Incorrect connection on the block diagram in the data sheet?
The user inquired about the VCC pin connection of an operational amplifier in a block diagram, specifically if it should be connected to REF6P6_S. The final answer confirmed that the VCC pin is not connected to the 6V6 pin, and the diagram is correct as there is no connection dot at the crossover. The opamp output drives the 6V6 pin, as indicated by the connection dot to the right of the crossover.
Category: Datasheet/Specs
Product Number: adr1001
Dear Sir/Madam
In the block diagram, the VCC pin of the heater's operational amplifier is connected to REF6P6_S. Is this correct in reality, or is the diagram incorrect?
Best regards, Zsolt
