ADV7626 Rx termination problem(DC level gone)
Product Number: ADV7626
I have seen a previous post on the Engineer Zone regarding a similar issue (ADV7625 evaluation boards Rx termination problem
Amos on 4 May 2015). As no specific solution was provided, I would like to ask about this again.
The symptoms are almost identical.
Currently, when connected to a MOUSE, DELL or HP computer, switching to the PC side causes the DC level on the TMDS line to be lost.
Even when the terminating resistor is kept ON at all times, the DC level sticks to GND, and the amplitude becomes larger than normal.
As an addition to my previous post, when the device is operating normally, switching the terminating resistor OFF and then back ON results in the same condition.
Please let me know if there is a way to recover from this state via some register setting (a software or hardware solution that does not involve plugging or unplugging the connector).
Translated with DeepL.com (free version)
  • Hi ,
    I assume you have followed all the suggestions provided in the mentioned thread.
    Could you please share your system’s register values during the issue scenario?
    Ebin
  • Thank you for your reply.
    Regarding the register values, as I am responsible for the hardware, I am not fully aware of the details, but I will look into it.
    Based on what we have discovered during our current investigations, the PC is able to display the screen if, after switching channels, we perform a system power-down on the TX side before raising the HOTPLG, reset the hdcp_rept_edid_reset register (Tx main map 0x5a), and then raise the HOTPLG. The issue is that we are currently unsure of the correct sequence for such system power-down, HOTPLG and reset operations, or whether there are any other appropriate register operations required.
    1. We need the register values during the issue case for Analysis
    2. Please follow the below sequence
    a. Disable HPD
    b. Enable TMDS termination
    c. Wait 100 ms
    d. Assert HPD
    e. Read EDID
    f. Wait for TMDS clock lock
    3. Please refer HDMI Layout Guideline
    Thanks ,
    Ebin
  • Thank you for the information.
    We have carried out the sequence you described.
    It appears that the main cause lies with the ADV7626 chip itself.
    In particular, this chip has a defect relating to HDCP (depending on how it is used).
    When an extender or HDMI device is connected to the RX or TX side (as seen in the logs),
    switching the channel on the RX side—given that there is only one HDCP register in the block diagram—requires particular care regarding the handling of Akey-related matters if the source is an HDCP-encrypted source. Depending on the PC,
    some may attempt to read the HDCP register before the PC’s HDMI DDC, which can result in HDCP authentication failing.
    I have added processing steps within the sequence you provided.
    a0. Channel switching
    a. Disable HPD
    c. Wait 100 ms
    c1. Reset the hdcp_rept_edid_reset register after detecting 5V
    d. Assert HPD
    e. Read EDID
    In addition to the above steps, we have applied conditions to the HPD on/off state depending on the situation.
    We have found that this can cause issues, at least in standard switching sequences.
  • 1663.ADV7625_Documentation_.zip7103.ADV7625-26-27_Ver1.0.txt.zip
    Hi ,
    I have attached the ADV752x User Manual and the script file for your reference. Kindly review these documents and try to validate the setup after disabling the HDCP option.
    Ebin
