ADV7513: What work 0x48 bit 6 "Video Input Bus Reverse" ?
Hi all
How do work  - ADV7513 0x48 bit6 "Video Input Bus Reverse" ?
(1) working as below?
0x48 bit 6 = 0
Pixel
Port #
23     R7     Cr7
22     R6     Cr6
16     R0     Cr0
15     G7     Y7
14     G6     Y6
8     G0     Y0
7     B7     Cb7
6     B6     Cb6
0     B0     Cb0
0x48 bit 6 = 1
Pixel
Port #
23     R0     Cr0
22     R1     Cr1
16     R7     Cr7
15     G1     Y0
14     G0     Y1
8     G7     Y7
7     B0     Cb0
6     B1     Cb1
0     B7     Cb7
(2) Affect only R,G,B or Y,Cb,Cr -bus?
   (not affect Hsync ,Ysync?)
Best Regards
aimPoint
  • Hello,
    It only effects the pixel data bus but it reverses the entire thing... not just inside the component... what was on bit 23 is now on bit 0, bit 22, is on bit 1, etc.
    Dave
  • Hi DaveD.
    Thank you answer.
    I understand as below.
    0x48 bit 6 = 0 (normal)
    #23  #22  ...   #1  #0
    R7   R6  .....  B1  B0
    0x48 bit 6 = 1 (reverse)
    #23  #22  ...   #1  #0
    B0   B1  .....  R6  R7
    Best Regards
    aimPoint
  • Hi aimPoint,
    Yes, that is what I meant.
    Dave
  • Hi DaveD.
    I was confirm the reverse operation in Eval Board (ADV7612 to ADV7511).
    The reverse operation is fine.
    However, it does not work where the customer has confirmed in the ADV7513.
    I heard ADV7511 & ADV7513 is same chip, difference is pin connection.
    I think of the connection reverse operation will become as follows. Is it correct?
    #35  #34  #33  #32  #31  #30   ...   #01 #00 ADV7511
    R11  R10  R09  R08  R07  R06   ...   B1  B0
    #23  #22  #21  #20  #19  #18   ...   #01 #00 ADV7513
    R07  R06  R05  R04  R03  R02   ...   B1  B0
    (R11)(R10) .....                          (R05)(R04) = ADV7511 bus name
    B00  B01  B02  B03  B04  B05   ...   R10 R11
    --   --    --     --      B00  B01   ...   R02 R03
    (B00)(B01)(B02)(B03)(B04)(B05)..  (R06)(R07) =ADV511 bus name
    Best Regards
    aimPoint
  • Hello,
    They aren't the same chip but very close.  The smaller bus would reverse in the same way as your diagram.
    Dave
  • HI DaveD
    Thank you answer.
    Why, reason for customers focusing on reverse operation,
    They are used to visually check the wiring abnormality of bits on the LSB side.
    As shown in the "Screen Image" tab in the attachment,
    The reverse operation is can see clearly abnormal  on LSB side.
    However, on account of the internal wiring in the ADV7513,
    It was found that it becomes dark image even if the reverse operation.
    And that can not be used for visually check the wiring abnormality.
    Best Regards
    aimPoint
    140626_V751x_rvs_op_En.xlsx
  • Is it clearly that, if I connected RGB888 with wrong LSB/MSB order, can I use BUS REVERSE + CSC to correct it only using Software? Or I can not use it, only thing I can do is re-design hardware?
    Johnson
