If I use your reference design solution, what testing will I need to do to certify my design?
So using the CN0537 reference design doesn’t exempt you from having to fully certify your design. By using the sensor, chamber, software and algorithm, it provides confidence that when you go for UL 217 certification that your design should pass the tests. Airflow in your mechanical enclosure design is going to be the key factor when trying to pass the testing. Regardless of using the ADI solution, your design will need to be fully certified.
