Soft start using triac
Hi everyone,
I want to develop a soft start system for the receiver. In real system, it is a power supply in the laboratory with a variable resistance value - hence programming the resistance R3 as a variable value determined by the voltage source.
The system to perform a soft start for the receiver, which causes a large current peak when switching on the voltage, is based on a triac, i.e. when the triac sees that the current flowing to R3 is 12A, it cuts off the sine wave at this point, which makes that the intensity will never reach a greater value.
Besides the soft start model, I am attaching the contents of trctriac.lib and TRIAC_Teccor.asy which I have implemented into the circuit in the form of a triac element.
The attached files is tectriac that should be resave as .lib and TRIAC_Teccor as asy (TRIAN_Teccor.asy into \LTspiceXVII\lib\sym and tectriac.lib into \LTspiceXVII\lib\sub).
Please help me develop an algorithm for setting the changeable angle. I thought about defining angle alpha using the arcus function, e.g. atan(I(R3))=12, but that was beyond my skills.
Anna
Version 4
SymbolType CELL
LINE Normal 0 44 36 44
LINE Normal 0 20 36 20
LINE Normal 36 20 20 44
LINE Normal 4 20 20 44
LINE Normal 32 0 32 20
LINE Normal 32 44 32 64
LINE Normal 28 44 64 44
LINE Normal 28 44 44 20
LINE Normal 44 20 60 44
LINE Normal 36 20 64 20
LINE Normal 0 64 -16 64
LINE Normal 0 64 20 44
WINDOW 0 48 0 Left 0
WINDOW 38 48 61 Left 0
SYMATTR Prefix X
SYMATTR Description Generic TRIAC symbol for use with a model that you supply.
SYMATTR ModelFile tectriac.lib
SYMATTR SpiceModel L6008L6
PIN 32 0 NONE 0
PINATTR PinName MT2
PINATTR SpiceOrder 1
PIN -16 64 NONE 0
PINATTR PinName G
PINATTR SpiceOrder 2
PIN 32 64 NONE 0
PINATTR PinName MT1
PINATTR SpiceOrder 3
8883.soft_start.asc
*SRC=L201E3;L201E3;TRIACS;TECCOR;200V 1A
*SYM=TRIAC
.SUBCKT L201E3    1  2  3
*     TERMINALS: MT2 G MT1
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  200MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL DIN  D (IS=5.35F)
.MODEL DIP  D (IS=5.35F N=1.19)
.MODEL DZ   D (IS=5.35F N=1.5 IBV=1U BV=200)
.MODEL POUT PNP (IS=5.35F BF=5 CJE=117P TF=38.2U)
.MODEL NOUT NPN (IS=5.35F BF=20 CJE=117P CJC=23.4P TF=2.55U)
.ENDS
*SRC=L401E3;L401E3;TRIACS;TECCOR;400V 1A
*SYM=TRIAC
.SUBCKT L401E3    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  400MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL DZ   D (IS=5.35F N=1.5 IBV=1U BV=400)
.ENDS
*SRC=L601E3;L601E3;TRIACS;TECCOR;600V 1A
*SYM=TRIAC
.SUBCKT L601E3    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  600MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL DZ   D (IS=5.35F N=1.5 IBV=1U BV=600)
.MODEL POUT PNP (IS=5.35F BF=5 CJE=235P TF=38.2U)
.MODEL NOUT NPN (IS=5.35F BF=20 CJE=235P CJC=46.9P TF=2.55U)
.ENDS
*SRC=L201E5;L201E5;TRIACS;TECCOR;200V 1A
*SYM=TRIAC
.SUBCKT L201E5    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  200MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL POUT PNP (IS=5.35F BF=5 CJE=117P TF=43.4U)
.MODEL NOUT NPN (IS=5.35F BF=20 CJE=117P CJC=23.4P TF=2.89U)
.ENDS
*SRC=L401E5;L401E5;TRIACS;TECCOR;400V 1A
*SYM=TRIAC
.SUBCKT L401E5    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  400MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.ENDS
*SRC=L601E5;L601E5;TRIACS;TECCOR;600V 1A
*SYM=TRIAC
.SUBCKT L601E5    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  600MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL POUT PNP (IS=5.35F BF=5 CJE=235P TF=43.4U)
.MODEL NOUT NPN (IS=5.35F BF=20 CJE=235P CJC=46.9P TF=2.89U)
.ENDS
*SRC=L201E6;L201E6;TRIACS;TECCOR;200V 1A
*SYM=TRIAC
.SUBCKT L201E6    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  200MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL POUT PNP (IS=5.35F BF=5 CJE=78.2P TF=63.8U)
.MODEL NOUT NPN (IS=5.35F BF=20 CJE=78.2P CJC=15.6P TF=4.25U)
.ENDS
*SRC=L401E6;L401E6;TRIACS;TECCOR;400V 1A
*SYM=TRIAC
.SUBCKT L401E6    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  400MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.ENDS
*SRC=L601E6;L601E6;TRIACS;TECCOR;600V 1A
*SYM=TRIAC
.SUBCKT L601E6    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  600MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL POUT PNP (IS=5.35F BF=5 CJE=117P TF=63.8U)
.MODEL NOUT NPN (IS=5.35F BF=20 CJE=117P CJC=23.4P TF=4.25U)
.ENDS
*SRC=L201E8;L201E8;TRIACS;TECCOR;200V 1A
*SYM=TRIAC
.SUBCKT L201E8    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  200MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL POUT PNP (IS=5.35F BF=5 CJE=67P TF=76.5U)
.MODEL NOUT NPN (IS=5.35F BF=20 CJE=67P CJC=13.4P TF=5.1U)
.ENDS
*SRC=L401E8;L401E8;TRIACS;TECCOR;400V 1A
*SYM=TRIAC
.SUBCKT L401E8    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  400MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.ENDS
*SRC=L601E8;L601E8;TRIACS;TECCOR;600V 1A
*SYM=TRIAC
.SUBCKT L601E8    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  600MEG
RT2 1 7  0.528
RH  7 6  750
RGP 8 3  545
RG  2 8  264
RS  8 4  526
DN  9 2  DIN OFF
RN  9 3  278
GNN  6 7 9 3 3.88M
GNP  4 5 9 3 5.12M
DP 2 10  DIP OFF
RP 10 3  162
GP  7 6 10 3 2.61M
.MODEL POUT PNP (IS=5.35F BF=5 CJE=93.8P TF=76.5U)
.MODEL NOUT NPN (IS=5.35F BF=20 CJE=93.8P CJC=18.8P TF=5.1U)
.ENDS
*SRC=L2004L3;L2004L3;TRIACS;TECCOR;200V 4A
*SYM=TRIAC
.SUBCKT L2004L3   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  50MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.MODEL DIN  D (IS=21.4F)
.MODEL DIP  D (IS=21.4F N=1.19)
.MODEL DZ   D (IS=21.4F N=1.5 IBV=4U BV=200)
.MODEL POUT PNP (IS=21.4F BF=5 CJE=375P TF=38.2U)
.MODEL NOUT NPN (IS=21.4F BF=20 CJE=375P CJC=75P TF=2.55U)
.ENDS
*SRC=L4004L3;L4004L3;TRIACS;TECCOR;400V 4A
*SYM=TRIAC
.SUBCKT L4004L3   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  100MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.MODEL DZ   D (IS=21.4F N=1.5 IBV=4U BV=400)
.ENDS
*SRC=L6004L3;L6004L3;TRIACS;TECCOR;600V 4A
*SYM=TRIAC
.SUBCKT L6004L3   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  150MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.MODEL DZ   D (IS=21.4F N=1.5 IBV=4U BV=600)
.MODEL POUT PNP (IS=21.4F BF=5 CJE=625P TF=38.2U)
.MODEL NOUT NPN (IS=21.4F BF=20 CJE=625P CJC=125P TF=2.55U)
.ENDS
*SRC=L2004L5;L2004L5;TRIACS;TECCOR;200V 4A
*SYM=TRIAC
.SUBCKT L2004L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  50MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.MODEL POUT PNP (IS=21.4F BF=5 CJE=375P TF=43.4U)
.MODEL NOUT NPN (IS=21.4F BF=20 CJE=375P CJC=75P TF=2.89U)
.ENDS
*SRC=L4004L5;L4004L5;TRIACS;TECCOR;400V 4A
*SYM=TRIAC
.SUBCKT L4004L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  100MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.ENDS
*SRC=L6004L5;L6004L5;TRIACS;TECCOR;600V 4A
*SYM=TRIAC
.SUBCKT L6004L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  150MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.MODEL POUT PNP (IS=21.4F BF=5 CJE=938P TF=43.4U)
.MODEL NOUT NPN (IS=21.4F BF=20 CJE=938P CJC=188P TF=2.89U)
.ENDS
*SRC=L2004L6;L2004L6;TRIACS;TECCOR;200V 4A
*SYM=TRIAC
.SUBCKT L2004L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  50MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.MODEL POUT PNP (IS=21.4F BF=5 CJE=313P TF=63.8U)
.MODEL NOUT NPN (IS=21.4F BF=20 CJE=313P CJC=62.5P TF=4.25U)
.ENDS
*SRC=L4004L6;L4004L6;TRIACS;TECCOR;400V 4A
*SYM=TRIAC
.SUBCKT L4004L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  100MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.ENDS
*SRC=L6004L6;L6004L6;TRIACS;TECCOR;400V 4A
*SYM=TRIAC
.SUBCKT L6004L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  100MEG
RT2 1 7  0.132
RH  7 6  187
RGP 8 3  136
RG  2 8  65.9
RS  8 4  131
DN  9 2  DIN OFF
RN  9 3  69.5
GNN  6 7 9 3 15.5M
GNP  4 5 9 3 20.5M
DP 2 10  DIP OFF
RP 10 3  40.5
GP  7 6 10 3 10.4M
.MODEL POUT PNP (IS=21.4F BF=5 CJE=469P TF=63.8U)
.MODEL NOUT NPN (IS=21.4F BF=20 CJE=469P CJC=93.8P TF=4.25U)
.ENDS
*SRC=L2004L8;L2004L8;TRIACS;TECCOR;200V 4A
*SYM=TRIAC
.SUBCKT L2004L8   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  20MEG
RT2 1 7  0.123
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.MODEL DIN  D (IS=115F)
.MODEL DIP  D (IS=115F N=1.19)
.MODEL DZ   D (IS=115F N=1.5 IBV=10U BV=200)
.MODEL POUT PNP (IS=115F BF=5 CJE=1.44N TF=76.5U)
.MODEL NOUT NPN (IS=115F BF=20 CJE=1.44N CJC=287P TF=5.1U)
.ENDS
*SRC=L4004L8;L4004L8;TRIACS;TECCOR;400V 4A
*SYM=TRIAC
.SUBCKT L4004L8   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  40MEG
RT2 1 7  0.123
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.MODEL DZ   D (IS=115F N=1.5 IBV=10U BV=400)
.ENDS
*SRC=L6004L8;L6004L8;TRIACS;TECCOR;600V 4A
*SYM=TRIAC
.SUBCKT L6004L8   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  60MEG
RT2 1 7  0.123
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.MODEL DZ   D (IS=115F N=1.5 IBV=10U BV=600)
.MODEL POUT PNP (IS=115F BF=5 CJE=2.01N TF=76.5U)
.MODEL NOUT NPN (IS=115F BF=20 CJE=2.01N CJC=402P TF=5.1U)
.ENDS
*SRC=L2006L5;L2006L5;TRIACS;TECCOR;200V 6A
*SYM=TRIAC
.SUBCKT L2006L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  82.2M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.MODEL DIN  D (IS=76.4F)
.MODEL DIP  D (IS=76.4F N=1.19)
.MODEL DZ   D (IS=76.4F N=1.5 IBV=20U BV=200)
.MODEL POUT PNP (IS=76.4F BF=5 CJE=838P TF=43.4U)
.MODEL NOUT NPN (IS=76.4F BF=20 CJE=838P CJC=168P TF=2.89U)
.ENDS
*SRC=L4006L5;L4006L5;TRIACS;TECCOR;400V 6A
*SYM=TRIAC
.SUBCKT L4006L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  20MEG
RT2 1 7  82.2M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.MODEL DZ   D (IS=76.4F N=1.5 IBV=20U BV=400)
.MODEL POUT PNP (IS=76.4F BF=5 CJE=1.12N TF=43.4U)
.MODEL NOUT NPN (IS=76.4F BF=20 CJE=1.12N CJC=223P TF=2.89U)
.ENDS
*SRC=L6006L5;L6006L5;TRIACS;TECCOR;600V 6A
*SYM=TRIAC
.SUBCKT L6006L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  30MEG
RT2 1 7  82.2M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.MODEL DZ   D (IS=76.4F N=1.5 IBV=20U BV=600)
.MODEL POUT PNP (IS=76.4F BF=5 CJE=1.68N TF=43.4U)
.MODEL NOUT NPN (IS=76.4F BF=20 CJE=1.68N CJC=335P TF=2.89U)
.ENDS
*SRC=L2006L6;L2006L6;TRIACS;TECCOR;200V 6A
*SYM=TRIAC
.SUBCKT L2006L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  82.2M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.MODEL POUT PNP (IS=76.4F BF=5 CJE=838P TF=63.8U)
.MODEL NOUT NPN (IS=76.4F BF=20 CJE=838P CJC=168P TF=4.25U)
.ENDS
*SRC=L4006L6;L4006L6;TRIACS;TECCOR;400V 6A
*SYM=TRIAC
.SUBCKT L4006L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  20MEG
RT2 1 7  82.2M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.MODEL POUT PNP (IS=76.4F BF=5 CJE=1.12N TF=63.8U)
.MODEL NOUT NPN (IS=76.4F BF=20 CJE=1.12N CJC=223P TF=4.25U)
.ENDS
*SRC=L6006L6;L6006L6;TRIACS;TECCOR;600V 6A
*SYM=TRIAC
.SUBCKT L6006L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  30MEG
RT2 1 7  82.2M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.MODEL POUT PNP (IS=76.4F BF=5 CJE=1.34N TF=63.8U)
.MODEL NOUT NPN (IS=76.4F BF=20 CJE=1.34N CJC=268P TF=4.25U)
.ENDS
*SRC=L2006L8;L2006L8;TRIACS;TECCOR;200V 6A
*SYM=TRIAC
.SUBCKT L2006L8   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  82.2M
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.MODEL DZ   D (IS=115F N=1.5 IBV=20U BV=200)
.MODEL POUT PNP (IS=115F BF=5 CJE=1.12N TF=76.5U)
.MODEL NOUT NPN (IS=115F BF=20 CJE=1.12N CJC=223P TF=5.1U)
.ENDS
*SRC=L4006L8;L4006L8;TRIACS;TECCOR;400V 6A
*SYM=TRIAC
.SUBCKT L4006L8   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  20MEG
RT2 1 7  82.2M
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.MODEL DZ   D (IS=115F N=1.5 IBV=20U BV=400)
.MODEL POUT PNP (IS=115F BF=5 CJE=1.26N TF=76.5U)
.MODEL NOUT NPN (IS=115F BF=20 CJE=1.26N CJC=251P TF=5.1U)
.ENDS
*SRC=L6006L8;L6006L8;TRIACS;TECCOR;600V 6A
*SYM=TRIAC
.SUBCKT L6006L8   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  30MEG
RT2 1 7  82.2M
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.MODEL DZ   D (IS=115F N=1.5 IBV=20U BV=600)
.MODEL POUT PNP (IS=115F BF=5 CJE=1.68N TF=76.5U)
.MODEL NOUT NPN (IS=115F BF=20 CJE=1.68N CJC=335P TF=5.1U)
.ENDS
*SRC=L2008L6;L2008L6;TRIACS;TECCOR;200V 8A
*SYM=TRIAC
.SUBCKT L2008L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  61.6M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.ENDS
*SRC=L4008L6;L4008L6;TRIACS;TECCOR;400V 8A
*SYM=TRIAC
.SUBCKT L4008L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  20MEG
RT2 1 7  61.6M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.ENDS
*SRC=L6008L6;L6008L6;TRIACS;TECCOR;800V 8A
*SYM=TRIAC
.SUBCKT L6008L6   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  40MEG
RT2 1 7  61.6M
RH  7 6  52.5
RGP 8 3  120
RG  2 8  58
RS  8 4  12
DN  9 2  DIN OFF
RN  9 3  61.2
GNN  6 7 9 3 55.4M
GNP  4 5 9 3 70.5M
DP 2 10  DIP OFF
RP 10 3  35.6
GP  7 6 10 3 37.3M
.MODEL DZ   D (IS=76.4F N=1.5 IBV=20U BV=800)
.MODEL POUT PNP (IS=76.4F BF=100 CJE=1.6p TF=0)
.MODEL NOUT NPN (IS=76.4F BF=100 CJE=1.6p CJC=3p TF=0)
.ENDS
*SRC=L2002L8;L2002L8;TRIACS;TECCOR;200V 8A
*SYM=TRIAC
.SUBCKT L2002L8   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  61.6M
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.ENDS
*SRC=L4008L8;L4008L8;TRIACS;TECCOR;600V 8A
*SYM=TRIAC
.SUBCKT L4008L8   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  30MEG
RT2 1 7  61.6M
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.ENDS
*SRC=Q201E3;Q201E3;TRIACS;TECCOR;200V 1A
*SYM=TRIAC
.SUBCKT Q201E3    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  0.493
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.MODEL POUT PNP (IS=115F BF=5 CJE=1.26N TF=63.8U)
.MODEL NOUT NPN (IS=115F BF=20 CJE=1.26N CJC=251P TF=4.25U)
.ENDS
*SRC=Q401E3;Q401E3;TRIACS;TECCOR;400V 1A
*SYM=TRIAC
.SUBCKT Q401E3    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  20MEG
RT2 1 7  0.493
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.ENDS
*SRC=Q501E3;Q501E3;TRIACS;TECCOR;500V 1A
*SYM=TRIAC
.SUBCKT Q501E3    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  25MEG
RT2 1 7  0.493
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.MODEL DZ   D (IS=115F N=1.5 IBV=20U BV=500)
.MODEL POUT PNP (IS=115F BF=5 CJE=1.68N TF=63.8U)
.MODEL NOUT NPN (IS=115F BF=20 CJE=1.68N CJC=335P TF=4.25U)
.ENDS
*SRC=Q601E3;Q601E3;TRIACS;TECCOR;600V 1A
*SYM=TRIAC
.SUBCKT Q601E3    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  30MEG
RT2 1 7  0.493
RH  7 6  35
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 83M
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 55.9M
.ENDS
*SRC=Q201E4;Q201E4;TRIACS;TECCOR;200V 1A
*SYM=TRIAC
.SUBCKT Q201E4    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  0.493
RH  7 6  21
RGP 8 3  24
RG  2 8  11.6
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.138
GNP  4 5 9 3 0.261
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 93.2M
.MODEL DIN  D (IS=191F)
.MODEL DIP  D (IS=191F N=1.19)
.MODEL DZ   D (IS=191F N=1.5 IBV=20U BV=200)
.MODEL POUT PNP (IS=191F BF=5 CJE=1.68N TF=76.5U)
.MODEL NOUT NPN (IS=191F BF=20 CJE=1.68N CJC=335P TF=5.1U)
.ENDS
*SRC=Q401E4;Q401E4;TRIACS;TECCOR;400V 1A
*SYM=TRIAC
.SUBCKT Q401E4    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  20MEG
RT2 1 7  0.493
RH  7 6  21
RGP 8 3  24
RG  2 8  11.6
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.138
GNP  4 5 9 3 0.261
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 93.2M
.MODEL DZ   D (IS=191F N=1.5 IBV=20U BV=400)
.ENDS
*SRC=Q501E4;Q501E4;TRIACS;TECCOR;500V 1A
*SYM=TRIAC
.SUBCKT Q501E4    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  25MEG
RT2 1 7  0.493
RH  7 6  21
RGP 8 3  24
RG  2 8  11.6
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.138
GNP  4 5 9 3 0.261
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 93.2M
.MODEL DZ   D (IS=191F N=1.5 IBV=20U BV=500)
.MODEL POUT PNP (IS=191F BF=5 CJE=2.09N TF=76.5U)
.MODEL NOUT NPN (IS=191F BF=20 CJE=2.09N CJC=419P TF=5.1U)
.ENDS
*SRC=Q601E4;Q601E4;TRIACS;TECCOR;600V 1A
*SYM=TRIAC
.SUBCKT Q601E4    1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  30MEG
RT2 1 7  0.493
RH  7 6  21
RGP 8 3  24
RG  2 8  11.6
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.138
GNP  4 5 9 3 0.261
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 93.2M
.MODEL DZ   D (IS=191F N=1.5 IBV=20U BV=600)
.ENDS
*SRC=Q2004L3;Q2004L3;TRIACS;TECCOR;200V 4A
*SYM=TRIAC
.SUBCKT Q2004L3   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  4MEG
RT2 1 7  0.123
RH  7 6  26.2
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 0.111
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 74.6M
.MODEL DIN  D (IS=153F)
.MODEL DIP  D (IS=153F N=1.19)
.MODEL DZ   D (IS=153F N=1.5 IBV=50U BV=200)
.MODEL POUT PNP (IS=153F BF=5 CJE=1.34N TF=63.8U)
.MODEL NOUT NPN (IS=153F BF=20 CJE=1.34N CJC=268P TF=4.25U)
.ENDS
*SRC=Q4004L3;Q4004L3;TRIACS;TECCOR;400V 4A
*SYM=TRIAC
.SUBCKT Q4004L3   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  0.123
RH  7 6  26.2
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 0.111
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 74.6M
.MODEL DZ   D (IS=153F N=1.5 IBV=50U BV=400)
.ENDS
*SRC=Q5004L3;Q5004L3;TRIACS;TECCOR;500V 4A
*SYM=TRIAC
.SUBCKT Q5004L3   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  0.123
RH  7 6  26.2
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 0.111
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 74.6M
.MODEL DZ   D (IS=153F N=1.5 IBV=50U BV=500)
.MODEL POUT PNP (IS=153F BF=5 CJE=1.68N TF=63.8U)
.MODEL NOUT NPN (IS=153F BF=20 CJE=1.68N CJC=335P TF=4.25U)
.ENDS
*SRC=Q6004L3;Q6004L3;TRIACS;TECCOR;600V 4A
*SYM=TRIAC
.SUBCKT Q6004L3   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  12MEG
RT2 1 7  0.123
RH  7 6  26.2
RGP 8 3  60
RG  2 8  29
RS  8 4  6
DN  9 2  DIN OFF
RN  9 3  30.6
GNN  6 7 9 3 0.111
GNP  4 5 9 3 0.141
DP 2 10  DIP OFF
RP 10 3  17.8
GP  7 6 10 3 74.6M
.MODEL DZ   D (IS=153F N=1.5 IBV=50U BV=600)
.ENDS
*SRC=Q2004L4;Q2004L4;TRIACS;TECCOR;200V 4A
*SYM=TRIAC
.SUBCKT Q2004L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  4MEG
RT2 1 7  0.123
RH  7 6  17.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.166
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.112
.MODEL DIN  D (IS=229F)
.MODEL DIP  D (IS=229F N=1.19)
.MODEL DZ   D (IS=229F N=1.5 IBV=50U BV=200)
.MODEL POUT PNP (IS=229F BF=5 CJE=1N TF=76.5U)
.MODEL NOUT NPN (IS=229F BF=20 CJE=1N CJC=201P TF=5.1U)
.ENDS
*SRC=Q4004L4;Q4004L4;TRIACS;TECCOR;400V 4A
*SYM=TRIAC
.SUBCKT Q4004L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  0.123
RH  7 6  17.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.166
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.112
.MODEL DZ   D (IS=229F N=1.5 IBV=50U BV=400)
.ENDS
*SRC=Q5004L4;Q5004L4;TRIACS;TECCOR;500V 4A
*SYM=TRIAC
.SUBCKT Q5004L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  0.123
RH  7 6  17.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.166
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.112
.MODEL DZ   D (IS=229F N=1.5 IBV=50U BV=500)
.MODEL POUT PNP (IS=229F BF=5 CJE=1.34N TF=76.5U)
.MODEL NOUT NPN (IS=229F BF=20 CJE=1.34N CJC=268P TF=5.1U)
.ENDS
*SRC=Q6004L4;Q6004L4;TRIACS;TECCOR;600V 4A
*SYM=TRIAC
.SUBCKT Q6004L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  12MEG
RT2 1 7  0.123
RH  7 6  17.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.166
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.112
.MODEL DZ   D (IS=229F N=1.5 IBV=50U BV=600)
.ENDS
*SRC=Q7004L4;Q7004L4;TRIACS;TECCOR;700V 4A
*SYM=TRIAC
.SUBCKT Q7004L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  14MEG
RT2 1 7  0.123
RH  7 6  17.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.166
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.112
.MODEL DZ   D (IS=229F N=1.5 IBV=50U BV=700)
.MODEL POUT PNP (IS=229F BF=5 CJE=1.68N TF=76.5U)
.MODEL NOUT NPN (IS=229F BF=20 CJE=1.68N CJC=335P TF=5.1U)
.ENDS
*SRC=Q8004L4;Q8004L4;TRIACS;TECCOR;800V 4A
*SYM=TRIAC
.SUBCKT Q8004L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  16MEG
RT2 1 7  0.123
RH  7 6  17.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.166
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.112
.MODEL DZ   D (IS=229F N=1.5 IBV=50U BV=800)
.ENDS
*SRC=Q2006L4;Q2006L4;TRIACS;TECCOR;200V 6A
*SYM=TRIAC
.SUBCKT Q2006L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  4MEG
RT2 1 7  82.2M
RH  7 6  10.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.186
.MODEL DIN  D (IS=382F)
.MODEL DIP  D (IS=382F N=1.19)
.MODEL DZ   D (IS=382F N=1.5 IBV=50U BV=200)
.MODEL POUT PNP (IS=382F BF=5 CJE=838P TF=76.5U)
.MODEL NOUT NPN (IS=382F BF=20 CJE=838P CJC=168P TF=5.1U)
.ENDS
*SRC=Q4006L4;Q4006L4;TRIACS;TECCOR;400V 6A
*SYM=TRIAC
.SUBCKT Q4006L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  82.2M
RH  7 6  10.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.186
.MODEL DZ   D (IS=382F N=1.5 IBV=50U BV=400)
.ENDS
*SRC=Q5006L4;Q5006L4;TRIACS;TECCOR;500V 6A
*SYM=TRIAC
.SUBCKT Q5006L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  82.2M
RH  7 6  10.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 0.186
.MODEL DZ   D (IS=382F N=1.5 IBV=50U BV=500)
.MODEL POUT PNP (IS=382F BF=5 CJE=1.12N TF=76.5U)
.MODEL NOUT NPN (IS=382F BF=20 CJE=1.12N CJC=223P TF=5.1U)
.ENDS
*SRC=Q6006L5;Q6006L5;TRIACS;TECCOR;600V 6A
*SYM=TRIAC
.SUBCKT Q6006L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  12MEG
RT2 1 7  82.2M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.MODEL DZ   D (IS=382F N=1.5 IBV=50U BV=600)
.ENDS
*SRC=Q7006L5;Q7006L5;TRIACS;TECCOR;700V 6A
*SYM=TRIAC
.SUBCKT Q7006L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  14MEG
RT2 1 7  82.2M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.MODEL DZ   D (IS=382F N=1.5 IBV=50U BV=700)
.MODEL POUT PNP (IS=382F BF=5 CJE=1.34N TF=76.5U)
.MODEL NOUT NPN (IS=382F BF=20 CJE=1.34N CJC=268P TF=5.1U)
.ENDS
*SRC=Q8006L5;Q8006L5;TRIACS;TECCOR;800V 6A
*SYM=TRIAC
.SUBCKT Q8006L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  16MEG
RT2 1 7  82.2M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.MODEL DZ   D (IS=382F N=1.5 IBV=50U BV=800)
.ENDS
*SRC=Q2008L4;Q2008L4;TRIACS;TECCOR;200V 8A
*SYM=TRIAC
.SUBCKT Q2008L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  4MEG
RT2 1 7  61.6M
RH  7 6  10.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 4.29
.MODEL POUT PNP (IS=382F BF=5 CJE=670P TF=76.5U)
.MODEL NOUT NPN (IS=382F BF=20 CJE=670P CJC=134P TF=5.1U)
.ENDS
*SRC=Q4008L4;Q4008L4;TRIACS;TECCOR;400V 8A
*SYM=TRIAC
.SUBCKT Q4008L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  61.6M
RH  7 6  10.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 4.29
.ENDS
*SRC=Q5008L4;Q5008L4;TRIACS;TECCOR;500V 8A
*SYM=TRIAC
.SUBCKT Q5008L4   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  61.6M
RH  7 6  10.5
RGP 8 3  24
RG  2 8  11.6
RS  8 4  2.4
DN  9 2  DIN OFF
RN  9 3  12.2
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.352
DP 2 10  DIP OFF
RP 10 3  7.12
GP  7 6 10 3 4.29
.MODEL POUT PNP (IS=382F BF=5 CJE=761P TF=76.5U)
.MODEL NOUT NPN (IS=382F BF=20 CJE=761P CJC=152P TF=5.1U)
.ENDS
*SRC=Q6008L5;Q6008L5;TRIACS;TECCOR;600V 8A
*SYM=TRIAC
.SUBCKT Q6008L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  12MEG
RT2 1 7  61.6M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.ENDS
*SRC=Q7008L5;Q7008L5;TRIACS;TECCOR;700V 8A
*SYM=TRIAC
.SUBCKT Q7008L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  14MEG
RT2 1 7  61.6M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.ENDS
*SRC=Q8008L5;Q8008L5;TRIACS;TECCOR;800V 8A
*SYM=TRIAC
.SUBCKT Q8008L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  16MEG
RT2 1 7  61.6M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.ENDS
*SRC=Q2010L5;Q2010L5;TRIACS;TECCOR;200V 10A
*SYM=TRIAC
.SUBCKT Q2010L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  4MEG
RT2 1 7  49.3M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.MODEL POUT PNP (IS=382F BF=5 CJE=479P TF=76.5U)
.MODEL NOUT NPN (IS=382F BF=20 CJE=479P CJC=95.7P TF=5.1U)
.ENDS
*SRC=Q4010L5;Q4010L5;TRIACS;TECCOR;400V 10A
*SYM=TRIAC
.SUBCKT Q4010L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  49.3M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.ENDS
*SRC=Q5010L5;Q5010L5;TRIACS;TECCOR;500V 10A
*SYM=TRIAC
.SUBCKT Q5010L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  49.3M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.MODEL POUT PNP (IS=382F BF=5 CJE=558P TF=76.5U)
.MODEL NOUT NPN (IS=382F BF=20 CJE=558P CJC=112P TF=5.1U)
.ENDS
*SRC=Q6010L5;Q6010L5;TRIACS;TECCOR;600V 10A
*SYM=TRIAC
.SUBCKT Q6010L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  12MEG
RT2 1 7  49.3M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.ENDS
*SRC=Q7010L5;Q7010L5;TRIACS;TECCOR;700V 10A
*SYM=TRIAC
.SUBCKT Q7010L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  14MEG
RT2 1 7  49.3M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.ENDS
*SRC=Q8010L5;Q8010L5;TRIACS;TECCOR;800V 10A
*SYM=TRIAC
.SUBCKT Q8010L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  49.3M
RH  7 6  10.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  3
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.277
GNP  4 5 9 3 0.521
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 4.29
.MODEL DZ   D (IS=382F N=1.5 IBV=100U BV=800)
.ENDS
*SRC=Q2015L5;Q2015L5;TRIACS;TECCOR;200V 15A
*SYM=TRIAC
.SUBCKT Q2015L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  4MEG
RT2 1 7  32.9M
RH  7 6  7.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.388
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 6
.MODEL DIN  D (IS=535F)
.MODEL DIP  D (IS=535F N=1.19)
.MODEL DZ   D (IS=535F N=1.5 IBV=50U BV=200)
.MODEL POUT PNP (IS=535F BF=5 CJE=586P TF=102U)
.MODEL NOUT NPN (IS=535F BF=20 CJE=586P CJC=117P TF=6.8U)
.ENDS
*SRC=Q4015L5;Q4015L5;TRIACS;TECCOR;400V 15A
*SYM=TRIAC
.SUBCKT Q4015L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  32.9M
RH  7 6  7.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.388
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 6
.MODEL DZ   D (IS=535F N=1.5 IBV=50U BV=400)
.ENDS
*SRC=Q5015L5;Q5015L5;TRIACS;TECCOR;500V 15A
*SYM=TRIAC
.SUBCKT Q5015L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  10MEG
RT2 1 7  32.9M
RH  7 6  7.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.388
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 6
.MODEL DZ   D (IS=535F N=1.5 IBV=50U BV=500)
.MODEL POUT PNP (IS=535F BF=5 CJE=670P TF=102U)
.MODEL NOUT NPN (IS=535F BF=20 CJE=670P CJC=134P TF=6.8U)
.ENDS
*SRC=Q6015L5;Q6015L5;TRIACS;TECCOR;600V 15A
*SYM=TRIAC
.SUBCKT Q6015L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  12MEG
RT2 1 7  32.9M
RH  7 6  7.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.388
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 6
.MODEL DZ   D (IS=535F N=1.5 IBV=50U BV=600)
.ENDS
*SRC=Q7015L5;Q7015L5;TRIACS;TECCOR;700V 15A
*SYM=TRIAC
.SUBCKT Q7015L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  7MEG
RT2 1 7  32.9M
RH  7 6  7.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.388
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 6
.MODEL DZ   D (IS=535F N=1.5 IBV=100U BV=700)
.MODEL POUT PNP (IS=535F BF=5 CJE=782P TF=102U)
.MODEL NOUT NPN (IS=535F BF=20 CJE=782P CJC=156P TF=6.8U)
.ENDS
*SRC=Q8015L5;Q8015L5;TRIACS;TECCOR;800V 15A
*SYM=TRIAC
.SUBCKT Q8015L5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  32.9M
RH  7 6  7.5
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.388
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 6
.MODEL DZ   D (IS=535F N=1.5 IBV=100U BV=800)
.ENDS
*SRC=Q2025R5;Q2025R5;TRIACS;TECCOR;200V 25A
*SYM=TRIAC
.SUBCKT Q2025R5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  2MEG
RT2 1 7  25.4M
RH  7 6  5.25
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.554
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 0.373
.MODEL DIN  D (IS=764F)
.MODEL DIP  D (IS=764F N=1.19)
.MODEL DZ   D (IS=764F N=1.5 IBV=100U BV=200)
.MODEL POUT PNP (IS=764F BF=5 CJE=838P TF=102U)
.MODEL NOUT NPN (IS=764F BF=20 CJE=838P CJC=168P TF=6.8U)
.ENDS
*SRC=Q4025R5;Q4025R5;TRIACS;TECCOR;400V 25A
*SYM=TRIAC
.SUBCKT Q4025R5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  4MEG
RT2 1 7  25.4M
RH  7 6  5.25
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.554
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 0.373
.MODEL DZ   D (IS=764F N=1.5 IBV=100U BV=400)
.ENDS
*SRC=Q5025R5;Q5025R5;TRIACS;TECCOR;500V 25A
*SYM=TRIAC
.SUBCKT Q5025R5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  5MEG
RT2 1 7  25.4M
RH  7 6  5.25
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.554
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 0.373
.MODEL DZ   D (IS=764F N=1.5 IBV=100U BV=500)
.MODEL POUT PNP (IS=764F BF=5 CJE=957P TF=102U)
.MODEL NOUT NPN (IS=764F BF=20 CJE=957P CJC=191P TF=6.8U)
.ENDS
*SRC=Q6025R5;Q6025R5;TRIACS;TECCOR;600V 25A
*SYM=TRIAC
.SUBCKT Q6025R5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  6MEG
RT2 1 7  25.4M
RH  7 6  5.25
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.554
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 0.373
.MODEL DZ   D (IS=764F N=1.5 IBV=100U BV=600)
.ENDS
*SRC=Q7025R5;Q7025R5;TRIACS;TECCOR;700V 25A
*SYM=TRIAC
.SUBCKT Q7025R5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  7MEG
RT2 1 7  25.4M
RH  7 6  5.25
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.554
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 0.373
.MODEL DZ   D (IS=764F N=1.5 IBV=100U BV=700)
.MODEL POUT PNP (IS=764F BF=5 CJE=1.12N TF=102U)
.MODEL NOUT NPN (IS=764F BF=20 CJE=1.12N CJC=223P TF=6.8U)
.ENDS
*SRC=Q8025R5;Q8025R5;TRIACS;TECCOR;800V 25A
*SYM=TRIAC
.SUBCKT Q8025R5   1  2  3
QN1  5 4 3  NOUT OFF
QN2 11 6 7  NOUT OFF
QP1 6 11 3  POUT OFF
QP2  4 5 7  POUT OFF
DF  4  5  DZ OFF
DR  6 11  DZ OFF
RF  4 6  8MEG
RT2 1 7  25.4M
RH  7 6  5.25
RGP 8 3  12
RG  2 8  5.8
RS  8 4  1.2
DN  9 2  DIN OFF
RN  9 3  6.12
GNN  6 7 9 3 0.554
GNP  4 5 9 3 0.705
DP 2 10  DIP OFF
RP 10 3  3.56
GP  7 6 10 3 0.373
.MODEL DZ   D (IS=764F N=1.5 IBV=100U BV=800)
.ENDS
