[ADV7480] Question About PCB Assembly Inspection with the Device Powered Off
Product Number: ADV7480
I have a question regarding a PCB assembly inspection for the ADV7480WBBCZ-RL.
Our customer is planning to apply a test signal sequentially between each device pin and GND while all power supplies to the ADV7480 are turned off, in order to detect open solder joints.
The test conditions under consideration are as follows:
1. AC test signal
  Applied voltage: 140 mVrms
  Frequency: 10 kHz
  Applied between the pin under test and GND
2. DC test signal
  Applied voltage: 0.6 V
  Current limit: 2 mA
  Purpose: Measurement of the parasitic/protection diode characteristics
Could you please confirm whether it is acceptable to apply the above test conditions to the ADV7480 while DVDD, AVDD, TVDD, and DVDDIO are not powered?
In addition, according to the Absolute Maximum Ratings, the voltage range for each pin is specified as −0.3 V to the corresponding VDD + 0.3 V.
When the corresponding VDD supply is not powered, should we consider the absolute maximum voltage range for the associated pins to be −0.3 V to +0.3 V?
Thank you for your support.
