Alternating black and red pixel on the vertical line
The user is experiencing a flickering effect on red guidelines in NTSC video streaming through the ADV7281-M chip, even when manually deinterlacing one-field frames. The final answer suggests checking the PLL power supply (PVDD) for noise, ensuring a clean and stable power rail, and verifying the power-up sequence. The user's configuration includes ITU-R BT.656-4 compatibility, but toggling this setting did not resolve the issue.
Product Number: ADV7281
We are encountering an issue with the ADV7281-M chip in our video-in pipeline when streaming an NTSC video source from the ECU to the SoC.
Since our video source includes guidelines for parking assistance, it is streamed to the SoC in an alternate interlaced mode (i.e., one field per buffer). In a single-field frame, we observed that the red guideline (a red square with a red diagonal and a black border) exhibits a problem: the red and black pixels alternate vertically, causing a flickering effect on the guideline, as the attached image.
We suspect that there may be issues with the Y channel after the ADV7281-M chip decodes the analog video signal. To investigate, we have conducted several experiments with the ADV configuration, such as:
Comb filter gain control - tried all mode
Luma peaking gain: changed the gain
- Luma filter - Y shaping filter
- Luma Automatic Gain Control (on/off)
However, the issue still persists. Does anyone have any idea what might be causing this issue, or any suggestions for ADV7281-M configuration settings we could experiment with to potentially resolve it?
Vinh Nguyen
    Kindly note that Progressive MIPI output is only available on the ADV7280-M and ADV7282-M models, but you were using the ADV7281-M part.
    The advanced interlaced-to-progressive (I2P) function allows the 'ADV7280, ADV7280-M, ADV7282, ADV7282-M and ADV7283' to convert an interlaced video input into a progressive video output.
    Poornima
  • Hello Poornima Subramani,
    Thank you for your reply!
    As we do deinterlacing in the remaining part of the video-in pipeline. However, even if we collect one-field frames and deinterlace manually, the resulting video is the same.
    The problem here is that we observed "Alternating black and red pixels vertically" on the one-field frame captured from ADV, which suggests that maybe the issue originates from the ADV7281-m.
    Vinh
       As stated in previous reply, ADV7281-M part doesn't support I2P functionality.
      Please confirm whether you are observing the same issue even without I2P ?
    Poornima
  •   Please confirm whether you are observing the same issue even without I2P ?
    Hi Poornima, Yes, the issue persists on one-field frame (odd/even frames) (without I2P).
    Vinh
    If Possible, Please share your register configuration.
    Please make sure whether ADV728x is programmed correctly with ADI recommended I2C writes,
    Also make sure the power rails to the ADV728x are clean and stable
    Please ensure with good ground connections on the board i.e ground plane.
    Also try disabling the PLL (Register 0x00[1]) and see if this reduces flicker. If it does, your PVDD supply has noise on it.
    If the issue disappears with the PLL disabled is a good indicator that the problem lies in the external loop filter circuitry. The external loop filter circuit is extremely sensitive and connecting it to an unfiltered supply will most likely in all cases lead to poor performance.
    Any noise on the external loop filter circuit supply can cause a poor performance.
    Please crosscheck your schematic with reference one and follow the basic circuits and layouts as per reference designs.
    Note: "ADI recommended Write" - if those writes are not included, the part would not work reliably (unless those values are default anyway). Those registers are generally internal settings that let us handle process variation which is why they are determined during characterization. The settings that show up as "ADI Recommended Settings" are the values that work reliably across voltage and temperature. They really should be called "ADI Required setting.
    In these applications note AN-1337 at AN-1337 with covers most of the issues that customers encounter when interfacing the ADV728x-M family of parts with MIPI receivers.
    Poornima
  • Hello Poornima,
    Sorry for the late reply, and thank you very much for your hints!
    However, I couldn’t find the PLL register settings, to be honest. According to the ADV hardware manual [1], the register address 0x00 is for input control. Could you please specify the page where the PLL register settings are located?
    Currently, I’m adding some logs to capture all of our ADV7281-M settings while requesting the tester to run our use case. I would also like to try disabling the PLL, as you suggested. I also observed that the “ADI Recommended Write” is configured as follows:
            adv7180_write(state, 0x0080, 0x51); // page 0, reg=0x80, val=0x51.
            adv7180_write(state, 0x0081, 0x51);
            adv7180_write(state, 0x0082, 0x68);
    [1] https://www.analog.com/media/en/technical-documentation/user-guides/adv7280_7281_7282_7283_ug-637.pdf
    Thank you for your support!
    Vinh
      Please let us know your DAC part and there we have the register for disabling the PLL.
    Poornima
  • Hello Poornima,
    From my understanding is that this DAC ("Digital to Analog Converter") part is from our "Video source ECU." Unfortunately, it is provided by our third party, and it is a black box for us.
    Thanks
    Vinh
      If DAC is a black box in your case, Please check the PLL power supply(PVDD) since PVDD is very important for maintaining the video stability.  Ideally it should be ferrite bead isolated from other supplies.
    All power rails can affect the output images and PVDD is most sensitive to noise. So first check PVDD noise both high frequency and lower frequency around the horizontal rates.  If noise is coupled into PVDD then the PLL might lose lock and causing image issues.
    Also during power-up, could you check the power supplies, reset and powerdown pins using an oscilloscope. Just to double check that the optimal power-up sequence is followed. You can also check if noise is present on the supplies (The PVDD and AVDD are the most sensitive to noise).
    Kindly note that, By default the ADV728x outputs in a BT.656-3 format. For example if the receiver is expecting ITU-R BT.656-4 but ITU-R BT.656-3 is being output from the ADV728x then this can cause abnormal result in the screen, So could you please try toggling the BT656-4 bit (User Map, Register 0x04 bit [7]).
    When the BT.656-4 bit equals to 0 (default), the ADV728x-T outputs video that is compatible with the ITU-R BT.656-3 standard. When the BT.656-4 bit equals 1, the ADV728x-T outputs video that is compatible with the ITU-R BT.656-4 standard.
    Please check with below register and let us know the result,
    Poornima
  • Hello Poornima,
    As I have tried with ITU-R BT.656-3/-4 standard as the script bellow:
    # set SUB_USR_EN to access user submap
    set_reg 0x21 0x0e 0x00
    # Set ITU-R BT.656-4 compatible
    update_bit 0x21 0x04 7 7 1
    take_surface_shoot $AVM_SURFACE_ID "itu-r_bt656_4_compatible"
    # Set ITU-R BT.656-3 compatible
    update_bit 0x21 0x04 7 7 0
    take_surface_shoot $AVM_SURFACE_ID "itu-r_bt656_3_compatible"
    And I didn't find any difference between the images (please note that these are one-field images without deinterlacing).
    Please also check our adv7281-m configuration in the attached file
    init_device - init_device
    adv7281_set_power_pin - adv7281_set_power_pin
    adv7281_write - ADV7281 write: page:0, reg=0x000f, val=0x04
    adv7281_write - ADV7281 write: page:0, reg=0x000f, val=0x80
    adv7281_init - adv7281_init
    adv7281_write - ADV7281 write: page:0, reg=0x00fe, val=0x88
    adv7281_init - ADI recommended writes for improved video quality
    adv7281_write - ADV7281 write: page:0, reg=0x0080, val=0x51
    adv7281_write - ADV7281 write: page:0, reg=0x0081, val=0x51
    adv7281_write - ADV7281 write: page:0, reg=0x0082, val=0x68
    adv7281_init - ADI required writes
    adv7281_write - ADV7281 write: page:0, reg=0x0003, val=0x4e
    adv7281_write - ADV7281 write: page:0, reg=0x0004, val=0x57
    adv7281_write - ADV7281 write: page:0, reg=0x001d, val=0xc0
    adv7281_write - ADV7281 write: page:0, reg=0x0013, val=0x00
    adv7281_set_power - adv7281_set_power
    adv7281_csi_write - CSI: write: client.addr=0x0044, reg=0x00de, val=0x02
    adv7281_csi_write - CSI: write: client.addr=0x0044, reg=0x00d2, val=0xf7
    adv7281_csi_write - CSI: write: client.addr=0x0044, reg=0x00d8, val=0x65
    adv7281_csi_write - CSI: write: client.addr=0x0044, reg=0x00e0, val=0x09
    adv7281_csi_write - CSI: write: client.addr=0x0044, reg=0x002c, val=0x00
    adv7281_csi_write - CSI: write: client.addr=0x0044, reg=0x001f, val=0xc0
    adv7281_set_bt656 - adv7281_set_bt656
    adv7281_write - ADV7281 write: page:0, reg=0x0004, val=0xd7
    adv7281_select_input - adv7281_select_input
    adv7281_write - ADV7281 write: page:0, reg=0x0000, val=0x0e
    adv7281_write - ADV7281 write: page:128, reg=0x809c, val=0x00
    adv7281_write - ADV7281 write: page:128, reg=0x809c, val=0xff
    adv7281_write - ADV7281 write: page:0, reg=0x0017, val=0x41
    adv7281_write - ADV7281 write: page:0, reg=0x0052, val=0xc0
    adv7281_write - ADV7281 write: page:0, reg=0x0053, val=0x4e
    adv7281_write - ADV7281 write: page:0, reg=0x0054, val=0x80
    adv7281_write - ADV7281 write: page:0, reg=0x005f, val=0xa8
    adv7281_write - ADV7281 write: page:0, reg=0x005a, val=0x90
    adv7281_write - ADV7281 write: page:0, reg=0x0060, val=0xb0
    adv7281_write - ADV7281 write: page:128, reg=0x80b6, val=0x08
    adv7281_write - ADV7281 write: page:128, reg=0x80c0, val=0xa0
    adv7281_write - ADV7281 write: page:0, reg=0x0031, val=0x02
    adv7281_write - ADV7281 write: page:0, reg=0x0051, val=0xa4
    init_device - Optimize ACE Performce
    adv7281_write - ADV7281 write: page:64, reg=0x4084, val=0x00
    adv7281_write - ADV7281 write: page:64, reg=0x4080, val=0x80
    adv7281_write - ADV7281 write: page:32, reg=0x2040, val=0xd1
    adv7281_write - ADV7281 write: page:32, reg=0x2044, val=0x03
    adv7281_write - ADV7281 write: page:32, reg=0x2048, val=0x00
    adv7281_write - ADV7281 write: page:32, reg=0x204c, val=0x0a
    adv7281_write - ADV7281 write: page:32, reg=0x2050, val=0x00
    update_lock_status - update_lock_status
    adv7281_write - ADV7281 write: page:32, reg=0x2043, val=0x00
    adv7281_write - ADV7281 write: page:32, reg=0x204b, val=0x00
    adv7281 1-0021: Registered irq 210
    adv7281_write - ADV7281 write: page:32, reg=0x2043, val=0x02
    adv7281_write - ADV7281 write: page:32, reg=0x2043, val=0x01
    adv7281_write - ADV7281 write: page:32, reg=0x204b, val=0x08
    adv7281_write - ADV7281 write: page:32, reg=0x204b, val=0x02
    adv7281_s_stream - adv7281_s_stream
    adv7281_csi_write - CSI: write: client.addr=0x0044, reg=0x0000, val=0x00
    Thank you!
    Vinh
