Clarification on Design Recommendation Status of ADV7280BCPZ vs ADV7280A
Contains AI Generated Content
The user inquires about the ADV7280BCPZ's future availability and compatibility with ADV7280A. The support team confirms that ADV7280BCPZ is not recommended for new designs but does not provide assurance on its discontinuation timeline. ADV7280A is a drop-in replacement with the same pinout and software compatibility, except for an updated IDENT code and a modified crystal circuit requiring an additional resistor.
Category: Datasheet/Specs
Product Number: ADV7280
Dear ADI Support Team,
Hello, this is Andrew Song from VDS Korea.
We are currently planning a new project with the part number ADV7280BCPZ and are preparing the circuit design accordingly.
However, we recently found the following on your official website:
ADV7280"Not Recommended for New Designs"
ADV7280A"Recommended for New Designs"
To avoid confusion in the design stage, we would appreciate your clarification on the following points:
  1. Does the notice “Not Recommended for New Designs” mean the ADV7280BCPZ (non-M version) will be phased out or discontinued soon?
  2. Can you officially recommend ADV7280A as a drop-in replacement for ADV7280BCPZ?
  3. Are there any functional, pinout, or register-level differences between ADV7280 and ADV7280A that we should consider before changing the design?
  4. If we proceed with ADV7280BCPZ, will there be any risk in long-term supply or support?
Thank you in advance for your confirmation.
     Please find the below response for your queries,
                    We don't provide assurance letters about component availability on this support community. The status (Product Life Cycle) of each product is available on its respective product page on analog.com. For further information on Product Life Cycles, Monitoring Product Life Cycle Status and Obsolescence Information please see this page : https://www.analog.com/en/products/landing-pages/001/product-life-cycle-information.html
         3. Are there any functional, pinout, or register-level differences between ADV7280 and ADV7280A that we should consider before changing the design ?
                ADV7280A has the same pin-out as ADV7280 and is software compatible with the ADV7280 with the exception of an updated IDENT code.
               The only differences between the ADV728x parts and the ADV728xA parts are as follows:
                    The crystal circuit
                    The silicon revision ID
    As you are probably aware, the ADV728xA parts have been released to offer increased support for external crystal oscillators. The new products are recommended and should be adopted in your customer's next design cycles for maximum robustness. The parts are software and pin-out compatible with the existing devices.
    An additional resistor is required in the crystal circuit. The silicon revision ID was updated to differentiate between the different version of ADV728x and ADV728xA.
    Other than temperature, Below you can find the difference between ADV7280 and ADV7281 part. Please note ADV7282A-M,ADV7281A-M are same die, but features may differ for different chipset in same family.
    Poornima
