I am working with the ADRV9009 eval card (ADRV9009-W/PCBZ) for the Xilinx ZCU102 board. I am using the NO-OS software branch 2018_R2 found here
https://github.com/analogdevicesinc/no-OS/tree/2018_R2
The issue I am having is that when I try to set the profile for the RX (Non-OS RX) to get 200MHz instantaneous BW I get the following warning
warning: TAL_FRAMER_A status 0x21
With the following status
rx_jesd status:
Link is enabled
Measured Link Clock: 245.787 MHz
Reported Link Clock: 245.760 MHz
Lane rate: 9830.400 MHz
Lane rate / 40: 245.760 MHz
Link status: CGS
SYSREF captured: Yes
SYSREF alignment error: No
Because the link status is stuck at CGS the ADC data is not making it to the FPGA. I have an ILA attached to the ADC outputs and they are all zeros. The outputs for the ADC's are as expected when I run with the 100MHz instantaneous BW or the default RX profile that is provided with the NO-OS software. As soon as I try and run at fs=245.76MHz IBW=200MHz the JESD locks up.
Here are my RX Profile settings.
/* Rx settings */
.rx =
.rxProfile =
.rxFir =
.gain_dB = -6, /* filter gain */
.numFirCoefs = 48, /* number of coefficients in the FIR filter */
.coefs = &rxFirCoefs[0]
.rxFirDecimation = 2, /* Rx FIR decimation (1,2,4) */
.rxDec5Decimation = 4, /* Decimation of Dec5 or Dec4 filter (5,4) */
.rhb1Decimation = 1, /* RX Half band 1 decimation (1 or 2) */
.rxOutputRate_kHz = 2*122880, /* Rx IQ data rate in kHz */
.rfBandwidth_Hz = 200000000, /* The Rx RF passband bandwidth for the profile */
.rxBbf3dBCorner_kHz = 200000, /* Rx BBF 3dB corner in kHz */
.rxAdcProfile = {265, 146, 181, 90, 1280, 366, 1257, 27, 1258, 17, 718, 39, 48, 46, 27, 161, 0, 0, 0, 0, 40, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905}, /* pointer to custom ADC profile */
.rxDdcMode = TAL_RXDDC_BYPASS, /* Rx DDC mode */
.rxNcoShifterCfg =
.bandAInputBandWidth_kHz = 0,
.bandAInputCenterFreq_kHz = 0,
.bandANco1Freq_kHz = 0,
.bandANco2Freq_kHz = 0,
.bandBInputBandWidth_kHz = 0,
.bandBInputCenterFreq_kHz = 0,
.bandBNco1Freq_kHz = 0,
.bandBNco2Freq_kHz = 0
.framerSel = TAL_FRAMER_A, /* Rx JESD204b framer configuration */
.rxGainCtrl =
.gainMode = TAL_MGC, /* taliserxGainMode_t gainMode */
.rx1GainIndex = 255, /* uint8_t rx1GainIndex */
.rx2GainIndex = 255, /* uint8_t rx2GainIndex */
.rx1MaxGainIndex = 255, /* uint8_t rx1MaxGainIndex */
.rx1MinGainIndex = 195, /* uint8_t rx1MinGainIndex */
.rx2MaxGainIndex = 255, /* uint8_t rx2MaxGainIndex */
.rx2MinGainIndex = 195 /* uint8_t rx2MinGainIndex */
.rxChannels = TAL_RX1RX2, /* The desired Rx Channels to enable during initialization */
JESD framer profile settings
/* JESD204B settings */
.jesd204Settings =
/* Framer A settings */
.framerA =
.bankId = 1, /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
.deviceId = 0, /* JESD204B Configuration Device ID - link identification number. (Valid 0..255) */
.lane0Id = 0, /* JESD204B Configuration starting Lane ID. If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31) */
.M = 4, /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
.K = 32, /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes) */
.F = 4, /* F (number of bytes per frame) */
.Np = 16, /* Np (converter sample resolution) */
.scramble = 1, /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled. */
.externalSysref = 1, /* 0=use internal SYSREF, 1= use external SYSREF */
.serializerLanesEnabled = 0x03, /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
.serializerLaneCrossbar = 0xE4, /* serializerLaneCrossbar */
.lmfcOffset = 31, /* lmfcOffset - LMFC offset value for deterministic latency setting */
.newSysrefOnRelink = 0, /* newSysrefOnRelink */
.syncbInSelect = 0, /* syncbInSelect; */
.overSample = 0, /* 1=overSample, 0=bitRepeat */
.syncbInLvdsMode = 1,
.syncbInLvdsPnInvert = 0,
.enableManualLaneXbar = 0 /* 0=auto, 1=manual */
/* Framer B settings */
.framerB =
.bankId = 0, /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
.M = 2, /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
.F = 2, /* F (number of bytes per frame) */
.serializerLanesEnabled = 0x0C, /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
.syncbInSelect = 1, /* syncbInSelect; */
Here are my initial JESD settings
struct jesd204_rx_init rx_jesd_init = {
"rx_jesd",
RX_JESD_BASEADDR,
4,
32,
1,
rx_div40_rate_hz / 1000,
rx_lane_rate_khz,
here is the complete output from the serial terminal
d Link Clock: 61.447 MHz
Reported Link Clock: 61.440 MHz
Lane rate: 2457.600 MHz
Lane rate / 40: 61.440 MHz
SYNC~: deasserted
Link status: DATA
rx_os_jesd status:
Link is enabled
Measured Link Clock: 61.446 MHz
Link status: DATA
rx_dac: Successfully initialized (122894287 Hz)
rx_adc: Successfully initialized (245787048 Hz)
rx_os_adc: Successfully initialized (61447143 Hz)
