I couldn't find any details about the short circuit behaviour of the ADR4520 voltage reference.
The datasheet specifies the maximum source & sink limits,but not what happens in case of a short on the output or in case those limits are exceeded.
Is it safe to short the refrence output to ground for a short while or to overload the output in fault situations(short excessive current draw)?
In my design I used a ceramic X7R 10uF cap(minimum 1uF specified) on the output for stability ,but I ommited the 100nF ceramic one(or higher valued one) for better transient response and HF filtering ,does it have a significant impact,for now I can't see any oscilations on my scope(did see them without any output capacitor filtering though).
Thank you for your time,
Andrei
