NVIDIA Jetson Orin Nano running a custom Linux image (analogdevicesinc/gmsl: Gigabit Multimedia Serial Link (GMSL) technology from Analog Devices, Inc. (ADI)).
AD-GMSL522-SL carrier board.
MAX96716F EV kit connected to the carrier board through the Samtec connector. (i2c address 0x98)
MAX96717F EV kit connected to the MAX96716F over GMSL Link A using a coaxial cable. (i2c address 0x80)
An SPI peripheral connected to the serializer side.
/dev/spidev has been verified.-
Jetson Orin Nano: SPI Master
MAX96716F: SPI Subordinate
MAX96717F: SPI Main
SPI peripheral: SPI Slave
SS1 asserts correctly.
The SPI clock is generated correctly.
MOSI contains the expected transmitted data (e.g. 0xA5).
The SPI waveform on the deserializer MFP pins appears correct.
The serializer SPI clock output remains at a constant logic level.
The serializer SS1 output also remains at a constant logic level.
The serializer MOSI pin exhibits some activity, but it does not appear to be a valid SPI MOSI waveform.
RIB 98 0177 1 1RIB 98 0177 1 2RIB 98 0177 1 3RIB 98 0177 1 ...RIB 80 0177 1 00x0025) increase on both the deserializer and serializer, which suggests that packets are traversing the GMSL link.-
SPI Mode 0 and SPI Mode 3.
One-byte and four-byte SPI transfers.
Different SPI Main/Subordinate configurations.
Different GPIO/MFP configurations.
RO/BNE configurations from the MAX96717F user guide (max96717fr-user-guide.pdf).
Verification of SPI timing using an oscilloscope.
Verification that the Jetson SPI controller is functioning correctly.
Is there any additional configuration required before the serializer begins driving its local SPI interface?
Are there any required link-initialization or reset procedures specific to the MAX96716F/MAX96717F? It seems to Auto-Link when both evkits are detected (indicated by LOCK LEDs on each evkit)
Are there any recommended registers or status indicators that you would suggest checking to verify that the SPI control tunnel is operating correctly?
RIB 98 0162 1 00 RIB 98 0170 1 09 RIB 98 0171 1 01 RIB 98 0172 1 03 RIB 98 0173 1 1E RIB 98 0174 1 1E RIB 98 0175 1 1E RIB 98 0176 1 04 RIB 98 0177 1 <incrementing> RIB 98 0178 1 00 RIB 98 0179 1 00 RIB 98 002C 1 04 RIB 80 0170 1 0B RIB 80 0171 1 01 RIB 80 0172 1 03 RIB 80 0173 1 1E RIB 80 0174 1 1E RIB 80 0175 1 1E RIB 80 0176 1 04 RIB 80 0177 1 00 RIB 80 0178 1 00 RIB 80 0179 1 00 RIB 80 002C 1 04
RIB 98 0001 1 1 RIB 98 0003 1 0 RIB 98 0005 1 0 RIB 98 0006 1 DE RIB 98 0010 1 11 RIB 98 0013 1 DA RIB 80 0001 1 4 RIB 80 0003 1 0 RIB 80 0005 1 0 RIB 80 0006 1 90 RIB 80 0010 1 1 RIB 80 0013 1 DA
