we are planning to use ADV7482 as HDMI receiver, and we will be interfacing digital output port to the FPGA.
we wanted to know ADV7482 supports resolution "1080p 30" and "1080p 60" framerate.
Thanks and Regards,
Pavithra M
ADV7482
Production
The ADV7482 is an integrated video decoder and HDMI®
receiver, targeted at connectivity enabled head units requiring a
wired, uncompressed digital audio...
Datasheet
ADV7482 on Analog.com
Thanks and Regards,
Pavithra M
ADV7482 receiver can support a maximum pixel clock frequency of 162 MHz, allowing HDTV formats up to 1080p and display resolutions up to UXGA (1600 × 1200 at 60 Hz).
Kindly note that,1080p30 and 1080p60 will come under 162Mhz pixel clock.
Generally pixel clock is calculated as : Pixel clock = Horizontal total pixels * Vertical total pixels * Vertical Frequency.
Poornima
Hi Poornima,
Thank you for the update.
In datasheet of ADV7482 we could see 1080i as supported video resolution, 1080p is not specified. Attached the image for reference.
Thanks and Regards,
Pavithra M
We can support the format as long as the pixel clock doesn't exceed.
Hi Poornima,
