Considering the ADR525 as a replacement for the TI TL431CLP. In the original circuit configuration using the TL431CLP blow.
Is it possible to obtain approximately 6V using the ADR525 as shown below? I would like to confirm if it is possible to configure it with a 2.4kΩ resistor between the Trim terminal and GND, a 3.3kΩ resistor on the cathode side of the Zener diode, and a 12V power supply via a 680Ω resistor to output Vout.
If this is difficult, please introduce a reference circuit and devices that would produce approximately 6V.
