ADV7393- Sync on Green
I have to confirm the ADV7393 sync on RGB output.
I need the sync signal on output green line, so if i enable the Sync on RGB bit to high, shall i get the sync signal only on green DAC output line or all RGB output lines?
From the DAC green output line i am going to separate the composite sync output by using EL1881.
kindly confirm weather i will get the sync signal on DAC green output line?
Sivakumar
