically have a correlation to GBW or Ft. Timing specs only describe how long it takes the switch to turn on or off, which then relates to the maximum switching frequency. GBW or Ft would be related more to the capacitance of the switch and its on resistance. So a switch with a 10pF capacitance and 10ohm Ron would have an Ft of about 1.6GHz, likely a much higher equivalent bandwidth than the switching speed.
