Adv7343 help
Product Number: ADV7343
Hello, i want to send  800x600 video, via adv 7343,
Which is connected to stm32l4, with i2c, i also managed to generate and send clk, hsync, vsync.
R -> DAC 1
G -> DAC 2
B -> DAC 3
PAL -> DAC 4 (optional)
Or both? But I'm newbie...
Please help me to set up configuration codes.
I looked for the "adv 7343 horizontal sync width" but that script sadly didn't work for me
Here's the script from that solution
//SW reset
56 00 <- 10 // powerup output
56 01 00 // SD input mode.
56 02 20// SYNC output disabled RGB component outputs
56 80 11//PAL standard. SSAF luma filter enabled. 1.3 MHz chroma filter enabled.
56 82 c3// Pixel data valid. CVBS out. SSAF PrPb filter enabled. Active video edge control enabled.
56 87 80// RGB input enabled.
56 88 12// 24-Bit RGB input enabled // non interlaced mode
56 8a 0a// Timing Mode 2 . HSYNC/VSYNC(FIELD) synchronization.
This is my 1 project, please help :)
