i followed through on the auto graphics process for non supported graphics but it seems to still not be getting a lock no matter what i change.
DVI input format:Hactive: 1280
Vactive: 960
I/P: progressive
Htotal: 1800
Hblank: 520
Hfront: 98
Hsync: 114
Hback: 308
Hpol: low
Vtotal: 981
Vblank: 21
Vfront: 1
Vsync: 3
Vback: 17
Vpol: low
HFreq: 58.1KHz
VFreq: 59.2Hz
Pclock: 104.6MHz
code:
// Program the primary mode to graphics: PRIM_MODE[5:0] = 0b0010
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_IO, ADV7604_REG_IO_PRIM_MODE, 0b00000010 );
// Program the video standard to auto graphics: VID_STD[3:0] = 0b00111
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_IO, ADV7604_REG_IO_VID_STD, 0b00000111 );
// Generate the pixel clock for 1280 x 960 resolution
// Firstly, PLL_DIV_MAN_EN is set to 1 to enable manual programming of the PLL block.
// Secondly, one of the two following methods is used to calculate the value of PLL_DIV_RATIO[12:0] to give the required pixel clock.
// Method one or method two is chosen, depending on the information available about the non standard format.
u_int32_t pc = 104600000;
u_int32_t hsync = 58100;
u_int32_t pClock = pc/hsync;
u_int8_t first = (pClock>>8)| 0xC0;
u_int8_t last = pClock;
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_IO, ADV7604_REG_IO_16, first );
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_IO, ADV7604_REG_IO_17, last );
// Configuring the Free Run Mode Line Length
// The expected line length for non standard formats must be programmed to the CP core. FR_LL[10:0] (free run line length) is the number
// of system clock cycles in the ideal line length of the video format.
uint8_t baseReg;
u_int32_t sysClock = 28636300;
u_int32_t freemode = sysClock/hsync;
first = freemode>>8;
last = freemode;
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8F, first );
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_90, last );
status = adv7604_read( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_46_2, &baseReg );
baseReg |= (first& 0b111);
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_46_2, baseReg );
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_48, last );
// Setting the Free Run Mode Number of Lines per Field
// The expected number of lines per field for non standard formats must be programmed to the CP core.
u_int16_t vTotal = 981;
u_int16_t numLines = vTotal<<4;
first = numLines>>8;
last = numLines;
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_AB_1, first );
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_AB_2, last );
// Configuring the Interlaced or Progressive Parameter
// Progressive Mode
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_91, 0x50 );
// Adjust the horizontal and vertical position, height, and width by varying the values of DE_H_START[9:0] and DE_H_END[9:0].
// Also need to adjust the values in DE_V_START[9:0] and DE_V_END[9:0]
// s sign e sign
// DE_H_START
// DE_H_END
uint16_t de_h_start = 308;
uint16_t de_h_end = -98;
status = adv7604_read(this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8B, &baseReg );
baseReg &= 0xF0;
baseReg += (0x03&(de_h_start>>8))<<2;
baseReg += (0x03&(de_h_end>>8));
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8B, baseReg);
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8C, (de_h_end & 0xff) );
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8D, (de_h_start & 0xff) );
// DE_V_START split DE_V_END
uint8_t de_v_start = 17;
uint8_t de_v_end = -1;
baseReg = de_v_start<<4;
baseReg += (de_v_end & 0x0F);
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_8E, baseReg );
// CP_START_VBI
// split
// CP_END_VBI (no interlacing)
uint16_t cp_start_vbi = 981-1+1;
uint16_t cp_end_vbi = 3+17+1;
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A5_1, (cp_start_vbi>>4) );
baseReg = (cp_start_vbi<<4)& 0xF0;
baseReg+= ((cp_end_vbi>>8)& 0x0F);
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A5_2, baseReg );
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A7, (cp_end_vbi&0xFF) );
// CP_START_VBI_EVEN
// CP_END_VBI_EVEN (interlacing)
uint16_t cp_start_vbi_even = 981-0+1;
uint16_t cp_end_vbi_even = 981+3+18+1;
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A8_1, (cp_start_vbi_even>>4) );
baseReg = (cp_start_vbi_even<<4)& 0xF0;
baseReg+= ((cp_end_vbi_even>>8)& 0x0F);
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A8_2, baseReg );
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_AA, (cp_end_vbi_even&0xFF) );
// Adjusting the Vertical or Horizontal Alignment
// Adjust the EAV and SAV code position by varying the values in CP_START_EAV[11:0] and CP_START_SAV[11:0]
// CP_START_SAV
// CP_START_EAV
uint16_t cp_start_sav = 114+308-4;
uint16_t cp_start_eav = 1800-98;
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A2_1, (cp_start_sav>>4) );
baseReg = (cp_start_sav<<4)& 0xF0;
baseReg+= ((cp_start_eav>>8)& 0x0F);
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A2_2, 0xa6 );
status = adv7604_write( this->adv7604_fd, this->hENCFPGA, ADV7604_ADDR_CP, ADV7604_REG_CP_A4, (cp_start_eav &0xFF) );
The timing above does not even meet the VESA CVT formulas. Is this what you intended?
Here's what I get for 1280 x 960 @ 60
interesting. ill try those values but this is a AGM-300 Standard our customer asked for so i'm not sure that will work.
I'm not familiar with an AGM-300 standard. Could you provide a link to information on this standard?
the specs for it are above. im looking into where the customer got it as well.
I was hoping for a pdf or doc so I could read more about it and keep it in my standards collection
