Hi
I am DFAE in Japan.
ADR03 temp pin votage is typcal 550mv in the datasheet.
Could you give me the votage distribution data of temp pin?
Best regards
N.Kokubo
ADR03
Production
The ADR01, ADR02, ADR03, and ADR06 are precision 10.0 V, 5.0 V, 2.5 V, and 3.0 V, respectively, band gap voltage references featuring high accuracy, high...
Datasheet
ADR03 on Analog.com
Hi
I am DFAE in Japan.
Best regards
N.Kokubo
This is difficult to answer, as we do not test in an oil bath. Variation in measured value would include temperature change.
Hi
I understand you.
Our customer has one more question.
Figure 39 in Datasheet has two straight lines in the graph.
Why are there two lines?
Best regards
N.Kokubo
It is not clear why there are two lines, though it may be to show that there is some uncertainty.
Hi
Thank you for your reply.
I close this question.
Best regards
N.Kokubo
Hi
Best regards
N.Kokubo
