LTSpice - LT6650 Simulation Model quiescent current
Product Number: LTSPICE 17.0.35.0
Software Version: LTSPICE 17.0.35.0
I am using LTSPICE to develop a very low power device.  This is for the wake event trigger, so is always powered from a battery even when sleeping.
So the current draw must be minimal.
I am using the model for the LT6650 low power reference, this is being used to supply a reference to a sensor that wakes the device.
The datasheet says Iq at 5V should be (typically) 6uA, but I am seeing 23uA with zero load.
I've tried the simulation model test harness and got the same result.
Is the datasheet incorrect or the model or am I just using it wrong?
TIA
Jay.
Top Replies
  • Hi   I confirmed the issue that you are experiencing. It is possible that the IQ parameter was not designed in the model.
    Gio
