Video Decoder IC supporting Interlace to Progressive conversion
Product Number: ADV7182A
We are using ADV7182A for Analog CVBS PAL video interface. The output of ADV7182A is digital BT.601 standard of resolution 720x576 interlaced video @ 50 fields/sec is being fed to Video Codec engine which only supports progressive video for Video compression and decompression.
Does AD offer any chip based solution which captures Analog CVBS PAL video but outputs digital default video of 720 x 576 progressive @ 25 fps ?
The reverse use case is also applicable for video encoder side, which takes digital default video 720 X 576 progressive @ 25 fps and outputs Analog CVBS PAL video.
