Hi, I trying to select the highest voltage channel among the four voltage channel using an analog circuit.
four 0~2V video input signals A, B, C and D output highest voltage output 1,2.
Please write down how to modify the circuit.
If there's an IC that works, please recommend it.
Thank you!
Good day. We are currently looking into this. We'll get back to you. Thank you.
Gilbeys
Good day. You can use multiple comparators to determine the maximum input voltage. Can you share with us the specifications of your inputs? You can also use video multiplexer.
Gilbeys
