PAL square pixel support on ADV7481
The user inquired about using the ADV7481 to convert a composite PAL analog video stream to a digital PAL square pixel format (768x576) and output it via the MIPI CSI-2 interface. The support engineer confirmed that the ADV7481 supports this output resolution and provided a register configuration for square pixel mode. The user noted that the ad748x kernel driver supports only 720 active pixels per line and requested a patch, to which the engineer referred the user to a reference configuration file.
Product Number: AD7481
We would like to use the ADV7481 to convert an analog video stream (composite PAL) into a digital video stream in the "PAL square pixel" format (i.e., 768×576) and output it via the MIPI CSI-2 interface. Does the ADV7481 support this output resolution?
Thank you in advance for your support,
Mattia
